Deepstream example doesn't work!
Hi
I want the Deepstream example to work.
I entered the command below.
cd /opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app
deepstream-app -c source1_usb_dec_infer_resnet_int8.txt
But I get the below error.
tes@ubuntu:/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app$ deepstream-app -c source1_usb_dec_infer_resnet_int8.txt
Could not open DRM failed
** ERROR: <main:716>: Failed to set pipeline to PAUSED
Quitting
ERROR from sink_sub_bin_sink1: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstNvDrmVideoSink:sink_sub_bin_sink1:
Failed to start
App run failed
I had the same case on the forum but no solution.
I have a USB camera connected to Orin.
My Orin environment is below.
help me.
help me… please…
Moving this topic to the DeepStream SDK forum for visibility.
I appreciate any help!
• DeepStream Version
• TensorRT Version
Have you tested your usb camera with v4l2 tool? Can you show us the result of “v4l2-ctl --list-formats-ext” command?
@Fiona.Chen
Thank you for your help.
    JETSON-AGX-ORIN-DEV-KIT
    6.1.1
    5.0.2 (L4T 35.1.0)
  • TensorRT Version
    8.4.1.5
    I don’t know how to find out
    questions
  • How to reproduce the issue?
    I just want to run the example below.
  • Requirement details
    I want the above sample to work.
The result of v4l2-ctl --list-formats-ext is below.
ioctl: VIDIOC_ENUM_FMT
        Type: Video Capture
        [0]: 'MJPG' (Motion-JPEG, compressed)
                Size: Discrete 1920x1080
                        Interval: Discrete 0.033s (30.000 fps)
                        Interval: Discrete 0.017s (60.000 fps)
                        Interval: Discrete 0.008s (120.101 fps)
                Size: Discrete 1280x1024
        [1]: 'YUYV' (YUYV 4:2:2)
                        Interval: Discrete 0.167s (6.000 fps)
                        Interval: Discrete 0.111s (9.000 fps)
                        Interval: Discrete 0.050s (20.000 fps)
I had the same error.
I changed the config file “source1_usb_dec_infer_resnet_int8.txt” as follows.
[sink0]
type=2 # default 5
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=nvdrmvideosink
@muller
Thank you!
As you advised, when I changed the type from 5(nvdrmvideosink) to 2(EglSink), the image of the USB camera was displayed on the display!
I checked based on your advice.
I found the following web.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_ref_app_deepstream.html#sink-group
Setting type=2 seems to be deprecated.
I would like to know the reason why type=5 doesn’t work.
I am deeply grateful to @muller .
I suddenly thought…
Is it necessary for the image format of the USB camera to be H.264?
The cameras I use are MJPEG or YUY2 only.
No.
For the nvdrmvideosink, you need to disable gdm and enable drm driver first. Accelerated GStreamer — Jetson Linux Developer Guide documentation (nvidia.com)
@Fiona.Chen
Thank you!
I entered the following commands in order.
However, with “sudo systemctl stop gdm” command, the display connected to JETSON-AGX-ORIN-DEV-KIT disappeared.
Do I need to SSH into another computer and enter the commands after this?
$ sudo systemctl stop gdm
$ sudo loginctl terminate-seat seat0
For Jetson Orin use
$ sudo modprobe nvidia-drm modeset=1
Yes
@Fiona.Chen
I will try!
I tried it, but I ran into a new problem.
What is the reason for this?
I don’t want to give up until the end
echo@ubuntu:/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app$ deepstream-app -c source1_usb_dec_infer_resnet_int8.txt
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:07.401085367  4391 0xffff2c0022c0 INFO                 nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x368x640
1   OUTPUT kFLOAT conv2d_bbox     16x23x40
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:07.614119415  4391 0xffff2c0022c0 INFO                 nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
0:00:07.660844974  4391 0xffff2c0022c0 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
        h: Print this help
        q: Quit
        p: Pause
        r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
**PERF:  FPS 0 (Avg)
**PERF:  0.00 (0.00)
** INFO: <bus_callback:194>: Pipeline ready
** INFO: <bus_callback:180>: Pipeline running
Failed to set plane
Failed to display frame buffer
0:00:08.202352890  4391 0xaaaac167b5e0 WARN                 nvinfer gstnvinfer.cpp:2300:gst_nvinfer_output_loop:<primary_gie> error: Internal data stream error.
0:00:08.202430303  4391 0xaaaac167b5e0 WARN                 nvinfer gstnvinfer.cpp:2300:gst_nvinfer_output_loop:<primary_gie> error: streaming stopped, reason error (-5)
ERROR from primary_gie: Internal data stream error.
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(2300): gst_nvinfer_output_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
Quitting
ERROR from sink_bin_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstQueue:sink_bin_queue:
ERROR from src_elem: Internal data stream error.
Debug info: gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstV4l2Src:src_elem:
ERROR from primary_gie_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstQueue:primary_gie_queue:
App run failed
Hi
I was able to achieve inference from a USB camera with the script on the web below.
However, the result is inferior to yolo…
