hello,
so after setting the display to 0 using
export DISPLAY=:0
and using the following command
gst-launch-1.0 videotestsrc ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so" ! "video/x-raw(memory:NVMM), format=(string)RGBA" ! nvoverlaysink
the output of the terminal is
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
and the test display showed up like this
https://images.app.goo.gl/RfJ3L6x3K9oXFAXe6
but when I try
export DISPLAY=:1
then do the same command this is the output
nvbuf_utils: Could not get EGL display connection
it just freeze like this and nothing show up
