I have been using CUDA on windows for a while and decided i needed to start porting the code to linux.
In windows I used the --host-compilation=c++ flag to force the compiler to compile my code (which contains C++ strings, exceptions, …) and it worked without problems. If I try to compile my code on linux however, nvcc doesn’t seem to accept --host-compilation, it just keeps compiling it as C code, thus giving me some(allot) errors when using the STL.
I’m wondering about this flag. I run CUDA on openSUSE 11 and it works fine with C++ without any compiler flag.
edit: I assume you did not use gcc/g+±compiler on windows, right? Well, perhaps your code is translatet with g++ ( the linux c++ compiler ) but your code is just incompatible.
I dont have much time to look into this error at the moment (lots of other things to do) but I fixed it for now with a regular const char * instead of a std::string
One thing that might be worth trying is to check you have g++ installed
IIRC I had a problem where some C++ was failing to compile (not finding STL) because I had gcc but not g++ (I think its actually the same compiler but different default include paths)
--host-compilation <language>
Specify C vs. C++ language for host code in CUDA source files. Allowed values for this option: ’C’,’C++’,’c’,’c++’. Default value: ’C++’.
So my first guess would be to just leave the whole –host-compilation option away because C++ is enabled by default.
Sometimes when I want to write pure C code it happens that I mix in C++. In my case the option
--host-compilation;c
works fine to find all the places where I coded C++ accidently.
My nvcc version is this one:
kwk@~:$ nvcc --version
Copyright (c) 2005-2007 NVIDIA Corporation
Built on Thu_Jun_19_04:48:21_PDT_2008
Cuda compilation tools, release 2.0, V0.2.1221
