TX2 CSI PXL_SOF syncpt timeout
hi everyone,
i’m porting adv7281ma on tx2 with JetPack_4.2_Linux_P3310. Now i have a issue:
adv7281ma is output Color Bars 576p to tx2,but csi can’t capture the stream.
dmesg log:
[ 99.231112] adv7180 2-0020: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 99.231148] adv7180 2-0020: camera_common_dpd_disable: csi 0
[ 99.231151] adv7180 2-0020: adv7180_power_on: power on
[ 99.235076] tegra-ivc-vi-notify ivc-b000000.rtcpu:vinotify@12c0: vi_notify_channel_enable_reports: ch:0
[ 99.236846] adv7180 2-0020: v4l2sd_stream++ enable 1
[ 99.236851] adv7180 2-0020: adv7180_set_mode: power on
[ 99.236856] adv7180 2-0020: adv7180_start_streaming: power on
[ 99.439220] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 99.445618] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 99.455361] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x00000002
[ 99.464104] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000002
[ 99.472039] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000002
[ 99.480530] tegra-ivc-vi-notify ivc-b000000.rtcpu:vinotify@12c0: vi_notify_channel_enable_reports: ch:0
[ 99.683236] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 99.689610] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 99.699367] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x00000002
[ 99.708100] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000002
[ 99.715956] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000002
my dts config:
compatible = "adi,adv7281-ma";
			reg = <0x20>;
			devnode = "video0";
			physical_w = "3.674";
			physical_h = "2.738";
			avdd-reg = "vana";
			iovdd-reg = "vif";
			vertical-flip = "true";
			clocks = <0x10 0x59 0x10 0x10d>;
			clock-names = "extperiph1", "pllp_grtba";
			mclk = "extperiph1";
			clock-frequency = <0x16e3600>;
			reset-gpios = <0x1b 0x8d 0x0>;
			pwdn-gpios = <0x1b 0x88 0x0>;
			vana-supply = <0x2b>;
			vif-supply = <0x2c>;
			status = "okay";
			linux,phandle = <0x118>;
			phandle = <0x118>;
			mode0 {
				mclk_khz = "24000";
				num_lanes = [31 00];
				tegra_sinterface = "serial_a";//serial_c
				phy_mode = "DPHY";
				discontinuous_clk = "no";//"yes";
				dpcm_enable = "false";
				cil_settletime = "120";//[30 00];
				active_w = "720";//"2592";
				active_h = "576";//"1944";
				mode_type = "yuv";//"bayer";
				pixel_phase = "uyvy";//"rggb";//"bggr";
				csi_pixel_bit_depth = "16";//"10";
				readout_orientation = "90";
				line_length = "720";//"2688";
				inherent_gain = [31 00];
				mclk_multiplier = "6.67";
				pix_clk_hz = "160000000";
				gain_factor = "10";
				min_gain_val = "10";
				max_gain_val = "160";
				step_gain_val = [31 00];
				default_gain = "10";
				min_hdr_ratio = [31 00];
				max_hdr_ratio = [31 00];
				framerate_factor = "1000000";
				min_framerate = "1816577";
				max_framerate = "30000000";
				step_framerate = [31 00];
				default_framerate = "30000000";
				exposure_factor = "1000000";
				min_exp_time = "34";
				max_exp_time = "550385";
				step_exp_time = [31 00];
				default_exp_time = "33334";
				embedded_metadata_height = [31 00];//30
			ports {
				#address-cells = <0x1>;
				#size-cells = <0x0>;
				status = "okay";
				port@0 {
					reg = <0x0>;
					status = "okay";
					endpoint {
						status = "okay";
						port-index = <0x0>;
						bus-width = <0x1>;
						remote-endpoint = <0x2d>;
						linux,phandle = <0x5d>;
						phandle = <0x5d>;
vi@15700000 {
			compatible = "nvidia,tegra186-vi";
			power-domains = <0x1f 0xb>;
			reg = <0x0 0x15700000 0x0 0x100000>;
			interrupts = <0x0 0xc9 0x4 0x0 0xca 0x4 0x0 0xcb 0x4>;
			resets = <0x10 0x33 0x10 0x8f>;
			reset-names = "vi", "tsctnvi";
			clocks = <0x10 0x33 0x10 0xb4 0x10 0xb5>;
			clock-names = "vi", "nvcsi", "nvcsilp";
			iommus = <0x11 0x4>;
			iommu-group-id = <0x1>;
			status = "okay";
			avdd_dsi_csi-supply = <0x30>;
			num-channels = <0x1>;
			linux,phandle = <0x4e>;
			phandle = <0x4e>;
			ports {
				status = "okay";
				port@0 {
					reg = <0x0>;
					status = "okay";
					linux,phandle = <0x19a>;
					phandle = <0x19a>;
					endpoint {
						port-index = <0x0>;
						bus-width = <0x1>;
						remote-endpoint = <0x5f>;
						vc-id = <0x0>;//0x0
						status = "okay";
						linux,phandle = <0x5e>;
						phandle = <0x5e>;
				port@1 {
					reg = <0x1>;
					status = "disabled";
					linux,phandle = <0x19b>;
					phandle = <0x19b>;
					endpoint {
						port-index = <0x0>;
						bus-width = <0x2>;
						vc-id = <0x1>;
						linux,phandle = <0x19c>;
						phandle = <0x19c>;
				port@2 {
					reg = <0x2>;
					linux,phandle = <0x19d>;
					phandle = <0x19d>;
					endpoint {
						port-index = <0x2>;
						bus-width = <0x2>;
						vc-id = <0x0>;
						linux,phandle = <0x19e>;
						phandle = <0x19e>;
nvcsi@150c0000 {
			compatible = "nvidia,tegra186-nvcsi";
			reg = <0x0 0x150c0000 0x0 0x40000>;
			resets = <0x10 0x58>;
			clocks = <0x10 0xb4 0x10 0xb5 0x10 0x20e 0x10 0x10d>;
			clock-names = "nvcsi", "nvcsilp", "nvcsi_parent", "nvcsilp_parent";
			interrupts = <0x0 0x77 0x4>;
			iommus = <0x11 0x2>;
			status = "okay";
			num-ports = <0x6>;
			nvidia,csi_regulator = "avdd_dsi_csi";
			linux,phandle = <0x17d>;
			phandle = <0x17d>;
			channel@0 {
				reg = <0x0>;
				status = "okay";
				linux,phandle = <0x17e>;
				phandle = <0x17e>;
				ports {
					status = "okay";
					port@0 {
						reg = <0x0>;
						status = "okay";
						linux,phandle = <0x17f>;
						phandle = <0x17f>;
						endpoint@0 {
							port-index = <0x0>;
							bus-width = <0x1>;
							remote-endpoint = <0x5d>;
							status = "okay";
							linux,phandle = <0x2d>;
							phandle = <0x2d>;
					port@1 {
						reg = <0x1>;
						status = "okay";
						linux,phandle = <0x180>;
						phandle = <0x180>;
						endpoint@1 {
							remote-endpoint = <0x5e>;
							status = "okay";
							linux,phandle = <0x5f>;
							phandle = <0x5f>;
			channel@1 {
				reg = <0x1>;
				linux,phandle = <0x181>;
				phandle = <0x181>;
				ports {
					port@0 {
						reg = <0x0>;
						linux,phandle = <0x182>;
						phandle = <0x182>;
						endpoint@2 {
							port-index = <0x0>;
							bus-width = <0x2>;
							linux,phandle = <0x183>;
							phandle = <0x183>;
					port@1 {
						reg = <0x1>;
						linux,phandle = <0x184>;
						phandle = <0x184>;
						endpoint@3 {
							linux,phandle = <0x185>;
							phandle = <0x185>;
tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		num_csi_lanes = <0x1>;
		max_lane_speed = <0x16e360>;
		min_bits_per_pixel = <0xa>;
		vi_peak_byte_per_pixel = <0x2>;
		vi_bw_margin_pct = <0x19>;
		max_pixel_rate = <0x27100>;
		isp_peak_byte_per_pixel = <0x5>;
		isp_bw_margin_pct = <0x19>;
		tpg_max_iso = <0x3bc400>;
		linux,phandle = <0x1c9>;
		phandle = <0x1c9>;
		modules {
			module0 {
				badge = "e3326_front_P5V27C";
				position = "rear";
				orientation = [31 00];
				status = "okay";
				linux,phandle = <0x1ca>;
				phandle = <0x1ca>;
				drivernode0 {
					pcl_id = "v4l2_sensor";
					devname = "ov5693 2-0020";
					proc-device-tree = "/proc/device-tree/i2c@3180000/ov5693_c@20";
					status = "okay";
					linux,phandle = <0x1cb>;
					phandle = <0x1cb>;
				drivernode1 {
					pcl_id = "v4l2_lens";
					proc-device-tree = "/proc/device-tree/e3326_lens_ov5693@P5V27C/";
					linux,phandle = <0x1cc>;
					phandle = <0x1cc>;
my hw sch:
CSI0_CLK(G28),CSI0_CLK(G27),CSI0_D0(F29),CSI0_D0(F28)
Can anyone help me to check my settings?
tek@tek-desktop:~$ v4l2-compliance -d /dev/video0
v4l2-compliance SHA   : not available
Driver Info:
        Driver name   : tegra-video
        Card type     : vi-output, adv7180 2-0020
        Bus info      : platform:15700000.vi:0
        Driver version: 4.9.140
        Capabilities  : 0x84200001
                Video Capture
                Streaming
                Extended Pix Format
                Device Capabilities
        Device Caps   : 0x04200001
                Video Capture
                Streaming
                Extended Pix Format
Compliance test for device /dev/video0 (not using libv4l2):
Required ioctls:
        test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
        test second video open: OK
        test VIDIOC_G/S_PRIORITY: OK
        test for unlimited opens: OK
Debug ioctls:
        test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
        test VIDIOC_LOG_STATUS: OK
Input ioctls:
        test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
        test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
        test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
        test VIDIOC_ENUMAUDIO: OK (Not Supported)
        test VIDIOC_G/S/ENUMINPUT: OK
        test VIDIOC_G/S_AUDIO: OK (Not Supported)
        Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
        test VIDIOC_G/S_MODULATOR: OK (Not Supported)
        test VIDIOC_ENUMAUDOUT: OK (Not Supported)
        test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
        test VIDIOC_G/S_AUDOUT: OK (Not Supported)
        Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
        test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
        test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
        test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
        test VIDIOC_G/S_EDID: OK (Not Supported)
Test input 0:
        Control ioctls:
                test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
                test VIDIOC_QUERYCTRL: OK
                test VIDIOC_G/S_CTRL: OK
                test VIDIOC_G/S/TRY_EXT_CTRLS: OK
                test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
                test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
                Standard Controls: 1 Private Controls: 20
        Format ioctls:
                test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
                test VIDIOC_G/S_PARM: OK (Not Supported)
                test VIDIOC_G_FBUF: OK (Not Supported)
                test VIDIOC_G_FMT: OK
                test VIDIOC_TRY_FMT: OK
                warn: v4l2-test-formats.cpp(997): S_FMT cannot handle an invalid pixelformat.
                warn: v4l2-test-formats.cpp(998): This may or may not be a problem. For more information see:
                warn: v4l2-test-formats.cpp(999): http://www.mail-archive.com/linux-media@vger.kernel.org/msg56550.html
                fail: v4l2-test-formats.cpp(1013): S_FMT cannot handle an invalid format
                test VIDIOC_S_FMT: FAIL
                test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
                test Cropping: OK (Not Supported)
                test Composing: OK (Not Supported)
                fail: v4l2-test-formats.cpp(1550): doioctl(node, VIDIOC_S_FMT, &fmt)
                fail: v4l2-test-formats.cpp(1647): doioctl(node, VIDIOC_S_FMT, &fmt)
                test Scaling: FAIL
        Codec ioctls:
                test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
                test VIDIOC_G_ENC_INDEX: OK (Not Supported)
                test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
        Buffer ioctls:
                test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
                test VIDIOC_EXPBUF: OK
Test input 0:
tek@tek-desktop:~$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
        Index       : 0
        Type        : Video Capture
        Pixel Format: 'UYVY'
tek@tek-desktop:~$ media-ctl -p -d /dev/media0
Media controller API version 0.1.0
Media device information
driver          tegra-vi4
model           NVIDIA Tegra Video Input Device
serial
bus info
hw revision     0x3
driver version  0.0.0
Device topology
- entity 1: 150c0000.nvcsi--1 (2 pads, 2 links)
            type V4L2 subdev subtype Unknown flags 0
            device node name /dev/v4l-subdev0
        pad0: Sink
                <- "adv7180 2-0020":0 [ENABLED]
        pad1: Source
                -> "vi-output, adv7180 2-0020":0 [ENABLED]
- entity 4: adv7180 2-0020 (1 pad, 1 link)
            type V4L2 subdev subtype Sensor flags 0
            device node name /dev/v4l-subdev1
        pad0: Source
                [fmt:UYVY8_2X8/640x480 field:none colorspace:srgb]
                -> "150c0000.nvcsi--1":0 [ENABLED]
- entity 6: vi-output, adv7180 2-0020 (1 pad, 1 link)
            type Node subtype V4L flags 0
            device node name /dev/video0
        pad0: Sink
                <- "150c0000.nvcsi--1":1 [ENABLED]
From the REG NVCSI_STREAM_1_ERROR_STATUS2VI_VC0_0 show the “PH ECC single bit error” try below to disable the ECC to check.
diff --git a/drivers/media/platform/tegra/camera/csi/csi4_fops.c b/drivers/media/platform/tegra/camera/csi/csi4_fops.c
index 0377d7b..b3d01d3 100644
--- a/drivers/media/platform/tegra/camera/csi/csi4_fops.c
+++ b/drivers/media/platform/tegra/camera/csi/csi4_fops.c
@@ -76,8 +76,18 @@ static void csi4_stream_init(struct tegra_csi_channel *chan, int port_num)
        csi4_stream_write(chan, port_num, INTR_STATUS, 0x3ffff);
        csi4_stream_write(chan, port_num, ERR_INTR_STATUS, 0x7ffff);
        csi4_stream_write(chan, port_num, ERROR_STATUS2VI_MASK, 0x0);
-       csi4_stream_write(chan, port_num, INTR_MASK, 0x0);
-       csi4_stream_write(chan, port_num, ERR_INTR_MASK, 0x0);
+       csi4_stream_write(chan, port_num, INTR_MASK, PH_ECC_MULTI_BIT_ERR |
+                       PD_CRC_ERR_VC0 | PH_ECC_SINGLE_BIT_ERR_VC0);
+       csi4_stream_write(chan, port_num, ERR_INTR_MASK, PH_ECC_MULTI_BIT_ERR |
+       csi4_stream_write(chan, port_num, ERROR_STATUS2VI_MASK,
+                       CFG_ERR_STATUS2VI_MASK_VC0 |
+                       CFG_ERR_STATUS2VI_MASK_VC1 |
+                       CFG_ERR_STATUS2VI_MASK_VC2 |
+                       CFG_ERR_STATUS2VI_MASK_VC3);
when applyed this patch,csi can’t capture stream yet.
dmesg:
[  120.185654] adv7180 2-0020: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[  120.185691] adv7180 2-0020: camera_common_dpd_disable: csi 0
[  120.185696] adv7180 2-0020: adv7180_power_on: power on
[  120.186940] nvcsi 150c0000.nvcsi: settle time reading from props
[  120.186949] nvcsi 150c0000.nvcsi: csi_port: 0
[  120.190043] tegra-ivc-vi-notify ivc-b000000.rtcpu:vinotify@12c0: vi_notify_channel_enable_reports: ch:0
[  120.191860] nvcsi 150c0000.nvcsi: csi4_start_streaming port_idx=0, lanes=1
[  120.191864] nvcsi 150c0000.nvcsi: csi4_stream_init csi_port = 0
[  120.191876] nvcsi 150c0000.nvcsi: csi4_stream_config
[  120.191886] nvcsi 150c0000.nvcsi: csi4_stream_config (0) read VC0_DPCM_CTRL = 00000000
[  120.191889] nvcsi 150c0000.nvcsi: settle time reading from props
[  120.191893] nvcsi 150c0000.nvcsi: settle time reading from props
[  120.191895] nvcsi 150c0000.nvcsi: csi4_phy_config
[  120.191901] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000000
[  120.191909] nvcsi 150c0000.nvcsi: cil core clock: 204, csi clock: 89
[  120.191912] nvcsi 150c0000.nvcsi: csi settle time: 33, cil settle time: 20
[  120.191922] adv7180 2-0020: v4l2sd_stream++ enable 1
[  120.191927] adv7180 2-0020: adv7180_set_mode: power on
[  120.191932] adv7180 2-0020: adv7180_start_streaming
[  120.393301] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[  120.399786] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[  120.409737] nvcsi 150c0000.nvcsi: csi4_stop_streaming port_idx=0, lanes=1
[  120.409756] nvcsi 150c0000.nvcsi: settle time reading from props
[  120.409760] nvcsi 150c0000.nvcsi: settle time reading from props
[  120.409767] nvcsi 150c0000.nvcsi: csi4_phy_config
[  120.409775] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000001
[  120.409782] nvcsi 150c0000.nvcsi: csi4_stream_check_status
[  120.409796] nvcsi 150c0000.nvcsi: csi4_cil_check_status 406
[  120.409804] nvcsi 150c0000.nvcsi: csi4_start_streaming port_idx=0, lanes=1
[  120.409808] nvcsi 150c0000.nvcsi: csi4_stream_init csi_port = 0
[  120.409821] nvcsi 150c0000.nvcsi: csi4_stream_config
[  120.409830] nvcsi 150c0000.nvcsi: csi4_stream_config (0) read VC0_DPCM_CTRL = 00000000
[  120.409833] nvcsi 150c0000.nvcsi: settle time reading from props
[  120.409836] nvcsi 150c0000.nvcsi: settle time reading from props
[  120.409839] nvcsi 150c0000.nvcsi: csi4_phy_config
[  120.409871] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000000
[  120.409880] nvcsi 150c0000.nvcsi: cil core clock: 204, csi clock: 89
[  120.409885] nvcsi 150c0000.nvcsi: csi settle time: 33, cil settle time: 20
[  120.410173] tegra-ivc-vi-notify ivc-b000000.rtcpu:vinotify@12c0: vi_notify_channel_enable_reports: ch:0
[  120.612956] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[  120.619426] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
Have enable the trace log to check if can get more information.
https://elinux.org/Jetson_TX2_Camera_BringUp
[code]
root@tek-desktop:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (tek@tek) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #124 SMP PREEMPT Wed Dec 25 18:42:15 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2055168
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523776 pages, LIFO batch:31
[ 0.000000] Normal zone: 24008 pages used for memmap
[ 0.000000] Normal zone: 1531392 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc1f7023000 s53400 r8192 d32616 u94208
[ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2022968
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.983055.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29420(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7975428K/8220672K available (15166K kernel code, 2916K rwdata, 6556K rodata, 8576K init, 607K bss, 179708K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095c0000 ( 6592 KB)
[ 0.000000] .init : 0xffffff80095c0000 - 0xffffff8009e20000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f9008 ( 2917 KB)
[ 0.000000] .bss : 0xffffff800a0f9008 - 0xffffff800a190e3c ( 608 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009499] Console: colour dummy device 80x25
[ 0.014159] console [tty0] enabled
[ 0.017715] bootconsole [uart8250] disabled
[ 0.022088] kmemleak: Kernel memory leak detector disabled
[ 0.022105] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022119] pid_max: default: 32768 minimum: 301
[ 0.022437] Security Framework initialized
[ 0.022598] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022609] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.023228] ftrace: allocating 46820 entries in 183 pages
[ 0.147441] sched-energy: Sched-energy-costs installed from DT
[ 0.147461] ASID allocator initialised with 65536 entries
[ 0.181859] tegra-id: chipid=21817.
[ 0.181874] tegra-id: opt_subrevision=1.
[ 0.181895] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.181909] DTS File Name: …/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.181924] DTB Build time: Dec 12 2019 18:39:48
[ 0.229849] CPU1: Booted secondary processor [4e0f0030]
[ 0.261505] CPU2: Booted secondary processor [4e0f0030]
[ 0.293349] CPU3: Booted secondary processor [411fd073]
[ 0.325345] CPU4: Booted secondary processor [411fd073]
[ 0.357342] CPU5: Booted secondary processor [411fd073]
[ 0.357395] Brought up 6 CPUs
[ 0.357435] SMP: Total of 6 processors activated.
[ 0.357447] CPU features: detected feature: 32-bit EL0 Support
[ 0.358215] CPU: All CPU(s) started at EL2
[ 0.358270] alternatives: patching kernel code
[ 0.367611] devtmpfs: initialized
[ 0.393762] Initilizing CustomIPI irq domain
[ 0.393951] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.393976] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.394844] pinctrl core: initialized pinctrl subsystem
[ 0.395049] OS set in device tree is not L4T.
[ 0.395191] regulator-dummy: no parameters
[ 0.395322] Initializing plugin-manager
[ 0.395376] Plugin module not found
[ 0.395420] Plugin-manager status disabled
[ 0.396672] NET: Registered protocol family 16
[ 0.397379] pstore: using zlib compression
[ 0.397826] console [pstore-1] enabled
[ 0.397890] pstore: Registered ramoops as persistent store backend
[ 0.397960] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.417585] cpuidle: using governor menu
[ 0.419969] bpmp: waiting for handshake
[ 0.420003] bpmp: handshake completed
[ 0.420045] bpmp: synchronizing channels
[ 0.420097] bpmp: channels synchronized
[ 0.420126] bpmp: mail init ok
[ 0.423910] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.423956] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.423989] arm-smmu 12000000.iommu: stage 1 translation
[ 0.424023] arm-smmu 12000000.iommu: stage 2 translation
[ 0.424055] arm-smmu 12000000.iommu: nested translation
[ 0.424113] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.424164] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.424216] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.424253] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.424290] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.428979] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.429078] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.431794] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.433381] Registering BPMP clocks…
[ 0.433572] tegra_bpmp_clk_init: clock init ok (636 clks)
[ 0.434211] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.436247] tegra_powergate_init: DONE
[ 0.436318] DTS File Name: …/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.436384] DTB Build time: Dec 12 2019 18:39:48
[ 0.439444] Tegra reboot handler registered.
