• Hardware Platform (Jetson)
• DeepStream Version: 6.0
• JetPack Version (valid for Jetson only): 4.6
• TensorRT Version
There is a error when running deesptream. the log is as follows.
2023-02-24 10:50:20,887 **PERF: 10.93 (10.91) 10.79 (10.67) 10.00 (9.89) 10.75 (10.64)
2023-02-24 10:50:25,887 **PERF: 8.80 (9.69) 8.82 (9.56) 8.39 (9.01) 8.94 (9.69)
2023-02-24 10:50:30,888 **PERF: 8.41 (9.15) 8.33 (9.13) 8.31 (8.71) 8.36 (9.15)
2023-02-24 10:50:35,889 **PERF: 8.33 (8.95) 8.32 (8.88) 8.34 (8.62) 8.34 (8.95)
2023-02-24 10:50:38,220 0:00:27.550979371 31459 0x55c1bcb850 WARN nvinfer gstnvinfer.cpp:1418:convert_batch_and_push_to_input_thread:<secondary_gie_1> error: NvBufSurfTransform failed with error -3 while converting buffer
2023-02-24 10:50:38,220 ERROR from secondary_gie_1: NvBufSurfTransform failed with error -3 while converting buffer
2023-02-24 10:50:38,220 Debug info: gstnvinfer.cpp(1418): convert_batch_and_push_to_input_thread (): /GstPipeline:pipeline/GstBin:secondary_gie_bin/GstNvInfer:secondary_gie_1
2023-02-24 10:50:38,233 ----------------------------------
2023-02-24 10:50:38,234 transform_flag:7
2023-02-24 10:50:38,235 transform_flip:0
2023-02-24 10:50:38,235 transform_filter:6
2023-02-24 10:50:38,235 src_rect: 1128:352:86:30
2023-02-24 10:50:38,235 dst_rect: 0:0:94:24
2023-02-24 10:50:38,236 ----------------------------------
2023-02-24 10:50:38,236 Quitting
2023-02-24 10:50:39,248 App run failed
The NvBufSurfTransformParams struct parameters are as follow when this error happened.
