•	Hardware Platform (Jetson / GPU) Orin
•	DeepStream Version 6.01
•	JetPack Version (valid for Jetson only) % Dev preview 5
•	TensorRT Version
•	NVIDIA GPU Driver Version (valid for GPU only)
•	Issue Type( questions, new requirements, bugs)
•	How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
•	Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Unable to install DS prereqs :
E: Package ‘libssl1.0.0’ has no installation candidate
E: Version ‘2.11-1’ for ‘libjansson4’ was not found
Used :
sudo apt update
sudo apt dist-upgrade
sudo reboot
sudo apt install nvidia-jetpack
to install - had to change repos to r34.1 to get upgrade to recognize apt install nvidia-jetpack
Iain