[ 0.441616] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.441755] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.441803] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.441836] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.441867] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.442177] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.442233] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.442756] iommu: Adding device 3460000.sdhci to group 0
[ 0.442953] __mc_override_sid(): override sid=23 oid=26 ord=1 at offset=318
[ 0.442960] __mc_override_sid(): override sid=23 oid=30 ord=1 at offset=338
[ 0.443733] iommu: Adding device 3400000.sdhci to group 1
[ 0.443928] __mc_override_sid(): override sid=26 oid=23 ord=1 at offset=300
[ 0.443934] __mc_override_sid(): override sid=26 oid=27 ord=1 at offset=320
[ 0.445766] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.445820] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.445988] __mc_override_sid(): override sid=29 oid=5 ord=1 at offset=f8
[ 0.445995] __mc_override_sid(): override sid=29 oid=11 ord=1 at offset=1e8
[ 0.446426] iommu: Adding device 3160000.i2c to group 3
[ 0.447023] iommu: Adding device c240000.i2c to group 4
[ 0.447511] iommu: Adding device 3180000.i2c to group 5
[ 0.448001] iommu: Adding device 3190000.i2c to group 6
[ 0.448651] iommu: Adding device 31b0000.i2c to group 7
[ 0.449164] iommu: Adding device 31c0000.i2c to group 8
[ 0.449670] iommu: Adding device c250000.i2c to group 9
[ 0.450146] iommu: Adding device 31e0000.i2c to group 10
[ 0.452613] iommu: Adding device 3210000.spi to group 11
[ 0.453108] iommu: Adding device c260000.spi to group 12
[ 0.453596] iommu: Adding device 3240000.spi to group 13
[ 0.454625] iommu: Adding device 3100000.serial to group 14
[ 0.455100] iommu: Adding device 3110000.serial to group 15
[ 0.455557] iommu: Adding device c280000.serial to group 16
[ 0.456017] iommu: Adding device 3130000.serial to group 17
[ 0.457834] iommu: Adding device 2490000.ether_qos to group 18
[ 0.457890] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.458075] __mc_override_sid(): override sid=20 oid=50 ord=1 at offset=470
[ 0.458083] __mc_override_sid(): override sid=20 oid=51 ord=1 at offset=478
[ 0.458790] iommu: Adding device b000000.rtcpu to group 19
[ 0.461343] iommu: Adding device 13e10000.host1x to group 20
[ 0.461860] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.462315] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.462783] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.463219] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.463714] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.464159] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.464574] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.465025] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.465670] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.466540] iommu: Adding device 15700000.vi to group 30
[ 0.466628] __mc_override_sid(): override sid=4 oid=33 ord=1 at offset=390
[ 0.467071] iommu: Adding device 15600000.isp to group 31
[ 0.467149] __mc_override_sid(): override sid=5 oid=12 ord=1 at offset=220
[ 0.467163] __mc_override_sid(): override sid=5 oid=13 ord=1 at offset=230
[ 0.467176] __mc_override_sid(): override sid=5 oid=14 ord=1 at offset=238
[ 0.467751] iommu: Adding device 15210000.nvdisplay to group 32
[ 0.468081] __mc_override_sid(): override sid=9 oid=54 ord=1 at offset=490
[ 0.468096] __mc_override_sid(): override sid=9 oid=69 ord=1 at offset=508
[ 0.468506] iommu: Adding device 15340000.vic to group 33
[ 0.468881] iommu: Adding device 154c0000.nvenc to group 34
[ 0.469242] iommu: Adding device 15480000.nvdec to group 35
[ 0.469761] iommu: Adding device 15380000.nvjpg to group 36
[ 0.470609] iommu: Adding device 15500000.tsec to group 37
[ 0.470947] iommu: Adding device 15100000.tsecb to group 38
[ 0.471906] iommu: Adding device 15810000.se to group 39
[ 0.472255] iommu: Adding device 15820000.se to group 40
[ 0.472616] iommu: Adding device 15830000.se to group 41
[ 0.472952] iommu: Adding device 15840000.se to group 42
[ 0.474203] iommu: Adding device smmu_test to group 43
[ 0.475087] mc: mapped MMIO address: 0xffffff800a680000 → 0x2c10000
[ 0.475148] mc: mapped MMIO address: 0xffffff800a6a0000 → 0x2c20000
[ 0.475201] mc: mapped MMIO address: 0xffffff800a6c0000 → 0x2c30000
[ 0.475253] mc: mapped MMIO address: 0xffffff800a6e0000 → 0x2c40000
[ 0.475328] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c50000
[ 0.475382] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.475427] mc-err: mcerr ops are set to t18x
[ 0.475709] mc-err: Set intmask: 0xf3140
[ 0.475729] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.477262] iommu: Adding device 3530000.xhci to group 44
[ 0.477325] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.477500] __mc_override_sid(): override sid=27 oid=15 ord=1 at offset=250
[ 0.477516] __mc_override_sid(): override sid=27 oid=16 ord=1 at offset=258
[ 0.478493] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.478537] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.479819] iommu: Adding device 17000000.gp10b to group 45
[ 0.481153] tegra-reset 5000000.clock: registered 193 resets.
[ 0.483993] iommu: Adding device d000000.bpmp to group 46
[ 0.484391] bpmp: ping status is 0
[ 0.484560] bpmp d000000.bpmp: firmware tag is 69fa4e41a01fc02a4db1adf71922a54c
[ 0.487976] bpmp d000000.bpmp: probe ok
[ 0.491716] iommu: Adding device 2600000.dma to group 47
[ 0.493275] GPIO line 459 (pcie0_lane2_mux) hogged as output/low
[ 0.493365] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.493422] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.493496] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.493876] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.499430] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.499753] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.502050] iommu: Adding device 10003000.pcie-controller to group 48
[ 0.502113] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.502276] __mc_override_sid(): override sid=17 oid=1 ord=1 at offset=70
[ 0.502284] __mc_override_sid(): override sid=17 oid=8 ord=1 at offset=188
[ 0.502554] iommu: Adding device sound to group 49
[ 0.503055] iommu: Adding device 3510000.hda to group 50
[ 0.503250] __mc_override_sid(): override sid=18 oid=2 ord=1 at offset=a8
[ 0.503257] __mc_override_sid(): override sid=18 oid=9 ord=1 at offset=1a8
[ 0.514012] iommu: Adding device c1a0000.aon to group 51
[ 0.514624] vdd-ac-bat: 5000 mV
[ 0.517521] random: fast init done
[ 0.517662] vdd-1v8-ap: 1800 mV
[ 0.546428] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.552371] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.552862] SCSI subsystem initialized
[ 0.553076] libata version 3.00 loaded.
[ 0.553281] usbcore: registered new interface driver usbfs
[ 0.553356] usbcore: registered new interface driver hub
[ 0.553480] usbcore: registered new device driver usb
[ 0.557100] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 0.558232] gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
[ 0.559386] gpiochip_setup_dev: registered GPIOs 208 to 223 on device: gpiochip4 (tca9539)
[ 0.570997] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.578042] vddio-ddr: at 1125 mV
[ 0.581877] avdd_dsi_csi: 1200 mV
[ 0.585874] vdd-1v8: 1800 mV
[ 0.589882] vdd-3v3-sys: 3300 mV
[ 0.591288] spmic-ldo0: at 1800 mV
[ 0.592135] spmic-ldo1: at 800 mV
[ 0.597889] vddio-3v3: 3300 mV
[ 0.598637] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.601895] vdd-rtc: at 800 mV
[ 0.602855] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.605947] spmic-ldo6: at 1500 mV
[ 0.609882] vdd-pex-1v00: 1000 mV
[ 0.610666] dvdd-pex: 1000 mV
[ 0.611501] GPIO line 205 (spmic_gpio_input) hogged as input
[ 0.611725] GPIO line 206 (spmic_gpio_input) hogged as input
[ 0.612117] gpiochip_setup_dev: registered GPIOs 200 to 207 on device: gpiochip5 (max77620-gpio)
[ 0.614545] max77620 4-003c: max77620 probe successful
[ 0.615084] media: Linux media interface: v0.10
[ 0.615154] Linux video capture interface: v2.00
[ 0.619649] pps_core: LinuxPPS API ver. 1 registered
[ 0.619687] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.619795] PTP clock support registered
[ 0.620466] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.620524] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.623185] tegra_fiq_debugger_init: found FIQ source (IRQ 385)
[ 0.627502] Advanced Linux Sound Architecture Driver Initialized.
[ 0.627991] Bluetooth: Core ver 2.22
[ 0.628051] NET: Registered protocol family 31
[ 0.628077] Bluetooth: HCI device and connection manager initialized
[ 0.628111] Bluetooth: HCI socket layer initialized
[ 0.628139] Bluetooth: L2CAP socket layer initialized
[ 0.628194] Bluetooth: SCO socket layer initialized
[ 0.629248] en-vdd-sd: 3300 mV
[ 0.629921] en-vdd-cam: 1800 mV
[ 0.633910] vdd-hdmi: 3300 mV
[ 0.634473] vdd-usb0-5v: 5000 mV
[ 0.634914] vdd-usb1-5v: 5000 mV
[ 0.637893] en-vdd-ts-1v8: 1800 mV
[ 0.641903] en-vdd-ts-hv-3v3: 3300 mV
[ 0.642198] en-vdd-disp-3v3: 3300 mV
[ 0.642752] en-mdm-pwr-3v7: 3700 mV
[ 0.643325] en-vdd-cam-hv-2v8: 2800 mV
[ 0.643911] en-vdd-cam-1v2: 1200 mV
[ 0.644648] vdd-fan: 5000 mV
[ 0.644952] vdd-3v3: 3300 mV
[ 0.645222] en-vdd-vcm-2v8: 2800 mV
[ 0.645562] vdd-usb2-5v: 5000 mV
[ 0.645892] vdd-sys-bl: 3300 mV
[ 0.646638] usb-hub-en1: 3300 mV
[ 0.647340] en-vdd-sys: 1200 mV
[ 0.648177] usb-hub-reset: 3300 mV
[ 0.648989] usb-hub-en2: 3300 mV
[ 0.651577] emc bwmgr registration successful for pmqos client
[ 0.651957] camchar: rtcpu character device driver loaded
[ 0.652766] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.654927] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.655876] clocksource: Switched to clocksource arch_sys_counter
[ 0.695051] VFS: Disk quotas dquot_6.6.0
[ 0.695300] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.695940] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.696840] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.696870] nvmap_page_pool_init: Total RAM pages: 2010241
[ 0.696892] nvmap_page_pool_init: nvmap page pool size: 251280 pages (981 MB)
[ 0.697117] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.700646] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.712620] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.712830] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.713204] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.713368] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.713514] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.713647] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.713840] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.713961] AFIR is not constant read client, don’t program init LA value
[ 0.713965] AFIW is not constant read client, don’t program init LA value
[ 0.713972] AONW is not constant read client, don’t program init LA value
[ 0.713975] AONDMAR is not constant read client, don’t program init LA value
[ 0.713978] AONDMAW is not constant read client, don’t program init LA value
[ 0.713981] APEDMAR is not constant read client, don’t program init LA value
[ 0.713984] APEDMAW is not constant read client, don’t program init LA value
[ 0.713990] APEW is not constant read client, don’t program init LA value
[ 0.713993] AXISR is not constant read client, don’t program init LA value
[ 0.713996] AXISW is not constant read client, don’t program init LA value
[ 0.714002] BPMPW is not constant read client, don’t program init LA value
[ 0.714005] BPMPDMAR is not constant read client, don’t program init LA value
[ 0.714008] BPMPDMAW is not constant read client, don’t program init LA value
[ 0.714011] EQOSR is not constant read client, don’t program init LA value
[ 0.714014] EQOSW is not constant read client, don’t program init LA value
[ 0.714020] ETRW is not constant read client, don’t program init LA value
[ 0.714023] GPUSRD is not constant read client, don’t program init LA value
[ 0.714026] GPUSWR is not constant read client, don’t program init LA value
[ 0.714029] GPUSRD2 is not constant read client, don’t program init LA value
[ 0.714032] GPUSWR2 is not constant read client, don’t program init LA value
[ 0.714038] HDAW is not constant read client, don’t program init LA value
[ 0.714041] HOST1X_DMAR is not constant read client, don’t program init LA value
[ 0.714044] ISP_RA is not constant read client, don’t program init LA value
[ 0.714047] ISP_WA is not constant read client, don’t program init LA value
[ 0.714049] ISP_WB is not constant read client, don’t program init LA value
[ 0.714055] MPCOREW is not constant read client, don’t program init LA value
[ 0.714058] NVDECR is not constant read client, don’t program init LA value
[ 0.714060] NVDECW is not constant read client, don’t program init LA value
[ 0.714063] NVDISPLAYR is not constant read client, don’t program init LA value
[ 0.714067] NVENCSRD is not constant read client, don’t program init LA value
[ 0.714069] NVENCSWR is not constant read client, don’t program init LA value
[ 0.714072] NVJPGSRD is not constant read client, don’t program init LA value
[ 0.714075] NVJPGSWR is not constant read client, don’t program init LA value
[ 0.714081] SATAR is not constant read client, don’t program init LA value
[ 0.714084] SATAW is not constant read client, don’t program init LA value
[ 0.714090] SCEW is not constant read client, don’t program init LA value
[ 0.714093] SCEDMAR is not constant read client, don’t program init LA value
[ 0.714096] SCEDMAW is not constant read client, don’t program init LA value
[ 0.714098] SDMMCR is not constant read client, don’t program init LA value
[ 0.714101] SDMMCW is not constant read client, don’t program init LA value
[ 0.714104] SDMMCRA is not constant read client, don’t program init LA value
[ 0.714106] SDMMCWA is not constant read client, don’t program init LA value
[ 0.714109] SDMMCRAA is not constant read client, don’t program init LA value
[ 0.714112] SDMMCWAA is not constant read client, don’t program init LA value
[ 0.714115] SDMMCRAB is not constant read client, don’t program init LA value
[ 0.714117] SDMMCWAB is not constant read client, don’t program init LA value
[ 0.714120] SESRD is not constant read client, don’t program init LA value
[ 0.714123] SESWR is not constant read client, don’t program init LA value
[ 0.714126] TSECSRD is not constant read client, don’t program init LA value
[ 0.714128] TSECSWR is not constant read client, don’t program init LA value
[ 0.714131] TSECBSRD is not constant read client, don’t program init LA value
[ 0.714134] TSECBSWR is not constant read client, don’t program init LA value
[ 0.714137] UFSHCR is not constant read client, don’t program init LA value
[ 0.714140] UFSHCW is not constant read client, don’t program init LA value
[ 0.714142] VI_W is not constant read client, don’t program init LA value
[ 0.714145] VICSRD is not constant read client, don’t program init LA value
[ 0.714148] VICSWR is not constant read client, don’t program init LA value
[ 0.714151] XUSB_DEVR is not constant read client, don’t program init LA value
[ 0.714154] XUSB_DEVW is not constant read client, don’t program init LA value
[ 0.714156] XUSB_HOSTR is not constant read client, don’t program init LA value
[ 0.714159] XUSB_HOSTW is not constant read client, don’t program init LA value
[ 0.714284] la/ptsa driver initialized.
[ 0.714311] tek.xing pre_t19x_iso_plat_init max_emc_clk 1866000, max_emc_clk = 1866000
[ 0.714359] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.714381] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.715508] NET: Registered protocol family 2
[ 0.717562] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.718187] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.719003] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.719072] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.719212] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.720112] NET: Registered protocol family 1
[ 0.721281] RPC: Registered named UNIX socket transport module.
[ 0.721308] RPC: Registered udp transport module.
[ 0.721328] RPC: Registered tcp transport module.
[ 0.721347] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.721373] PCI: CLS 0 bytes, default 64
[ 0.721638] Trying to unpack rootfs image as initramfs…
[ 0.739532] host1x 13e10000.host1x: initialized
[ 0.740998] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.745686] audit: initializing netlink subsys (disabled)
[ 0.745744] audit: type=2000 audit(0.628:1): initialized
[ 0.746356] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.757840] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.760505] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.762064] 9p: Installing v9fs 9p2000 file system support
[ 0.768385] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.768575] io scheduler noop registered
[ 0.769215] io scheduler cfq registered (default)
[ 0.774057] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.834113] iommu: Adding device aconnect@2a41000:adsp_audio to group 52
[ 0.872779] iommu: Adding device 2993000.adsp to group 53
[ 0.873895] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.877064] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 0.881069] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.882578] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.883858] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.885171] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.887903] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 0.889013] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.889446] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 0.889696] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.889854] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.889884] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1000000, vi_iso_bw=1500000, max_bw=3916800
[ 0.892137] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 0.892578] tsec 15500000.tsec: initialized
[ 0.893945] tsec 15100000.tsecb: initialized
[ 0.897485] nvdec 15480000.nvdec: initialized
[ 0.903077] falcon 15340000.vic: initialized
[ 0.904663] falcon 154c0000.nvenc: initialized
[ 0.906083] falcon 15380000.nvjpg: initialized
[ 0.910515] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.912342] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.913970] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.915548] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.917101] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.918635] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.920221] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.921777] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.924678] tegradccommon 15200000.dc_common: host1x channel mapped
[ 0.924718] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 0.924773] tegradccommon 15200000.dc_common: dma mapping done
[ 0.926855] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 0.927008] generic_infoframe_type: 0x87
[ 0.927100] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.927143] tegradc 15210000.nvdisplay: Display dc.ffffff800b610000 registered with id=0
[ 0.935976] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.936019] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.936074] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.936383] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 0.936411] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 0.937627] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.938526] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.939311] kfuse 3830000.kfuse: initialized
[ 0.941223] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.942126] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 0.942251] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 0.946149] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.949968] console [ttyS0] disabled
[ 0.950043] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 0.950316] tegradc 15210000.nvdisplay: probed
[ 1.321708] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.729101] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.135775] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.137804] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.138190] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 2.138198] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.138203] pci_bus 0000:00: root bus resource [mem 0x40100000-0x47ffffff]
[ 2.138208] pci_bus 0000:00: root bus resource [mem 0x48000000-0x7fffffff pref]
[ 2.138214] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.138253] pci 0000:00:03.0: [10de:10e6] type 01 class 0x060400
[ 2.138376] pci 0000:00:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.138570] iommu: Adding device 0000:00:03.0 to group 54
[ 2.138580] arm-smmu: forcing sodev map for 0000:00:03.0
[ 2.138628] __mc_override_sid(): override sid=17 oid=1 ord=1 at offset=70
[ 2.138632] __mc_override_sid(): override sid=17 oid=8 ord=1 at offset=188
[ 2.138688] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.138872] pci 0000:01:00.0: [8086:1531] type 00 class 0x020000
[ 2.138946] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x007fffff]
[ 2.138994] pci 0000:01:00.0: reg 0x18: [io 0x0000-0x001f]
[ 2.139019] pci 0000:01:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 2.139331] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 2.139571] iommu: Adding device 0000:01:00.0 to group 55
[ 2.139576] arm-smmu: forcing sodev map for 0000:01:00.0
[ 2.139605] __mc_override_sid(): override sid=17 oid=1 ord=1 at offset=70
[ 2.139609] __mc_override_sid(): override sid=17 oid=8 ord=1 at offset=188
[ 2.148048] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.148097] pci 0000:00:03.0: BAR 14: assigned [mem 0x40400000-0x40ffffff]
[ 2.148103] pci 0000:00:03.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.148113] pci 0000:01:00.0: BAR 0: assigned [mem 0x40800000-0x40ffffff]
[ 2.148127] pci 0000:01:00.0: BAR 3: assigned [mem 0x40400000-0x40403fff]
[ 2.148141] pci 0000:01:00.0: BAR 2: assigned [io 0x1000-0x101f]
[ 2.148157] pci 0000:00:03.0: PCI bridge to [bus 01]
[ 2.148162] pci 0000:00:03.0: bridge window [io 0x1000-0x1fff]
[ 2.148172] pci 0000:00:03.0: bridge window [mem 0x40400000-0x40ffffff]
[ 2.151312] pcieport 0000:00:03.0: Signaling PME through PCIe PME interrupt
[ 2.151316] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.151326] pcie_pme 0000:00:03.0:pcie001: service driver pcie_pme loaded
[ 2.151444] aer 0000:00:03.0:pcie002: service driver aer loaded
[ 3.329749] console [ttyS0] enabled
[ 3.330351] Console: switching to colour frame buffer device 80x30
[ 3.336019] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 3.341636] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 3.349434] serial-tegra 3130000.serial: RX in PIO mode
[ 3.350620] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 3.359113] [drm] Initialized
[ 3.375248] tegradc 15210000.nvdisplay: fb registered
[ 3.380863] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 3.386351] brd: module loaded
[ 3.394580] loop: module loaded
[ 3.397909] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.403819] tegra_profiler: auth: init
[ 3.408250] nct1008_nct72 7-004c: starting parse dt
[ 3.408513] THERMAL EST: found 3 subdevs
[ 3.408517] THERMAL EST num_resources: 0
[ 3.408521] [THERMAL EST subdev 0]
[ 3.408526] [THERMAL EST subdev 1]
[ 3.408530] [THERMAL EST subdev 2]
[ 3.408856] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 3.408858] THERMAL EST: thz register success.
[ 3.409030] THERMAL EST: end of probe, return err: 0
[ 3.410087] hisi_sas: driver version v1.6
[ 3.414820] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.414831] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.415911] scsi host0: tegra_ahci
[ 3.416877] scsi host1: tegra_ahci
[ 3.417071] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 3.417075] ata2: DUMMY
[ 3.423108] libphy: Fixed MDIO Bus: probed
[ 3.423507] tun: Universal TUN/TAP device driver, 1.6
[ 3.423509] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.425336] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.425339] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.425382] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.425384] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.425802] igb 0000:01:00.0: enabling device (0000 → 0002)
[ 3.484100] igb 0000:01:00.0 (unnamed net_device) (uninitialized): igb: eth%d NIC Link is Down
[ 3.485621] pps pps0: new PPS source ptp0
[ 3.485627] igb 0000:01:00.0: added PHC on eth0
[ 3.485632] igb 0000:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 3.485637] igb 0000:01:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 6c:61:74:75:6c:65
[ 3.485642] igb 0000:01:00.0: eth0: PBA No: FFFFFF-0FF
[ 3.485647] igb 0000:01:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 3.485981] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.485983] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.486043] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.486045] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.487586] eqos 2490000.ether_qos: no PHY interrupt found
[ 3.487795] eqos 2490000.ether_qos: can’t get pllrefe_vcoout clk (-2)
[ 3.492252] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a7 da 2f
[ 3.492399] libphy: dwc_phy: probed
[ 3.492790] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.495552] PPP generic driver version 2.4.2
[ 3.495780] PPP BSD Compression module registered
[ 3.495784] PPP Deflate Compression module registered
[ 3.495836] PPP MPPE Compression module registered
[ 3.495841] NET: Registered protocol family 24
[ 3.495930] usbcore: registered new interface driver r8152
[ 3.495973] usbcore: registered new interface driver asix
[ 3.496009] usbcore: registered new interface driver ax88179_178a
[ 3.496113] usbcore: registered new interface driver cdc_ether
[ 3.496203] usbcore: registered new interface driver net1080
[ 3.496300] usbcore: registered new interface driver cdc_subset
[ 3.496387] usbcore: registered new interface driver zaurus
[ 3.496480] usbcore: registered new interface driver cdc_ncm
[ 3.496768] VFIO - User Level meta-driver version: 0.3
[ 3.498756] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.498774] ehci-pci: EHCI PCI platform driver
[ 3.498869] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.498878] ohci-pci: OHCI PCI platform driver
[ 3.498966] ohci-platform: OHCI generic platform driver
[ 3.504800] tegra-xusb 3530000.xhci: No USB port has OTG_CAP
[ 3.506387] tegra-xusb 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 3.506392] tegra-xusb 3530000.xhci: Falling back to user helper
[ 3.506886] usbcore: registered new interface driver uas
[ 3.506935] usbcore: registered new interface driver usb-storage
[ 3.507109] usbcore: registered new interface driver usbserial
[ 3.510518] mousedev: PS/2 mouse device common for all mice
[ 3.510631] usbcore: registered new interface driver xpad
[ 3.644335] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.645916] Wake73 for irq=42
[ 3.647239] rtc rtc1: alarm rtc device
[ 3.647253] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.647280] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.647519] i2c /dev entries driver
[ 3.649753] tek.xing adv7180_probe
[ 3.649759] adv7180 2-0020: chip found @ 0x20 (3180000.i2c)
[ 3.649815] adv7180 2-0020: adv7180_parse_dt
[ 3.649824] adv7180 2-0020: mclk in DT extperiph1
[ 3.649829] adv7180 2-0020: adv7180_power_get
[ 3.649840] adv7180 2-0020: camera_common_parse_ports: port 0 num of lanes 1
[ 3.649857] adv7180 2-0020: parsing for mode0 props
[ 3.649912] adv7180 2-0020: adv7180_probe: name adv7180_a
[ 3.649917] adv7180 2-0020: camera_common_create_debugfs adv7180_a
[ 3.649934] adv7180 2-0020: tegracam sensor driver:adv7180_v2.0.6
[ 3.649938] adv7180 2-0020: adv7180_probe
[ 3.650085] tek.xing init_device line = 1270
[ 3.665852] adv7180 2-0020: adv7180_fill_string_ctrl
[ 3.665857] adv7180 2-0020: adv7180_fill_string_ctrl
[ 3.665861] adv7180 2-0020: adv7180_fill_string_ctrl
[ 3.668024] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.672923] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.673528] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 3.675040] parse_throttle_dt_data: Num cap clks = 4
[ 3.675044] parse_throttle_dt_data: clk=mcpu type=1
[ 3.675047] parse_throttle_dt_data: clk=bcpu type=2
[ 3.675057] parse_throttle_dt_data: clk=gpu type=4
[ 3.675060] parse_throttle_dt_data: clk=emc type=3
[ 3.676349] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.677024] FAN dev name: pwm-fan
[ 3.677088] FAN:gpio request success.
