While trying to get some benchmark examples for testing the OMPT interface to run on my system, I encountered a small issue when trying to start a target region from inside a parallel and for region.
Take the following code as an example:
int main(void)
int num_iterations = 100;
#pragma omp parallel
#pragma omp for
for(int i = 0; i < num_iterations; ++i) {
#pragma omp target teams distribute parallel for nowait
for(int j = 0; j < 10; ++j){}
Trying to compile this code with NVHPC 23.3 causes the following error message to appear:
> nvc++ -fopenmp -mp=multicore,gpu -Minfo=all error.cpp
NVC++-F-0000-Internal compiler error. targetinfo symbol not found in uplevel struct 1079 (error.cpp: 8)
NVC++/x86-64 Linux 23.3-0: compilation aborted
Both the nowait clause and the num_iterations variable are important to this issue. Exchanging the variable by a constant value or removing the nowait causes the program to compile perfectly fine.
