I’m developing a camera application that uses nvargus as a processor for MIPI cameras. The application itself works as expected when running on the jetson natively.
When we compile and run the application from inside a docker container, which is based on nvcr.io/nvidia/l4t-base image the application fails in 1/3 cases. We use the following command to run the container from a script:
nvbuf_utils: Could not get EGL display connection
nvbuf_utils: ERROR getting proc addr of eglCreateImageKHR
nvbuf_utils: ERROR getting proc addr of eglDestroyImageKHR
nvbufsurface: eglGetDisplay failed with error 0x300c
nvbufsurface: Can't get EGL display
$ echo $DISPLAY
:0
$ xrandr
Screen 0: minimum 8 x 8, current 1024 x 600, maximum 32767 x 32767
HDMI-0 connected primary 1024x600+0+0 (normal left inverted right x axis y axis) 476mm x 268mm
1024x600 59.82*+
1920x1080 59.94 50.00
1280x1024 75.02
1280x720 59.94 50.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
$ sudo docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/:/tmp/ nvcr.io/nvidia/l4t-jetpack:r36.4.0
root@tegra-ubuntu:/# gst-launch-1.0 nvarguscamerasrc ! fakesink
(gst-launch-1.0:21): GStreamer-WARNING **: 08:12:13.412: External plugin loader failed. This most likely means that the plugin loader helper binary was not found or could not be run. You might need to set the GST_PLUGIN_SCANNER environment variable if your setup is unusual. This should normally not be required though.
No protocol specified
No EGL Display
nvbufsurftransform: Could not get EGL display connection
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 2464 x 2064 FR = 41.299998 fps Duration = 24213076 ; Analog Gain range min 0.000000, max 48.000000; Exposure Range min 1000, max 1000000000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 2464 H = 2064
seconds to Run = 0
Frame Rate = 41.299998
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Redistribute latency...
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:17.749971352
Setting pipeline to NULL ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Freeing pipeline ...
So EGL still cannot find the display.
Do you know if there is a way to use argus, nvbuffer without a display (or X11 in general)? In our application we can work without any display because we upload all images at some point so we could just get rid of the whole thing.
$ sudo docker run -it --rm --net=host --runtime nvidia -v /tmp/:/tmp/ nvcr.io/nvidia/l4t-jetpack:r36.4.0
root@tegra-ubuntu:/# echo $DISPLAY
(gst-launch-1.0:21): GStreamer-WARNING **: 07:34:48.074: External plugin loader failed. This most likely means that the plugin loader helper binary was not found or could not be run. You might need to set the GST_PLUGIN_SCANNER environment variable if your setup is unusual. This should normally not be required though.
Camera index = 0
Camera mode = 0
seconds to Run = 0
Execution ended after 0:00:53.056457608
seems like the issues with EGL are not there without setting DISPLAY. So what does that mean in my case?
I tested my setup without the DISPLAY variable but get the same error.
I found out that we were still including the old nvbuf_utils API and swiched completely to NvUtils and nvbufsurface but there are still issues:
This happens during a call to NvBufSurfaceMapEglImage. Any ideas what we can try?
Like I said we do not need a display to use our application if that opens other possibilities.
Looks like the camera can be launched in the environment. So your application still fails? If yes, please share a patch to jetson_multimedia_api 09 or 10 sample, and the steps. So that we can try it on developer kit.
FROM nvcr.io/nvidia/l4t-jetpack:r35.3.1
# register nvidias deb packages, create OS expected files to fake native environment, install tegra libs
RUN echo "deb https://repo.download.nvidia.com/jetson/t234 r35.3 main" >> /etc/apt/sources.list.d/nvidia-l4t-apt-source.list && \
mkdir -p /opt/nvidia/l4t-packages/ && touch /opt/nvidia/l4t-packages/.nv-l4t-disable-boot-fw-update-in-preinstall && \
mv /etc/ld.so.conf.d/nvidia-tegra.conf /etc/ld.so.conf.d/nvidia-tegra.conf.old && \
apt-get update && DEBIAN_FRONTEND=noninteractive apt-get install -y --no-install-recommends \
nvidia-l4t-core nvidia-l4t-jetson-multimedia-api && \
rm -rf /var/lib/apt/lists/* && apt-get clean
COPY . /app
WORKDIR /app
RUN rm samples/common/classes/NvDrmRenderer.cpp && \
sed -i 's\-ldrm\\g' samples/Rules.mk && cd samples/10_argus_camera_recording && make
The patch is applied to sample 10 and the docker file is placed in the root of jetson_multimedia_api like this: /some/path/jetson_multimedia_api/Dockerfile
and called with:
You should see that the sample will now sometimes crash.
I think the problem is coming from the compilation inside the docker and the installation of the nvmmapi instead of compiling with the runtime. We want to produce a ready to run container with our dockerfile so that is definitely the goal here.
another part to solving this mystery. I figured that if I use l4t-jetpack - instead of l4t-base - as the base and add nvidia as the default runtime, so that it is also available during build, the image that I build on the jetson is working as I would hope. The EGL error does not appear anymore.
So the solution to the issue would be adding the following to /etc/docker/daemon.json
the "default-runtime": "nvidia" was missing in my configuration. With this I can now build on the jetson with 5.1.1
But then another question. Is it possible to build this container while not on a Jetson device? Now the only way to build is on a jetson and not on a build server. Is there such an option?
Since the docker is based on hardware components of Jetson platform, it may not work to build it on a x86 host PC. Some functions may be dependent to the hardware components in Jetson SoC.
