When I run the below deepstream-app command on Jetson AGX Orin,
I get Could not open DRM failed error:
user@ubuntu-jetson:~/Desktop$ deepstream-app -c '/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/source1_usb_dec_infer_resnet_int8.txt'
** ERROR: <main:716>: Failed to set pipeline to PAUSED
Quitting
ERROR from sink_sub_bin_sink1: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstNvDrmVideoSink:sink_sub_bin_sink1:
Failed to start
App run failed
The deepstream installation (v6.1.1) followed these instructions, and there seems to be no problem with USB camera device recognition.
OS is Ubuntu 20.04.5 LTS,
Jetpack version is 5.0.1-b118 .
How can I solve this problem?
Any help would be appreciated.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