[ 3.677096] FAN: can’t find tach_gpio
[ 3.677130] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.677444] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 3.677449] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.677882] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.677888] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.677892] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.677896] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.677899] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.677903] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.677907] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.677911] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.677947] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.677952] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.680033] device-mapper: uevent: version 1.0.3
[ 3.680988] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.686809] cpufreq: platform driver Initialization: pass
[ 3.692197] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.692311] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.698561] sdhci: Secure Digital Host Controller Interface driver
[ 3.698564] sdhci: Copyright(c) Pierre Ossman
[ 3.698566] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.700073] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.702012] CMDQ: cmdq_platfm_init successful
[ 3.703259] CQE: CMD_TIMING bit set for R1B DCMD
[ 3.705227] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.710156] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.710196] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.710785] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.712491] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 256
[ 3.716986] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.717836] tegra-se-nvhost 15810000.se: initialized
[ 3.718924] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.719757] tegra-se-nvhost 15820000.se: initialized
[ 3.720922] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.721800] tegra-se-nvhost 15830000.se: initialized
[ 3.722482] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.723305] tegra-se-nvhost 15840000.se: initialized
[ 3.724305] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.724610] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.725788] usbcore: registered new interface driver usbhid
[ 3.725789] usbhid: USB HID core driver
[ 3.727965] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 3.727993] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 3.728089] ina3221x: probe of 0-0042 failed with error -121
[ 3.728317] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 3.728343] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 3.728491] ina3221x: probe of 0-0043 failed with error -121
[ 3.730849] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 3.735315] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.751232] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 3.751518] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.751639] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 3.751831] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 3.751897] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.752614] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 3.752682] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 3.752760] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 3.752808] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 3.752900] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 3.753928] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 3.753929] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.759959] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.763936] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 3.763981] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.801432] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 3.814969] mmc0: periodic cache flush enabled
[ 3.814982] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 3.815578] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.815767] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.816003] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.816301] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.819091] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31
[ 3.871666] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 3.873224] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 3.873639] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.873781] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.873846] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.874144] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874146] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 3.874148] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.874195] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874197] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 3.874198] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.874243] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874245] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 3.874246] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.874290] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874292] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 3.874293] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.874339] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874340] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 3.874342] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.874387] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874391] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 3.874392] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.874438] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874441] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 3.874443] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.874487] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874491] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 3.874492] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.874537] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874541] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 3.874542] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.874589] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874591] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 3.874592] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.874646] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874651] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 3.874652] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.874697] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874702] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 3.874703] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.874749] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874753] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 3.874755] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.874799] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874803] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 3.874804] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.874847] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874851] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 3.874852] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.874902] **** A57 ECC: Enabled
[ 3.874904] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 3.874960] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.875583] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.876973] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.877151] denver_knobs_init:MTS_VERSION:43068234
[ 3.882792] nvpmodel: initialized successfully
[ 3.886109] usbcore: registered new interface driver snd-usb-audio
[ 3.899698] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 3.902048] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 3.983849] OPE platform probe
[ 3.983923] OPE platform probe successful
[ 3.994944] tegra-asoc: sound: This is a dummy codec
[ 4.032947] mmc1: Applying tuning correction
[ 4.032974] mmc1: Tap value after applying correction 67
[ 4.032980] mmc1: hw tuning done …
[ 4.039197] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.040740] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.040809] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.040874] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.040938] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.041003] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.041065] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.041131] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.041199] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.041263] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.041329] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.041394] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.041461] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.041527] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.041594] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.041659] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.041725] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.041791] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.041855] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.041920] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.041986] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.065641] u32 classifier
[ 4.065642] Actions configured
[ 4.065700] Initializing XFRM netlink socket
[ 4.066248] NET: Registered protocol family 10
[ 4.067450] NET: Registered protocol family 17
[ 4.067465] NET: Registered protocol family 15
[ 4.067673] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.067777] Bluetooth: RFCOMM socket layer initialized
[ 4.067788] Bluetooth: RFCOMM ver 1.11
[ 4.067815] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.067822] Bluetooth: HIDP socket layer initialized
[ 4.067841] 9pnet: Installing 9P2000 support
[ 4.067902] Key type dns_resolver registered
[ 4.069248] Registered cp15_barrier emulation handler
[ 4.069264] Registered setend emulation handler
[ 4.070132] registered taskstats version 1
[ 4.072977] isp 15600000.isp: initialized
[ 4.073051] tek.xing tegra_camera_device_register, ling = 720,
[ 4.073053] tek.xing tegra_camera_device_register, ling = 725,
[ 4.076781] nvcsi 150c0000.nvcsi: initialized
[ 4.076803] tek.xing tegra_camera_device_register, ling = 720,
[ 4.076804] tek.xing tegra_camera_device_register, ling = 725,
[ 4.080346] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 4.080414] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 4.080476] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 4.080602] input: gpio-keys as /devices/gpio-keys/input/input2
[ 4.081923] tegra-vi4 15700000.vi: initialized
[ 4.082683] tek.xing tegra_vi_get_port_info, ling = 463,
[ 4.082686] tek.xing tegra_vi_get_port_info, ling = 473,ret = 0
[ 4.082688] tek.xing tegra_vi_get_port_info, ling = 486,ret = 0
[ 4.082689] tek.xing tegra_vi_get_port_info, ling = 496,ret = 0
[ 4.082690] tek.xing tegra_vi_get_port_info, ling = 503,ret = 0
[ 4.082692] tek.xing tegra_vi_get_port_info, ling = 518,ret = 0
[ 4.082693] tek.xing tegra_vi_get_port_info, ling = 473,ret = 0
[ 4.082695] tek.xing tegra_vi_get_port_info, ling = 473,ret = 0
[ 4.082697] tek.xing tegra_vi_get_port_info, ling = 473,ret = 0
[ 4.082698] tek.xing tegra_vi_get_port_info, ling = 473,ret = 0
[ 4.082700] tek.xing tegra_vi_get_port_info, ling = 473,ret = 0
[ 4.082701] tek.xing tegra_vi_get_port_info, ling = 541,ret = 0
[ 4.082772] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi–1 bound
[ 4.082784] tegra-vi4 15700000.vi: subdev adv7180 2-0020 bound
[ 4.082925] adv7180 2-0020: camera_common_g_fmt++
[ 4.083007] tek.xing tegra_camera_device_register, ling = 720,
[ 4.083008] tek.xing tegra_camera_device_register, ling = 725,
[ 4.088631] tek.xing tegra_camera_device_register, ling = 720,
[ 4.088633] tek.xing tegra_camera_device_register, ling = 725,
[ 4.088637] tek.xing tegra_vi4_probe, ling = 370,err = 0
[ 4.116013] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:16 UTC (946688416)
[ 4.116913] mmcblk mmc0:0001: Card claimed for testing.
[ 4.145011] bpmp: mounted debugfs mirror
[ 4.146434] bwmgr: missing cdev-type property
[ 4.154107] spmic-ldo0: disabling
[ 4.154298] spmic-ldo1: disabling
[ 4.154462] en-vdd-sd: disabling
[ 4.154464] en-vdd-cam: disabling
[ 4.154466] vdd-usb0-5v: disabling
[ 4.154468] vdd-usb1-5v: disabling
[ 4.154470] en-vdd-disp-3v3: disabling
[ 4.154472] en-mdm-pwr-3v7: disabling
[ 4.154474] en-vdd-cam-hv-2v8: disabling
[ 4.154476] en-vdd-cam-1v2: disabling
[ 4.154478] vdd-fan: disabling
[ 4.154501] vdd-3v3: disabling
[ 4.154503] en-vdd-vcm-2v8: disabling
[ 4.154505] vdd-usb2-5v: disabling
[ 4.154507] vdd-sys-bl: disabling
[ 4.154510] en-vdd-sys: disabling
[ 4.154513] ALSA device list:
[ 4.154515] #0: tegra-hda at 0x3518000 irq 382
[ 4.154516] #1: tegra-snd-t186ref-mobile-rt565x
[ 5.291647] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 5.297753] nct1008_nct72 7-004c: success parsing dt
[ 5.302838] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 5.341601] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 5.347489] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 5.385661] nct1008_nct72 7-004c: initial LOC temp: 20000
[ 5.391514] nct1008_nct72 7-004c: initial EXT temp: 32500
[ 5.397692] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 5.402890] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 5.408346] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 5.808282] EXT4-fs (mmcblk0p1): 13 orphan inodes deleted
[ 5.813723] EXT4-fs (mmcblk0p1): recovery complete
[ 5.826733] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.834893] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.846718] devtmpfs: mounted
[ 5.851658] Freeing unused kernel memory: 8576K
[ 6.008692] systemd[1]: System time before build time, advancing clock.
[ 6.041344] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.090573] cgroup: cgroup2: unknown option “nsdelegate”
[ 6.118539] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 6.143178] systemd[1]: Detected architecture arm64.
[ 6.232207] systemd[1]: Set hostname to .
[ 6.334496] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 6.351612] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.548529] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.559106] systemd[1]: Created slice System Slice.
[ 6.564608] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.571569] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 6.578356] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.585377] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.591796] systemd[1]: Listening on Syslog Socket.
[ 6.597221] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.633631] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.701412] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 6.887261] systemd-journald[2284]: Received request to flush runtime journal from PID 1
[ 7.695900] random: crng init done
[ 7.699317] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.871741] adv7180 2-0020: adv7180_open:
[ 7.876082] adv7180 2-0020: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 7.876152] adv7180 2-0020: camera_common_dpd_disable: csi 0
[ 7.876157] adv7180 2-0020: adv7180_power_on
[ 7.947977] nvcsi 150c0000.nvcsi: settle time reading from props
[ 7.947986] nvcsi 150c0000.nvcsi: csi_port: 0
[ 7.956341] adv7180 2-0020: adv7180_power_off
[ 7.956415] adv7180 2-0020: camera_common_dpd_enable: csi 0
[ 7.956419] adv7180 2-0020: camera_common_mclk_disable: disable MCLK
[ 7.967701] tegra-xusb 3530000.xhci: cannot find firmware…retry after 1 second
[ 8.109739] dhd_module_init in
[ 8.109817] found wifi platform device bcmdhd_wlan
[ 8.110984] wifi_platform_get_country_code_map: could not get country_code_map
[ 8.110987] wifi_plat_dev_drv_probe:platform country code map is not available
[ 8.111002] Power-up adapter ‘DHD generic adapter’
[ 8.111010] wifi_platform_set_power = 1
[ 8.165135] tegra-i2c c240000.i2c: no acknowledge from address 0x69
[ 8.172647] bmi160 1-0069: bmi_i2c_rd ERR: 0x00
[ 8.177235] bmi160 1-0069: bmi_init _id_i2c ERR
[ 8.189057] bmi160 1-0069: bmi_remove
[ 8.189060] bmi160 1-0069: bmi_probe done
[ 8.316910] wifi_platform_bus_enumerate device present 1
[ 8.337173] wifi_platform_bus_enumerate device present 0
[ 8.338037] F1 signature read @0x18000000=0x17214354
[ 8.343788] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.344676] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.344761] wifi_platform_get_mac_addr
[ 8.349597] ids dhd_log_netlink_init
[ 8.349920] wl_create_event_handler(): thread:wl_event_handler:12ed started
[ 8.349921] wl_event_handler :
[ 8.349923] tsk Enter, tsk = 0xffffffc1d8fc1a90
[ 8.350958] dhd_attach(): thread:dhd_watchdog_thread:12ee started
[ 8.351266] dhd_attach(): thread:dhd_dpc:12f4 started
[ 8.351388] dhd_attach(): thread:dhd_rxf:12f8 started
[ 8.351393] dhd_deferred_work_init: work queue initialized
[ 8.352088]
Dongle Host Driver, version 1.201.82 (r)
Compiled from
[ 8.352433] Register interface [wlan0] MAC: 00:04:4b:a7:da:2d
[ 8.352437] dhd_prot_ioctl : bus is down. we have nothing to do
[ 8.352672] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 67
[ 8.353715] wifi_platform_set_power = 0
[ 8.626140] nvgpu: 17000000.gp10b railgate_enable_store:343 [INFO] railgate is disabled.
[ 8.986685] tegra-xusb 3530000.xhci: Firmware timestamp: 2018-12-26 10:30:04 UTC, Version: 55.12 release
[ 8.996059] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.039950] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 9.039980] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 9.040821] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 9.040859] tegra-xusb 3530000.xhci: irq 70, io mem 0x03530000
[ 9.040992] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.040997] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.041000] usb usb1: Product: xHCI Host Controller
[ 9.041003] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 9.041006] usb usb1: SerialNumber: 3530000.xhci
[ 9.041446] hub 1-0:1.0: USB hub found
[ 9.041475] hub 1-0:1.0: 4 ports detected
[ 9.041752] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 9.041760] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 9.041885] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 9.041888] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.041891] usb usb2: Product: xHCI Host Controller
[ 9.041894] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 9.041896] usb usb2: SerialNumber: 3530000.xhci
[ 9.042183] hub 2-0:1.0: USB hub found
[ 9.042206] hub 2-0:1.0: 3 ports detected
[ 9.043952] Wake76 for irq=199
[ 9.043963] Wake77 for irq=199
[ 9.043965] Wake78 for irq=199
[ 9.043966] Wake79 for irq=199
[ 9.043967] Wake80 for irq=199
[ 9.043969] Wake81 for irq=199
[ 9.043970] Wake82 for irq=199
[ 9.062507] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.075675] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 9.144292] usb usb2: usb_suspend_both: status 0
[ 9.160939] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 9.164573] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 9.172611] CPU1: shutdown
[ 9.175327] psci: CPU1 killed.
[ 9.225312] CPU2: shutdown
[ 9.228143] psci: CPU2 killed.
[ 9.367900] usb 1-1: new full-speed USB device number 2 using tegra-xusb
[ 9.388748] usb 1-1: Ne
[code]
root@tek-desktop:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (tek@tek) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #124 SMP PREEMPT Wed Dec 25 18:42:15 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2055168
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523776 pages, LIFO batch:31
[ 0.000000] Normal zone: 24008 pages used for memmap
[ 0.000000] Normal zone: 1531392 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc1f7023000 s53400 r8192 d32616 u94208
[ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2022968
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.983055.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29420(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7975428K/8220672K available (15166K kernel code, 2916K rwdata, 6556K rodata, 8576K init, 607K bss, 179708K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095c0000 ( 6592 KB)
[ 0.000000] .init : 0xffffff80095c0000 - 0xffffff8009e20000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f9008 ( 2917 KB)
[ 0.000000] .bss : 0xffffff800a0f9008 - 0xffffff800a190e3c ( 608 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009499] Console: colour dummy device 80x25
[ 0.014159] console [tty0] enabled
[ 0.017715] bootconsole [uart8250] disabled
[ 0.022088] kmemleak: Kernel memory leak detector disabled
[ 0.022105] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022119] pid_max: default: 32768 minimum: 301
[ 0.022437] Security Framework initialized
[ 0.022598] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022609] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.023228] ftrace: allocating 46820 entries in 183 pages
[ 0.147441] sched-energy: Sched-energy-costs installed from DT
[ 0.147461] ASID allocator initialised with 65536 entries
[ 0.181859] tegra-id: chipid=21817.
[ 0.181874] tegra-id: opt_subrevision=1.
[ 0.181895] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.181909] DTS File Name: …/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.181924] DTB Build time: Dec 12 2019 18:39:48
[ 0.229849] CPU1: Booted secondary processor [4e0f0030]
[ 0.261505] CPU2: Booted secondary processor [4e0f0030]
[ 0.293349] CPU3: Booted secondary processor [411fd073]
[ 0.325345] CPU4: Booted secondary processor [411fd073]
[ 0.357342] CPU5: Booted secondary processor [411fd073]
[ 0.357395] Brought up 6 CPUs
[ 0.357435] SMP: Total of 6 processors activated.
[ 0.357447] CPU features: detected feature: 32-bit EL0 Support
[ 0.358215] CPU: All CPU(s) started at EL2
[ 0.358270] alternatives: patching kernel code
[ 0.367611] devtmpfs: initialized
[ 0.393762] Initilizing CustomIPI irq domain
[ 0.393951] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.393976] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.394844] pinctrl core: initialized pinctrl subsystem
[ 0.395049] OS set in device tree is not L4T.
[ 0.395191] regulator-dummy: no parameters
[ 0.395322] Initializing plugin-manager
[ 0.395376] Plugin module not found
[ 0.395420] Plugin-manager status disabled
[ 0.396672] NET: Registered protocol family 16
[ 0.397379] pstore: using zlib compression
[ 0.397826] console [pstore-1] enabled
[ 0.397890] pstore: Registered ramoops as persistent store backend
[ 0.397960] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.417585] cpuidle: using governor menu
[ 0.419969] bpmp: waiting for handshake
[ 0.420003] bpmp: handshake completed
[ 0.420045] bpmp: synchronizing channels
[ 0.420097] bpmp: channels synchronized
[ 0.420126] bpmp: mail init ok
[ 0.423910] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.423956] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.423989] arm-smmu 12000000.iommu: stage 1 translation
[ 0.424023] arm-smmu 12000000.iommu: stage 2 translation
[ 0.424055] arm-smmu 12000000.iommu: nested translation
[ 0.424113] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.424164] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.424216] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.424253] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.424290] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.428979] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.429078] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.431794] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.433381] Registering BPMP clocks…
[ 0.433572] tegra_bpmp_clk_init: clock init ok (636 clks)
[ 0.434211] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.436247] tegra_powergate_init: DONE
[ 0.436318] DTS File Name: …/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.436384] DTB Build time: Dec 12 2019 18:39:48
[ 0.439444] Tegra reboot handler registered.
[ 0.441616] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.441755] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.441803] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.441836] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.441867] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.442177] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.442233] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.442756] iommu: Adding device 3460000.sdhci to group 0
[ 0.442953] __mc_override_sid(): override sid=23 oid=26 ord=1 at offset=318
[ 0.442960] __mc_override_sid(): override sid=23 oid=30 ord=1 at offset=338
[ 0.443733] iommu: Adding device 3400000.sdhci to group 1
[ 0.443928] __mc_override_sid(): override sid=26 oid=23 ord=1 at offset=300
[ 0.443934] __mc_override_sid(): override sid=26 oid=27 ord=1 at offset=320
[ 0.445766] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.445820] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.445988] __mc_override_sid(): override sid=29 oid=5 ord=1 at offset=f8
[ 0.445995] __mc_override_sid(): override sid=29 oid=11 ord=1 at offset=1e8
[ 0.446426] iommu: Adding device 3160000.i2c to group 3
[ 0.447023] iommu: Adding device c240000.i2c to group 4
[ 0.447511] iommu: Adding device 3180000.i2c to group 5
[ 0.448001] iommu: Adding device 3190000.i2c to group 6
[ 0.448651] iommu: Adding device 31b0000.i2c to group 7
[ 0.449164] iommu: Adding device 31c0000.i2c to group 8
[ 0.449670] iommu: Adding device c250000.i2c to group 9
[ 0.450146] iommu: Adding device 31e0000.i2c to group 10
[ 0.452613] iommu: Adding device 3210000.spi to group 11
[ 0.453108] iommu: Adding device c260000.spi to group 12
[ 0.453596] iommu: Adding device 3240000.spi to group 13
[ 0.454625] iommu: Adding device 3100000.serial to group 14
[ 0.455100] iommu: Adding device 3110000.serial to group 15
[ 0.455557] iommu: Adding device c280000.serial to group 16
[ 0.456017] iommu: Adding device 3130000.serial to group 17
[ 0.457834] iommu: Adding device 2490000.ether_qos to group 18
[ 0.457890] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.458075] __mc_override_sid(): override sid=20 oid=50 ord=1 at offset=470
[ 0.458083] __mc_override_sid(): override sid=20 oid=51 ord=1 at offset=478
[ 0.458790] iommu: Adding device b000000.rtcpu to group 19
[ 0.461343] iommu: Adding device 13e10000.host1x to group 20
[ 0.461860] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.462315] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.462783] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.463219] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.463714] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.464159] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.464574] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.465025] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.465670] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.466540] iommu: Adding device 15700000.vi to group 30
[ 0.466628] __mc_override_sid(): override sid=4 oid=33 ord=1 at offset=390
[ 0.467071] iommu: Adding device 15600000.isp to group 31
[ 0.467149] __mc_override_sid(): override sid=5 oid=12 ord=1 at offset=220
[ 0.467163] __mc_override_sid(): override sid=5 oid=13 ord=1 at offset=230
[ 0.467176] __mc_override_sid(): override sid=5 oid=14 ord=1 at offset=238
[ 0.467751] iommu: Adding device 15210000.nvdisplay to group 32
[ 0.468081] __mc_override_sid(): override sid=9 oid=54 ord=1 at offset=490
[ 0.468096] __mc_override_sid(): override sid=9 oid=69 ord=1 at offset=508
[ 0.468506] iommu: Adding device 15340000.vic to group 33
[ 0.468881] iommu: Adding device 154c0000.nvenc to group 34
[ 0.469242] iommu: Adding device 15480000.nvdec to group 35
[ 0.469761] iommu: Adding device 15380000.nvjpg to group 36
[ 0.470609] iommu: Adding device 15500000.tsec to group 37
[ 0.470947] iommu: Adding device 15100000.tsecb to group 38
[ 0.471906] iommu: Adding device 15810000.se to group 39
[ 0.472255] iommu: Adding device 15820000.se to group 40
[ 0.472616] iommu: Adding device 15830000.se to group 41
[ 0.472952] iommu: Adding device 15840000.se to group 42
[ 0.474203] iommu: Adding device smmu_test to group 43
[ 0.475087] mc: mapped MMIO address: 0xffffff800a680000 → 0x2c10000
[ 0.475148] mc: mapped MMIO address: 0xffffff800a6a0000 → 0x2c20000
[ 0.475201] mc: mapped MMIO address: 0xffffff800a6c0000 → 0x2c30000
[ 0.475253] mc: mapped MMIO address: 0xffffff800a6e0000 → 0x2c40000
[ 0.475328] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c50000
[ 0.475382] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.475427] mc-err: mcerr ops are set to t18x
[ 0.475709] mc-err: Set intmask: 0xf3140
[ 0.475729] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.477262] iommu: Adding device 3530000.xhci to group 44
[ 0.477325] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.477500] __mc_override_sid(): override sid=27 oid=15 ord=1 at offset=250
[ 0.477516] __mc_override_sid(): override sid=27 oid=16 ord=1 at offset=258
[ 0.478493] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.478537] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.479819] iommu: Adding device 17000000.gp10b to group 45
[ 0.481153] tegra-reset 5000000.clock: registered 193 resets.
