Gentlemen,
I am getting a segmentation fault trying to compile code using nvcc version V0.2.1221. The code compiles and runs correctly in emulator mode. By removing sections of my code, I managed to coax an actual error message from nvcc. Here it is.
/usr/local/cuda/bin/nvcc --compiler-options -fno-strict-aliasing -DDEBUG -I. -I/usr/local/cuda/include -I/home/sbernste/NVIDIA_CUDA_SDK/projects/…/common/inc -DUNIX -O3 --compiler-options -W --compiler-options -Wall --compiler-options -Wimplicit --compiler-options -Wswitch --compiler-options -Wformat --compiler-options -Wchar-subscripts --compiler-options -Wparentheses --compiler-options -Wmultichar --compiler-options -Wtrigraphs --compiler-options -Wpointer-arith --compiler-options -Wcast-align --compiler-options -Wreturn-type --compiler-options -Wno-unused-function --compiler-options -fno-strict-aliasing -o obj/release/worker.cu_o -c worker.cu
ptxas /tmp/tmpxft_00005512_00000000-2_worker.ptx, line 145; error : Call has wrong number of parameters
Segmentation fault
make: *** [obj/release/worker.cu_o] Error 255
I’m a newbie at nvidia coding, so I am probably doing something stupid. Any ideas?
– stuck
tmurray
October 20, 2008, 10:58pm
2
can you post code?
also, you are using VS2005 SP1, right?
can you post code?
[snapback]454452[/snapback]
My employer does not permit me to post the code, and it is way too long to post anyway. I am trying to whittle it down and “sanitize” it.
Please forgive my ignorance, but what is V2005 SP1? I am running under ubuntu.
tmurray
October 21, 2008, 12:45am
4
sorry, for some reason I thought you were running on Windows. momentary lapse of reason, I guess.
and yeah, we can’t really do much unless we have a repro case. I’ve never seen that error, so I’m not sure what could be happening.
[snapback]454489[/snapback]
Is there any way I can submit a bug report?
A bug report requires you to provide a means of reproducing the failure. If you can’t post your code publicly, please send me or tmurray a PM with a test app that reproduces the failure.
[snapback]457144[/snapback]
I sent Tim the code last Friday.
