I am trying to use nsys start and nsys stop for profiling an application but during nsys stop I am getting following error
Can anyone tell what needs to be done
FATAL ERROR: /dvs/p4/build/sw/devtools/Agora/Rel/QuadD_Main/QuadD/Common/GpuTraits/Src/GpuTicksConverter.cpp(371): Throw in function QuadDCommon::TimestampType GpuTraits::GpuTicksConverter::ConvertToCpuTime(const QuadDCommon::Uuid&, uint64_t&) const
Dynamic exception type: boost::wrapexcept<QuadDCommon::NotFoundException>
std::exception::what: NotFoundException
[QuadDCommon::tag_message*] = No GPU associated to the given UUID
Nsight version
NVIDIA Nsight Systems version 2024.1.1.59-241133802077v0
Here is nvidia-smi output
| NVIDIA-SMI 525.85.12 Driver Version: 525.85.12 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA A100 80G... On | 00000000:41:00.0 Off | On |
| N/A 51C P0 103W / 300W | N/A | N/A Default |
| | | Enabled |
| MIG devices: |
| GPU GI CI MIG | Memory-Usage | Vol| Shared |
| ID ID Dev | BAR1-Usage | SM Unc| CE ENC DEC OFA JPG|
| | | ECC| |
| 0 2 0 0 | 39023MiB / 40192MiB | 56 0 | 4 0 2 0 0 |
| | 3MiB / 65535MiB | | |
| Processes: |
| ID ID Usage |
Greetings @jaiwant23,
Sorry to hear you are having this issue. Can you see if you can reproduce the error with the most recent version (2024.4) of the software?
Also, what command line arguments are you using to perform your profiling?
Hi @mhallock,
I tried the latest version also but same error is coming in that also and nsys session is getting killed also post that error.
This is version that I am using now
nsys --version
NVIDIA Nsight Systems version 2024.4.1.61-244134315967v0
Regarding the command line arguments I am starting the application with launch command with trace=cuda commands For profiling I am using nsys start and nsys stop command.
Error
Any way to debug to this or fix this ?
Hi @mhallock anything on above it seems the issue is happening on MIG based Gpu profiling ? Is there a wa y we can do nsight system profiling on that.
Thanks for the additional information - It does sound like MIG is causing the issue here. Can you describe your execution environment a little more? Is your app being run in a container? Is the container running in “privileged” mode?
Hi @mhallock,
Its running on a Kubernetes pod ( container) with gpu details mentioned below.
It is not running in privileged mode. Same setup works for full GPU.
Does Nividia Insight Profiler support MIG or not ?
| | | MIG M. |
| 0 NVIDIA A100 80G… On | 00000000:41:00.0 Off | On |
| | | Enabled |
| MIG devices: |
| | | ECC| |
| Processes: |
| ID ID Usage |
Thank you for the additional information.
Yes, MIG should be supported, at least for cuda trace. There are a few options relating to video APIs that are not. Just to understand your environment a little more so we can try and narrow in on the problem, can you tell me what hardware platform you are running on (physical x86_64 server, jetson-based system, or cloud instance)
Could you also provide the output of:
nsys status -e
Thank you for your patience.
Hi @mhallock ,
It is physical server : x86_64
nsys status -e
Timestamp counter supported: Yes
CPU Profiling Environment Check
Root privilege: disabled
Linux Kernel Paranoid Level = 1
Linux Distribution = CentOS
Linux Kernel Version = 5.15.138.1-4.cm2: OK
Linux perf_event_open syscall available: OK
Sampling trigger event available: OK
Intel(c) Last Branch Record support: Not Available
CPU Profiling Environment (process-tree): OK
CPU Profiling Environment (system-wide): Fail
See the product documentation at https://docs.nvidia.com/nsight-systems for more information,
including information on how to set the Linux Kernel Paranoid Level.
Thank you again for the info. I will to try and replicate this internally.
@jaiwant23 I’ve been able to reproduce it and figure out what is going on.
There is an issue between the driver version installed and the cuda profiling library used by nsys, that seems to be triggered only when MIG is enabled. The issue is not actually with k8s; I think you should hit the same error on the host as well if you try as a non-root user.
I’ve found three possible ways forward for you. You can pick any one of these and end up with a working configuration:
- Update the host to CUDA 12.2 w/ driver version 535.183.01, or newer
- Downgrade to an older version of nsys (2023.1.2 is the newest that I believe will function)
- Run the pod as privileged (it needs
CAP_SYS_ADMIN to work correctly with this driver version)
Thanks I will try and update if I see issue with above.
