Compiling attached testcase with
nvcc --ptx test.cu -o test.ptx
crashes nvcc for cases 0, 1 and 5 (see the define) with
Signal: Segmentation fault in Lowering phase.
<input>(0): Error: Signal Segmentation fault in phase Lowering -- processing aborted
*** Internal stack backtrace:
/usr/local/cuda/open64/lib//be [0x69cca2]
/usr/local/cuda/open64/lib//be [0x69d985]
/usr/local/cuda/open64/lib//be [0x69d05f]
/usr/local/cuda/open64/lib//be [0x69e338]
/lib64/libc.so.6 [0x2b4d2a51a5b0]
/usr/local/cuda/open64/lib//be [0x620529]
/usr/local/cuda/open64/lib//be [0x6197ff]
/usr/local/cuda/open64/lib//be [0x6151f1]
/usr/local/cuda/open64/lib//be [0x62422b]
/usr/local/cuda/open64/lib//be [0x61b30c]
/usr/local/cuda/open64/lib//be [0x6298d2]
/usr/local/cuda/open64/lib//be [0x6197ec]
/usr/local/cuda/open64/lib//be [0x625188]
/usr/local/cuda/open64/lib//be [0x6260ef]
/usr/local/cuda/open64/lib//be [0x417fd2]
/usr/local/cuda/open64/lib//be [0x418f31]
/usr/local/cuda/open64/lib//be [0x41a110]
/usr/local/cuda/open64/lib//be [0x41b6b8]
/lib64/libc.so.6(__libc_start_main+0xf4) [0x2b4d2a507ae4]
/usr/local/cuda/open64/lib//be [0x4178ca]
nvopencc INTERNAL ERROR: /usr/local/cuda/open64/lib//be died due to signal 4
nvcc is from CUDA 2.0 beta, nvcc --version is:
Copyright (c) 2005-2007 NVIDIA Corporation
Built on Wed_Apr__9_11:17:27_PDT_2008
Cuda compilation tools, release 1.1, V0.2.1221
System is Core2 Duo E4500, running x86_64 Linux with both gcc 4.2.1 and gcc 4.1.2, 2 GB system RAM and two GeForce 8800 GTX with 768 MB RAM each.
Looks a lot like it is related to spilling registers to local memory…
inittest.txt (391 Bytes)
