#include <cmath>
int main() {
int N = 10;
int b[N];
#pragma omp target teams distribute parallel for map(tofrom:b[0:N])
for (int i = 0; i < N; i++)
b[i] = std::abs(b[i]);
return 0;
But when I switch to long:
#include <cmath>
int main() {
long N = 10;
long b[N];
for (long i = 0; i < N; i++)
return 0;
I got error message:
nvc++ -O3 -mp -target=gpu -I$CUDA_ROOT/include -L$CUDA_ROOT/lib64 -lcudart -o long long.cpp
VC+±S-1062-Support procedure called within a compute region - labs (long.cpp: 56)
NVC++/x86-64 Linux 23.5-0: compilation completed with severe errors
OpenMP crayCC compiler works with the second snippet.
If I switch to “long long” it works too, but I need to work as much as possible with “long” not “long long”:
#include <cmath>
int main() {
long long N = 10;
long long b[N];
for (long long i = 0; i < N; i++)
return 0;
Ok, I work around my issue with a cast to “long long”:
#include <cmath>
int main() {
long N = 10;
long b[N];
b[i] = std::abs((long long)b[i]);
return 0;
Glad you found a work around. I tested the original program and was able to reproduce the error in 23.5, but it appears to have been fixed in 23.7.
% nvc++ -mp=gpu test.cpp -V23.5
NVC++-S-0000-Internal compiler error. Call in OpenACC region to support routine - labs (test.cpp: 56)
NVC++-S-0155-Compiler failed to translate accelerator region (see -Minfo messages) (test.cpp: 56)
% nvc++ -mp=gpu test.cpp -V23.7
Thanks Mat, good to know it has already been fixed. I will try to follow more closely the next releases, cause I have another nvc++ issue with long type used into target regions I should investigate.
