**• Hardware Platform (Jetson / GPU)GPU
**• DeepStream Version 6.0
**• TensorRT Version 8.2.1 GA
**• NVIDIA GPU Driver Version (valid for GPU only) 470.82.01
**• Issue Type( questions, new requirements, bugs) questions
**• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
ubuntu 20.04 GTX1060
sudo apt-get install ./deepstream-6.0_6.0-1_amd64.deb
The following packages have unsatisfied dependencies:
Deepstrain-6.0: dependency: cuda-cudart-11-1, but it cannot be installed
Dependency: cuda-cudart-dev-11-1 but cannot install it dependency: libnpp-11-1 but cannot install it
Dependency: libnpp-dev-11-1, but it cannot be installed
Dependency: libnvinfer7 (> = 7.2.1) but cannot install it dependency: libnvparsers7 (> = 7.2.1) but cannot install it
Dependency: libnvonnxparsers7 (> = 7.2.1) but cannot install it dependency: libnvinfer-plugin7 (> = 7.2.1) but cannot install it
E: The error cannot be fixed because you require some packages to remain as they are, that is, they break the dependencies between packages.
**• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Why am I prompted to install CUDA 11.1 and tensort 7.2?
Yes. but your package seems not the one downloaded from here. please check.
This is my environments with this package to install.
The following packages have unmet dependencies:
deepstream-6.0 : Depends: cuda-cudart-11-4 but it is not installable
Depends: cuda-cudart-dev-11-4 but it is not installable
Depends: libnpp-11-4 but it is not installable
Depends: libnpp-dev-11-4 but it is not installable
Depends: gstreamer1.0-libav but it is not installable
Depends: gstreamer1.0-plugins-bad but it is not installable
Depends: gstreamer1.0-plugins-good but it is not installable
Depends: libcairo2 (>= 1.15.10) but it is not installable
Depends: libglib2.0-0 (>= 2.56.4) but it is not installable
Depends: libgstreamer1.0-0 (>= 1.14.1) but it is not installable
Depends: libgstreamer1.0-dev (>= 1.14.1) but it is not installable
Depends: libgstreamer-plugins-base1.0-0 (>= 1.14.1) but it is not installable
Depends: libgstreamer-plugins-base1.0-dev (>= 1.14.1) but it is not installable
Depends: libnvinfer8 (>= 8.0.0) but it is not installable
Depends: libnvinfer-dev (>= 8.0.0) but it is not installable
Depends: libnvparsers8 (>= 8.0.0) but it is not installable
Depends: libnvparsers-dev (>= 8.0.0) but it is not installable
Depends: libnvonnxparsers8 (>= 8.0.0) but it is not installable
Depends: libnvonnxparsers-dev (>= 8.0.0) but it is not installable
Depends: libnvinfer-plugin8 (>= 8.0.0) but it is not installable
Depends: libnvinfer-plugin-dev (>= 8.0.0) but it is not installable
Depends: libpangocairo-1.0-0 (>= 1.40.14) but it is not installable
Depends: libx11-6 but it is not installable
Depends: libgstrtspserver-1.0-0 but it is not installable
E: Unable to correct problems, you have held broken packages.
