Can't use nvdrmvideosink in Jetson Xavier NX
I want to use nvdrmvideosink to display stream from one usb camera to one hdmi device.
But when I run the command which is ok in Jetson AGX Orin(usb device path /dev/video8) as shown bellow, the errors are output in the Xavier NX(usb device path /dev/video0).
The comands:
service gdm stop
loginctl terminate-seat seat0
modprobe tegra_udrm modeset=1
*export GST_DEBUG=FACTORY:4 *
gst-launch-1.0 v4l2src device=/dev/video8 ! videoconvert ! nvvidconv ! nvdrmvideosink max-bitrate=16384000 set_mode=0 sync=false
The Result:
gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! nvvidconv ! nvdrmvideosink max-bitrate=16384000 set_mode=0 sync=false -e
0:00:00.236774048 23904 0x55bd0f6390 INFO **GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create:** creating element "v4l2src"
0:00:00.240772603 23904 0x55bd0f6390 INFO **GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create:** creating element "videoconvert"
0:00:00.271175067 23904 0x55bd0f6390 INFO **GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create:** creating element "nvvidconv"
0:00:00.272795769 23904 0x55bd0f6390 INFO **GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create:** creating element "nvdrmvideosink"
0:00:00.273443928 23904 0x55bd0f6390 INFO **GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create:** creating element "pipeline"
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Failed to set plane
Failed to display frame buffer
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason error (-5)
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
Could anybody know why and how to solve it?
Do you also flash Jetpack 5.0.2 to the Xavier NX? not sur e if you use same version for both Orin and Xaiver NX.
And please try with videotestsrc and see if it works:
$ gst-launch-1.0 videotestsrc is-live=1 ! videoconvert ! nvvidconv ! nvdrmvideosink
No, I am not flash Jetpack 5.0.2 to Xavier NX.
I use the jetpack 4.5 in Xavier NX.
The result as bellow.
root@nx:/usr/local/robu/source# service gdm stop
root@nx:/usr/local/robu/source# loginctl terminate-seat seat0
root@nx:/usr/local/robu/source# modprobe tegra_udrm modeset=1
root@nx:/usr/local/robu/source# export GST_DEBUG=FACTORY:4
root@nx:/usr/local/robu/source# gst-launch-1.0 videotestsrc is-live=1 ! videoconvert ! nvvidconv ! nvdrmvideosink
Failed to set plane
ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error.
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0:
Execution ended after 0:00:00.015413958
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
root@nx:/usr/local/robu/source# gst-launch-1.0 videotestsrc is-live=1 ! videoconvert ! nvvidconv ! nvdrmvideosink -e
Failed to set plane
Waiting for EOS...
I can use nvoverlaysink:
root@nx:/usr/local/robu/source# gst-launch-1.0 videotestsrc is-live=1 ! videoconvert ! nvvidconv ! nvoverlaysink -e
For using Jetpack 4 release, please refer to this version of document:
Jetson Linux API Reference: 08_video_dec_drm (Direct Rendering Manager)
This command is not required for Jetpack 4:
Please not to execute it and try again.
https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/SD/Multimedia/AcceleratedGstreamer.html#gstreamer-1-0-installation-and-setup
I refer to the information before, it shows:
Load the DRM driver:
For Jetson Xavier use
$ sudo modprobe tegra_udrm modeset=1
For Jetson Orin use
$ sudo modprobe nvidia-drm modeset=1
The link you provided is not gstreamer related API and method, I think it have many low-level API to use,right ? It is a long time to use C program language for me, and the low-level API is hard for me. I am now using python mainly.
If not execute $ sudo modprobe tegra_udrm modeset=1, error also happens.
Failed to set plane
Waiting for EOS...
The steps between different release may not be identical. For Jetpack 4, the gstreamer user guide is in
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3261/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/accelerated_gstreamer.html#wwpID0E06P0HA
Thanks, I will have a try later.
One error output as bellow.
**root@nx**:**/sys/class/graphics/fb0**# echo 4 > blank
**root@nx**:**/sys/class/graphics/fb0**# echo 0x0 > device/win_mask
**root@nx**:**/sys/class/graphics/fb0**# echo 0x3f > device/win_mask
bash: echo: write error: Invalid argument
By default the commands should work:
A bit strange it does not work. Do you use Xavier NX developer kit? And would be great if you can try Jetpack 4.6.3.
For comparison, you may try this jetson_multimedia_api sample:
/usr/src/jetson_multimedia_api/samples/08_video_dec_drm/
The sample also uses DRM. Please give it a try.
I tried the command in another Xavier NX, and it indeed has no problem.
So it maybe something wrong with the machine I used before.
Thanks very much. I will use other machines instead of the one before.