[ 0.483993] iommu: Adding device d000000.bpmp to group 46
[ 0.484391] bpmp: ping status is 0
[ 0.484560] bpmp d000000.bpmp: firmware tag is 69fa4e41a01fc02a4db1adf71922a54c
[ 0.487976] bpmp d000000.bpmp: probe ok
[ 0.491716] iommu: Adding device 2600000.dma to group 47
[ 0.493275] GPIO line 459 (pcie0_lane2_mux) hogged as output/low
[ 0.493365] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.493422] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.493496] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.493876] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.499430] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.499753] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.502050] iommu: Adding device 10003000.pcie-controller to group 48
[ 0.502113] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.502276] __mc_override_sid(): override sid=17 oid=1 ord=1 at offset=70
[ 0.502284] __mc_override_sid(): override sid=17 oid=8 ord=1 at offset=188
[ 0.502554] iommu: Adding device sound to group 49
[ 0.503055] iommu: Adding device 3510000.hda to group 50
[ 0.503250] __mc_override_sid(): override sid=18 oid=2 ord=1 at offset=a8
[ 0.503257] __mc_override_sid(): override sid=18 oid=9 ord=1 at offset=1a8
[ 0.514012] iommu: Adding device c1a0000.aon to group 51
[ 0.514624] vdd-ac-bat: 5000 mV
[ 0.517521] random: fast init done
[ 0.517662] vdd-1v8-ap: 1800 mV
[ 0.546428] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.552371] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.552862] SCSI subsystem initialized
[ 0.553076] libata version 3.00 loaded.
[ 0.553281] usbcore: registered new interface driver usbfs
[ 0.553356] usbcore: registered new interface driver hub
[ 0.553480] usbcore: registered new device driver usb
[ 0.557100] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 0.558232] gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
[ 0.559386] gpiochip_setup_dev: registered GPIOs 208 to 223 on device: gpiochip4 (tca9539)
[ 0.570997] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.578042] vddio-ddr: at 1125 mV
[ 0.581877] avdd_dsi_csi: 1200 mV
[ 0.585874] vdd-1v8: 1800 mV
[ 0.589882] vdd-3v3-sys: 3300 mV
[ 0.591288] spmic-ldo0: at 1800 mV
[ 0.592135] spmic-ldo1: at 800 mV
[ 0.597889] vddio-3v3: 3300 mV
[ 0.598637] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.601895] vdd-rtc: at 800 mV
[ 0.602855] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.605947] spmic-ldo6: at 1500 mV
[ 0.609882] vdd-pex-1v00: 1000 mV
[ 0.610666] dvdd-pex: 1000 mV
[ 0.611501] GPIO line 205 (spmic_gpio_input) hogged as input
[ 0.611725] GPIO line 206 (spmic_gpio_input) hogged as input
[ 0.612117] gpiochip_setup_dev: registered GPIOs 200 to 207 on device: gpiochip5 (max77620-gpio)
[ 0.614545] max77620 4-003c: max77620 probe successful
[ 0.615084] media: Linux media interface: v0.10
[ 0.615154] Linux video capture interface: v2.00
[ 0.619649] pps_core: LinuxPPS API ver. 1 registered
[ 0.619687] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.619795] PTP clock support registered
[ 0.620466] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.620524] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.623185] tegra_fiq_debugger_init: found FIQ source (IRQ 385)
[ 0.627502] Advanced Linux Sound Architecture Driver Initialized.
[ 0.627991] Bluetooth: Core ver 2.22
[ 0.628051] NET: Registered protocol family 31
[ 0.628077] Bluetooth: HCI device and connection manager initialized
[ 0.628111] Bluetooth: HCI socket layer initialized
[ 0.628139] Bluetooth: L2CAP socket layer initialized
[ 0.628194] Bluetooth: SCO socket layer initialized
[ 0.629248] en-vdd-sd: 3300 mV
[ 0.629921] en-vdd-cam: 1800 mV
[ 0.633910] vdd-hdmi: 3300 mV
[ 0.634473] vdd-usb0-5v: 5000 mV
[ 0.634914] vdd-usb1-5v: 5000 mV
[ 0.637893] en-vdd-ts-1v8: 1800 mV
[ 0.641903] en-vdd-ts-hv-3v3: 3300 mV
[ 0.642198] en-vdd-disp-3v3: 3300 mV
[ 0.642752] en-mdm-pwr-3v7: 3700 mV
[ 0.643325] en-vdd-cam-hv-2v8: 2800 mV
[ 0.643911] en-vdd-cam-1v2: 1200 mV
[ 0.644648] vdd-fan: 5000 mV
[ 0.644952] vdd-3v3: 3300 mV
[ 0.645222] en-vdd-vcm-2v8: 2800 mV
[ 0.645562] vdd-usb2-5v: 5000 mV
[ 0.645892] vdd-sys-bl: 3300 mV
[ 0.646638] usb-hub-en1: 3300 mV
[ 0.647340] en-vdd-sys: 1200 mV
[ 0.648177] usb-hub-reset: 3300 mV
[ 0.648989] usb-hub-en2: 3300 mV
[ 0.651577] emc bwmgr registration successful for pmqos client
[ 0.651957] camchar: rtcpu character device driver loaded
[ 0.652766] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.654927] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.655876] clocksource: Switched to clocksource arch_sys_counter
[ 0.695051] VFS: Disk quotas dquot_6.6.0
[ 0.695300] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.695940] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.696840] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.696870] nvmap_page_pool_init: Total RAM pages: 2010241
[ 0.696892] nvmap_page_pool_init: nvmap page pool size: 251280 pages (981 MB)
[ 0.697117] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.700646] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.712620] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.712830] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.713204] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.713368] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.713514] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.713647] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.713840] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.713961] AFIR is not constant read client, don’t program init LA value
[ 0.713965] AFIW is not constant read client, don’t program init LA value
[ 0.713972] AONW is not constant read client, don’t program init LA value
[ 0.713975] AONDMAR is not constant read client, don’t program init LA value
[ 0.713978] AONDMAW is not constant read client, don’t program init LA value
[ 0.713981] APEDMAR is not constant read client, don’t program init LA value
[ 0.713984] APEDMAW is not constant read client, don’t program init LA value
[ 0.713990] APEW is not constant read client, don’t program init LA value
[ 0.713993] AXISR is not constant read client, don’t program init LA value
[ 0.713996] AXISW is not constant read client, don’t program init LA value
[ 0.714002] BPMPW is not constant read client, don’t program init LA value
[ 0.714005] BPMPDMAR is not constant read client, don’t program init LA value
[ 0.714008] BPMPDMAW is not constant read client, don’t program init LA value
[ 0.714011] EQOSR is not constant read client, don’t program init LA value
[ 0.714014] EQOSW is not constant read client, don’t program init LA value
[ 0.714020] ETRW is not constant read client, don’t program init LA value
[ 0.714023] GPUSRD is not constant read client, don’t program init LA value
[ 0.714026] GPUSWR is not constant read client, don’t program init LA value
[ 0.714029] GPUSRD2 is not constant read client, don’t program init LA value
[ 0.714032] GPUSWR2 is not constant read client, don’t program init LA value
[ 0.714038] HDAW is not constant read client, don’t program init LA value
[ 0.714041] HOST1X_DMAR is not constant read client, don’t program init LA value
[ 0.714044] ISP_RA is not constant read client, don’t program init LA value
[ 0.714047] ISP_WA is not constant read client, don’t program init LA value
[ 0.714049] ISP_WB is not constant read client, don’t program init LA value
[ 0.714055] MPCOREW is not constant read client, don’t program init LA value
[ 0.714058] NVDECR is not constant read client, don’t program init LA value
[ 0.714060] NVDECW is not constant read client, don’t program init LA value
[ 0.714063] NVDISPLAYR is not constant read client, don’t program init LA value
[ 0.714067] NVENCSRD is not constant read client, don’t program init LA value
[ 0.714069] NVENCSWR is not constant read client, don’t program init LA value
[ 0.714072] NVJPGSRD is not constant read client, don’t program init LA value
[ 0.714075] NVJPGSWR is not constant read client, don’t program init LA value
[ 0.714081] SATAR is not constant read client, don’t program init LA value
[ 0.714084] SATAW is not constant read client, don’t program init LA value
[ 0.714090] SCEW is not constant read client, don’t program init LA value
[ 0.714093] SCEDMAR is not constant read client, don’t program init LA value
[ 0.714096] SCEDMAW is not constant read client, don’t program init LA value
[ 0.714098] SDMMCR is not constant read client, don’t program init LA value
[ 0.714101] SDMMCW is not constant read client, don’t program init LA value
[ 0.714104] SDMMCRA is not constant read client, don’t program init LA value
[ 0.714106] SDMMCWA is not constant read client, don’t program init LA value
[ 0.714109] SDMMCRAA is not constant read client, don’t program init LA value
[ 0.714112] SDMMCWAA is not constant read client, don’t program init LA value
[ 0.714115] SDMMCRAB is not constant read client, don’t program init LA value
[ 0.714117] SDMMCWAB is not constant read client, don’t program init LA value
[ 0.714120] SESRD is not constant read client, don’t program init LA value
[ 0.714123] SESWR is not constant read client, don’t program init LA value
[ 0.714126] TSECSRD is not constant read client, don’t program init LA value
[ 0.714128] TSECSWR is not constant read client, don’t program init LA value
[ 0.714131] TSECBSRD is not constant read client, don’t program init LA value
[ 0.714134] TSECBSWR is not constant read client, don’t program init LA value
[ 0.714137] UFSHCR is not constant read client, don’t program init LA value
[ 0.714140] UFSHCW is not constant read client, don’t program init LA value
[ 0.714142] VI_W is not constant read client, don’t program init LA value
[ 0.714145] VICSRD is not constant read client, don’t program init LA value
[ 0.714148] VICSWR is not constant read client, don’t program init LA value
[ 0.714151] XUSB_DEVR is not constant read client, don’t program init LA value
[ 0.714154] XUSB_DEVW is not constant read client, don’t program init LA value
[ 0.714156] XUSB_HOSTR is not constant read client, don’t program init LA value
[ 0.714159] XUSB_HOSTW is not constant read client, don’t program init LA value
[ 0.714284] la/ptsa driver initialized.
[ 0.714311] tek.xing pre_t19x_iso_plat_init max_emc_clk 1866000, max_emc_clk = 1866000
[ 0.714359] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.714381] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.715508] NET: Registered protocol family 2
[ 0.717562] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.718187] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.719003] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.719072] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.719212] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.720112] NET: Registered protocol family 1
[ 0.721281] RPC: Registered named UNIX socket transport module.
[ 0.721308] RPC: Registered udp transport module.
[ 0.721328] RPC: Registered tcp transport module.
[ 0.721347] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.721373] PCI: CLS 0 bytes, default 64
[ 0.721638] Trying to unpack rootfs image as initramfs…
[ 0.739532] host1x 13e10000.host1x: initialized
[ 0.740998] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.745686] audit: initializing netlink subsys (disabled)
[ 0.745744] audit: type=2000 audit(0.628:1): initialized
[ 0.746356] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.757840] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.760505] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.762064] 9p: Installing v9fs 9p2000 file system support
[ 0.768385] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.768575] io scheduler noop registered
[ 0.769215] io scheduler cfq registered (default)
[ 0.774057] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.834113] iommu: Adding device aconnect@2a41000:adsp_audio to group 52
[ 0.872779] iommu: Adding device 2993000.adsp to group 53
[ 0.873895] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.877064] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 0.881069] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.882578] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.883858] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.885171] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.887903] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 0.889013] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.889446] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 0.889696] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.889854] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.889884] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1000000, vi_iso_bw=1500000, max_bw=3916800
[ 0.892137] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 0.892578] tsec 15500000.tsec: initialized
[ 0.893945] tsec 15100000.tsecb: initialized
[ 0.897485] nvdec 15480000.nvdec: initialized
[ 0.903077] falcon 15340000.vic: initialized
[ 0.904663] falcon 154c0000.nvenc: initialized
[ 0.906083] falcon 15380000.nvjpg: initialized
[ 0.910515] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.912342] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.913970] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.915548] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.917101] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.918635] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.920221] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.921777] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.924678] tegradccommon 15200000.dc_common: host1x channel mapped
[ 0.924718] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 0.924773] tegradccommon 15200000.dc_common: dma mapping done
[ 0.926855] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 0.927008] generic_infoframe_type: 0x87
[ 0.927100] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.927143] tegradc 15210000.nvdisplay: Display dc.ffffff800b610000 registered with id=0
[ 0.935976] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.936019] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.936074] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.936383] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 0.936411] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 0.937627] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.938526] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.939311] kfuse 3830000.kfuse: initialized
[ 0.941223] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.942126] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 0.942251] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 0.946149] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.949968] console [ttyS0] disabled
[ 0.950043] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 0.950316] tegradc 15210000.nvdisplay: probed
[ 1.321708] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.729101] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.135775] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.137804] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.138190] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 2.138198] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.138203] pci_bus 0000:00: root bus resource [mem 0x40100000-0x47ffffff]
[ 2.138208] pci_bus 0000:00: root bus resource [mem 0x48000000-0x7fffffff pref]
[ 2.138214] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.138253] pci 0000:00:03.0: [10de:10e6] type 01 class 0x060400
[ 2.138376] pci 0000:00:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.138570] iommu: Adding device 0000:00:03.0 to group 54
[ 2.138580] arm-smmu: forcing sodev map for 0000:00:03.0
[ 2.138628] __mc_override_sid(): override sid=17 oid=1 ord=1 at offset=70
[ 2.138632] __mc_override_sid(): override sid=17 oid=8 ord=1 at offset=188
[ 2.138688] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.138872] pci 0000:01:00.0: [8086:1531] type 00 class 0x020000
[ 2.138946] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x007fffff]
[ 2.138994] pci 0000:01:00.0: reg 0x18: [io 0x0000-0x001f]
[ 2.139019] pci 0000:01:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 2.139331] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 2.139571] iommu: Adding device 0000:01:00.0 to group 55
[ 2.139576] arm-smmu: forcing sodev map for 0000:01:00.0
[ 2.139605] __mc_override_sid(): override sid=17 oid=1 ord=1 at offset=70
[ 2.139609] __mc_override_sid(): override sid=17 oid=8 ord=1 at offset=188
[ 2.148048] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.148097] pci 0000:00:03.0: BAR 14: assigned [mem 0x40400000-0x40ffffff]
[ 2.148103] pci 0000:00:03.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.148113] pci 0000:01:00.0: BAR 0: assigned [mem 0x40800000-0x40ffffff]
[ 2.148127] pci 0000:01:00.0: BAR 3: assigned [mem 0x40400000-0x40403fff]
[ 2.148141] pci 0000:01:00.0: BAR 2: assigned [io 0x1000-0x101f]
[ 2.148157] pci 0000:00:03.0: PCI bridge to [bus 01]
[ 2.148162] pci 0000:00:03.0: bridge window [io 0x1000-0x1fff]
[ 2.148172] pci 0000:00:03.0: bridge window [mem 0x40400000-0x40ffffff]
[ 2.151312] pcieport 0000:00:03.0: Signaling PME through PCIe PME interrupt
[ 2.151316] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.151326] pcie_pme 0000:00:03.0:pcie001: service driver pcie_pme loaded
[ 2.151444] aer 0000:00:03.0:pcie002: service driver aer loaded
[ 3.329749] console [ttyS0] enabled
[ 3.330351] Console: switching to colour frame buffer device 80x30
[ 3.336019] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 3.341636] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 3.349434] serial-tegra 3130000.serial: RX in PIO mode
[ 3.350620] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 3.359113] [drm] Initialized
[ 3.375248] tegradc 15210000.nvdisplay: fb registered
[ 3.380863] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 3.386351] brd: module loaded
[ 3.394580] loop: module loaded
[ 3.397909] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.403819] tegra_profiler: auth: init
[ 3.408250] nct1008_nct72 7-004c: starting parse dt
[ 3.408513] THERMAL EST: found 3 subdevs
[ 3.408517] THERMAL EST num_resources: 0
[ 3.408521] [THERMAL EST subdev 0]
[ 3.408526] [THERMAL EST subdev 1]
[ 3.408530] [THERMAL EST subdev 2]
[ 3.408856] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 3.408858] THERMAL EST: thz register success.
[ 3.409030] THERMAL EST: end of probe, return err: 0
[ 3.410087] hisi_sas: driver version v1.6
[ 3.414820] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.414831] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.415911] scsi host0: tegra_ahci
[ 3.416877] scsi host1: tegra_ahci
[ 3.417071] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 3.417075] ata2: DUMMY
[ 3.423108] libphy: Fixed MDIO Bus: probed
[ 3.423507] tun: Universal TUN/TAP device driver, 1.6
[ 3.423509] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.425336] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.425339] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.425382] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.425384] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.425802] igb 0000:01:00.0: enabling device (0000 → 0002)
[ 3.484100] igb 0000:01:00.0 (unnamed net_device) (uninitialized): igb: eth%d NIC Link is Down
[ 3.485621] pps pps0: new PPS source ptp0
[ 3.485627] igb 0000:01:00.0: added PHC on eth0
[ 3.485632] igb 0000:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 3.485637] igb 0000:01:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 6c:61:74:75:6c:65
[ 3.485642] igb 0000:01:00.0: eth0: PBA No: FFFFFF-0FF
[ 3.485647] igb 0000:01:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 3.485981] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.485983] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.486043] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.486045] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.487586] eqos 2490000.ether_qos: no PHY interrupt found
[ 3.487795] eqos 2490000.ether_qos: can’t get pllrefe_vcoout clk (-2)
[ 3.492252] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a7 da 2f
[ 3.492399] libphy: dwc_phy: probed
[ 3.492790] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.495552] PPP generic driver version 2.4.2
[ 3.495780] PPP BSD Compression module registered
[ 3.495784] PPP Deflate Compression module registered
[ 3.495836] PPP MPPE Compression module registered
[ 3.495841] NET: Registered protocol family 24
[ 3.495930] usbcore: registered new interface driver r8152
[ 3.495973] usbcore: registered new interface driver asix
[ 3.496009] usbcore: registered new interface driver ax88179_178a
[ 3.496113] usbcore: registered new interface driver cdc_ether
[ 3.496203] usbcore: registered new interface driver net1080
[ 3.496300] usbcore: registered new interface driver cdc_subset
[ 3.496387] usbcore: registered new interface driver zaurus
[ 3.496480] usbcore: registered new interface driver cdc_ncm
[ 3.496768] VFIO - User Level meta-driver version: 0.3
[ 3.498756] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.498774] ehci-pci: EHCI PCI platform driver
[ 3.498869] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.498878] ohci-pci: OHCI PCI platform driver
[ 3.498966] ohci-platform: OHCI generic platform driver
[ 3.504800] tegra-xusb 3530000.xhci: No USB port has OTG_CAP
[ 3.506387] tegra-xusb 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 3.506392] tegra-xusb 3530000.xhci: Falling back to user helper
[ 3.506886] usbcore: registered new interface driver uas
[ 3.506935] usbcore: registered new interface driver usb-storage
[ 3.507109] usbcore: registered new interface driver usbserial
[ 3.510518] mousedev: PS/2 mouse device common for all mice
[ 3.510631] usbcore: registered new interface driver xpad
[ 3.644335] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.645916] Wake73 for irq=42
[ 3.647239] rtc rtc1: alarm rtc device
[ 3.647253] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.647280] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.647519] i2c /dev entries driver
[ 3.649753] tek.xing adv7180_probe
[ 3.649759] adv7180 2-0020: chip found @ 0x20 (3180000.i2c)
[ 3.649815] adv7180 2-0020: adv7180_parse_dt
[ 3.649824] adv7180 2-0020: mclk in DT extperiph1
[ 3.649829] adv7180 2-0020: adv7180_power_get
[ 3.649840] adv7180 2-0020: camera_common_parse_ports: port 0 num of lanes 1
[ 3.649857] adv7180 2-0020: parsing for mode0 props
[ 3.649912] adv7180 2-0020: adv7180_probe: name adv7180_a
[ 3.649917] adv7180 2-0020: camera_common_create_debugfs adv7180_a
[ 3.649934] adv7180 2-0020: tegracam sensor driver:adv7180_v2.0.6
[ 3.649938] adv7180 2-0020: adv7180_probe
[ 3.650085] tek.xing init_device line = 1270
[ 3.665852] adv7180 2-0020: adv7180_fill_string_ctrl
[ 3.665857] adv7180 2-0020: adv7180_fill_string_ctrl
[ 3.665861] adv7180 2-0020: adv7180_fill_string_ctrl
[ 3.668024] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.672923] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.673528] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 3.675040] parse_throttle_dt_data: Num cap clks = 4
[ 3.675044] parse_throttle_dt_data: clk=mcpu type=1
[ 3.675047] parse_throttle_dt_data: clk=bcpu type=2
[ 3.675057] parse_throttle_dt_data: clk=gpu type=4
[ 3.675060] parse_throttle_dt_data: clk=emc type=3
[ 3.676349] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.677024] FAN dev name: pwm-fan
[ 3.677088] FAN:gpio request success.
