Install DeepStream on Jetson Orin with JetPack 5.0.2
• Hardware Platform (Jetson / GPU) Orin AGX Devkit
• JetPack Version (valid for Jetson only) 5.0.2-b231
• TensorRT Version 8.4.1.5
The DeepStream installation instructions refer to 5.0.1 DP (corresponding to L4T 34.1.1 release).
Can I use the same instructions for my platform? My L4T version is R35.1
Yes. You must install JetPack 34.1.1 for installing DeepStream 6.1. There is no DeepStream for R35.1.
So, essentially, the answer is no, DeepStream is not yet available for 35.1. Are there any plans to release it in the near future?
I installed R35.1 with sdk manager as part of 5.02. Then I installed deepstream 6 and ran the deepstream-app on the usb sample config without a problem. I didn’t realize its not supported until now.
No DeepStream for R35.1 now. Every DeepStream version has its own corresponding JetPack version, not the other way.
