It seems like xrdp does not enable EGL libs, or there is hard-coded path while loading the EGL libs. So nveglglessink plugin does not work properly in the environment. You would need to customize the sample to use other renderer such as xvimagesink plugin.
As far as I understand, when using Headless Mode, error “Could not get EGL display connection” occurs. When I connected the monitor, keyboard and mouse, everything works. That is, using remote access it is impossible to obtain video or photo information? I’m right ?
If Jetson Nano is at remote location, we generally login through ssh and run commands in console. If we need to check video or photo, we will run scp to copy the files into local and check. For checking HDMI output, We would suggest access the device in person. It may be some constraint in checking display output remotely.
Now in “headless” mode there is another problem. All examples GitHub - dusty-nv/jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson. of working with a USB camera do not work, since the result is displayed on the screen. And if you add the monitor, then everything works, but if it’s in “headless” mode, then it doesn’t. In my case, I don’t need the result to be displayed on the screen. It will be enough to process the image from the USB camera, and save the result, for example, as a jpeg file or save recognition result to sql base. Is there a solution or example?
We would suggest use DeepStream SDK. Please install it through SDKManager and give it a try. For Jetson Nano the latest version is 6.0.1: NVIDIA Metropolis Documentation
