When I build my solution, I see this error:
1>------ Build started: Project: test_, Configuration: Debug X64 ------
1>Build started 11.2.2011 19:21:07.
1>PrepareForBuild:
1> Creating directory "C:\Users\snurkabill\Documents\Visual Studio 2010\Projects\test_\X64\Debug".
1>InitializeBuildStatus:
1> Creating “X64\Debug\test_.unsuccessfulbuild” because “AlwaysCreate” was specified.
1>CudaRtTarget:
1> Compiling test_.cu with CUDA Build Rule…
1> test_.cu
1>CUDART : Command-line error : invalid option: --stub_header_file_name
1>
1> 1 catastrophic error detected in this compilation.
1> Compilation terminated.
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\BuildCustomizations\CudaRuntimeApi30.targets(41,9): error MSB3721: The command ““C:\CUDA\bin64\nvcc.exe” -arch sm_11 --machine 64 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin” -D_DEBUG -g -Xcompiler “/EHsc /W3 /nologo /Od /Zi /MDd /D__nullptr=((void*)0) /Dnullptr=0 /Dnullptr_t=nullptr_t " -Xcudafe “–c++0x” -IC:\CUDA\include -maxrregcount=32 --compile -o "X64\Debug\test.obj" "C:\Users\snurkabill\Documents\Visual Studio 2010\Projects\test\test_\test_.cu”” exited with code 4.
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:01.02
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
I don’t know what does it mean.
please, can anyone help me?
If you need my SW: win7 64bit, cuda 3.0, VS2010.