[ 3.677096] FAN: can’t find tach_gpio
[ 3.677130] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.677444] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 3.677449] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.677882] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.677888] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.677892] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.677896] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.677899] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.677903] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.677907] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.677911] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.677947] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.677952] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.680033] device-mapper: uevent: version 1.0.3
[ 3.680988] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.686809] cpufreq: platform driver Initialization: pass
[ 3.692197] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.692311] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.698561] sdhci: Secure Digital Host Controller Interface driver
[ 3.698564] sdhci: Copyright(c) Pierre Ossman
[ 3.698566] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.700073] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.702012] CMDQ: cmdq_platfm_init successful
[ 3.703259] CQE: CMD_TIMING bit set for R1B DCMD
[ 3.705227] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.710156] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.710196] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.710785] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.712491] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 256
[ 3.716986] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.717836] tegra-se-nvhost 15810000.se: initialized
[ 3.718924] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.719757] tegra-se-nvhost 15820000.se: initialized
[ 3.720922] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.721800] tegra-se-nvhost 15830000.se: initialized
[ 3.722482] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.723305] tegra-se-nvhost 15840000.se: initialized
[ 3.724305] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.724610] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.725788] usbcore: registered new interface driver usbhid
[ 3.725789] usbhid: USB HID core driver
[ 3.727965] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 3.727993] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 3.728089] ina3221x: probe of 0-0042 failed with error -121
[ 3.728317] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 3.728343] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 3.728491] ina3221x: probe of 0-0043 failed with error -121
[ 3.730849] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 3.735315] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.751232] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 3.751518] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.751639] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 3.751831] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 3.751897] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.752614] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 3.752682] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 3.752760] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 3.752808] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 3.752900] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 3.753928] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 3.753929] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.759959] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.763936] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 3.763981] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.801432] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 3.814969] mmc0: periodic cache flush enabled
[ 3.814982] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 3.815578] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.815767] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.816003] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.816301] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.819091] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31
[ 3.871666] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 3.873224] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 3.873639] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.873781] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.873846] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.874144] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874146] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 3.874148] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.874195] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874197] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 3.874198] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.874243] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874245] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 3.874246] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.874290] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874292] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 3.874293] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.874339] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874340] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 3.874342] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.874387] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874391] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 3.874392] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.874438] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874441] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 3.874443] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.874487] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874491] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 3.874492] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.874537] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874541] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 3.874542] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.874589] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874591] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 3.874592] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.874646] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874651] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 3.874652] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.874697] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874702] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 3.874703] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.874749] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874753] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 3.874755] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.874799] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874803] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 3.874804] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.874847] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 3.874851] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 3.874852] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.874902] **** A57 ECC: Enabled
[ 3.874904] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 3.874960] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.875583] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.876973] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.877151] denver_knobs_init:MTS_VERSION:43068234
[ 3.882792] nvpmodel: initialized successfully
[ 3.886109] usbcore: registered new interface driver snd-usb-audio
[ 3.899698] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 3.902048] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 3.983849] OPE platform probe
[ 3.983923] OPE platform probe successful
[ 3.994944] tegra-asoc: sound: This is a dummy codec
[ 4.032947] mmc1: Applying tuning correction
[ 4.032974] mmc1: Tap value after applying correction 67
[ 4.032980] mmc1: hw tuning done …
[ 4.039197] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.040740] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.040809] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.040874] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.040938] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.041003] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.041065] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.041131] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.041199] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.041263] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.041329] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.041394] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.041461] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.041527] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.041594] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.041659] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.041725] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.041791] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.041855] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.041920] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.041986] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.065641] u32 classifier
[ 4.065642] Actions configured
[ 4.065700] Initializing XFRM netlink socket
[ 4.066248] NET: Registered protocol family 10
[ 4.067450] NET: Registered protocol family 17
[ 4.067465] NET: Registered protocol family 15
[ 4.067673] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.067777] Bluetooth: RFCOMM socket layer initialized
[ 4.067788] Bluetooth: RFCOMM ver 1.11
[ 4.067815] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.067822] Bluetooth: HIDP socket layer initialized
[ 4.067841] 9pnet: Installing 9P2000 support
[ 4.067902] Key type dns_resolver registered
[ 4.069248] Registered cp15_barrier emulation handler
[ 4.069264] Registered setend emulation handler
[ 4.070132] registered taskstats version 1
[ 4.072977] isp 15600000.isp: initialized
[ 4.073051] tek.xing tegra_camera_device_register, ling = 720,
[ 4.073053] tek.xing tegra_camera_device_register, ling = 725,
[ 4.076781] nvcsi 150c0000.nvcsi: initialized
[ 4.076803] tek.xing tegra_camera_device_register, ling = 720,
[ 4.076804] tek.xing tegra_camera_device_register, ling = 725,
[ 4.080346] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 4.080414] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 4.080476] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 4.080602] input: gpio-keys as /devices/gpio-keys/input/input2
[ 4.081923] tegra-vi4 15700000.vi: initialized
[ 4.082683] tek.xing tegra_vi_get_port_info, ling = 463,
[ 4.082686] tek.xing tegra_vi_get_port_info, ling = 473,ret = 0
[ 4.082688] tek.xing tegra_vi_get_port_info, ling = 486,ret = 0
[ 4.082689] tek.xing tegra_vi_get_port_info, ling = 496,ret = 0
[ 4.082690] tek.xing tegra_vi_get_port_info, ling = 503,ret = 0
[ 4.082692] tek.xing tegra_vi_get_port_info, ling = 518,ret = 0
[ 4.082693] tek.xing tegra_vi_get_port_info, ling = 473,ret = 0
[ 4.082695] tek.xing tegra_vi_get_port_info, ling = 473,ret = 0
[ 4.082697] tek.xing tegra_vi_get_port_info, ling = 473,ret = 0
[ 4.082698] tek.xing tegra_vi_get_port_info, ling = 473,ret = 0
[ 4.082700] tek.xing tegra_vi_get_port_info, ling = 473,ret = 0
[ 4.082701] tek.xing tegra_vi_get_port_info, ling = 541,ret = 0
[ 4.082772] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi–1 bound
[ 4.082784] tegra-vi4 15700000.vi: subdev adv7180 2-0020 bound
[ 4.082925] adv7180 2-0020: camera_common_g_fmt++
[ 4.083007] tek.xing tegra_camera_device_register, ling = 720,
[ 4.083008] tek.xing tegra_camera_device_register, ling = 725,
[ 4.088631] tek.xing tegra_camera_device_register, ling = 720,
[ 4.088633] tek.xing tegra_camera_device_register, ling = 725,
[ 4.088637] tek.xing tegra_vi4_probe, ling = 370,err = 0
[ 4.116013] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:16 UTC (946688416)
[ 4.116913] mmcblk mmc0:0001: Card claimed for testing.
[ 4.145011] bpmp: mounted debugfs mirror
[ 4.146434] bwmgr: missing cdev-type property
[ 4.154107] spmic-ldo0: disabling
[ 4.154298] spmic-ldo1: disabling
[ 4.154462] en-vdd-sd: disabling
[ 4.154464] en-vdd-cam: disabling
[ 4.154466] vdd-usb0-5v: disabling
[ 4.154468] vdd-usb1-5v: disabling
[ 4.154470] en-vdd-disp-3v3: disabling
[ 4.154472] en-mdm-pwr-3v7: disabling
[ 4.154474] en-vdd-cam-hv-2v8: disabling
[ 4.154476] en-vdd-cam-1v2: disabling
[ 4.154478] vdd-fan: disabling
[ 4.154501] vdd-3v3: disabling
[ 4.154503] en-vdd-vcm-2v8: disabling
[ 4.154505] vdd-usb2-5v: disabling
[ 4.154507] vdd-sys-bl: disabling
[ 4.154510] en-vdd-sys: disabling
[ 4.154513] ALSA device list:
[ 4.154515] #0: tegra-hda at 0x3518000 irq 382
[ 4.154516] #1: tegra-snd-t186ref-mobile-rt565x
[ 5.291647] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 5.297753] nct1008_nct72 7-004c: success parsing dt
[ 5.302838] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 5.341601] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 5.347489] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 5.385661] nct1008_nct72 7-004c: initial LOC temp: 20000
[ 5.391514] nct1008_nct72 7-004c: initial EXT temp: 32500
[ 5.397692] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 5.402890] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 5.408346] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 5.808282] EXT4-fs (mmcblk0p1): 13 orphan inodes deleted
[ 5.813723] EXT4-fs (mmcblk0p1): recovery complete
[ 5.826733] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.834893] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.846718] devtmpfs: mounted
[ 5.851658] Freeing unused kernel memory: 8576K
[ 6.008692] systemd[1]: System time before build time, advancing clock.
[ 6.041344] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.090573] cgroup: cgroup2: unknown option “nsdelegate”
[ 6.118539] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 6.143178] systemd[1]: Detected architecture arm64.
[ 6.232207] systemd[1]: Set hostname to .
[ 6.334496] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 6.351612] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.548529] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.559106] systemd[1]: Created slice System Slice.
[ 6.564608] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.571569] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 6.578356] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.585377] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.591796] systemd[1]: Listening on Syslog Socket.
[ 6.597221] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.633631] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.701412] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 6.887261] systemd-journald[2284]: Received request to flush runtime journal from PID 1
[ 7.695900] random: crng init done
[ 7.699317] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.871741] adv7180 2-0020: adv7180_open:
[ 7.876082] adv7180 2-0020: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 7.876152] adv7180 2-0020: camera_common_dpd_disable: csi 0
[ 7.876157] adv7180 2-0020: adv7180_power_on
[ 7.947977] nvcsi 150c0000.nvcsi: settle time reading from props
[ 7.947986] nvcsi 150c0000.nvcsi: csi_port: 0
[ 7.956341] adv7180 2-0020: adv7180_power_off
[ 7.956415] adv7180 2-0020: camera_common_dpd_enable: csi 0
[ 7.956419] adv7180 2-0020: camera_common_mclk_disable: disable MCLK
[ 7.967701] tegra-xusb 3530000.xhci: cannot find firmware…retry after 1 second
[ 8.109739] dhd_module_init in
[ 8.109817] found wifi platform device bcmdhd_wlan
[ 8.110984] wifi_platform_get_country_code_map: could not get country_code_map
[ 8.110987] wifi_plat_dev_drv_probe:platform country code map is not available
[ 8.111002] Power-up adapter ‘DHD generic adapter’
[ 8.111010] wifi_platform_set_power = 1
[ 8.165135] tegra-i2c c240000.i2c: no acknowledge from address 0x69
[ 8.172647] bmi160 1-0069: bmi_i2c_rd ERR: 0x00
[ 8.177235] bmi160 1-0069: bmi_init _id_i2c ERR
[ 8.189057] bmi160 1-0069: bmi_remove
[ 8.189060] bmi160 1-0069: bmi_probe done
[ 8.316910] wifi_platform_bus_enumerate device present 1
[ 8.337173] wifi_platform_bus_enumerate device present 0
[ 8.338037] F1 signature read @0x18000000=0x17214354
[ 8.343788] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.344676] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.344761] wifi_platform_get_mac_addr
[ 8.349597] ids dhd_log_netlink_init
[ 8.349920] wl_create_event_handler(): thread:wl_event_handler:12ed started
[ 8.349921] wl_event_handler :
[ 8.349923] tsk Enter, tsk = 0xffffffc1d8fc1a90
[ 8.350958] dhd_attach(): thread:dhd_watchdog_thread:12ee started
[ 8.351266] dhd_attach(): thread:dhd_dpc:12f4 started
[ 8.351388] dhd_attach(): thread:dhd_rxf:12f8 started
[ 8.351393] dhd_deferred_work_init: work queue initialized
[ 8.352088]
Dongle Host Driver, version 1.201.82 (r)
Compiled from
[ 8.352433] Register interface [wlan0] MAC: 00:04:4b:a7:da:2d
[ 8.352437] dhd_prot_ioctl : bus is down. we have nothing to do
[ 8.352672] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 67
[ 8.353715] wifi_platform_set_power = 0
[ 8.626140] nvgpu: 17000000.gp10b railgate_enable_store:343 [INFO] railgate is disabled.
[ 8.986685] tegra-xusb 3530000.xhci: Firmware timestamp: 2018-12-26 10:30:04 UTC, Version: 55.12 release
[ 8.996059] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.039950] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 9.039980] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 9.040821] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 9.040859] tegra-xusb 3530000.xhci: irq 70, io mem 0x03530000
[ 9.040992] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.040997] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.041000] usb usb1: Product: xHCI Host Controller
[ 9.041003] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 9.041006] usb usb1: SerialNumber: 3530000.xhci
[ 9.041446] hub 1-0:1.0: USB hub found
[ 9.041475] hub 1-0:1.0: 4 ports detected
[ 9.041752] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 9.041760] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 9.041885] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 9.041888] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.041891] usb usb2: Product: xHCI Host Controller
[ 9.041894] usb usb2: Manufa
[code]root@tek-desktop:~# cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 804/804 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
    v4l2-ctl-7529  [000] ....   184.201566: tegra_channel_open: vi-output, adv7180 2-0020
    v4l2-ctl-7529  [000] ....   184.202579: tegra_channel_set_power: adv7180 2-0020 : 0x1
    v4l2-ctl-7529  [000] ....   184.202587: camera_common_s_power: status : 0x1
    v4l2-ctl-7529  [000] ....   184.202637: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
    v4l2-ctl-7529  [000] ....   184.202639: csi_s_power: enable : 0x1
    v4l2-ctl-7529  [005] ....   184.206649: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [004] … 184.207672: tegra_channel_set_stream: enable : 0x1
vi-output, adv7-7530 [003] … 184.213434: tegra_channel_set_stream: 150c0000.nvcsi–1 : 0x1
vi-output, adv7-7530 [003] … 184.213437: csi_s_stream: enable : 0x1
vi-output, adv7-7530 [003] … 184.213506: tegra_channel_set_stream: adv7180 2-0020 : 0x1
kworker/3:3-3808 [003] … 184.234943: rtos_queue_peek_from_isr_failed: tstamp:6138962459 queue:0x0b4b4500
kworker/3:3-3808 [003] … 184.234947: rtcpu_start: tstamp:6138963815
kworker/3:3-3808 [003] … 184.234950: rtos_queue_send_from_isr_failed: tstamp:6138972656 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.234951: rtos_queue_send_from_isr_failed: tstamp:6138972773 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.234952: rtos_queue_send_from_isr_failed: tstamp:6138972882 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.234953: rtos_queue_send_from_isr_failed: tstamp:6138972988 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.234955: rtos_queue_send_from_isr_failed: tstamp:6138973092 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.234956: rtos_queue_send_from_isr_failed: tstamp:6138973194 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.234957: rtos_queue_send_from_isr_failed: tstamp:6138973299 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.234958: rtos_queue_send_from_isr_failed: tstamp:6138973404 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.234961: rtos_queue_send_failed: tstamp:6138973910 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.234962: rtos_queue_send_from_isr_failed: tstamp:6138976009 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.234963: rtos_queue_send_from_isr_failed: tstamp:6138976115 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.234964: rtos_queue_send_from_isr_failed: tstamp:6138976222 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.234965: rtos_queue_send_from_isr_failed: tstamp:6138976328 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.234966: rtos_queue_send_from_isr_failed: tstamp:6138976436 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.234967: rtos_queue_send_from_isr_failed: tstamp:6138976541 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.234968: rtos_queue_send_from_isr_failed: tstamp:6138976645 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.234969: rtos_queue_send_from_isr_failed: tstamp:6138976748 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.234970: rtos_queue_send_failed: tstamp:6138977734 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.402928: rtos_queue_peek_from_isr_failed: tstamp:6143962837 queue:0x0b4b4500
vi-output, adv7-7530 [000] … 184.432031: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [000] … 184.432069: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 184.458902: rtos_queue_send_from_isr_failed: tstamp:6145994444 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.458907: rtos_queue_send_from_isr_failed: tstamp:6145994591 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.458908: rtos_queue_send_from_isr_failed: tstamp:6145994731 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.458910: rtos_queue_send_from_isr_failed: tstamp:6145994870 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.458912: rtos_queue_send_from_isr_failed: tstamp:6145995007 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.458914: rtos_queue_send_from_isr_failed: tstamp:6145995146 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.458915: rtos_queue_send_from_isr_failed: tstamp:6145995283 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.458917: rtos_queue_send_from_isr_failed: tstamp:6145995425 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.458921: rtos_queue_send_failed: tstamp:6145996139 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.458922: rtos_queue_send_from_isr_failed: tstamp:6146000115 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.458924: rtos_queue_send_from_isr_failed: tstamp:6146000255 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.458926: rtos_queue_send_from_isr_failed: tstamp:6146000396 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.458928: rtos_queue_send_from_isr_failed: tstamp:6146000536 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.458930: rtos_queue_send_from_isr_failed: tstamp:6146000675 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.458932: rtos_queue_send_from_isr_failed: tstamp:6146000812 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.458934: rtos_queue_send_from_isr_failed: tstamp:6146000959 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.458936: rtos_queue_send_from_isr_failed: tstamp:6146001095 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.458937: rtos_queue_send_failed: tstamp:6146001664 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.458939: rtos_queue_send_from_isr_failed: tstamp:6146011519 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.458941: rtos_queue_send_from_isr_failed: tstamp:6146011658 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.458943: rtos_queue_send_from_isr_failed: tstamp:6146011797 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.458945: rtos_queue_send_from_isr_failed: tstamp:6146011935 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.458946: rtos_queue_send_from_isr_failed: tstamp:6146012078 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.458948: rtos_queue_send_from_isr_failed: tstamp:6146012215 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.458950: rtos_queue_send_from_isr_failed: tstamp:6146012353 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.458952: rtos_queue_send_from_isr_failed: tstamp:6146012490 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.458954: rtos_queue_send_failed: tstamp:6146013104 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.458955: rtos_queue_send_from_isr_failed: tstamp:6146016740 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.458957: rtos_queue_send_from_isr_failed: tstamp:6146016878 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.458959: rtos_queue_send_from_isr_failed: tstamp:6146017018 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.458961: rtos_queue_send_from_isr_failed: tstamp:6146017158 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.458962: rtos_queue_send_from_isr_failed: tstamp:6146017302 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.458964: rtos_queue_send_from_isr_failed: tstamp:6146017440 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.458966: rtos_queue_send_from_isr_failed: tstamp:6146017577 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.458968: rtos_queue_send_from_isr_failed: tstamp:6146017715 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.458970: rtos_queue_send_failed: tstamp:6146019116 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.570988: rtos_queue_peek_from_isr_failed: tstamp:6148962837 queue:0x0b4b4500
