@hwilper
Here is the terminal output of a session, where I do the following:
- I get version of nsys
- I set perf_event_paranoid to 1
- I run nsys status -e
- I try to profile sample_hello_world
- It then complains about privileges.
nvidia@tegra-ubuntu:~$ nsys --version
NVIDIA Nsight Systems version 2021.1.1.66-6c5c5cb
nvidia@tegra-ubuntu:~$ sudo sh -c 'echo 1 >/proc/sys/kernel/perf_event_paranoid'
nvidia@tegra-ubuntu:~$ nsys status -e
Timestamp counter supported: Yes
Sampling Environment Check
Linux Kernel Paranoid Level = 1: OK
Linux Distribution = Ubuntu
Linux Kernel Version = 4.14.102-rt53-tegra: OK
Linux perf_event_open syscall available: OK
Sampling trigger event available: OK
Intel(c) Last Branch Record support: Not Available
Root privileges: No
Kernel module: Available
Sampling Environment: OK
nvidia@tegra-ubuntu:~$ nsys profile --stats=true /usr/local/driveworks/bin/sample_hello_world
WARNING: CPU sampling requires root privileges, disabling.
WARNING: Backtraces will not be collected because sampling is disabled.
WARNING: 'timer' backtrace collection trigger will not be used because sampling is disabled.
WARNING: 'sched' backtrace collection trigger will not be used because sampling is disabled.
Collecting data...
Welcome to Driveworks SDK
[27-10-2021 09:45:32] Platform: Detected DDPX - Tegra A
[27-10-2021 09:45:32] TimeSource: monotonic epoch time offset is 1635287828840403
[27-10-2021 09:45:32] PTP Time is available from NVPPS Driver
[27-10-2021 09:45:35] Platform: number of GPU devices detected 2
[27-10-2021 09:45:35] Platform: currently selected GPU device discrete ID 0
[27-10-2021 09:45:35] SDK: Resources mounted from /usr/local/driveworks-2.2/data/
[27-10-2021 09:45:35] SDK: Create NvMediaDevice
[27-10-2021 09:45:35] egl::Display: found 2 EGL devices
[27-10-2021 09:45:35] egl::Display: use drm device: drm-nvdc
[27-10-2021 09:45:36] TimeSource: monotonic epoch time offset is 1635287828840403
[27-10-2021 09:45:36] PTP Time is available from NVPPS Driver
[27-10-2021 09:45:36] Initialize DriveWorks SDK v2.2.3136
[27-10-2021 09:45:36] Release build with GNU 7.3.1 from heads/buildbrain-branch-0-gca7b4b26e65 against Drive PDK v5.1.6.1
Context of Driveworks SDK successfully initialized.
Version: 2.2.3136
GPU devices detected: 2
[27-10-2021 09:45:36] Platform: currently selected GPU device discrete ID 0
Device: 0, Graphics Device
CUDA Driver Version / Runtime Version : 10.2 / 10.2
CUDA Capability Major/Minor version number: 7.5
Total amount of global memory in MBytes:7679.94
Memory Clock rate Khz: 1440000
Memory Bus Width bits: 256
L2 Cache Size: 4194304
Maximum 1D Texture Dimension Size (x): 131072
Maximum 2D Texture Dimension Size (x,y): 131072, 65536
Maximum 3D Texture Dimension Size (x,y,z): 16384, 16384, 16384
Maximum Layered 1D Texture Size, (x): 32768 num: 2048
Maximum Layered 2D Texture Size, (x,y): 32768, 32768 num: 2048
Total amount of constant memory bytes: 65536
Total amount of shared memory per block bytes: 49152
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1024
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): 1024,1024,64
Max dimension size of a grid size (x,y,z): 2147483647,65535,65535
Maximum memory pitch bytes: 2147483647
Texture alignment bytes: 512
Concurrent copy and kernel execution: Yes, copy engines num: 3
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device PCI Domain ID: 1, Device PCI Bus ID: 1, Device PCI location ID: 0
Compute Mode: Default (multiple host threads can use ::cudaSetDevice() with device simultaneously)
Concurrent kernels: 1
Concurrent memory: 0
[27-10-2021 09:45:36] Platform: currently selected GPU device integrated ID 1
Device: 1, Xavier
CUDA Capability Major/Minor version number: 7.2
Total amount of global memory in MBytes:27924.1
Memory Clock rate Khz: 1109000
L2 Cache Size: 524288
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Concurrent copy and kernel execution: Yes, copy engines num: 1
Integrated GPU sharing Host Memory: Yes
Device PCI Domain ID: 0, Device PCI Bus ID: 0, Device PCI location ID: 0
[27-10-2021 09:45:36] Releasing Driveworks SDK Context
[27-10-2021 09:45:36] SDK: Release NvMediaDevice
[27-10-2021 09:45:36] SDK: Release NvMedia2D
Happy autonomous driving!
Processing events...
Saving temporary "/tmp/nsys-report-a54f-91de-ec85-a25e.qdstrm" file to disk...
Creating final output files...
Processing [==============================================================100%]
Saved report file to "/tmp/nsys-report-a54f-91de-ec85-a25e.qdrep"
Exporting 20389 events: [=================================================100%]
Exported successfully to
/tmp/nsys-report-a54f-91de-ec85-a25e.sqlite
Operating System Runtime API Statistics:
Time(%) Total Time (ns) Num Calls Average Minimum Maximum Name
75.9 9828574656 8 1228571832.0 1227597664 1229691488 pthread_cond_wait
13.4 1731574752 26 66599028.9 6720 522776064 poll
4.9 630196896 602 1046838.7 992 420651872 ioctl
4.0 513571712 11 46688337.5 17980832 91741312 system
0.8 103936448 10 10393644.8 3520 100133792 pthread_join
0.8 99899616 1 99899616.0 99899616 99899616 sem_timedwait
0.2 24564160 18272 1344.4 992 1058176 read
0.0 3984032 36 110667.6 5920 2254208 open
0.0 1868160 11 169832.7 111648 224672 pthread_create
0.0 1581728 81 19527.5 4096 94656 mmap
0.0 1554016 97 16020.8 5824 79008 write
0.0 1205920 782 1542.1 1088 90912 sched_yield
0.0 1029824 11 93620.4 36032 142016 sem_wait
0.0 808576 42 19251.8 4416 126400 fopen
0.0 754688 67 11264.0 1120 109184 fgets
0.0 445728 76 5864.8 2304 65920 putc
0.0 432032 9 48003.6 16384 115264 fopen64
0.0 350080 19 18425.3 1152 47552 fflush
0.0 313824 21 14944.0 5600 34848 munmap
0.0 257504 20 12875.2 4640 66528 fclose
0.0 222048 63 3524.6 1120 42816 sigaction
0.0 212064 3 70688.0 14208 117120 writev
0.0 207296 27 7677.6 1056 91808 fputs
0.0 159584 10 15958.4 1024 52448 pthread_cond_broadcast
0.0 136704 3 45568.0 27232 77856 connect
0.0 125120 6 20853.3 15680 24832 socket
0.0 124352 4 31088.0 16288 45952 fread
0.0 86464 28 3088.0 1536 6208 fcntl
0.0 80768 7 11538.3 1152 36480 fwrite
0.0 65920 1 65920.0 65920 65920 open64
0.0 45344 3 15114.7 12224 18240 pipe2
0.0 26176 2 13088.0 3744 22432 fgets_unlocked
0.0 17696 2 8848.0 6400 11296 recvfrom
Report file moved to "/home/nvidia/report2.qdrep"
Report file moved to "/home/nvidia/report2.sqlite"
