Hi ShaneCCC,
I hoped it would be solved, but :
nvidia@cam5-jp43:~$ find /proc/device-tree/host1x/nvdisplay@152*/status | xargs strings
disabled
okay
disabled
nvidia@cam5-jp43:~$ export DISPLAY=:0
nvidia@cam5-jp43:~$ xinit
X.Org X Server 1.19.6
Release Date: 2017-12-20
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.4.0-148-generic aarch64 Ubuntu
Current Operating System: Linux cam5-jp43 4.9.140-topdir-g6b7ebe9-dirty #483 SMP PREEMPT Mon Apr 6 22:27:53 CEST 2020 aarch64
Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
Build Date: 03 June 2019 08:11:53AM
xorg-server 2:1.19.6-1ubuntu4.3 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Apr 7 11:57:01 2020
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
nvidia@cam5-jp43:~$ nvidia@cam5-jp43:~$ gst-launch-1.0 nvarguscamerasrc ! fakesink
nvbuf_utils: Could not get EGL display connection
nvbuf_utils: ERROR getting proc addr of eglCreateImageKHR
nvbuf_utils: ERROR getting proc addr of eglDestroyImageKHR
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:532 No cameras available
Got EOS from element "pipeline0".
Execution ended after 0:00:00.099414706
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 87)
nvidia@cam5-jp43:~$
I have looked at ‘dmesg’, and found this :
[ 1.117710] tegradc 15210000.nvdisplay: mandatory prop:nvidia,dc-connector not defined
[ 1.117757] tegradc: probe of 15210000.nvdisplay failed with error -22
but the other nvdisplay entries have that property :
nvidia@cam5-jp43:~$ find /proc/device-tree/host1x/nvdisplay@152* -name nvidia,dc-connector
/proc/device-tree/host1x/nvdisplay@15200000/nvidia,dc-connector
/proc/device-tree/host1x/nvdisplay@15220000/nvidia,dc-connector
nvidia@cam5-jp43:~$
I will try nvdisplay@15200000
That fails again, but now differently :
nvidia@cam5-jp43:~$ dmesg | grep nvdisplay
[ 0.423643] platform 15200000.nvdisplay: calling of_iommu_configure
[ 0.423769] iommu: Adding device 15200000.nvdisplay to group 32
[ 0.423775] of_property_read_bool(/host1x/nvdisplay@15200000, iommu_sodev_map) -> 0
[ 1.118532] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/dsi
[ 1.118539] tegradc 15200000.nvdisplay: tegra_dc_parse_panel_ops: could not find panel for /host1x/dsi
[ 1.118560] tegradc 15200000.nvdisplay: err:-19 parsing panel_ops
nvidia@cam5-jp43:~$
I will look at that now
