Full Rx tty buffer handling escalates to kernel panic because of an error in tegra_uart_rx_error_handle_timer.
“RxData DMA copy to tty layer failed” should simply indicate that received bytes are not read by the application and the tty buffer is full. However when the error_timer expires after 0.5s there is a NULL pointer dereference, see attached log:
We use prebuilt image from JetPack 5.1.1, Jetson Linux 35.3.1, Xavier NX and a custom carrier board but same devicetree
To replicate it is easier to limit the TTYB_DEFAULT_MEM_LIMIT to fill the buffer faster
Fix would be to simply use the corresponding field name in
static void tegra_uart_rx_error_handle_timer(struct timer_list * _data)
-struct tegra_uart_port *tup = from_timer(tup,_data,timer);
+struct tegra_uart_port *tup = from_timer(tup,_data,error_timer);
Can NVIDIA confirm this please?
console.log (3.6 KB)
