my suggestion is to file a bug.
Related topics
| NVCC bug: Incorrect template method definition syntax can pass nvcc compilation | 0 | 466 | October 12, 2023 | |
| Starting with CUDA 12.4, nvcc can't deduce a template type in template function under weird conditions | 5 | 547 | July 19, 2024 | |
| A bug of NVCC compiler | 0 | 506 | March 12, 2022 | |
| NVCC 12.0 lacking support for floating point template parameters with C++20 | 1 | 948 | February 10, 2023 | |
| Possible bug: nvcc and gcc 4.9.3 get into conflict over unnamed type template parameters | 2 | 771 | July 22, 2015 | |
| NVRTC Variadic Template Support | 0 | 376 | April 1, 2020 | |
| Bug: nvcc and gcc 4.9.3 get into conflict over unnamed type template parameters | 1 | 1224 | July 24, 2015 | |
| Struct as template argument problem | 6 | 2409 | June 10, 2009 | |
| Strange behavior of Cuda compiler when using template loops | 1 | 823 | October 9, 2018 | |
| [bug report] default template parameter for class types as non template type parameter does not work | 2 | 126 | April 11, 2025 |
