Setting pipeline to PAUSED ...
Could not open DRM failed
0:00:00.182451894 5302 0xaaaac3192c70 ERROR nvdrmvideosink gstnvdrmvideosink.c:835:gst_nvdrmvideosink_start: drm_util_init failed
0:00:00.182598807 5302 0xaaaac3192c70 WARN basesink gstbasesink.c:5367:gst_base_sink_change_state:<nvdrmvideosink0> error: Failed to start
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstNvDrmVideoSink:nvdrmvideosink0: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Additional debug info:
gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:pipeline0/GstNvDrmVideoSink:nvdrmvideosink0:
Failed to start
Setting pipeline to NULL ...
Freeing pipeline ...
I don’t understand what is the reason especially as it was working fine with Jetpack 4.6 on my Jetson Nano from a docker container using deepstream 6.0 base image.
I have check the release note but it is not clear to me such limitation is expected from the docker container for this new release.
Thank you for letting us know if some alternative exists especially as the nvoverlaysink has been removed either.
Is there any updates or alternative to get this working properly ?
I have tried the following pipeline as a workaround to get the video sink on the HDMI output.
I runs properly (within Docker) but as the buffers are transferred to the CPU for processing the performance is too low to be used for digital signage for example and affect the whole pipeline quality.
Probably it’s an unsupported use case, nvdrmvideosink only work well when there’s no compositor running in background, and that’s not possible inside a docker. It may have worked by fluke, but this is not a supported use case IMO.
Can you run pipeline gst-launch-1.0 videotestsrc ! video/x-raw,width=1280,height=720 ! queue ! nvdrmvideosink conn_id=0 plane_id=1 set_mode=1 sync=1 -e
directly from device?
if you need nvdrmvideosink, you need to run from device. otherwise, the pipeline which includes transfer the GPU buffer to CPU buffer is unavoidable.
you can consider using nveglglessink instead.
As mentioned in my initial post I can run the pipeline using nvdrmvideosink from the host only but not from the docker container (based on Nvidia official image).
It is a regression in Deepstream 6.1.1 as it was working properly in Deepstream 6.0 (docker image)
As for nveglglessink correct me if I am wrong but it requires a X server / Wayland to run. Our environment is headless which is anyway required for nvdrmvideosink not to conflict with the compositor.
If the nvdrmvideosink plugin is not supported in docker containers from 5.0.2GA / DP 6.1.1 it would be great if it could be reflected in the documentation to make it clear.
I think as cloud native applications are progressing on the edge being able to support digital signage applications using Docker could be great.
At this stage I understand the Jetson is not the right solution for that if we build such containerized applications.
As mentioned in this thread I am talking about the support from within the Nvidia Docker container. Also I refer to Jetpack 6 version 36.3.0 not previous 34.1 one.
My request is same as in the original post. I want to know if the nvdrmvideosink is supported officially when used inside the container (not from the host directly). It is not clear to me from the documentation.
There is no such information in DeepStream document. You may raise the request to the Jetson document since the Jetson container is based on the L4T container.
