• Hardware Platform GPU
• DeepStream Version 6.3
• TensorRT Version8.6.1
• NVIDIA GPU Driver Version (valid for GPU only) 535.104.05
• Issue Type ** questions, new requirements, bugs)
Using new nvstreammux the nvbufsurftrasnform library fails with error -1:
gst-stream-error-quark: NvBufSurfTransform failed with error -1 while converting buffer (1): gstnvinfer.cpp(1463): convert_batch_and_push_to_input_thread (): /GstPipeline:inference_pipeline_0/GstNvInfer:detector
When the pgie tries to do preprocessing on the video-src.
We have a decodebin that will read streams from a udpsrc like:
udpsrc ! queue ! application/x-rtp,encoding-name=H26X ! rtph26Xdepay ! h26Xparse ! nvv4ld2decoder ! nvvideoconvert flip-method=90 ! videorate ! video/x-raw(memory:NVMM), format=NV12, width={width}, height={height}, framerate={framerate}/1, gpu-id={gpu_id}, nvbuf-memory-type=nvbuf-mem-cuda-device ! queue
Some streams will have rotation so the widht and height properties are updated accordingly.
eg:
rotation_map = {
0: "none",
90: "clockwise",
180: "rotate-180",
-90: "counterclockwise",
270: "counterclockwise",
rotation_value = rotation_map.get(rotation, 0)
if rotation in [90, -90, 270]:
height, width = width, height
Then this is attached to a new nvstreammux and goes to a nvinfer element that resizes the frames to 640x640
m.pad ! nvstreammux ! nvinfer ! fakesink
When running with multiple streams (reproduced with 60) the nvinfer will failed with the mentioned error, and will start logging [ERROR push 353] push failed [-5] disabling all inferring.
Also there is a lot of warnings on the nvvideoconvert:
0:03:00.742824249 349371 0x7552a82fc060 WARN nvvideoconvert gstnvvideoconvert.c:1962:gst_nvvideoconvert_fixate_caps:<decoder_nvvidconv_043c13c9-5771-494c-8829-481d18b9c3f8> gpu-id property is set based on SRC caps. Property config setting (if any) is overridden!!
0:03:00.743702496 349371 0x75513404be40 WARN nvvideoconvert gstnvvideoconvert.c:1957:gst_nvvideoconvert_fixate_caps:<decoder_nvvidconv_605267f6-3b7a-4633-b0ec-6e7cb8f193cf> nvbuf-memory-type property is set based on SRC caps. Property config setting (if any) is overridden!!
0:03:00.743714036 349371 0x75513404be40 WARN nvvideoconvert gstnvvideoconvert.c:1962:gst_nvvideoconvert_fixate_caps:<decoder_nvvidconv_605267f6-3b7a-4633-b0ec-6e7cb8f193cf> gpu-id property is set based on SRC caps. Property config setting (if any) is overridden!!