vi-output, adv7-7530 [000] … 184.651863: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [000] … 184.651900: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 184.682935: rtos_queue_send_from_isr_failed: tstamp:6152868707 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.682944: rtos_queue_send_from_isr_failed: tstamp:6152868854 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.682946: rtos_queue_send_from_isr_failed: tstamp:6152868994 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.682948: rtos_queue_send_from_isr_failed: tstamp:6152869134 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.682951: rtos_queue_send_from_isr_failed: tstamp:6152869271 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.682953: rtos_queue_send_from_isr_failed: tstamp:6152869410 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.682955: rtos_queue_send_from_isr_failed: tstamp:6152869546 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.682958: rtos_queue_send_from_isr_failed: tstamp:6152869684 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.682962: rtos_queue_send_failed: tstamp:6152870442 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.682965: rtos_queue_send_from_isr_failed: tstamp:6152874258 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.682967: rtos_queue_send_from_isr_failed: tstamp:6152874402 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.682970: rtos_queue_send_from_isr_failed: tstamp:6152874541 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.682972: rtos_queue_send_from_isr_failed: tstamp:6152874681 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.682974: rtos_queue_send_from_isr_failed: tstamp:6152874817 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.682977: rtos_queue_send_from_isr_failed: tstamp:6152874955 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.682979: rtos_queue_send_from_isr_failed: tstamp:6152875113 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.682982: rtos_queue_send_from_isr_failed: tstamp:6152875250 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.682984: rtos_queue_send_failed: tstamp:6152875821 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.682987: rtos_queue_send_from_isr_failed: tstamp:6152883431 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.682989: rtos_queue_send_from_isr_failed: tstamp:6152883570 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.682991: rtos_queue_send_from_isr_failed: tstamp:6152883709 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.682994: rtos_queue_send_from_isr_failed: tstamp:6152883847 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.682996: rtos_queue_send_from_isr_failed: tstamp:6152883987 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.682999: rtos_queue_send_from_isr_failed: tstamp:6152884125 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.683001: rtos_queue_send_from_isr_failed: tstamp:6152884262 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.683003: rtos_queue_send_from_isr_failed: tstamp:6152884401 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.683006: rtos_queue_send_failed: tstamp:6152884996 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.683008: rtos_queue_send_from_isr_failed: tstamp:6152887531 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.683011: rtos_queue_send_from_isr_failed: tstamp:6152887674 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.683013: rtos_queue_send_from_isr_failed: tstamp:6152887813 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.683015: rtos_queue_send_from_isr_failed: tstamp:6152887951 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.683018: rtos_queue_send_from_isr_failed: tstamp:6152888089 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.683020: rtos_queue_send_from_isr_failed: tstamp:6152888225 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.683022: rtos_queue_send_from_isr_failed: tstamp:6152888362 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.683025: rtos_queue_send_from_isr_failed: tstamp:6152888506 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.683027: rtos_queue_send_failed: tstamp:6152889842 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.738933: rtos_queue_peek_from_isr_failed: tstamp:6153962874 queue:0x0b4b4500
kworker/3:3-3808 [003] … 184.850943: rtos_queue_peek_from_isr_failed: tstamp:6158962852 queue:0x0b4b4500
vi-output, adv7-7530 [000] … 184.871803: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [000] … 184.871846: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 184.906953: rtos_queue_send_from_isr_failed: tstamp:6159741524 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.906959: rtos_queue_send_from_isr_failed: tstamp:6159741666 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.906961: rtos_queue_send_from_isr_failed: tstamp:6159741825 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.906964: rtos_queue_send_from_isr_failed: tstamp:6159741964 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.906966: rtos_queue_send_from_isr_failed: tstamp:6159742110 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.906968: rtos_queue_send_from_isr_failed: tstamp:6159742248 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.906971: rtos_queue_send_from_isr_failed: tstamp:6159742385 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.906973: rtos_queue_send_from_isr_failed: tstamp:6159742523 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.906977: rtos_queue_send_failed: tstamp:6159743236 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.906979: rtos_queue_send_from_isr_failed: tstamp:6159747466 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.906982: rtos_queue_send_from_isr_failed: tstamp:6159747606 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.906984: rtos_queue_send_from_isr_failed: tstamp:6159747744 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.906986: rtos_queue_send_from_isr_failed: tstamp:6159747891 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.906989: rtos_queue_send_from_isr_failed: tstamp:6159748027 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.906991: rtos_queue_send_from_isr_failed: tstamp:6159748165 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.906993: rtos_queue_send_from_isr_failed: tstamp:6159748302 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.906996: rtos_queue_send_from_isr_failed: tstamp:6159748439 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.906998: rtos_queue_send_failed: tstamp:6159749010 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.907001: rtos_queue_send_from_isr_failed: tstamp:6159756899 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.907003: rtos_queue_send_from_isr_failed: tstamp:6159757038 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.907006: rtos_queue_send_from_isr_failed: tstamp:6159757180 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.907009: rtos_queue_send_from_isr_failed: tstamp:6159757319 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.907011: rtos_queue_send_from_isr_failed: tstamp:6159757455 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.907013: rtos_queue_send_from_isr_failed: tstamp:6159757593 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.907016: rtos_queue_send_from_isr_failed: tstamp:6159757729 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.907018: rtos_queue_send_from_isr_failed: tstamp:6159757866 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.907020: rtos_queue_send_failed: tstamp:6159758424 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.907023: rtos_queue_send_from_isr_failed: tstamp:6159760711 queue:0x0b4a7258
kworker/3:3-3808 [003] … 184.907025: rtos_queue_send_from_isr_failed: tstamp:6159760851 queue:0x0b4aad68
kworker/3:3-3808 [003] … 184.907027: rtos_queue_send_from_isr_failed: tstamp:6159760990 queue:0x0b4ac998
kworker/3:3-3808 [003] … 184.907030: rtos_queue_send_from_isr_failed: tstamp:6159761129 queue:0x0b4ae518
kworker/3:3-3808 [003] … 184.907032: rtos_queue_send_from_isr_failed: tstamp:6159761266 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 184.907035: rtos_queue_send_from_isr_failed: tstamp:6159761404 queue:0x0b4b0098
kworker/3:3-3808 [003] … 184.907037: rtos_queue_send_from_isr_failed: tstamp:6159761541 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 184.907039: rtos_queue_send_from_isr_failed: tstamp:6159761677 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 184.907042: rtos_queue_send_failed: tstamp:6159763089 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.018964: rtos_queue_peek_from_isr_failed: tstamp:6163962871 queue:0x0b4b4500
vi-output, adv7-7530 [005] … 185.091840: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [005] … 185.091878: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 185.130900: rtos_queue_send_from_isr_failed: tstamp:6166616775 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.130905: rtos_queue_send_from_isr_failed: tstamp:6166616918 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.130907: rtos_queue_send_from_isr_failed: tstamp:6166617059 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.130909: rtos_queue_send_from_isr_failed: tstamp:6166617198 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.130910: rtos_queue_send_from_isr_failed: tstamp:6166617352 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.130912: rtos_queue_send_from_isr_failed: tstamp:6166617490 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.130913: rtos_queue_send_from_isr_failed: tstamp:6166617635 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.130915: rtos_queue_send_from_isr_failed: tstamp:6166617772 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.130921: rtos_queue_send_failed: tstamp:6166618524 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.130922: rtos_queue_send_from_isr_failed: tstamp:6166622867 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.130924: rtos_queue_send_from_isr_failed: tstamp:6166623024 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.130926: rtos_queue_send_from_isr_failed: tstamp:6166623164 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.130927: rtos_queue_send_from_isr_failed: tstamp:6166623304 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.130929: rtos_queue_send_from_isr_failed: tstamp:6166623441 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.130930: rtos_queue_send_from_isr_failed: tstamp:6166623579 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.130932: rtos_queue_send_from_isr_failed: tstamp:6166623720 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.130934: rtos_queue_send_from_isr_failed: tstamp:6166623858 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.130935: rtos_queue_send_failed: tstamp:6166624427 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.130936: rtos_queue_send_from_isr_failed: tstamp:6166632649 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.130938: rtos_queue_send_from_isr_failed: tstamp:6166632788 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.130939: rtos_queue_send_from_isr_failed: tstamp:6166632927 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.130941: rtos_queue_send_from_isr_failed: tstamp:6166633065 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.130942: rtos_queue_send_from_isr_failed: tstamp:6166633203 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.130944: rtos_queue_send_from_isr_failed: tstamp:6166633339 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.130945: rtos_queue_send_from_isr_failed: tstamp:6166633476 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.130947: rtos_queue_send_from_isr_failed: tstamp:6166633614 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.130948: rtos_queue_send_failed: tstamp:6166634196 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.130950: rtos_queue_send_from_isr_failed: tstamp:6166636513 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.130951: rtos_queue_send_from_isr_failed: tstamp:6166636656 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.130953: rtos_queue_send_from_isr_failed: tstamp:6166636814 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.130954: rtos_queue_send_from_isr_failed: tstamp:6166636954 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.130956: rtos_queue_send_from_isr_failed: tstamp:6166637101 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.130957: rtos_queue_send_from_isr_failed: tstamp:6166637238 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.130959: rtos_queue_send_from_isr_failed: tstamp:6166637374 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.130960: rtos_queue_send_from_isr_failed: tstamp:6166637512 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.130962: rtos_queue_send_failed: tstamp:6166638906 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.186906: rtos_queue_peek_from_isr_failed: tstamp:6168962872 queue:0x0b4b4500
vi-output, adv7-7530 [005] … 185.312120: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [005] … 185.312158: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 185.354936: rtos_queue_send_from_isr_failed: tstamp:6173491953 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.354945: rtos_queue_send_from_isr_failed: tstamp:6173492095 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.354948: rtos_queue_send_from_isr_failed: tstamp:6173492235 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.354951: rtos_queue_send_from_isr_failed: tstamp:6173492375 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.354954: rtos_queue_send_from_isr_failed: tstamp:6173492512 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.354956: rtos_queue_send_from_isr_failed: tstamp:6173492648 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.354959: rtos_queue_send_from_isr_failed: tstamp:6173492786 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.354961: rtos_queue_send_from_isr_failed: tstamp:6173492923 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.354965: rtos_queue_send_failed: tstamp:6173493635 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.354967: rtos_queue_send_from_isr_failed: tstamp:6173502145 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.354970: rtos_queue_send_from_isr_failed: tstamp:6173502308 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.354972: rtos_queue_send_from_isr_failed: tstamp:6173502446 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.354974: rtos_queue_send_from_isr_failed: tstamp:6173502586 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.354977: rtos_queue_send_from_isr_failed: tstamp:6173502725 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.354979: rtos_queue_send_from_isr_failed: tstamp:6173502862 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.354981: rtos_queue_send_from_isr_failed: tstamp:6173503000 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.354984: rtos_queue_send_from_isr_failed: tstamp:6173503139 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.354986: rtos_queue_send_failed: tstamp:6173503696 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.354989: rtos_queue_send_from_isr_failed: tstamp:6173515170 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.354991: rtos_queue_send_from_isr_failed: tstamp:6173515314 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.354994: rtos_queue_send_from_isr_failed: tstamp:6173515454 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.354996: rtos_queue_send_from_isr_failed: tstamp:6173515594 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.354998: rtos_queue_send_from_isr_failed: tstamp:6173515732 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.355001: rtos_queue_send_from_isr_failed: tstamp:6173515869 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.355003: rtos_queue_send_from_isr_failed: tstamp:6173516007 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.355005: rtos_queue_send_from_isr_failed: tstamp:6173516149 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.355008: rtos_queue_send_failed: tstamp:6173516723 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.355010: rtos_queue_send_from_isr_failed: tstamp:6173519824 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.355013: rtos_queue_send_from_isr_failed: tstamp:6173519963 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.355015: rtos_queue_send_from_isr_failed: tstamp:6173520103 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.355017: rtos_queue_send_from_isr_failed: tstamp:6173520242 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.355020: rtos_queue_send_from_isr_failed: tstamp:6173520378 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.355022: rtos_queue_send_from_isr_failed: tstamp:6173520515 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.355024: rtos_queue_send_from_isr_failed: tstamp:6173520653 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.355027: rtos_queue_send_from_isr_failed: tstamp:6173520789 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.355029: rtos_queue_send_failed: tstamp:6173522163 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.355032: rtos_queue_peek_from_isr_failed: tstamp:6173962856 queue:0x0b4b4500
kworker/3:3-3808 [003] … 185.522891: rtos_queue_peek_from_isr_failed: tstamp:6178962879 queue:0x0b4b4500
vi-output, adv7-7530 [000] … 185.531913: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [000] … 185.531954: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 185.578948: rtos_queue_send_from_isr_failed: tstamp:6180368000 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.578956: rtos_queue_send_from_isr_failed: tstamp:6180368142 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.578960: rtos_queue_send_from_isr_failed: tstamp:6180368283 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.578963: rtos_queue_send_from_isr_failed: tstamp:6180368422 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.578965: rtos_queue_send_from_isr_failed: tstamp:6180368559 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.578967: rtos_queue_send_from_isr_failed: tstamp:6180368698 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.578970: rtos_queue_send_from_isr_failed: tstamp:6180368834 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.578973: rtos_queue_send_from_isr_failed: tstamp:6180368972 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.578976: rtos_queue_send_failed: tstamp:6180369682 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.578978: rtos_queue_send_from_isr_failed: tstamp:6180373523 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.578981: rtos_queue_send_from_isr_failed: tstamp:6180373663 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.578983: rtos_queue_send_from_isr_failed: tstamp:6180373802 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.578985: rtos_queue_send_from_isr_failed: tstamp:6180373942 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.578988: rtos_queue_send_from_isr_failed: tstamp:6180374079 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.578991: rtos_queue_send_from_isr_failed: tstamp:6180374218 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.578993: rtos_queue_send_from_isr_failed: tstamp:6180374357 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.578995: rtos_queue_send_from_isr_failed: tstamp:6180374493 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.578998: rtos_queue_send_failed: tstamp:6180375052 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.579000: rtos_queue_send_from_isr_failed: tstamp:6180384599 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.579002: rtos_queue_send_from_isr_failed: tstamp:6180384739 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.579005: rtos_queue_send_from_isr_failed: tstamp:6180384900 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.579008: rtos_queue_send_from_isr_failed: tstamp:6180385041 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.579010: rtos_queue_send_from_isr_failed: tstamp:6180385179 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.579012: rtos_queue_send_from_isr_failed: tstamp:6180385316 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.579015: rtos_queue_send_from_isr_failed: tstamp:6180385454 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.579017: rtos_queue_send_from_isr_failed: tstamp:6180385590 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.579019: rtos_queue_send_failed: tstamp:6180386151 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.579022: rtos_queue_send_from_isr_failed: tstamp:6180388698 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.579024: rtos_queue_send_from_isr_failed: tstamp:6180388837 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.579027: rtos_queue_send_from_isr_failed: tstamp:6180388974 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.579029: rtos_queue_send_from_isr_failed: tstamp:6180389113 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.579031: rtos_queue_send_from_isr_failed: tstamp:6180389250 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.579034: rtos_queue_send_from_isr_failed: tstamp:6180389388 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.579036: rtos_queue_send_from_isr_failed: tstamp:6180389525 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.579038: rtos_queue_send_from_isr_failed: tstamp:6180389663 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.579041: rtos_queue_send_failed: tstamp:6180391098 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.690933: rtos_queue_peek_from_isr_failed: tstamp:6183962919 queue:0x0b4b4500
vi-output, adv7-7530 [005] … 185.752116: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [005] … 185.752155: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 185.802990: rtos_queue_send_from_isr_failed: tstamp:6187247196 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.802998: rtos_queue_send_from_isr_failed: tstamp:6187247346 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.803001: rtos_queue_send_from_isr_failed: tstamp:6187247489 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.803003: rtos_queue_send_from_isr_failed: tstamp:6187247629 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.803006: rtos_queue_send_from_isr_failed: tstamp:6187247768 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.803008: rtos_queue_send_from_isr_failed: tstamp:6187247905 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.803010: rtos_queue_send_from_isr_failed: tstamp:6187248045 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.803013: rtos_queue_send_from_isr_failed: tstamp:6187248184 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.803018: rtos_queue_send_failed: tstamp:6187248931 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.803020: rtos_queue_send_from_isr_failed: tstamp:6187253564 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.803023: rtos_queue_send_from_isr_failed: tstamp:6187253702 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.803025: rtos_queue_send_from_isr_failed: tstamp:6187253841 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.803028: rtos_queue_send_from_isr_failed: tstamp:6187253981 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.803030: rtos_queue_send_from_isr_failed: tstamp:6187254120 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.803032: rtos_queue_send_from_isr_failed: tstamp:6187254257 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.803035: rtos_queue_send_from_isr_failed: tstamp:6187254399 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.803037: rtos_queue_send_from_isr_failed: tstamp:6187254536 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.803040: rtos_queue_send_failed: tstamp:6187255103 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.803042: rtos_queue_send_from_isr_failed: tstamp:6187265173 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.803045: rtos_queue_send_from_isr_failed: tstamp:6187265312 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.803047: rtos_queue_send_from_isr_failed: tstamp:6187265471 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.803049: rtos_queue_send_from_isr_failed: tstamp:6187265611 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.803052: rtos_queue_send_from_isr_failed: tstamp:6187265749 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.803054: rtos_queue_send_from_isr_failed: tstamp:6187265885 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.803056: rtos_queue_send_from_isr_failed: tstamp:6187266022 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.803059: rtos_queue_send_from_isr_failed: tstamp:6187266160 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.803061: rtos_queue_send_failed: tstamp:6187266748 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.803063: rtos_queue_send_from_isr_failed: tstamp:6187269851 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.803066: rtos_queue_send_from_isr_failed: tstamp:6187269991 queue:0x0b4aad68
kworker/3:3-3808 [003] … 185.803068: rtos_queue_send_from_isr_failed: tstamp:6187270130 queue:0x0b4ac998
kworker/3:3-3808 [003] … 185.803071: rtos_queue_send_from_isr_failed: tstamp:6187270269 queue:0x0b4ae518
kworker/3:3-3808 [003] … 185.803073: rtos_queue_send_from_isr_failed: tstamp:6187270410 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 185.803076: rtos_queue_send_from_isr_failed: tstamp:6187270549 queue:0x0b4b0098
kworker/3:3-3808 [003] … 185.803078: rtos_queue_send_from_isr_failed: tstamp:6187270686 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 185.803080: rtos_queue_send_from_isr_failed: tstamp:6187270824 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 185.803083: rtos_queue_send_failed: tstamp:6187272238 queue:0x0b4a7258
kworker/3:3-3808 [003] … 185.858950: rtos_queue_peek_from_isr_failed: tstamp:6188962908 queue:0x0b4b4500
kworker/3:3-3808 [003] … 185.970884: rtos_queue_peek_from_isr_failed: tstamp:6193962902 queue:0x0b4b4500
vi-output, adv7-7530 [005] … 185.971831: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [005] … 185.971866: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 186.026983: rtos_queue_send_from_isr_failed: tstamp:6194117091 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.026991: rtos_queue_send_from_isr_failed: tstamp:6194117234 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.026993: rtos_queue_send_from_isr_failed: tstamp:6194117375 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.026999: rtos_queue_send_from_isr_failed: tstamp:6194117516 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.027002: rtos_queue_send_from_isr_failed: tstamp:6194117653 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.027005: rtos_queue_send_from_isr_failed: tstamp:6194117790 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.027008: rtos_queue_send_from_isr_failed: tstamp:6194117929 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.027010: rtos_queue_send_from_isr_failed: tstamp:6194118066 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.027014: rtos_queue_send_failed: tstamp:6194118829 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.027016: rtos_queue_send_from_isr_failed: tstamp:6194123033 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.027019: rtos_queue_send_from_isr_failed: tstamp:6194123171 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.027021: rtos_queue_send_from_isr_failed: tstamp:6194123310 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.027023: rtos_queue_send_from_isr_failed: tstamp:6194123450 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.027026: rtos_queue_send_from_isr_failed: tstamp:6194123588 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.027028: rtos_queue_send_from_isr_failed: tstamp:6194123747 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.027031: rtos_queue_send_from_isr_failed: tstamp:6194123886 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.027033: rtos_queue_send_from_isr_failed: tstamp:6194124023 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.027035: rtos_queue_send_failed: tstamp:6194124580 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.027038: rtos_queue_send_from_isr_failed: tstamp:6194133234 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.027040: rtos_queue_send_from_isr_failed: tstamp:6194133389 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.027042: rtos_queue_send_from_isr_failed: tstamp:6194133529 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.027045: rtos_queue_send_from_isr_failed: tstamp:6194133669 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.027047: rtos_queue_send_from_isr_failed: tstamp:6194133807 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.027049: rtos_queue_send_from_isr_failed: tstamp:6194133944 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.027052: rtos_queue_send_from_isr_failed: tstamp:6194134083 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.027055: rtos_queue_send_from_isr_failed: tstamp:6194134227 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.027057: rtos_queue_send_failed: tstamp:6194134784 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.027059: rtos_queue_send_from_isr_failed: tstamp:6194136990 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.027062: rtos_queue_send_from_isr_failed: tstamp:6194137130 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.027064: rtos_queue_send_from_isr_failed: tstamp:6194137269 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.027066: rtos_queue_send_from_isr_failed: tstamp:6194137408 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.027069: rtos_queue_send_from_isr_failed: tstamp:6194137544 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.027071: rtos_queue_send_from_isr_failed: tstamp:6194137681 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.027074: rtos_queue_send_from_isr_failed: tstamp:6194137824 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.027076: rtos_queue_send_from_isr_failed: tstamp:6194137961 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.027078: rtos_queue_send_failed: tstamp:6194139345 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.138973: rtos_queue_peek_from_isr_failed: tstamp:6198962898 queue:0x0b4b4500
