• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 6.3
• JetPack Version (valid for Jetson only): NA
• TensorRT Version: 8.5
• NVIDIA GPU Driver Version (valid for GPU only): NA
• Issue Type( questions, new requirements, bugs): questions
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing): NA
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description): NA
The installation instruction says to install NVIDIA driver 530.41.03, for professional and consumer GPUs; can I use version 535+ instead?
