When i call a kernel for execution what number of blocks and number of threads per block must i set? This is depended by gpu but i do not understand how i must set it.
For example, if have a gpu with 32 cores how i can set these two numbers? The number of 512 threads per block dependent by gpu?
Take look at this code which does vector -vector addition.
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
// CUDA kernel. Each thread takes care of one element of c
__global__ void vecAdd(float *a, float *b, float *c, int n)
// Get our global thread ID
int id = blockIdx.x*blockDim.x+threadIdx.x;
// Make sure we do not go out of bounds
if (id < n)
c[id] = a[id] + b[id];
int main( int argc, char* argv[] )
// Size of vectors
int n = 100000;
// Host input vectors
float *h_a;
float *h_b;
//Host output vector
float *h_c;
// Device input vectors
float *d_a;
float *d_b;
//Device output vector
float *d_c;
// Size, in bytes, of each vector
size_t bytes = n*sizeof(float);
// Allocate memory for each vector on host
h_a = (float*)malloc(bytes);
h_b = (float*)malloc(bytes);
h_c = (float*)malloc(bytes);
// Allocate memory for each vector on GPU
cudaMalloc(&d_a, bytes);
cudaMalloc(&d_b, bytes);
cudaMalloc(&d_c, bytes);
int i;
// Initialize vectors on host
for( i = 0; i < n; i++ ) {
h_a[i] = sinf(i)*sinf(i);
h_b[i] = cosf(i)*cosf(i);
// Copy host vectors to device
cudaMemcpy( d_a, h_a, bytes, cudaMemcpyHostToDevice);
cudaMemcpy( d_b, h_b, bytes, cudaMemcpyHostToDevice);
int blockSize, gridSize;
// Number of threads in each thread block
blockSize = 1024;
// Number of thread blocks in grid
gridSize = (int)ceil((float)n/blockSize);
// Execute the kernel
vecAdd<<<gridSize, blockSize>>>(d_a, d_b, d_c, n);
// Copy array back to host
cudaMemcpy( h_c, d_c, bytes, cudaMemcpyDeviceToHost );
// Sum up vector c and print result divided by n, this should equal 1 within error
float sum = 0;
for(i=0; i<n; i++)
sum += h_c[i];
printf("final result: %f\n", sum/n);
// Release device memory
cudaFree(d_a);
cudaFree(d_b);
cudaFree(d_c);
// Release host memory
free(h_a);
free(h_b);
free(h_c);
return 0;
