your VI tracing messages also not including VI drivers initialization function calls. you should saw messages with rtcpu_vinotify_handle_msg workers.
could you please co-working with your hardware engineer to probe the MIPI signaling, you should also checking the regulator settings. thanks
How long does it take for your sensor to start sending data? If it takes more than 1500 ms from when s_stream is called to when the data arrives you’ll see a failure. I can’t recall if that manifests as PXL_SOF syncpt timeout error but I would assume that it would.
Hi nicolas.norena:
After checking the pdf which you added in the comment #22, It said that MIPI CSI data signal should be 1.2V,0.3V,0.1V,or 0V, but our deteted wave is 0.8V, what about yours? Do we need to review the Hardware design again with the HW engineers?
I can’t find the ov5693.c in the 32.2 source files. The development guide says that the reference is imx185_1.c, and I can’t find it too…
The adv7180.c driver in the sources is not ready to be used in TX2?
