[problem] Using nsys profile stuck at Collecting Data stage
I am using nsys profile to measure the performance of my program. My program can run on 2 nodes, with 2 A100 GPUs each. However, it is stuck at the Collecting Data stage. I have also tried running some simple programs and programs that only run on a single node with nsys profile, and they were able to pass the Collecting Data stage.
The running command is “sh run.sh”. The program code in the run.sh file is:
#! /bin/bash
NODE_RANK=0
NNODES=2
GPUS_PER_NODE=2
MASTER_PORT=22
MASTER_ADDR=10.x.x.19
# ib ip = 10.4.9.19
# gpu6 ip = 10.254.46.19
DISTRIBUTED_ARGS="--nproc_per_node $GPUS_PER_NODE --nnodes $NNODES --node_rank $NODE_RANK --master_addr $MASTER_ADDR --master_port $MASTER_PORT"
DATETIME=`date +'date_%y-%m-%d_time_%H-%M-%S'`
TENSORBOARD_PATH=./tensorboard/$DATETIME
config_json="deepspeed.json"
VOCAB_FILE=vocab.txt
# DATASET_1="/nfs/data001/001.txt_document_context"
DATASET_2="xxx/002.txt_document_context"
DATASET_3="xxx/003.txt_document_context"
DATASET_4="xxx/004.txt_document_context"
DATASET_5="xxx/005.txt_document_context"
DATASET_6="xxx/006.txt_document_context"
DATASET_7="xxx/007.txt_document_context"
DATASET_8="xxx/008.txt_document_context"
DATASET_9="xxx/009.txt_document_context"
DATASET_10="xxx/010.txt_document_context"
DATASET_11="xxx/011.txt_document_context"
DATASET_12="xxx/012.txt_document_context"
DATASET_13="xxx/013.txt_document_context"
DATASET_14="xxx/014.txt_document_context"
DATASET_15="xxx/015.txt_document_context"
DATASET_16="xxx/016.txt_document_context"
DATASET_17="xxx/017.txt_document_context"
DATASET_18="xxx/018.txt_document_context"
DATA_PATH=" \
        0.1 ${DATASET_11} \
        0.1 ${DATASET_2} \
        0.1 ${DATASET_3} \
        0.1 ${DATASET_4} \
        0.1 ${DATASET_5} \
        0.1 ${DATASET_6} \
        0.1 ${DATASET_7} \
        0.1 ${DATASET_8} \
        0.1 ${DATASET_9} \
        0.1 ${DATASET_10}"
gpt_options="\
        --distributed-backend nccl \
        --tokenizer-type EncDecTokenizer \
        --optimizer lamb \
        --lr-decay-style cosine \
        --vocab-file $VOCAB_FILE \
        --tensor-model-parallel-size 1 \
        --num-layers 40 \
        --train-samples 10024 \
        --hidden-size 3072 \
        --num-attention-heads 24 \
        --seq-length 2048 \
        --max-position-embeddings 2048 \
        --micro-batch-size 1 \
        --global-batch-size 8 \
        --lr-warmup-samples 1024 \
        --lr 5e-3 \
        --min-lr 1e-05 \
        --weight-decay 0.0005 \
        --adam-beta1 0.9 \
        --adam-beta2 0.95 \
        --log-interval 1 \
        --eval-iters -1 \
        --data-path ${DATA_PATH} \
        --save-interval 2000 \
        --split 100,0,0 \
        --init-method-std 0.002 \
        --fp16 \
        --DDP-impl local \
        --checkpoint-num-layers 1 \
        --log-num-zeros-in-grad \
        --log-params-norm \
        --tensorboard-dir $TENSORBOARD_PATH \
        --tensorboard-log-interval 1 \
        --num-workers 8 \
        --pipeline-model-parallel-size 4
deepspeed_options=" \
        --deepspeed \
        --deepspeed_config ${config_json} \
        --zero-stage 1 \
        --deepspeed-activation-checkpointing
full_options="${gpt_options} ${deepspeed_options}"
nsys profile -w true deepspeed --hostfile="xxx/hostfile" --num_nodes ${NNODES} --num_gpus ${GPUS_PER_NODE}  ./pretrain_gpt.py ${full_options}
Moved to the Nsight Systems category.
Lets try cutting down on what you are collecting and see if that helps.
“nsys profile” will collect CUDA, NVTX, and OS runtime traces as well as sampling CPU backtraces.
Depending on what you need, you might want to drop the backtraces and OSRT with
nsys profile --trace=cuda,nvtx --sample=none
You might also want to consider putting a duration in there, like (-d 20) and/or a delay (-y 20) so that the run is shorter. Usually for performance problems the patterns repeat over and over and you only need to catch a few.
How long is the application currently running for?
