tianshu@node31-a100:~/fusion$ /usr/local/cuda-11.4/nsight-systems-2022.5/bin/nsys status -e
Timestamp counter supported: Yes
CPU Profiling Environment Check
Root privilege: disabled
Linux Kernel Paranoid Level = 1
Linux Distribution = Ubuntu
Linux Kernel Version = 5.4.0-107-generic: OK
Linux perf_event_open syscall available: OK
Sampling trigger event available: OK
Intel(c) Last Branch Record support: Not Available
CPU Profiling Environment (process-tree): OK
CPU Profiling Environment (system-wide): Fail
tianshu@node31-a100:~/fusion$ /usr/local/cuda-11.4/nsight-systems-2022.5/bin/nsys --version
NVIDIA Nsight Systems version 2022.5.1.82-32078057v0
a100:~/fusion$ nvidia-smi
Tue Feb 28 13:44:58 2023
| NVIDIA-SMI 470.103.01 Driver Version: 470.103.01 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA A100-SXM... On | 00000000:07:00.0 Off | 0 |
| N/A 28C P0 18W / 400W | 5475MiB / 39538MiB | 0% Default |
| | | Disabled |
| 1 NVIDIA A100-SXM... On | 00000000:0A:00.0 Off | 0 |
| N/A 26C P0 52W / 400W | 3MiB / 39538MiB | 0% Default |
| | | Disabled |
| 2 NVIDIA A100-SXM... On | 00000000:47:00.0 Off | 0 |
| N/A 26C P0 54W / 400W | 3MiB / 39538MiB | 0% Default |
| | | Disabled |
| 3 NVIDIA A100-SXM... On | 00000000:4D:00.0 Off | 0 |
| N/A 28C P0 54W / 400W | 3MiB / 39538MiB | 0% Default |
| | | Disabled |
| 4 NVIDIA A100-SXM... On | 00000000:87:00.0 Off | 0 |
| | | Disabled |
| 5 NVIDIA A100-SXM... On | 00000000:8D:00.0 Off | 0 |
| N/A 27C P0 53W / 400W | 3MiB / 39538MiB | 0% Default |
| | | Disabled |
| 6 NVIDIA A100-SXM... On | 00000000:C7:00.0 Off | 0 |
| N/A 26C P0 56W / 400W | 3MiB / 39538MiB | 0% Default |
| | | Disabled |
| 7 NVIDIA A100-SXM... On | 00000000:CA:00.0 Off | 0 |
| N/A 28C P0 59W / 400W | 2058MiB / 39538MiB | 0% Default |
| | | Disabled |
and when I solely run the application, it works well.
(base) tianshu@node31-a100:~/fusion/newGCNFusion_copy_2$ conda activate work2
(work2) tianshu@node31-a100:~/fusion/newGCNFusion_copy_2$ python gcn_test.py
cuda:0
TC_Blocks: 23772
Exp_Edges: 6085632
Prep. (ms): 122.526
but “ModuleError” occered when profile with the nsys
, so what’s the problem with this?
(work2) tianshu@node31-a100:~/fusion/newGCNFusion_copy_2$ sudo /usr/local/cuda-11.4/nsight-systems-2022.5/bin/nsys profile python gcn_test.py
File "gcn_test.py", line 57
SyntaxError: Non-ASCII character '\xe7' in file gcn_test.py on line 57, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
Generating '/tmp/nsys-report-efba.qdstrm'
[1/1] [========================100%] report2.nsys-rep
Generated:
/home/tianshu/fusion/newGCNFusion_copy_2/report2.nsys-rep
and I replace “python” with “python3”, above error dissapear and new error occered, and that’s the problem puzzled me.
(work2) tianshu@node31-a100:~/fusion/newGCNFusion_copy_2$ sudo /usr/local/cuda-11.4/nsight-systems-2022.5/bin/nsys profile python3 gcn_test.py
File "gcn_test.py", line 1, in <module>
import dgl
ModuleNotFoundError: No module named 'dgl'
Generating '/tmp/nsys-report-c23c.qdstrm'
[1/1] [========================100%] report3.nsys-rep
Generated:
/home/tianshu/zjlab/fusion/newGCNFusion_copy_2/report3.nsys-rep
