jetson@jetson:/data/src/jetsonUtilities$ ./jetsonInfo.py
NVIDIA Jetson Nano (Developer Kit Version)
L4T 32.7.1 [ JetPack UNKNOWN ]
Ubuntu 18.04.6 LTS
Kernel Version: 4.9.253-tegra
CUDA 10.2.300
CUDA Architecture: 5.3
OpenCV version: 4.1.1
OpenCV Cuda: NO
CUDNN: 8.2.1.32
TensorRT: 8.2.1.8
Vision Works: 1.6.0.501
VPI: ii libnvvpi1 1.2.3 arm64 NVIDIA Vision Programming Interface library
Vulcan: 1.2.70
Deepstream 6.0.1
question
On the base install of the jetson i have a DISPLAY=:0
and when i run
gst-launch-1.0 -v videotestsrc ! nvvideoconvert ! "video/x-raw(memory:NVMM)" ! nvdsosd ! appsink
it works alright ( i know it doesn’t do anything interesting, but it works)
I then startup a docker container like:
docker run --rm -it --name=test1 --cap-add=SYS_PTRACE --cap-add=sys_nice --runtime=nvidia --privileged --net=host -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix -v $HOME/.Xauthority:/root/.Xauthority nvcr.io/nvidia/deepstream-l4t:6.0.1-samples
and i run the same pipeline it complains about
No EGL Display
nvbufsurftransform: Could not get EGL display connection
No protocol specified
and
WARNING: erroneous pipeline: no element "nvvideoconvert"
full log:
jetson@jetson:/data/src/dockers$ docker run --rm -it --name=test1 --cap-add=SYS_PTRACE --cap-add=sys_nice --runtime=nvidia --privileged --net=host -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix -v $HOME/.Xauthority:/root/.Xauthority nvcr.io/nvidia/deepstream-l4t:6.0.1-samples
root@jetson:/opt/nvidia/deepstream/deepstream-6.0# clear
root@jetson:/opt/nvidia/deepstream/deepstream-6.0# gst-launch-1.0 -v videotestsrc ! nvvideoconvert ! "video/x-raw(memory:NVMM)" ! nvdsosd ! appsink
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:20): GStreamer-WARNING **: 03:10:51.877: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
No EGL Display
(gst-plugin-scanner:21): GStreamer-WARNING **: 03:10:51.930: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:32): GStreamer-WARNING **: 03:10:53.035: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
No EGL Display
No EGL Display
No EGL Display
No EGL Display
nvbuf_utils: Could not get EGL display connection
(Argus) Error FileOperationFailed: Connecting to nvargus-daemon failed: No such file or directory (in src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 205)
(Argus) Error FileOperationFailed: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 106)
root@jetson:/opt/nvidia/deepstream/deepstream-6.0# printenv
DS_REL_PKG_DIR=deepstream_sdk_v6.0.1_jetson
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:
LD_LIBRARY_PATH=/usr/local/cuda-10.2/lib64
DISPLAY=:0
TAG=gmc1
HOSTNAME=jetson
DS_REL_PKG=deepstream_sdk_v6.0.1_jetson.tbz2
NVIDIA_VISIBLE_DEVICES=all
DS_VERSION=6.0.1
PWD=/opt/nvidia/deepstream/deepstream-6.0
HOME=/root
TERM=xterm
PLATFORM=jetson
NVIDIA_DRIVER_CAPABILITIES=all
SHLVL=1
PATH=/usr/local/cuda-10.2/bin:/usr/local/cuda/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
_=/usr/bin/printenv
can anyone see something wrong here ?
