From the documentation link, Quickstart Guide — DeepStream 6.2 Release documentation, I’m trying to install deepstream via debian package and I get below error.
nvidia@Chandra:~/Downloads$ sudo apt-get install ./deepstream-6.2_6.2.0-1_arm64.deb
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'deepstream-6.2' instead of './deepstream-6.2_6.2.0-1_arm64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
deepstream-6.2 : Depends: cuda-cudart-11-4 but it is not installable or
cuda-cudart-11-7 but it is not installable
Depends: cuda-cudart-dev-11-4 but it is not installable or
cuda-cudart-dev-11-7 but it is not installable
Depends: libnpp-11-4 but it is not installable or
libnpp-11-7 but it is not installable
Depends: libnpp-dev-11-4 but it is not installable or
libnpp-dev-11-7 but it is not installable
Depends: libcufft-11-4 but it is not installable or
libcufft-11-7 but it is not installable
Depends: libgstreamer1.0-0 (>= 1.16.0) but 1.14.5-0ubuntu1~18.04.2 is to be installed
Depends: libgstreamer1.0-dev (>= 1.16.0) but 1.14.5-0ubuntu1~18.04.2 is to be installed
Depends: libgstreamer-plugins-base1.0-0 (>= 1.16.0) but 1.14.5-0ubuntu1~18.04.3 is to be installed
Depends: libgstreamer-plugins-base1.0-dev (>= 1.16.0) but 1.14.5-0ubuntu1~18.04.3 is to be installed
Depends: libnvvpi2 (>= 2.0.2) but it is not installable
Depends: libyaml-cpp-dev (>= 0.6.2) but 0.5.2-4ubuntu1 is to be installed
E: Unable to correct problems, you have held broken packages.
Details of my system configuration are below:
CUDA: 10.2.300
cuDNN:8.2.1.32
TensorRT:8.2.1.8
Jetson: Nano
Ubuntu: 18.04
OpenCV: 4.1.1.
Jetpack:4.6.1
Could you pls help to resolve this? Thank you.
