Hi, i’m developing a project with a few files in cuda, one in assembly and the others in C++.
I made my own makefile, that calls g++ (for the .cpp files), nasm (for the .asm file) and nvcc (for the .cu files).
When i use the shell to do the make, it’s all fine. But when eclipse calls make, i get the error:
nvcc: command not found
as if nvcc were not in the path.
it’s extrange because eclipse finds nasm without problems.
I think it can be a eclipse configuration problem.
