jp5.1.1
kernel NULL pointer to reboot on orin nx
kernel 串口空指针,会导致重启
[2024-03-16 07:27:20] [32840.435637] serial-tegra 3100000.serial: RxData PIO to tty layer failed
[2024-03-16 07:27:20] [32840.442440] serial-tegra 3100000.serial: RxData PIO to tty layer failed
[2024-03-16 07:27:20] [32840.449244] serial-tegra 3100000.serial: RxData PIO to tty layer failed
[2024-03-16 07:27:20] [32840.462156] serial-tegra 3100000.serial: RxData PIO to tty layer failed
[2024-03-16 07:27:21] [32840.999609] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000001
[2024-03-16 07:27:21] [32841.008650] Mem abort info:
[2024-03-16 07:27:21] [32841.011520] ESR = 0x96000044
[2024-03-16 07:27:21] [32841.014656] EC = 0x25: DABT (current EL), IL = 32 bits
[2024-03-16 07:27:21] [32841.020104] SET = 0, FnV = 0
[2024-03-16 07:27:21] [32841.023241] EA = 0, S1PTW = 0
[2024-03-16 07:27:21] [32841.026463] Data abort info:
[2024-03-16 07:27:21] [32841.029410] ISV = 0, ISS = 0x00000044
[2024-03-16 07:27:21] [32841.033343] CM = 0, WnR = 1
[2024-03-16 07:27:21] [32841.036388] user pgtable: 4k pages, 48-bit VAs, pgdp=000000013a1c2000
[2024-03-16 07:27:21] [32841.042994] [0000000000000001] pgd=0000000000000000, p4d=0000000000000000
[2024-03-16 07:27:21] [32841.049979] Internal error: Oops: 96000044 [#1] PREEMPT SMP
[2024-03-16 07:27:21] [32841.055712] Modules linked in: input_leds fuse nvidia_modeset(OE) r8168(OE) xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink iptable_nat nf_nat nf_conntrack nf_defrag_ia
[2024-03-16 07:27:21] [32841.055783] spi_tegra114 nvidia(OE) binfmt_misc nvmap ip_tables x_tables [last unloaded: mtd]
[2024-03-16 07:27:21] [32841.155723] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W OE 5.10.104-tegra #1
[2024-03-16 07:27:21] [32841.163915] Hardware name: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS r35.3.1-5e812e4-dirty 11/05/2023
[2024-03-16 07:27:21] [32841.176027] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=--)
[2024-03-16 07:27:21] [32841.182183] pc : tegra_uart_rx_error_handle_timer+0x5c/0x80
[2024-03-16 07:27:21] [32841.187882] lr : tegra_uart_rx_error_handle_timer+0x28/0x80
[2024-03-16 07:27:21] [32841.193587] sp : ffff800010003da0
[2024-03-16 07:27:21] [32841.196980] x29: ffff800010003da0 x28: ffff6b7b68381cc0
[2024-03-16 07:27:21] [32841.202421] x27: 00000001007c21d0 x26: ffff800010003e70
[2024-03-16 07:27:21] [32841.207863] x25: ffff6b78064da350 x24: ffffb6376a456000
[2024-03-16 07:27:21] [32841.213309] x23: ffffb6376a4626c0 x22: 00000001007c21d0
[2024-03-16 07:27:21] [32841.218750] x21: 0000000000000101 x20: ffff6b78064da0b0
[2024-03-16 07:27:21] [32841.224191] x19: ffff6b78064d2350 x18: 0000000000000000
[2024-03-16 07:27:21] [32841.229625] x17: 0000000000000000 x16: 0000000000000000
[2024-03-16 07:27:21] [32841.235070] x15: 0000fffffdedca08 x14: 000000000000001e
[2024-03-16 07:27:21] [32841.240514] x13: 000000000000009a x12: 0000000000000024
[2024-03-16 07:27:21] [32841.245953] x11: 0000000000000000 x10: 0000000000000001
[2024-03-16 07:27:21] [32841.251384] x9 : 0400000000000000 x8 : ffff6b7b68381ce8
[2024-03-16 07:27:21] [32841.256817] x7 : ffff6b7b68381d30 x6 : 00000001fffe0000
[2024-03-16 07:27:21] [32841.262255] x5 : 0000000000000011 x4 : 0000000000000000
[2024-03-16 07:27:21] [32841.267687] x3 : 0000000000000001 x2 : 00000000fff6e034
[2024-03-16 07:27:21] [32841.273127] x1 : 0000000000000000 x0 : 0000000000000001
[2024-03-16 07:27:21] [32841.278568] Call trace:
[2024-03-16 07:27:21] [32841.281065] tegra_uart_rx_error_handle_timer+0x5c/0x80
[2024-03-16 07:27:21] [32841.286407] call_timer_fn+0x3c/0x200
[2024-03-16 07:27:21] [32841.290150] run_timer_softirq+0x464/0x5d0
[2024-03-16 07:27:21] [32841.294338] __do_softirq+0x140/0x3e8
[2024-03-16 07:27:21] [32841.298086] irq_exit+0xc0/0xe0
[2024-03-16 07:27:21] [32841.301288] __handle_domain_irq+0x74/0xd0
[2024-03-16 07:27:21] [32841.305484] gic_handle_irq+0x68/0x134
[2024-03-16 07:27:21] [32841.309320] el1_irq+0xd0/0x180
[2024-03-16 07:27:21] [32841.312532] cpuidle_enter_state+0xb8/0x410
[2024-03-16 07:27:21] [32841.316806] cpuidle_enter+0x40/0x60
[2024-03-16 07:27:21] [32841.320465] call_cpuidle+0x44/0x80
[2024-03-16 07:27:21] [32841.324037] do_idle+0x208/0x270
[2024-03-16 07:27:21] [32841.327343] cpu_startup_entry+0x30/0x70
[2024-03-16 07:27:21] [32841.331360] rest_init+0xdc/0xe8
[2024-03-16 07:27:21] [32841.334664] arch_call_rest_init+0x18/0x20
[2024-03-16 07:27:21] [32841.338854] start_kernel+0x514/0x54c
[2024-03-16 07:27:21] [32841.342606] Code: 39786404 f97eba60 9ac42063 8b030000 (b9000002)
[2024-03-16 07:27:21] [32841.348855] ---[ end trace 0c8830142e224f53 ]---
[2024-03-16 07:27:21] [32841.359155] Kernel panic - not syncing: Oops: Fatal exception in interrupt
[2024-03-16 07:27:21] [32841.366204] SMP: stopping secondary CPUs
[2024-03-16 07:27:21] [32841.370218] Kernel Offset: 0x363758730000 from 0xffff800010000000
[2024-03-16 07:27:21] [32841.376450] PHYS_OFFSET: 0xffff948900000000
[2024-03-16 07:27:21] [32841.380726] CPU features: 0x0040006,4a80aa38
[2024-03-16 07:27:21] [32841.385098] Memory Limit: none
[2024-03-16 07:27:21] [32841.393779] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
minicom_log20240316.txt (365.4 KB)
