Deepstream-app sample running failure
**• Hardware Platform (Jetson / GPU)**gtx 3090ti
• DeepStream Version6.0.1
• TensorRT Version8.0.1.6
**• NVIDIA GPU Driver Version (valid for GPU only)**510.68.02
• Issue Type( questions, new requirements, bugs) running failure
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) deepstream-app -c ./configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
libEGL warning: DRI3: Screen seems not DRI3 capable
libEGL warning: DRI2: failed to authenticate
0:00:02.571137175 14497 0x5632013a6640 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/home/xxxx/00_Projects/deepstream6.0-demo/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:02.571228686 14497 0x5632013a6640 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /home/xxxxx/00_Projects/deepstream6.0-demo/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
0:00:02.573388530 14497 0x5632013a6640 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/home/xxxxxxx/00_Projects/deepstream6.0-demo/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:194>: Pipeline ready
I guest this issue is libEGL, but I can’t slove it, please help me, thank you!
You can use gdb to check where it got segfault.
you also can use sink fakesink to check if the segfault issue exist.
