When I use nsys profile --gpu-metrics-device=0 python3 examples/test_ngram.py, I can capture GPU and CPU information. However, CUDA information cannot be captured.
When I use nsys profile python3 examples/test_ngram.py, I can capture CUDA and CPU information. But I cannot capture GPU information.
What is the issue here?
Can you tell me a little more about the system you are running on?
What is the result of running
nsys status -e
Are you running in a container?
Also, could you share the two report files?
Thank you very much for your reply. I have investigated this issue and found a solution. I was analyzing the performance of vllm v1 version. When I added --trace-fork-before-exec=true --cuda-graph-trace=node, I was able to capture CUDA information. However, I have encountered a new problem. Please advise.
I didn’t get the information for python, I hope to correlate cuda and python calls.
nsys profile --trace-fork-before-exec=true --cuda-graph-trace=node --force-overwrite true --cudabacktrace=kernel --python-backtrace=cuda python3 test_ngram.py
report5 (4).nsys-rep.zip (13.7 MB)
Hello, thank you for your reply. I have updated the question. Please take a look
Timestamp counter supported: Yes
CPU Profiling Environment Check
Root privilege: enabled
Linux Kernel Paranoid Level = 2
Linux Distribution = Ubuntu
nsys status -e
Linux Kernel Version = 5.4.54-1.0.0.std7c.el7.2.x86_64: OK
Linux perf_event_open syscall available: OK
Sampling trigger event available: OK
Intel(c) Last Branch Record support: Not Available
CPU Profiling Environment (process-tree): OK
CPU Profiling Environment (system-wide): OK
This line is suspicious, further inspection reveals my CPU model is
Intel(R) Xeon(R) Platinum 8458P does not support LBR. Maybe that’s the key point of the issue.
To get this, I think you’ll need to enable the Python sampling feature, see the following two CLI options that are related:
--python-sampling=
Possible values are 'true' or 'false'.
Sample Python backtrace.
Default is 'false'.
Note: This feature provides meaningful backtraces for Python processes.
When profiling Python-only workflows, consider disabling the CPU sampling option to reduce overhead.
--python-sampling-frequency=
Specify Python sampling frequency.
Minimum supported frequency is '1' (Hz).
Maximum supported frequency is '2000' (Hz).
Default is '1000' (Hz).
