• Hardware Platform (Jetson / GPU) : JETSON
• DeepStream Version : 6.0.1
• JetPack Version (valid for Jetson only): Jetpack 5.0.2 GA [L4T 35.1.0]
• TensorRT Version: 8.4.0
I am working on a demo that demonstrates the usage of NvBufSurfTransform, here is the core code:
void Test() {
uint32_t width = 1920;
uint32_t height = 1080;
uint32_t dst_width = 640;
uint32_t dst_height = 360;
NvBufSurfaceCreateParams params1 = {
.gpuId = 0,
.width = width,
.height = height,
.size = 0,
.isContiguous = true,
.colorFormat = NVBUF_COLOR_FORMAT_RGBA,
.layout = NVBUF_LAYOUT_PITCH,
.memType = NVBUF_MEM_SURFACE_ARRAY,
NvBufSurface *surface1 = NULL;
int ret = NvBufSurfaceCreate(&surface1, 1, ¶ms1);
if(ret != 0 || !surface1) {
exit(-1);
ret = NvBufSurfaceMemSet (surface1, -1, -1, 255);
if(ret != 0) {
exit(-1);
NvBufSurfaceCreateParams params2 = {
.gpuId = 0,
.width = dst_width,
.height = dst_height,
.size = 0,
NvBufSurface *surface2 = NULL;
ret = NvBufSurfaceCreate(&surface2, 1, ¶ms2);
if(ret != 0 || !surface2) {
exit(-1);
NvBufSurfTransformRect src_rect, dst_rect;
src_rect.top = 0;
src_rect.left = 0;
src_rect.width = width;
src_rect.height = height;
dst_rect.top = 0;
dst_rect.left = 0;
dst_rect.width = dst_width;
dst_rect.height = dst_height;
NvBufSurfTransformParams nvbufsurface_params;
memset(&nvbufsurface_params, 0, sizeof(nvbufsurface_params));
nvbufsurface_params.src_rect = &src_rect;
nvbufsurface_params.dst_rect = &dst_rect;
nvbufsurface_params.transform_filter = NvBufSurfTransformInter_Default;
nvbufsurface_params.transform_flag = NVBUFSURF_TRANSFORM_CROP_SRC | NVBUFSURF_TRANSFORM_CROP_DST | NVBUFSURF_TRANSFORM_FILTER;
NvBufSurfTransformConfigParams transform_config_params;
memset(&transform_config_params, 0, sizeof(transform_config_params));
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
ret = NvBufSurfTransformSetSessionParams (&transform_config_params);
if(ret != 0) {
exit(-1);
ret = NvBufSurfaceMemSet (surface2, -1, -1, 0);
if(ret != 0) {
exit(-1);
ret = NvBufSurfTransform (surface1, surface2, &nvbufsurface_params);
if (ret != NvBufSurfTransformError_Success) {
printf ("NvBufSurfTransform failed with error %d while converting buffer\n", ret);
When I running the demo, the NvBufSurfTransform will return -3, that is NvBufSurfTransformError_Invalid_Params. Then I further set DBG_NVBUFSURFTRANSFORM in my env, the logs is here:
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:1620: NvBufSurfTransformSessionCreate=> Session created 0xaaaaff557ba0 (nil)
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:1741: libnvbufsurf_transform_init=> Init lib 0xaaaaff557ba0
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:566: taskTrim=> Starting clean up thread
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:1620: NvBufSurfTransformSessionCreate=> Session created 0xaaaaff6125e0 (nil)
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:1790: NvBufSurfTransformSetSessionParams=> No session associated created 0xaaaaff6125e0 for thread=281472958662912
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:2208: NvBufSurfTransformAsync=> src buffers are empty NULL
NvBufSurfTransform failed with error -3 while converting buffer
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:1652: libnvbufsurf_transform_deinit=> Deinit lib
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:1644: NvBufSurfTransformSessionDestroy=> Session destroyed 0xaaaaff557ba0
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:601: taskTrim=> Exiting Clean up thread
