Hello! Does anybody know where to find an information about nvcc output like
“ptxas info : Used 11 registers, 24+20 bytes smem, 52 bytes cmem[0], 4 bytes cmem[1]” ?
It’s clearly that cmem is constant memory, smem - shared, but what is cmem[0] and cmem[1] mean? and maybe there are some other meaningfull indices also?
The question is not about shared/constant/etc. I want to know about the [1]/[14]/…
Documentation says “1-program variables, 14-compiler generated”, but I see another numbers in output: cmem[0] and cmem[1], is it the same as in doc and in the same order? or the banks could be arbitrary? And how about texture, it is also constant?