Hi @mhallock ,
I did try the first 2 solutions
Using cuda 12.2 : There are incompatibility issue that we are observing with respective to use cuda 12 version with TF serving external/org_tensorflow/tensorflow/compiler/xla/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library 'libcudart.so.11.0'; dlerror: libcudart.so.11.0: cannot open shared object file: No such file or directory 2024-07-05 13:44:07.595307: W external/org_tensorflow/tensorflow/compiler/xla/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library 'libcublas.so.11'; dlerror: libcublas.so.11: cannot open shared object file: No such file or directory
Downgrading nsys version : I did downgrade the version to the following one nsys --version NVIDIA Nsight Systems version 2022.1.3.3-1c7b5f7
But still same issue is occuring.
For running pod in privileged mode can it be run using the following way options nvidia NVreg_RestrictProfilingToAdminUsers=0 in /etc/modprobe.d.
was checking this issue NVIDIA Development Tools Solutions - | NVIDIA Developer since CAP_SYS_ADMIN is very high privileged permission
Hi @jaiwant23,
Sorry to hear you are still encountering issues.
It looks like you’d have to upgrade tensorflow to use the newer cuda versions. While that is a good thing in the long run, probably not what you want to do right now.
With driver version 525 that you were initially using, I tried four different nsys versions, but I did not try as far back as 2022.1. I tried (installed via apt):
- 2022.4.2: Worked
- 2023.1.2: Worked
- 2023.3.3: Failed
- 2023.2.3: Failed
I will need to investigate this option. Edit: setting NVreg_RestrictProfilingToAdminUsers=0 should be sufficient.
This does appear to work. Be mindful you have to do it on the host OS, not in the container.
Hi @mhallock ,
For options nvidia NVreg_RestrictProfilingToAdminUsers=0 tried this option also by having a file like this
/etc/modprobe.d ]$ cat nvidia.conf
The node/host was also rebooted but still same issue I did check the ncu command which was failing earlier due to permission issue NVIDIA Development Tools Solutions - | NVIDIA Developer is now working so the flag is taking effect but nsys profiling for mig is still somehow having issue.
Hi @mhallock were you able to check this.
Greetings,
I’m sorry that didn’t work for you. My test setup is clearly not recreating your true issue properly.
We are working on a fix for the current nsys version and MIG problems. I’d still like to better understand exactly what you are encountering so that we can ensure it is addressed, since all of my mitigations so far have been unsuccessful.
Can you confirm/try a few things for me?
- That you’ve tried nsys version 2023.1.2, that one worked “out of the box” for me on CUDA 12.0.
- that your command line is just
nsys launch -t cuda <application>, and not trying to capture any other trace types or options?
- Can you try profiling some simple cuda samples? I have been using
vectorAdd and UnifiedMemoryPerf in my testing. I’m curious if your actual application is triggering something that my tests are not.
- Can you test that both directly on the host and in a container to see if there is a difference in behavior?
- Lastly, can you try collecting just GPU metrics? Use
nsys profile --gpu-metrics-device=all --duration=5 as I think that should exercise the module option that you’ve set. I’m just curious.
Thank you!
Hi @mhallock ,
1st
I tried MIG profiling using below simple code I am seeing same issue in that also.
Here is the test sample
#include <cstdio>
__global__ void helloFromGPU() {
printf("Hello World from GPU!\n");
int main() {
helloFromGPU<<<1, 10>>>();
cudaError_t err = cudaGetLastError();
if (err != cudaSuccess) {
printf("CUDA error: %s\n", cudaGetErrorString(err));
err = cudaDeviceSynchronize();
fflush(stdout); // Flush the output after device code execution
return 0;
- It was run using following
nsys profile -t cuda ./testsample
- It only works with nsys 2022.4.2.1
- it also does not work with
- I ran the above code inside a K8s pod.
2nd
For this nsys profile --gpu-metrics-device=all --duration=5 on above example I am getting this output on MIG gpu
nsys profile --gpu-metrics-device=all --duration=5 ./example
Illegal --gpu-metrics-device arguments.
None of the installed GPUs are supported. See the user guide: https://docs.nvidia.com/nsight-systems/UserGuide/index.html#gms-introduction
usage: nsys profile [<args>] [application] [<application args>]
Try 'nsys profile --help' for more information.
For above nsys version was nsys --version NVIDIA Nsight Systems version 2024.4.1.61-244134315967v0
@jaiwant23 Thank you so much for testing that out and the additional information! I will be in touch soon.
