Help!
- The orignal error log is “gstnvenc.c:289:gst_nvenc_create_cuda_context: Failed to initialise CUDA, error code: 0x00000064”, when gst-plugin-bad( 1.16.1) calls cuInit(). The calling sequenc is qemu-kvm(v4.2)–> libspice-server.so–>gstreamer–>libgstnvenc.so(all in one host system,centos 7.7). I checked /proc/
pidof qemu-kvm/maps,no /dev/nvidax found.
2.Strangely, encodeing with nvh265enc in gst-launch-1.0 or simple test programes calling libgstnvenc.so (hence cuInit) works much good, this to say, test programes–>gstreamer–>libgstnvenc.so is ok, /dev/nvidia0 can be found in memory maps of the test programes.
I hava checked that all programes, including qemu-kvm, run in user of “root”, and that the libcuda.so, libcudart.so ,libnvidia-encode.so and others are loaded correctly.
The gstreamer and the plugin supports upto CUDA10.1, mine is cuda10.0 and the deviceQuery pass with the following info:
CUDA Device Query (Runtime API) version (CUDART static linking)Detected 4 CUDA Capable device(s) Device 0: "Tesla V100-PCIE-32GB" CUDA Driver Version / Runtime Version 11.0 / 10.0 CUDA Capability Major/Minor version number: 7.0 Total amount of global memory: 32510 MBytes (34089730048 bytes) (80) Multiprocessors, ( 64) CUDA Cores/MP: 5120 CUDA Cores GPU Max Clock rate: 1380 MHz (1.38 GHz) Memory Clock rate: 877 Mhz Memory Bus Width: 4096-bit L2 Cache Size: 6291456 bytes Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384) Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers Total amount of constant memory: 65536 bytes Total amount of shared memory per block: 49152 bytes Total number of registers available per block: 65536 Warp size: 32 Maximum number of threads per multiprocessor: 2048 Maximum number of threads per block: 1024 Max dimension size of a thread block (x,y,z): (1024, 1024, 64) Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535) Maximum memory pitch: 2147483647 bytes Texture alignment: 512 bytes Concurrent copy and kernel execution: Yes with 7 copy engine(s) Run time limit on kernels: No Integrated GPU sharing Host Memory: No Support host page-locked memory mapping: Yes Alignment requirement for Surfaces: Yes Device has ECC support: Enabled Device supports Unified Addressing (UVA): Yes Device supports Compute Preemption: Yes Supports Cooperative Kernel Launch: Yes Supports MultiDevice Co-op Kernel Launch: Yes Device PCI Domain ID / Bus ID / location ID: 0 / 24 / 0 Compute Mode: < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) > ... Compute Mode: < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) > > Peer access from Tesla V100-PCIE-32GB (GPU0) -> Tesla V100-PCIE-32GB (GPU1) : Yes > Peer access from Tesla V100-PCIE-32GB (GPU0) -> Tesla V100-PCIE-32GB (GPU2) : Yes > Peer access from Tesla V100-PCIE-32GB (GPU0) -> Tesla V100-PCIE-32GB (GPU3) : Yes > Peer access from Tesla V100-PCIE-32GB (GPU1) -> Tesla V100-PCIE-32GB (GPU0) : Yes > Peer access from Tesla V100-PCIE-32GB (GPU1) -> Tesla V100-PCIE-32GB (GPU2) : Yes > Peer access from Tesla V100-PCIE-32GB (GPU1) -> Tesla V100-PCIE-32GB (GPU3) : Yes > Peer access from Tesla V100-PCIE-32GB (GPU2) -> Tesla V100-PCIE-32GB (GPU0) : Yes > Peer access from Tesla V100-PCIE-32GB (GPU2) -> Tesla V100-PCIE-32GB (GPU1) : Yes > Peer access from Tesla V100-PCIE-32GB (GPU2) -> Tesla V100-PCIE-32GB (GPU3) : Yes > Peer access from Tesla V100-PCIE-32GB (GPU3) -> Tesla V100-PCIE-32GB (GPU0) : Yes > Peer access from Tesla V100-PCIE-32GB (GPU3) -> Tesla V100-PCIE-32GB (GPU1) : Yes > Peer access from Tesla V100-PCIE-32GB (GPU3) -> Tesla V100-PCIE-32GB (GPU2) : Yes
nvidia-smi runs well and 4 GPUS is shown:
| NVIDIA-SMI 450.51.05 Driver Version: 450.51.05 CUDA Version: 11.0 |
| | | MIG M. |
| 0 Tesla V100-PCIE… Off | 00000000:18:00.0 Off | 0 |
| N/A 31C P0 23W / 250W | 0MiB / 32510MiB | 0% Default |
| | | N/A |
| 1 Tesla V100-PCIE… Off | 00000000:3B:00.0 Off | 0 |
| N/A 33C P0 26W / 250W | 0MiB / 32510MiB | 0% Default |
| | | N/A |
| 2 Tesla V100-PCIE… Off | 00000000:86:00.0 Off | 0 |
| N/A 31C P0 24W / 250W | 0MiB / 32510MiB | 0% Default |
| | | N/A |
| 3 Tesla V100-PCIE… Off | 00000000:AF:00.0 Off | 0 |
| N/A 32C P0 23W / 250W | 0MiB / 32510MiB | 0% Default |
| | | N/A |
The strange error is killing me >_<
