First I want to appologize for inappropriate title, it should be
A meaning of nvcc output with option --ptxas-options=-v
I do not know how to change the title, so it is left as it was created (by mistake).
Hallo all,
I compile a program which consists of many separate source files (mostly definitions of objects v member device functions). Because my program was to slow (perheaps too frequent access to global memory), I decided to use nvcc compile option –ptxas-options=-v to find out how memory is distributed among all memory types. But I am unable to interpret the output. The output of the compilation is as follows:
nvcc -Xcompiler -rdynamic -lineinfo -dc -g -G --ptxas-options=-v -arch sm_21 file1.cu
ptxas info : 304 bytes gmem, 40 bytes cmem[14]
ptxas info : Function properties for function1_id
88 bytes stack frame, 68 bytes spill stores, 68 bytes spill loads
ptxas info : Compiling entry function 'Kernel_id' for 'sm_21'
ptxas info : Function properties for Kernel_id
120 bytes stack frame, 0 bytes spill stores, 0 bytes spill loads
ptxas info : Used 55 registers, 48 bytes smem, 120 bytes cmem[0]
… and a lot of other infos similar to previous one from different files, but the info for the kernel occurs only once.
Can someone please clarify to me, what are the meaning of the output infos (ptxas infos)? I want to find out how data are distributed among different types of memories and further optimize their distribution.
Thank you for any hints,
Dalibor
