• Hardware Platform (Jetson / GPU) Quadro 5000
• DeepStream Version 6.4
• TensorRT Version 8.6
• NVIDIA GPU Driver Version (valid for GPU only) 535.104.05
**• How to reproduce the issue ? sudo apt-get install /deepstream-6.4_6.4.0-1_amd64.deb
I cannot install deep stream from the package
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Note, selecting ‘deepstream-6.4’ instead of ‘/deepstream-6.4_6.4.0-1_amd64.deb’
The following NEW packages will be installed:
deepstream-6.4
0 upgraded, 1 newly installed, 0 to remove and 4 not upgraded.
4 not fully installed or removed.
Need to get 0 B/788 MB of archives.
After this operation, 1 036 MB of additional disk space will be used.
Get:1 /deepstream-6.4_6.4.0-1_amd64.deb deepstream-6.4 amd64 6.4.0-1 [788 MB]
(Reading database … 230927 files and directories currently installed.)
Preparing to unpack …/deepstream-6.4_6.4.0-1_amd64.deb …
Unpacking deepstream-6.4 (6.4.0-1) …
dpkg: error processing archive /deepstream-6.4_6.4.0-1_amd64.deb (–unpack):
trying to overwrite ‘/opt/riva/backends/libtriton_riva_asr_decoder_cpu.so’, which is also in package deepstream-6.2 6.2.0-1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
