So i have a Jetson Orin AGX 32GB developer kit and successfully emulated the NX orin 8Gb on it during flashing. I installed Deepstream, cuda, tensorrt through SDK manager and all installations were successful.
In older versions, i always used nvoverlaysink in my deepstream pipelines, but since it’s not there anymore in newer releases, I am trying to test the nvdrmvideosink in a simple pipeline which is
gst-launch-1.0 videotestsrc ! nvvidconv ! 'video/x-raw(memory:NVMM), format=I420' ! nvdrmvideosink
I tried running that but faced the following error
Setting pipeline to PAUSED ...
Could not open DRM failed
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstNvDrmVideoSink:nvdrmvideosink0: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Additional debug info:
gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:pipeline0/GstNvDrmVideoSink:nvdrmvideosink0:
Failed to start
Setting pipeline to NULL ...
Freeing pipeline ...
i realized from other forum posts that nvdrmvideosink requires that i disable the GUI, so i did that using the commands
sudo systemctl set-default multi-user.target
sudo reboot
but upon rebooting, my display just showed no signal and no terminal showed up.
I accessed the orin through SSH, and ran also the following command as suggested in other forum posts
sudo modprobe nvidia-drm modeset=1
Then tried running the same command again, faced a different error this time
Pipeline is PREROLLING ...
cannot create framebuffer
Cannot create frame buffer
ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error.
gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0:
streaming stopped, reason not-negotiated (-4)
ERROR: pipeline doesn't want to preroll.
So i am not really sure what the problem is.
So my question is, what are the steps i need to do to run a simple pipeline with nvdrmvideosink on my Orin? Also Why is there no signal on the monitor after running the sudo systemctl set-default multi-user.target command? i used to work on older jetson devices.
• Hardware Platform: Jetson Orin AGX as Orin NX 8GB through emulation
• DeepStream Version 6.2
• JetPack Version 5.1.1
• TensorRT Version 8.5.2.2
