[problem] Nsight System cannot collect program performance data in a multi-node distributed environment
I am using Nsight System to profile a multi-node distributed model training. When I specify NNODES=2 (two nodes, with 2 A100 GPUs on each node), the generated dqrep report shows “CUDA profiling might have not been started correctly.” and “No CUDA events collected. Does the process use CUDA?” However, if I specify NNODES=1 (single node operation), Nsight System can profile normally.
The running command is “sh run.sh”. The program code in the run.sh file is:
#! /bin/bash
NODE_RANK=0
NNODES=2
GPUS_PER_NODE=2
MASTER_PORT=22
MASTER_ADDR=10.x.x.19
# ib ip = 10.4.9.19
# gpu6 ip = 10.254.46.19
DISTRIBUTED_ARGS="--nproc_per_node $GPUS_PER_NODE --nnodes $NNODES --node_rank $NODE_RANK --master_addr $MASTER_ADDR --master_port $MASTER_PORT"
DATETIME=`date +'date_%y-%m-%d_time_%H-%M-%S'`
TENSORBOARD_PATH=./tensorboard/$DATETIME
config_json="deepspeed.json"
VOCAB_FILE=vocab.txt
# DATASET_1="/nfs/data001/001.txt_document_context"
DATASET_2="xxx/002.txt_document_context"
DATASET_3="xxx/003.txt_document_context"
DATASET_4="xxx/004.txt_document_context"
DATASET_5="xxx/005.txt_document_context"
DATASET_6="xxx/006.txt_document_context"
DATASET_7="xxx/007.txt_document_context"
DATASET_8="xxx/008.txt_document_context"
DATASET_9="xxx/009.txt_document_context"
DATASET_10="xxx/010.txt_document_context"
DATASET_11="xxx/011.txt_document_context"
DATASET_12="xxx/012.txt_document_context"
DATASET_13="xxx/013.txt_document_context"
DATASET_14="xxx/014.txt_document_context"
DATASET_15="xxx/015.txt_document_context"
DATASET_16="xxx/016.txt_document_context"
DATASET_17="xxx/017.txt_document_context"
DATASET_18="xxx/018.txt_document_context"
DATA_PATH=" \
        0.1 ${DATASET_11} \
        0.1 ${DATASET_2} \
        0.1 ${DATASET_3} \
        0.1 ${DATASET_4} \
        0.1 ${DATASET_5} \
        0.1 ${DATASET_6} \
        0.1 ${DATASET_7} \
        0.1 ${DATASET_8} \
        0.1 ${DATASET_9} \
        0.1 ${DATASET_10}"
gpt_options="\
        --distributed-backend nccl \
        --tokenizer-type EncDecTokenizer \
        --optimizer lamb \
        --lr-decay-style cosine \
        --vocab-file $VOCAB_FILE \
        --tensor-model-parallel-size 1 \
        --num-layers 40 \
        --train-samples 10024 \
        --hidden-size 3072 \
        --num-attention-heads 24 \
        --seq-length 2048 \
        --max-position-embeddings 2048 \
        --micro-batch-size 1 \
        --global-batch-size 8 \
        --lr-warmup-samples 1024 \
        --lr 5e-3 \
        --min-lr 1e-05 \
        --weight-decay 0.0005 \
        --adam-beta1 0.9 \
        --adam-beta2 0.95 \
        --log-interval 1 \
        --eval-iters -1 \
        --data-path ${DATA_PATH} \
        --save-interval 2000 \
        --split 100,0,0 \
        --init-method-std 0.002 \
        --fp16 \
        --DDP-impl local \
        --checkpoint-num-layers 1 \
        --log-num-zeros-in-grad \
        --log-params-norm \
        --tensorboard-dir $TENSORBOARD_PATH \
        --tensorboard-log-interval 1 \
        --num-workers 8 \
        --pipeline-model-parallel-size 4
deepspeed_options=" \
        --deepspeed \
        --deepspeed_config ${config_json} \
        --zero-stage 1 \
        --deepspeed-activation-checkpointing
full_options="${gpt_options} ${deepspeed_options}"
nsys profile -t cuda deepspeed --hostfile="xxx/hostfile" --num_nodes ${NNODES} --num_gpus ${GPUS_PER_NODE}  ./pretrain_gpt.py ${full_options}
If you need more information, feel free to contact me.
@ztasoulas can you please look into this?
A senior student suggested that I add the ‘nsys’ command when using the RPC command to start remote process in Python.
I will try this method
Hi @1793030808,
Could you try the following:
  1. Create the following script (referring to it here as nsys_profile.sh)
#! /bin/bash
gpt_options="\
        --optimizer lamb \
        --num-layers 40 \
        --seq-length 2048 \
        --lr 5e-3 \
        --min-lr 1e-05 \
        --adam-beta1 0.9 \
        --adam-beta2 0.95 \
        --log-interval 1 \
        --eval-iters -1 \
        --split 100,0,0 \
        --fp16 \
        --DDP-impl local \
        --log-params-norm \
        --num-workers 8 \
        --deepspeed \
        --zero-stage 1 \
# Depending on the system setup, python might need to be python3
nsys profile -t cuda python ./pretrain_gpt.py ${full_options}
  1. Give execution permissions to the above script.
  2. Modify the last line of run.sh to be (also gpt_options, deepspeed_options and full_options won’t be needed anymore):
deepspeed --no_python --hostfile="xxx/hostfile" --num_nodes ${NNODES} --num_gpus ${GPUS_PER_NODE} nsys_profile.sh
