I am trying to run deepstream-transfer-learning-app as a system service, using a single CSI camera as a source and fakesink as the only sink. Although the app runs properly when run from terminal, attempts to run it as a system service result in nvargus crashing.
When I run the program from terminal, I find it runs smoothly for at least 1 hour. However, when I try to run the same program as a system service it stops after some ~35 seconds, displaying the following information in the associated journalctl log:
SYNC_IOC_FENCE_INFO ioctl failed with 9
ERROR from src_elem: DISCONNECTED
Debug info: Argus Error Status
CONSUMER: ERROR OCCURRED
Quitting
GST_ARGUS: Cleaning up
App run failed
My service definition file looks like this (replacing by full paths):
[Unit]
Description=Deepstream App Service
StartLimitIntervalSec=0[Service]
ExecStart=/opt/nvidia/deepstream/<PATH_TO_PROGRAM>/deepstream-transfer-learning-app -c <PATH_TO_CONFIG_FILE>
Type=simple
Restart=no[Install]
WantedBy=multi-user.target
I tried to check nvargus-daemon by initializing it from terminal using sudo /usr/sbin/nvargus-daemon, and I found the following information:
=== NVIDIA Libargus Camera Service (0.98.3)=== Listening for connections…=== deepstream-transfer-learning-app[31405]: Connection established (7F7D9C91D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
LSC: LSC surface is not based on full res!
(NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
(NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 107)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
NvPclOpen: PCL Open Failed. Error: 0xf
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 593)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 305)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 471)
Acquiring SCF Camera device source via index 1 has failed. === deepstream-transfer-learning-app[31405]: CameraProvider initialized (0x7f789e4d80)LSC: LSC surface is not based on full res!
CRASH STARTS HERE
SCF: Error InvalidState: (propagating from src/services/gl/EGLStreamProducer.cpp, function presentBufferInternal(), line 542)
=== deepstream-transfer-learning-app[31405]: CameraProvider destroyed (0x7f789e4d80)=== deepstream-transfer-learning-app[31405]: Connection closed (7F7D9C91D0)=== deepstream-transfer-learning-app[31405]: Connection cleaned up (7F7D9C91D0)
I have tried setting the user in the system definition file and calling the application from a script that I later called from the service definition file. Both situations resulted in the same error. Do you have any idea of what may be causing this situation?
• Hardware Platform (Jetson / GPU) Nvidia Jetson Nano Developer Kit 4GB
• DeepStream Version 6.0.1
• JetPack Version (valid for Jetson only) 4.6.2
• TensorRT Version 8.2.1