vi-output, adv7-7530 [004] … 186.192064: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [004] … 186.192102: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 186.194907: rtos_queue_send_from_isr_failed: tstamp:6200995607 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.194911: rtos_queue_send_from_isr_failed: tstamp:6200995754 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.194913: rtos_queue_send_from_isr_failed: tstamp:6200995894 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.194915: rtos_queue_send_from_isr_failed: tstamp:6200996034 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.194916: rtos_queue_send_from_isr_failed: tstamp:6200996175 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.194917: rtos_queue_send_from_isr_failed: tstamp:6200996314 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.194918: rtos_queue_send_from_isr_failed: tstamp:6200996453 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.194919: rtos_queue_send_from_isr_failed: tstamp:6200996590 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.194922: rtos_queue_send_failed: tstamp:6200997401 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.194923: rtos_queue_send_from_isr_failed: tstamp:6201004530 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.194925: rtos_queue_send_from_isr_failed: tstamp:6201004668 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.194926: rtos_queue_send_from_isr_failed: tstamp:6201004807 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.194927: rtos_queue_send_from_isr_failed: tstamp:6201004947 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.194928: rtos_queue_send_from_isr_failed: tstamp:6201005086 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.194930: rtos_queue_send_from_isr_failed: tstamp:6201005223 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.194931: rtos_queue_send_from_isr_failed: tstamp:6201005361 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.194932: rtos_queue_send_from_isr_failed: tstamp:6201005498 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.194933: rtos_queue_send_failed: tstamp:6201006053 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.194934: rtos_queue_send_from_isr_failed: tstamp:6201014916 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.194935: rtos_queue_send_from_isr_failed: tstamp:6201015055 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.194937: rtos_queue_send_from_isr_failed: tstamp:6201015197 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.194938: rtos_queue_send_from_isr_failed: tstamp:6201015336 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.194939: rtos_queue_send_from_isr_failed: tstamp:6201015474 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.194940: rtos_queue_send_from_isr_failed: tstamp:6201015610 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.194941: rtos_queue_send_from_isr_failed: tstamp:6201015747 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.194943: rtos_queue_send_from_isr_failed: tstamp:6201015885 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.194944: rtos_queue_send_failed: tstamp:6201016468 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.194945: rtos_queue_send_from_isr_failed: tstamp:6201018750 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.194946: rtos_queue_send_from_isr_failed: tstamp:6201018890 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.194947: rtos_queue_send_from_isr_failed: tstamp:6201019029 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.194948: rtos_queue_send_from_isr_failed: tstamp:6201019168 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.194950: rtos_queue_send_from_isr_failed: tstamp:6201019305 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.194951: rtos_queue_send_from_isr_failed: tstamp:6201019443 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.194952: rtos_queue_send_from_isr_failed: tstamp:6201019580 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.194953: rtos_queue_send_from_isr_failed: tstamp:6201019718 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.194954: rtos_queue_send_failed: tstamp:6201021103 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.306939: rtos_queue_peek_from_isr_failed: tstamp:6203962921 queue:0x0b4b4500
vi-output, adv7-7530 [004] … 186.411748: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [004] … 186.411783: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 186.418859: rtos_queue_send_from_isr_failed: tstamp:6207865616 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.418863: rtos_queue_send_from_isr_failed: tstamp:6207865757 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.418865: rtos_queue_send_from_isr_failed: tstamp:6207865897 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.418866: rtos_queue_send_from_isr_failed: tstamp:6207866040 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.418867: rtos_queue_send_from_isr_failed: tstamp:6207866178 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.418868: rtos_queue_send_from_isr_failed: tstamp:6207866316 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.418869: rtos_queue_send_from_isr_failed: tstamp:6207866453 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.418870: rtos_queue_send_from_isr_failed: tstamp:6207866591 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.418873: rtos_queue_send_failed: tstamp:6207867297 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.418874: rtos_queue_send_from_isr_failed: tstamp:6207870096 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.418875: rtos_queue_send_from_isr_failed: tstamp:6207870234 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.418876: rtos_queue_send_from_isr_failed: tstamp:6207870373 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.418877: rtos_queue_send_from_isr_failed: tstamp:6207870513 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.418878: rtos_queue_send_from_isr_failed: tstamp:6207870652 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.418879: rtos_queue_send_from_isr_failed: tstamp:6207870789 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.418881: rtos_queue_send_from_isr_failed: tstamp:6207870931 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.418882: rtos_queue_send_from_isr_failed: tstamp:6207871067 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.418883: rtos_queue_send_failed: tstamp:6207871650 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.418884: rtos_queue_send_from_isr_failed: tstamp:6207879179 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.418885: rtos_queue_send_from_isr_failed: tstamp:6207879319 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.418886: rtos_queue_send_from_isr_failed: tstamp:6207879459 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.418887: rtos_queue_send_from_isr_failed: tstamp:6207879599 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.418888: rtos_queue_send_from_isr_failed: tstamp:6207879736 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.418889: rtos_queue_send_from_isr_failed: tstamp:6207879874 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.418890: rtos_queue_send_from_isr_failed: tstamp:6207880011 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.418891: rtos_queue_send_from_isr_failed: tstamp:6207880151 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.418892: rtos_queue_send_failed: tstamp:6207880717 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.418893: rtos_queue_send_from_isr_failed: tstamp:6207883896 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.418894: rtos_queue_send_from_isr_failed: tstamp:6207884036 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.418896: rtos_queue_send_from_isr_failed: tstamp:6207884175 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.418897: rtos_queue_send_from_isr_failed: tstamp:6207884314 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.418898: rtos_queue_send_from_isr_failed: tstamp:6207884455 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.418899: rtos_queue_send_from_isr_failed: tstamp:6207884591 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.418900: rtos_queue_send_from_isr_failed: tstamp:6207884730 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.418901: rtos_queue_send_from_isr_failed: tstamp:6207884867 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.418902: rtos_queue_send_failed: tstamp:6207886221 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.474933: rtos_queue_peek_from_isr_failed: tstamp:6208962945 queue:0x0b4b4500
kworker/3:3-3808 [003] … 186.642849: rtos_queue_peek_from_isr_failed: tstamp:6213962929 queue:0x0b4b4500
kworker/3:3-3808 [003] … 186.642855: rtos_queue_send_from_isr_failed: tstamp:6214741060 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.642856: rtos_queue_send_from_isr_failed: tstamp:6214741201 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.642857: rtos_queue_send_from_isr_failed: tstamp:6214741342 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.642858: rtos_queue_send_from_isr_failed: tstamp:6214741481 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.642860: rtos_queue_send_from_isr_failed: tstamp:6214741617 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.642861: rtos_queue_send_from_isr_failed: tstamp:6214741755 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.642862: rtos_queue_send_from_isr_failed: tstamp:6214741893 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.642863: rtos_queue_send_from_isr_failed: tstamp:6214742031 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.642865: rtos_queue_send_failed: tstamp:6214742762 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.642866: rtos_queue_send_from_isr_failed: tstamp:6214745109 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.642867: rtos_queue_send_from_isr_failed: tstamp:6214745248 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.642868: rtos_queue_send_from_isr_failed: tstamp:6214745387 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.642869: rtos_queue_send_from_isr_failed: tstamp:6214745525 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.642870: rtos_queue_send_from_isr_failed: tstamp:6214745663 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.642871: rtos_queue_send_from_isr_failed: tstamp:6214745800 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.642872: rtos_queue_send_from_isr_failed: tstamp:6214745938 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.642873: rtos_queue_send_from_isr_failed: tstamp:6214746075 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.642874: rtos_queue_send_failed: tstamp:6214746669 queue:0x0b4a7258
vi-output, adv7-7530 [005] … 186.665232: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [005] … 186.665260: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 186.698831: rtos_queue_send_from_isr_failed: tstamp:6215804354 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.698833: rtos_queue_send_from_isr_failed: tstamp:6215804460 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.698834: rtos_queue_send_from_isr_failed: tstamp:6215804566 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.698835: rtos_queue_send_from_isr_failed: tstamp:6215804674 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.698837: rtos_queue_send_from_isr_failed: tstamp:6215804779 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.698838: rtos_queue_send_from_isr_failed: tstamp:6215804883 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.698839: rtos_queue_send_from_isr_failed: tstamp:6215804986 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.698840: rtos_queue_send_from_isr_failed: tstamp:6215805094 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.698841: rtos_queue_send_failed: tstamp:6215805530 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.698842: rtos_queue_send_from_isr_failed: tstamp:6215807117 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.698843: rtos_queue_send_from_isr_failed: tstamp:6215807222 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.698844: rtos_queue_send_from_isr_failed: tstamp:6215807328 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.698845: rtos_queue_send_from_isr_failed: tstamp:6215807434 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.698846: rtos_queue_send_from_isr_failed: tstamp:6215807538 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.698847: rtos_queue_send_from_isr_failed: tstamp:6215807643 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.698849: rtos_queue_send_from_isr_failed: tstamp:6215807748 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.698850: rtos_queue_send_from_isr_failed: tstamp:6215807853 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.698851: rtos_queue_send_failed: tstamp:6215808787 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.810878: rtos_queue_peek_from_isr_failed: tstamp:6218962919 queue:0x0b4b4500
vi-output, adv7-7530 [004] … 186.904729: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [004] … 186.904765: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 186.922845: rtos_queue_send_from_isr_failed: tstamp:6222696049 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.922848: rtos_queue_send_from_isr_failed: tstamp:6222696190 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.922849: rtos_queue_send_from_isr_failed: tstamp:6222696330 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.922850: rtos_queue_send_from_isr_failed: tstamp:6222696470 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.922852: rtos_queue_send_from_isr_failed: tstamp:6222696608 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.922853: rtos_queue_send_from_isr_failed: tstamp:6222696745 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.922855: rtos_queue_send_from_isr_failed: tstamp:6222696883 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.922856: rtos_queue_send_from_isr_failed: tstamp:6222697020 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.922858: rtos_queue_send_failed: tstamp:6222697776 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.922860: rtos_queue_send_from_isr_failed: tstamp:6222700250 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.922861: rtos_queue_send_from_isr_failed: tstamp:6222700389 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.922862: rtos_queue_send_from_isr_failed: tstamp:6222700528 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.922864: rtos_queue_send_from_isr_failed: tstamp:6222700666 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.922865: rtos_queue_send_from_isr_failed: tstamp:6222700804 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.922866: rtos_queue_send_from_isr_failed: tstamp:6222700941 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.922867: rtos_queue_send_from_isr_failed: tstamp:6222701080 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.922869: rtos_queue_send_from_isr_failed: tstamp:6222701217 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.922870: rtos_queue_send_failed: tstamp:6222701775 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.922871: rtos_queue_send_from_isr_failed: tstamp:6223285423 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.922873: rtos_queue_send_from_isr_failed: tstamp:6223285599 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.922874: rtos_queue_send_from_isr_failed: tstamp:6223285742 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.922875: rtos_queue_send_from_isr_failed: tstamp:6223285880 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.922877: rtos_queue_send_from_isr_failed: tstamp:6223286019 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.922878: rtos_queue_send_from_isr_failed: tstamp:6223286155 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.922879: rtos_queue_send_from_isr_failed: tstamp:6223286294 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.922881: rtos_queue_send_from_isr_failed: tstamp:6223286435 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.922882: rtos_queue_send_failed: tstamp:6223287025 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.922883: rtos_queue_send_from_isr_failed: tstamp:6223289547 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.922884: rtos_queue_send_from_isr_failed: tstamp:6223289704 queue:0x0b4aad68
kworker/3:3-3808 [003] … 186.922886: rtos_queue_send_from_isr_failed: tstamp:6223289843 queue:0x0b4ac998
kworker/3:3-3808 [003] … 186.922887: rtos_queue_send_from_isr_failed: tstamp:6223289982 queue:0x0b4ae518
kworker/3:3-3808 [003] … 186.922888: rtos_queue_send_from_isr_failed: tstamp:6223290118 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 186.922890: rtos_queue_send_from_isr_failed: tstamp:6223290255 queue:0x0b4b0098
kworker/3:3-3808 [003] … 186.922891: rtos_queue_send_from_isr_failed: tstamp:6223290393 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 186.922892: rtos_queue_send_from_isr_failed: tstamp:6223290530 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 186.922893: rtos_queue_send_failed: tstamp:6223291962 queue:0x0b4a7258
kworker/3:3-3808 [003] … 186.978989: rtos_queue_peek_from_isr_failed: tstamp:6223962959 queue:0x0b4b4500
kworker/3:3-3808 [003] … 187.090948: rtos_queue_peek_from_isr_failed: tstamp:6228962958 queue:0x0b4b4500
vi-output, adv7-7530 [004] … 187.146142: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [004] … 187.146173: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 187.146844: rtos_queue_send_from_isr_failed: tstamp:6230196999 queue:0x0b4a7258
kworker/3:3-3808 [003] … 187.146846: rtos_queue_send_from_isr_failed: tstamp:6230197141 queue:0x0b4aad68
kworker/3:3-3808 [003] … 187.146847: rtos_queue_send_from_isr_failed: tstamp:6230197288 queue:0x0b4ac998
kworker/3:3-3808 [003] … 187.146848: rtos_queue_send_from_isr_failed: tstamp:6230197426 queue:0x0b4ae518
kworker/3:3-3808 [003] … 187.146849: rtos_queue_send_from_isr_failed: tstamp:6230197564 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 187.146850: rtos_queue_send_from_isr_failed: tstamp:6230197701 queue:0x0b4b0098
kworker/3:3-3808 [003] … 187.146850: rtos_queue_send_from_isr_failed: tstamp:6230197839 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 187.146851: rtos_queue_send_from_isr_failed: tstamp:6230197976 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 187.146853: rtos_queue_send_failed: tstamp:6230198763 queue:0x0b4a7258
kworker/3:3-3808 [003] … 187.146854: rtos_queue_send_from_isr_failed: tstamp:6230201586 queue:0x0b4a7258
kworker/3:3-3808 [003] … 187.146855: rtos_queue_send_from_isr_failed: tstamp:6230201726 queue:0x0b4aad68
kworker/3:3-3808 [003] … 187.146856: rtos_queue_send_from_isr_failed: tstamp:6230201865 queue:0x0b4ac998
kworker/3:3-3808 [003] … 187.146857: rtos_queue_send_from_isr_failed: tstamp:6230202004 queue:0x0b4ae518
kworker/3:3-3808 [003] … 187.146858: rtos_queue_send_from_isr_failed: tstamp:6230202141 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 187.146861: rtos_queue_send_from_isr_failed: tstamp:6230202290 queue:0x0b4b0098
kworker/3:3-3808 [003] … 187.146863: rtos_queue_send_from_isr_failed: tstamp:6230202430 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 187.146865: rtos_queue_send_from_isr_failed: tstamp:6230202568 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 187.146867: rtos_queue_send_failed: tstamp:6230203171 queue:0x0b4a7258
kworker/3:3-3808 [003] … 187.146869: rtos_queue_send_from_isr_failed: tstamp:6230832980 queue:0x0b4a7258
kworker/3:3-3808 [003] … 187.146871: rtos_queue_send_from_isr_failed: tstamp:6230833085 queue:0x0b4aad68
kworker/3:3-3808 [003] … 187.146874: rtos_queue_send_from_isr_failed: tstamp:6230833193 queue:0x0b4ac998
kworker/3:3-3808 [003] … 187.146876: rtos_queue_send_from_isr_failed: tstamp:6230833299 queue:0x0b4ae518
kworker/3:3-3808 [003] … 187.146878: rtos_queue_send_from_isr_failed: tstamp:6230833403 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 187.146880: rtos_queue_send_from_isr_failed: tstamp:6230833507 queue:0x0b4b0098
kworker/3:3-3808 [003] … 187.146882: rtos_queue_send_from_isr_failed: tstamp:6230833610 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 187.146884: rtos_queue_send_from_isr_failed: tstamp:6230833714 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 187.146886: rtos_queue_send_failed: tstamp:6230834196 queue:0x0b4a7258
kworker/3:3-3808 [003] … 187.146889: rtos_queue_send_from_isr_failed: tstamp:6230835503 queue:0x0b4a7258
kworker/3:3-3808 [003] … 187.146891: rtos_queue_send_from_isr_failed: tstamp:6230835610 queue:0x0b4aad68
kworker/3:3-3808 [003] … 187.146893: rtos_queue_send_from_isr_failed: tstamp:6230835715 queue:0x0b4ac998
kworker/3:3-3808 [003] … 187.146895: rtos_queue_send_from_isr_failed: tstamp:6230835834 queue:0x0b4ae518
kworker/3:3-3808 [003] … 187.146897: rtos_queue_send_from_isr_failed: tstamp:6230835939 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 187.146899: rtos_queue_send_from_isr_failed: tstamp:6230836043 queue:0x0b4b0098
kworker/3:3-3808 [003] … 187.146901: rtos_queue_send_from_isr_failed: tstamp:6230836148 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 187.146904: rtos_queue_send_from_isr_failed: tstamp:6230836253 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 187.146906: rtos_queue_send_failed: tstamp:6230837198 queue:0x0b4a7258
kworker/3:3-3808 [003] … 187.258930: rtos_queue_peek_from_isr_failed: tstamp:6233962955 queue:0x0b4b4500
kworker/3:3-3808 [003] … 187.370960: rtos_queue_send_from_isr_failed: tstamp:6237645113 queue:0x0b4a7258
kworker/3:3-3808 [003] … 187.370969: rtos_queue_send_from_isr_failed: tstamp:6237645259 queue:0x0b4aad68
kworker/3:3-3808 [003] … 187.370972: rtos_queue_send_from_isr_failed: tstamp:6237645404 queue:0x0b4ac998
kworker/3:3-3808 [003] … 187.370974: rtos_queue_send_from_isr_failed: tstamp:6237645544 queue:0x0b4ae518
kworker/3:3-3808 [003] … 187.370977: rtos_queue_send_from_isr_failed: tstamp:6237645681 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 187.370979: rtos_queue_send_from_isr_failed: tstamp:6237645818 queue:0x0b4b0098
kworker/3:3-3808 [003] … 187.370981: rtos_queue_send_from_isr_failed: tstamp:6237645954 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 187.370984: rtos_queue_send_from_isr_failed: tstamp:6237646110 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 187.370988: rtos_queue_send_failed: tstamp:6237646846 queue:0x0b4a7258
kworker/3:3-3808 [003] … 187.370991: rtos_queue_send_from_isr_failed: tstamp:6237648906 queue:0x0b4a7258
kworker/3:3-3808 [003] … 187.370994: rtos_queue_send_from_isr_failed: tstamp:6237649044 queue:0x0b4aad68
kworker/3:3-3808 [003] … 187.370996: rtos_queue_send_from_isr_failed: tstamp:6237649182 queue:0x0b4ac998
kworker/3:3-3808 [003] … 187.370998: rtos_queue_send_from_isr_failed: tstamp:6237649320 queue:0x0b4ae518
kworker/3:3-3808 [003] … 187.371001: rtos_queue_send_from_isr_failed: tstamp:6237649458 queue:0x0b4af2d8
kworker/3:3-3808 [003] … 187.371003: rtos_queue_send_from_isr_failed: tstamp:6237649594 queue:0x0b4b0098
kworker/3:3-3808 [003] … 187.371006: rtos_queue_send_from_isr_failed: tstamp:6237649730 queue:0x0b4b0e58
kworker/3:3-3808 [003] … 187.371008: rtos_queue_send_from_isr_failed: tstamp:6237649866 queue:0x0b4b1c18
kworker/3:3-3808 [003] … 187.371011: rtos_queue_send_failed: tstamp:6237650415 queue:0x0b4a7258
vi-output, adv7-7530 [004] … 187.382165: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt cb
vi-output, adv7-7530 [004] … 187.382200: tegra_channel_capture_frame: sof:-549620695332.-267798123776
kworker/3:3-3808 [003] … 187.426930: rtos_queue_send_from_isr_failed: tstamp:6238206605 queue:0x0b4a7258
kworker/3:3-3808 [003] … 187.426937: rtos_queue_send_from_isr_fa
can you see all the log ?
The trace log show didn’t receive any validate data from the MIPI bus. May need to probe the signal.
now, adv7281ma output an color bar, in the meantime, i captured the signal on D0P D0N CLKP CLKN.
which one did’t receive any validata data ? vi or csi?
can you help me to check the vi and csi’s setting in dts.
The bus-width is different in the vi scope and nvcsi scope.
port@0 {
					reg = <0x0>;
					status = "okay";
					linux,phandle = <0x19a>;
					phandle = <0x19a>;
					endpoint {
						port-index = <0x0>;
						bus-width = <0x1>;
						remote-endpoint = <0x5f>;
						vc-id = <0x0>;//0x0
						status = "okay";
						linux,phandle = <0x5e>;
						phandle = <0x5e>;
i reviewed again,do you mean channel@1’s port in nvcsi? it’s disabled.
Then, I didn’t found errors now. Could you modify the VI/CSI driver to print the port/lanes to confirm it apply the configure from the dtb correctly.
we used 1 lane of csi0,are below settings right?
port-index = <0x0>;
bus-width = <0x1>;
vc-id = <0x0>;//0x0
[  120.185654] adv7180 2-0020: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[  120.185691] adv7180 2-0020: camera_common_dpd_disable: csi 0
[  120.185696] adv7180 2-0020: adv7180_power_on: power on
[  120.186940] nvcsi 150c0000.nvcsi: settle time reading from props
[  120.186949] nvcsi 150c0000.nvcsi: csi_port: 0
[  120.190043] tegra-ivc-vi-notify ivc-b000000.rtcpu:vinotify@12c0: vi_notify_channel_enable_reports: ch:0
[  120.191860] nvcsi 150c0000.nvcsi: csi4_start_streaming port_idx=0, lanes=1
[  120.191864] nvcsi 150c0000.nvcsi: csi4_stream_init csi_port = 0
[  120.191876] nvcsi 150c0000.nvcsi: csi4_stream_config
[  120.191886] nvcsi 150c0000.nvcsi: csi4_stream_config (0) read VC0_DPCM_CTRL = 00000000
[  120.191889] nvcsi 150c0000.nvcsi: settle time reading from props
[  120.191893] nvcsi 150c0000.nvcsi: settle time reading from props
[  120.191895] nvcsi 150c0000.nvcsi: csi4_phy_config
[  120.191901] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000000
[  120.191909] nvcsi 150c0000.nvcsi: cil core clock: 204, csi clock: 89
[  120.191912] nvcsi 150c0000.nvcsi: csi settle time: 33, cil settle time: 20
[  120.191922] adv7180 2-0020: v4l2sd_stream++ enable 1
[  120.191927] adv7180 2-0020: adv7180_set_mode: power on
[  120.191932] adv7180 2-0020: adv7180_start_streaming
[  120.393301] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[  120.399786] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
Picture link: 百度网盘-链接不存在 password: 3irt
this picture was captured on D0P.
is it okay?
The setting is correct as device tree define.
when i upgrade source code to R32.2.3.
what dose mean of the below logs?
