NvBufSurfTransform produces wrong result in GPU compute mode
Hello Everyone! I’ve been facing an issue for a while and couldn’t find a solution for it I think it is a bug inside Nvidia libraries. The overall structure of the application is that I read frames from a file via a gstreamer pipeline process and push them to another gstreamer pipeline to encode them into a file. Pipelines are like this:
Input pipeline: filesrc -> qtdemux -> h264parse -> nvv4l2decoder -> nvvidconv (video/x-raw(memory:NVMM), format=RGBA) -> appsink
Output pipeline: appsrc (video/x-raw(memory:NVMM), format=RGBA) -> nvvidconv -> (video/x-raw(memory:NVMM), format=NV12) -> nvv4l2h264enc -> h264parse -> qtmux -> filesrc
Execution block is like this:
void executeThread()
    NvBufSurfTransformConfigParams config_params;
    config_params.compute_mode = NvBufSurfTransformCompute_GPU;
    config_params.gpu_id = 0;
    config_params.cuda_stream = m_cuda_stream;
    if (NvBufSurfTransformSetSessionParams(&config_params) != NvBufSurfTransformError_Success)
        LOG_ERROR("NvBufSurfTransform set session failed");
        exit(-1);
    while (true)
        std::unique_lock<std::mutex> lock(m_execute_mutex);
        m_execute_cond.wait(lock);
        NvBufSurface *in_surface = NULL;
        NvBufSurfTransformParams transform_params;
        memset(&transform_params, 0, sizeof(NvBufSurfTransformParams));
        GstElement *input_pipeline = getPipeline(getIntputPipelineString(m_options).c_str());
        GstElement *output_pipeline = getPipeline(getOutputPipelineString(m_options).c_str());
        GstElement *appsink = gst_bin_get_by_name(GST_BIN(input_pipeline), "appsink0");
        GstElement *appsrc = gst_bin_get_by_name(GST_BIN(output_pipeline), "appsrc0");
        if (gst_element_set_state(input_pipeline, GST_STATE_PLAYING) == GST_STATE_CHANGE_FAILURE)
            LOG_ERROR("Input Pipeline is unable to be set playing!");
            break;
        if (gst_element_set_state(output_pipeline, GST_STATE_PLAYING) == GST_STATE_CHANGE_FAILURE)
            LOG_ERROR("Output Pipeline is unable to be set playing!");
            break;
        GstFlowReturn ret;
        GstBufferPool *pool = getBufferPool(m_options);
        GstBuffer *output_buffer = NULL;
        GstMemory *mem = NULL;
        int frame_id = 0;
        bool error = false;
        while (!error)
            GstSample *sample = gst_app_sink_pull_sample(GST_APP_SINK(appsink));
            if (!sample)
                break;
            GstBuffer *input_buffer = gst_sample_get_buffer(sample);
            GstMapInfo inmap;
            if (!gst_buffer_map(input_buffer, &inmap, GST_MAP_READ))
                break;
            in_surface = (NvBufSurface *)inmap.data;
            if (gst_buffer_pool_acquire_buffer(pool, &output_buffer, NULL) != GST_FLOW_OK)
                LOG_ERROR("Buffer cannot be acquired from pool.");
                break;
            if (!gst_buffer_peek_memory(output_buffer, 0))
                LOG_ERROR("Memory block of the buffer is not available.");
                break;
            GstMapInfo outmap;
            if (!gst_buffer_map(output_buffer, &outmap, GST_MAP_WRITE))
                break;
            NvBufSurface *surf = (NvBufSurface *)outmap.data;
            if (NvBufSurfTransform(in_surface, surf, &transform_params) != 0)
                LOG_ERROR("NvBufSurfTransform Failed");
                error = true;
                break;
            gst_buffer_unmap(output_buffer, &outmap);
            gst_buffer_unmap(input_buffer, &inmap);
            gst_sample_unref(sample);
            GST_BUFFER_PTS(output_buffer) = input_buffer->pts;
            g_signal_emit_by_name(appsrc, "push-buffer", output_buffer, &ret);
            gst_buffer_unref(output_buffer);
            frame_id++;
        /* Clean up */
        gst_object_unref(appsink);
        gst_object_unref(appsrc);
        gst_buffer_pool_set_active(pool, FALSE);
        gst_object_unref(pool);
        cleanUpPipeline(input_pipeline);
        cleanUpPipeline(output_pipeline);
            std::unique_lock<std::mutex> lock(m_is_running_mutex);
            m_is_running = false;
        LOG_INFO("Execution finished.");
If I remove the part setting NvBufSurfTransformConfigParams to NvBufSurfTransformCompute_GPU it works properly since it uses VIC to copy in_surface to surf(output buffer) however I need to do CUDA operations (please refer to gst-nvdewarper, I will warp frames using NVWarp API)
The issue doesn’t happen always. It produces correct results sometimes
ORIN NX 16 GB - Auvidea JNX42 Carrier board - Jetpack 5.1.1 - L4T 35.3.1
I’m attaching example videos:
video0.mp4: frames copied by VIC
video1.mp4: frames copied by GPU and error type 1
video2.mp4: frames copied by GPU and error type 2
videos.zip (5.2 MB)
If there is no fix for this, is there a way to copy the contents of a memory allocated by cudaMalloc to an NvBufSurface with mem_type NVBUF_MEM_SURFACE_ARRAY
Please use VIC engine for the conversion. It is hardware converter in Jetson chip and we generally use it on Jetson platforms. For copying data from GPU buffer to NvBufSurface, there are NvBufSurface and CUDA APIs to map the plane(s) to GPU. You can map it to GPU and copy data through cudaMemcpy()
Hi @DaneLLL I implemented the same approach as gst-nvdewarper, but it is not recommended apparently. I tried a couple of things but couldn’t find the solution, is there an example of copying data from a block allocated with cudaMalloc to NvBufSurface?
I tried this:
Memory allocation:
if (cudaMalloc(&dewarp_params.surface, dewarp_params.dst_pitch * dewarp_params.dst_height) != cudaSuccess)
    LOG_ERROR("Cuda malloc failed!");
    exit(-1);
Copying it to NvBufSurface:
GstMapInfo outmap;
    break;
surf->numFilled = 1;
int width = surf->surfaceList[0].width;
int height = surf->surfaceList[0].height;
int pitch = surf->surfaceList[0].pitch;
NvBufSurfaceMap(surf, 0, 0, NVBUF_MAP_WRITE);
cudaError_t err = cudaMemcpy2D(
    surf->surfaceList[0].mappedAddr.addr[0],
    pitch,
    dewarp_params.dst_pitch,
    width,
    height,
    cudaMemcpyDefault);
if (err != cudaSuccess)
    LOG_ERROR("ERROR cudaMemcpy2D: {0}", err);
cudaDeviceSynchronize();
NvBufSurfaceSyncForDevice(surf, 0, 0);
I’m getting this result:
pitch, width, and height values are equal in both dewarp_params struct and NvBufSurface. What am I doing wrong?
PS: MAXN and jetson_clocks are both enabled.
EDIT 1: Eventually issue is fixed by multiplying width by 4(bytes per pixel I guess) before cudaMemcpy. Unfortunately, cudaMemcpy is 2 times slower than NvBufSurfTransform on average, is it expected behavior or am I doing something wrong?
Please try Jetpack 5.1.3 and check if the issue is still present. If it exists still, would need your help to share test steps. So that we can set up and try.
I solved the issue by changing NvBufSurfTransform to cudaMemcpy2d. Currently, I’m not able to try Jetpack 5.1.3 so I cannot confirm the problem in NvBufSurfTransform remains.