[code]
root@tek:~# v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1
^C^C^C^C
root@tek:~# ^C
root@tek:~# ^C
root@tek:~# cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 1125/1125 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
    v4l2-ctl-8008  [000] ....   273.947034: tegra_channel_open: vi-output, adv7180 2-0021
    v4l2-ctl-8008  [000] ....   273.949762: tegra_channel_set_power: adv7180 2-0021 : 0x1
    v4l2-ctl-8008  [000] ....   273.949785: camera_common_s_power: status : 0x1
    v4l2-ctl-8008  [000] ....   273.949865: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
    v4l2-ctl-8008  [000] ....   273.949870: csi_s_power: enable : 0x1
    v4l2-ctl-8008  [000] ....   273.966524: tegra_channel_capture_setup: vnc_id 0 W 720 H 576 fmt 20
vi-output, adv7-8009 [003] … 273.967869: tegra_channel_set_stream: enable : 0x1
kworker/3:1-1809 [003] … 273.970707: rtos_queue_peek_from_isr_failed: tstamp:8841868485 queue:0x0b4b4500
kworker/3:1-1809 [003] … 273.970715: rtcpu_start: tstamp:8841871956
kworker/3:1-1809 [003] … 273.970721: rtos_queue_send_from_isr_failed: tstamp:8841989645 queue:0x0b4a7258
kworker/3:1-1809 [003] … 273.970725: rtos_queue_send_from_isr_failed: tstamp:8841990664 queue:0x0b4aad68
kworker/3:1-1809 [003] … 273.970728: rtos_queue_send_from_isr_failed: tstamp:8841991685 queue:0x0b4ac998
kworker/3:1-1809 [003] … 273.970731: rtos_queue_send_from_isr_failed: tstamp:8841992705 queue:0x0b4ae518
kworker/3:1-1809 [003] … 273.970733: rtos_queue_send_from_isr_failed: tstamp:8841993736 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 273.970736: rtos_queue_send_from_isr_failed: tstamp:8841994750 queue:0x0b4b0098
kworker/3:1-1809 [003] … 273.970739: rtos_queue_send_from_isr_failed: tstamp:8841995765 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 273.970741: rtos_queue_send_from_isr_failed: tstamp:8841996782 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 273.970747: rtos_queue_send_failed: tstamp:8842001586 queue:0x0b4a7258
kworker/3:1-1809 [003] … 273.970749: rtos_queue_send_from_isr_failed: tstamp:8842019956 queue:0x0b4a7258
kworker/3:1-1809 [003] … 273.970752: rtos_queue_send_from_isr_failed: tstamp:8842021240 queue:0x0b4aad68
kworker/3:1-1809 [003] … 273.970755: rtos_queue_send_from_isr_failed: tstamp:8842022263 queue:0x0b4ac998
kworker/3:1-1809 [003] … 273.970757: rtos_queue_send_from_isr_failed: tstamp:8842023296 queue:0x0b4ae518
kworker/3:1-1809 [003] … 273.970760: rtos_queue_send_from_isr_failed: tstamp:8842024313 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 273.970762: rtos_queue_send_from_isr_failed: tstamp:8842025599 queue:0x0b4b0098
kworker/3:1-1809 [003] … 273.970765: rtos_queue_send_from_isr_failed: tstamp:8842026620 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 273.970768: rtos_queue_send_from_isr_failed: tstamp:8842027653 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 273.970770: rtos_queue_send_failed: tstamp:8842042002 queue:0x0b4a7258
vi-output, adv7-8009 [000] … 273.994589: tegra_channel_set_stream: 150c0000.nvcsi–1 : 0x1
vi-output, adv7-8009 [000] … 273.994595: csi_s_stream: enable : 0x1
vi-output, adv7-8009 [000] … 273.994629: tegra_channel_set_stream: adv7180 2-0021 : 0x1
kworker/3:1-1809 [003] … 274.082676: rtcpu_vinotify_event: tstamp:8844009834 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:2 vi_tstamp:8844009052 data:0x00000001
kworker/3:1-1809 [003] … 274.082691: rtcpu_vinotify_event: tstamp:8844010434 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:8844009055 data:0x00000001
kworker/3:1-1809 [003] … 274.082698: rtcpu_vinotify_event: tstamp:8844027871 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8844027298 data:0x00000010
kworker/3:1-1809 [003] … 274.082701: rtcpu_vinotify_event: tstamp:8844651617 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8844651045 data:0x00000010
kworker/3:1-1809 [003] … 274.082704: rtcpu_vinotify_event: tstamp:8845277347 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8845276790 data:0x00000010
kworker/3:1-1809 [003] … 274.138687: rtcpu_vinotify_event: tstamp:8845901090 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8845900536 data:0x00000010
kworker/3:1-1809 [003] … 274.138694: rtcpu_vinotify_event: tstamp:8846526688 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8846526282 data:0x00000010
kworker/3:1-1809 [003] … 274.138708: rtos_queue_peek_from_isr_failed: tstamp:8846869182 queue:0x0b4b4500
kworker/3:1-1809 [003] … 274.138711: rtcpu_vinotify_event: tstamp:8847150597 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8847150029 data:0x00000010
kworker/3:1-1809 [003] … 274.194726: rtcpu_vinotify_event: tstamp:8847776343 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8847775775 data:0x00000010
kworker/3:1-1809 [003] … 274.194733: rtcpu_vinotify_event: tstamp:8848400089 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8848399521 data:0x00000010
kworker/3:1-1809 [003] … 274.194738: rtcpu_vinotify_event: tstamp:8849025833 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8849025266 data:0x00000010
vi-output, adv7-8009 [000] … 274.216903: tegra_channel_capture_setup: vnc_id 0 W 720 H 576 fmt 20
vi-output, adv7-8009 [000] … 274.216950: tegra_channel_capture_frame: sof:-549620695332.-267596731584
kworker/3:1-1809 [003] … 274.250676: rtcpu_vinotify_event: tstamp:8849649579 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8849649013 data:0x00000010
kworker/3:1-1809 [003] … 274.250695: rtos_queue_send_from_isr_failed: tstamp:8849818566 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.250702: rtos_queue_send_from_isr_failed: tstamp:8849819025 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.250709: rtos_queue_send_from_isr_failed: tstamp:8849819483 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.250715: rtos_queue_send_from_isr_failed: tstamp:8849819937 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.250720: rtos_queue_send_from_isr_failed: tstamp:8849820387 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.250725: rtos_queue_send_from_isr_failed: tstamp:8849820838 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.250729: rtos_queue_send_from_isr_failed: tstamp:8849821289 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.250734: rtos_queue_send_from_isr_failed: tstamp:8849821743 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.250743: rtos_queue_send_failed: tstamp:8849823845 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.250748: rtos_queue_send_from_isr_failed: tstamp:8849833115 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.250755: rtos_queue_send_from_isr_failed: tstamp:8849833570 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.250759: rtos_queue_send_from_isr_failed: tstamp:8849834024 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.250764: rtos_queue_send_from_isr_failed: tstamp:8849834479 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.250769: rtos_queue_send_from_isr_failed: tstamp:8849834930 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.250774: rtos_queue_send_from_isr_failed: tstamp:8849835383 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.250778: rtos_queue_send_from_isr_failed: tstamp:8849835835 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.250783: rtos_queue_send_from_isr_failed: tstamp:8849836288 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.250788: rtos_queue_send_failed: tstamp:8849838230 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.250793: rtos_queue_send_from_isr_failed: tstamp:8849850232 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.250797: rtos_queue_send_from_isr_failed: tstamp:8849850686 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.250802: rtos_queue_send_from_isr_failed: tstamp:8849851145 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.250807: rtos_queue_send_from_isr_failed: tstamp:8849851600 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.250812: rtos_queue_send_from_isr_failed: tstamp:8849852054 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.250816: rtos_queue_send_from_isr_failed: tstamp:8849852508 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.250821: rtos_queue_send_from_isr_failed: tstamp:8849852961 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.250826: rtos_queue_send_from_isr_failed: tstamp:8849853412 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.250831: rtos_queue_send_failed: tstamp:8849855379 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.250836: rtos_queue_send_from_isr_failed: tstamp:8849861180 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.250840: rtos_queue_send_from_isr_failed: tstamp:8849861631 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.250845: rtos_queue_send_from_isr_failed: tstamp:8849862083 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.250850: rtos_queue_send_from_isr_failed: tstamp:8849862535 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.250855: rtos_queue_send_from_isr_failed: tstamp:8849862985 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.250860: rtos_queue_send_from_isr_failed: tstamp:8849863436 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.250864: rtos_queue_send_from_isr_failed: tstamp:8849863886 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.250869: rtos_queue_send_from_isr_failed: tstamp:8849864336 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.250874: rtos_queue_send_failed: tstamp:8849870112 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.306661: rtos_queue_peek_from_isr_failed: tstamp:8851869153 queue:0x0b4b4500
kworker/3:1-1809 [003] … 274.474567: rtos_queue_send_from_isr_failed: tstamp:8856688099 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.474572: rtos_queue_send_from_isr_failed: tstamp:8856688556 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.474574: rtos_queue_send_from_isr_failed: tstamp:8856689014 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.474575: rtos_queue_send_from_isr_failed: tstamp:8856689467 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.474576: rtos_queue_send_from_isr_failed: tstamp:8856689918 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.474577: rtos_queue_send_from_isr_failed: tstamp:8856690435 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.474579: rtos_queue_send_from_isr_failed: tstamp:8856690892 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.474580: rtos_queue_send_from_isr_failed: tstamp:8856691344 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.474582: rtos_queue_send_failed: tstamp:8856693314 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.474584: rtos_queue_send_from_isr_failed: tstamp:8856700211 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.474585: rtos_queue_send_from_isr_failed: tstamp:8856700665 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.474586: rtos_queue_send_from_isr_failed: tstamp:8856701119 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.474587: rtos_queue_send_from_isr_failed: tstamp:8856701580 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.474588: rtos_queue_send_from_isr_failed: tstamp:8856702033 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.474590: rtos_queue_send_from_isr_failed: tstamp:8856702485 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.474591: rtos_queue_send_from_isr_failed: tstamp:8856702938 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.474592: rtos_queue_send_from_isr_failed: tstamp:8856703392 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.474593: rtos_queue_send_failed: tstamp:8856705303 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.474595: rtos_queue_peek_from_isr_failed: tstamp:8856868892 queue:0x0b4b4500
vi-output, adv7-8009 [000] … 274.477493: tegra_channel_capture_setup: vnc_id 0 W 720 H 576 fmt 20
vi-output, adv7-8009 [000] … 274.477526: tegra_channel_capture_frame: sof:-549620695332.-267596731584
kworker/3:1-1809 [003] … 274.530675: rtos_queue_send_from_isr_failed: tstamp:8858008550 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.530686: rtos_queue_send_from_isr_failed: tstamp:8858008691 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.530691: rtos_queue_send_from_isr_failed: tstamp:8858008835 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.530696: rtos_queue_send_from_isr_failed: tstamp:8858008979 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.530700: rtos_queue_send_from_isr_failed: tstamp:8858009116 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.530706: rtos_queue_send_from_isr_failed: tstamp:8858009254 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.530710: rtos_queue_send_from_isr_failed: tstamp:8858009390 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.530715: rtos_queue_send_from_isr_failed: tstamp:8858009527 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.530720: rtos_queue_send_failed: tstamp:8858010086 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.530725: rtos_queue_send_from_isr_failed: tstamp:8858012914 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.530730: rtos_queue_send_from_isr_failed: tstamp:8858013055 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.530735: rtos_queue_send_from_isr_failed: tstamp:8858013194 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.530740: rtos_queue_send_from_isr_failed: tstamp:8858013333 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.530746: rtos_queue_send_from_isr_failed: tstamp:8858013471 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.530751: rtos_queue_send_from_isr_failed: tstamp:8858013608 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.530756: rtos_queue_send_from_isr_failed: tstamp:8858013744 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.530761: rtos_queue_send_from_isr_failed: tstamp:8858013901 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.530766: rtos_queue_send_failed: tstamp:8858015346 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.642679: rtos_queue_peek_from_isr_failed: tstamp:8861869191 queue:0x0b4b4500
kworker/3:1-1809 [003] … 274.702553: rtos_queue_send_from_isr_failed: tstamp:8864811176 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.702560: rtos_queue_send_from_isr_failed: tstamp:8864811636 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.702562: rtos_queue_send_from_isr_failed: tstamp:8864812094 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.702565: rtos_queue_send_from_isr_failed: tstamp:8864812551 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.702567: rtos_queue_send_from_isr_failed: tstamp:8864813003 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.702569: rtos_queue_send_from_isr_failed: tstamp:8864813458 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.702571: rtos_queue_send_from_isr_failed: tstamp:8864813911 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.702573: rtos_queue_send_from_isr_failed: tstamp:8864814366 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.702576: rtos_queue_send_failed: tstamp:8864816468 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.702578: rtos_queue_send_from_isr_failed: tstamp:8864822938 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.702580: rtos_queue_send_from_isr_failed: tstamp:8864823392 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.702582: rtos_queue_send_from_isr_failed: tstamp:8864823846 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.702584: rtos_queue_send_from_isr_failed: tstamp:8864824301 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.702586: rtos_queue_send_from_isr_failed: tstamp:8864824758 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.702588: rtos_queue_send_from_isr_failed: tstamp:8864825213 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.702591: rtos_queue_send_from_isr_failed: tstamp:8864825690 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.702593: rtos_queue_send_from_isr_failed: tstamp:8864826140 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.702595: rtos_queue_send_failed: tstamp:8864828103 queue:0x0b4a7258
vi-output, adv7-8009 [000] … 274.721667: tegra_channel_capture_setup: vnc_id 0 W 720 H 576 fmt 20
vi-output, adv7-8009 [000] … 274.721718: tegra_channel_capture_frame: sof:-549620695332.-267596731584
kworker/3:1-1809 [003] … 274.754724: rtos_queue_send_from_isr_failed: tstamp:8865636200 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.754746: rtos_queue_send_from_isr_failed: tstamp:8865636383 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.754751: rtos_queue_send_from_isr_failed: tstamp:8865636557 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.754756: rtos_queue_send_from_isr_failed: tstamp:8865636732 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.754760: rtos_queue_send_from_isr_failed: tstamp:8865636907 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.754765: rtos_queue_send_from_isr_failed: tstamp:8865637082 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.754770: rtos_queue_send_from_isr_failed: tstamp:8865637258 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.754775: rtos_queue_send_from_isr_failed: tstamp:8865637432 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.754790: rtos_queue_send_failed: tstamp:8865638192 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.754795: rtos_queue_send_from_isr_failed: tstamp:8865642398 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.754800: rtos_queue_send_from_isr_failed: tstamp:8865642584 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.754813: rtos_queue_send_from_isr_failed: tstamp:8865642772 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.754818: rtos_queue_send_from_isr_failed: tstamp:8865642948 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.754823: rtos_queue_send_from_isr_failed: tstamp:8865643141 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.754828: rtos_queue_send_from_isr_failed: tstamp:8865643318 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.754833: rtos_queue_send_from_isr_failed: tstamp:8865643490 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.754839: rtos_queue_send_from_isr_failed: tstamp:8865643665 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.754844: rtos_queue_send_failed: tstamp:8865645644 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.810691: rtos_queue_peek_from_isr_failed: tstamp:8866869215 queue:0x0b4b4500
kworker/3:1-1809 [003] … 274.922666: rtos_queue_peek_from_isr_failed: tstamp:8871869059 queue:0x0b4b4500
vi-output, adv7-8009 [003] … 274.958870: tegra_channel_capture_setup: vnc_id 0 W 720 H 576 fmt 20
vi-output, adv7-8009 [003] … 274.958959: tegra_channel_capture_frame: sof:-549620695332.-267596731584
kworker/3:1-1809 [003] … 274.978622: rtos_queue_send_from_isr_failed: tstamp:8872483395 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.978628: rtos_queue_send_from_isr_failed: tstamp:8872483850 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.978631: rtos_queue_send_from_isr_failed: tstamp:8872484304 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.978634: rtos_queue_send_from_isr_failed: tstamp:8872484756 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.978637: rtos_queue_send_from_isr_failed: tstamp:8872485206 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.978639: rtos_queue_send_from_isr_failed: tstamp:8872485656 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.978642: rtos_queue_send_from_isr_failed: tstamp:8872486106 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.978645: rtos_queue_send_from_isr_failed: tstamp:8872486556 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.978649: rtos_queue_send_failed: tstamp:8872488696 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.978652: rtos_queue_send_from_isr_failed: tstamp:8872498757 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.978655: rtos_queue_send_from_isr_failed: tstamp:8872499316 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.978657: rtos_queue_send_from_isr_failed: tstamp:8872499768 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.978660: rtos_queue_send_from_isr_failed: tstamp:8872500223 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.978663: rtos_queue_send_from_isr_failed: tstamp:8872500676 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.978666: rtos_queue_send_from_isr_failed: tstamp:8872501128 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.978668: rtos_queue_send_from_isr_failed: tstamp:8872501582 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.978671: rtos_queue_send_from_isr_failed: tstamp:8872502036 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.978673: rtos_queue_send_failed: tstamp:8872503830 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.978676: rtos_queue_send_from_isr_failed: tstamp:8873034732 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.978679: rtos_queue_send_from_isr_failed: tstamp:8873035188 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.978681: rtos_queue_send_from_isr_failed: tstamp:8873035645 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.978684: rtos_queue_send_from_isr_failed: tstamp:8873036103 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.978687: rtos_queue_send_from_isr_failed: tstamp:8873036562 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.978689: rtos_queue_send_from_isr_failed: tstamp:8873037137 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.978692: rtos_queue_send_from_isr_failed: tstamp:8873037599 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.978695: rtos_queue_send_from_isr_failed: tstamp:8873038078 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.978698: rtos_queue_send_failed: tstamp:8873039898 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.978700: rtos_queue_send_from_isr_failed: tstamp:8873047179 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.978703: rtos_queue_send_from_isr_failed: tstamp:8873047633 queue:0x0b4aad68
kworker/3:1-1809 [003] … 274.978706: rtos_queue_send_from_isr_failed: tstamp:8873048084 queue:0x0b4ac998
kworker/3:1-1809 [003] … 274.978708: rtos_queue_send_from_isr_failed: tstamp:8873048536 queue:0x0b4ae518
kworker/3:1-1809 [003] … 274.978711: rtos_queue_send_from_isr_failed: tstamp:8873048988 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 274.978714: rtos_queue_send_from_isr_failed: tstamp:8873049439 queue:0x0b4b0098
kworker/3:1-1809 [003] … 274.978716: rtos_queue_send_from_isr_failed: tstamp:8873049890 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 274.978719: rtos_queue_send_from_isr_failed: tstamp:8873050341 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 274.978722: rtos_queue_send_failed: tstamp:8873056586 queue:0x0b4a7258
kworker/3:1-1809 [003] … 274.978728: rtcpu_vinotify_event: tstamp:8873060436 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8873055509 data:0x00000010
kworker/3:1-1809 [003] … 275.034638: rtcpu_vinotify_event: tstamp:8873997645 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:2 vi_tstamp:8873996863 data:0x00000001
kworker/3:1-1809 [003] … 275.034645: rtcpu_vinotify_event: tstamp:8873998132 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:8873996867 data:0x00000001
kworker/3:1-1809 [003] … 275.034649: rtcpu_vinotify_event: tstamp:8874015681 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8874015110 data:0x00000010
kworker/3:1-1809 [003] … 275.034652: rtcpu_vinotify_event: tstamp:8874639426 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8874638857 data:0x00000010
kworker/3:1-1809 [003] … 275.034655: rtcpu_vinotify_event: tstamp:8875265199 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8875264602 data:0x00000010
kworker/3:1-1809 [003] … 275.090681: rtcpu_vinotify_event: tstamp:8875888920 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8875888349 data:0x00000010
kworker/3:1-1809 [003] … 275.090692: rtcpu_vinotify_event: tstamp:8876514662 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8876514094 data:0x00000010
kworker/3:1-1809 [003] … 275.090705: rtos_queue_peek_from_isr_failed: tstamp:8876869068 queue:0x0b4b4500
kworker/3:1-1809 [003] … 275.090709: rtcpu_vinotify_event: tstamp:8877138411 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8877137840 data:0x00000010
kworker/3:1-1809 [003] … 275.147029: rtcpu_vinotify_event: tstamp:8877764156 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8877763587 data:0x00000010
kworker/3:1-1809 [003] … 275.147066: rtcpu_vinotify_event: tstamp:8878387727 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8878387333 data:0x00000010
vi-output, adv7-8009 [003] … 275.195972: tegra_channel_capture_setup: vnc_id 0 W 720 H 576 fmt 20
vi-output, adv7-8009 [003] … 275.196002: tegra_channel_capture_frame: sof:-549620695332.-267596731584
kworker/3:1-1809 [003] … 275.202530: rtcpu_vinotify_event: tstamp:8879013702 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8879013079 data:0x00000010
kworker/3:1-1809 [003] … 275.202533: rtcpu_vinotify_event: tstamp:8879637396 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8879636826 data:0x00000010
kworker/3:1-1809 [003] … 275.202535: rtos_queue_send_from_isr_failed: tstamp:8879938224 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.202537: rtos_queue_send_from_isr_failed: tstamp:8879938411 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.202538: rtos_queue_send_from_isr_failed: tstamp:8879938589 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.202539: rtos_queue_send_from_isr_failed: tstamp:8879938768 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.202540: rtos_queue_send_from_isr_failed: tstamp:8879938940 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.202541: rtos_queue_send_from_isr_failed: tstamp:8879939122 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.202541: rtos_queue_send_from_isr_failed: tstamp:8879939294 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.202543: rtos_queue_send_from_isr_failed: tstamp:8879939482 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.202545: rtos_queue_send_failed: tstamp:8879940364 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.202546: rtos_queue_send_from_isr_failed: tstamp:8879943472 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.202547: rtos_queue_send_from_isr_failed: tstamp:8879943647 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.202548: rtos_queue_send_from_isr_failed: tstamp:8879943822 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.202549: rtos_queue_send_from_isr_failed: tstamp:8879944031 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.202550: rtos_queue_send_from_isr_failed: tstamp:8879944202 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.202551: rtos_queue_send_from_isr_failed: tstamp:8879944381 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.202552: rtos_queue_send_from_isr_failed: tstamp:8879944554 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.202553: rtos_queue_send_from_isr_failed: tstamp:8879944726 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.202554: rtos_queue_send_failed: tstamp:8879945478 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.202555: rtos_queue_send_from_isr_failed: tstamp:8880464276 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.202556: rtos_queue_send_from_isr_failed: tstamp:8880464392 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.202556: rtos_queue_send_from_isr_failed: tstamp:8880464497 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.202557: rtos_queue_send_from_isr_failed: tstamp:8880464603 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.202558: rtos_queue_send_from_isr_failed: tstamp:8880464708 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.202560: rtos_queue_send_from_isr_failed: tstamp:8880464814 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.202561: rtos_queue_send_from_isr_failed: tstamp:8880464919 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.202562: rtos_queue_send_from_isr_failed: tstamp:8880465024 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.202562: rtos_queue_send_failed: tstamp:8880465481 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.202563: rtos_queue_send_from_isr_failed: tstamp:8880467086 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.202564: rtos_queue_send_from_isr_failed: tstamp:8880467191 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.202565: rtos_queue_send_from_isr_failed: tstamp:8880467296 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.202566: rtos_queue_send_from_isr_failed: tstamp:8880467402 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.202567: rtos_queue_send_from_isr_failed: tstamp:8880467506 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.202568: rtos_queue_send_from_isr_failed: tstamp:8880467611 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.202569: rtos_queue_send_from_isr_failed: tstamp:8880467716 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.202570: rtos_queue_send_from_isr_failed: tstamp:8880467821 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.202571: rtos_queue_send_failed: tstamp:8880468746 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.258592: rtcpu_vinotify_event: tstamp:8881494606 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:2 vi_tstamp:8881493818 data:0x00000001
kworker/3:1-1809 [003] … 275.258598: rtcpu_vinotify_event: tstamp:8881495237 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:8881493820 data:0x00000001
kworker/3:1-1809 [003] … 275.258601: rtcpu_vinotify_event: tstamp:8881512640 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8881512063 data:0x00000010
kworker/3:1-1809 [003] … 275.258607: rtos_queue_peek_from_isr_failed: tstamp:8881869228 queue:0x0b4b4500
kworker/3:1-1809 [003] … 275.258609: rtcpu_vinotify_event: tstamp:8882136421 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8882135810 data:0x00000010
kworker/3:1-1809 [003] … 275.314680: rtcpu_vinotify_event: tstamp:8882762125 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8882761556 data:0x00000010
kworker/3:1-1809 [003] … 275.314690: rtcpu_vinotify_event: tstamp:8883385871 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8883385303 data:0x00000010
kworker/3:1-1809 [003] … 275.314695: rtcpu_vinotify_event: tstamp:8884011615 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8884011049 data:0x00000010
kworker/3:1-1809 [003] … 275.370603: rtcpu_vinotify_event: tstamp:8884635360 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8884634795 data:0x00000010
kworker/3:1-1809 [003] … 275.370612: rtcpu_vinotify_event: tstamp:8885261146 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8885260540 data:0x00000010
kworker/3:1-1809 [003] … 275.370617: rtcpu_vinotify_event: tstamp:8885884854 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8885884287 data:0x00000010
kworker/3:1-1809 [003] … 275.426509: rtcpu_vinotify_event: tstamp:8886510601 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8886510032 data:0x00000010
kworker/3:1-1809 [003] … 275.426514: rtos_queue_peek_from_isr_failed: tstamp:8886869082 queue:0x0b4b4500
kworker/3:1-1809 [003] … 275.426516: rtcpu_vinotify_event: tstamp:8887134197 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8887133779 data:0x00000010
kworker/3:1-1809 [003] … 275.426517: rtos_queue_send_from_isr_failed: tstamp:8887306804 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.426519: rtos_queue_send_from_isr_failed: tstamp:8887306983 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.426520: rtos_queue_send_from_isr_failed: tstamp:8887307160 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.426522: rtos_queue_send_from_isr_failed: tstamp:8887307334 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.426523: rtos_queue_send_from_isr_failed: tstamp:8887307508 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.426524: rtos_queue_send_from_isr_failed: tstamp:8887307683 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.426525: rtos_queue_send_from_isr_failed: tstamp:8887307858 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.426527: rtos_queue_send_from_isr_failed: tstamp:8887308032 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.426528: rtos_queue_send_failed: tstamp:8887308922 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.426530: rtos_queue_send_from_isr_failed: tstamp:8887311398 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.426531: rtos_queue_send_from_isr_failed: tstamp:8887311602 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.426532: rtos_queue_send_from_isr_failed: tstamp:8887311777 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.426533: rtos_queue_send_from_isr_failed: tstamp:8887311953 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.426534: rtos_queue_send_from_isr_failed: tstamp:8887312127 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.426535: rtos_queue_send_from_isr_failed: tstamp:8887312301 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.426537: rtos_queue_send_from_isr_failed: tstamp:8887312473 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.426538: rtos_queue_send_from_isr_failed: tstamp:8887312647 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.426542: rtos_queue_send_failed: tstamp:8887313346 queue:0x0b4a7258
vi-output, adv7-8009 [004] … 275.431879: tegra_channel_capture_setup: vnc_id 0 W 720 H 576 fmt 20
vi-output, adv7-8009 [004] … 275.431911: tegra_channel_capture_frame: sof:-549620695332.-267596731584
kworker/3:1-1809 [003] … 275.482589: rtos_queue_send_from_isr_failed: tstamp:8887834775 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.482595: rtos_queue_send_from_isr_failed: tstamp:8887834916 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.482598: rtos_queue_send_from_isr_failed: tstamp:8887835074 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.482601: rtos_queue_send_from_isr_failed: tstamp:8887835235 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.482605: rtos_queue_send_from_isr_failed: tstamp:8887835373 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.482608: rtos_queue_send_from_isr_failed: tstamp:8887835510 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.482610: rtos_queue_send_from_isr_failed: tstamp:8887835648 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.482613: rtos_queue_send_from_isr_failed: tstamp:8887835785 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.482616: rtos_queue_send_failed: tstamp:8887836354 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.482619: rtos_queue_send_from_isr_failed: tstamp:8887838214 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.482622: rtos_queue_send_from_isr_failed: tstamp:8887838360 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.482624: rtos_queue_send_from_isr_failed: tstamp:8887838499 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.482627: rtos_queue_send_from_isr_failed: tstamp:8887838638 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.482630: rtos_queue_send_from_isr_failed: tstamp:8887838775 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.482632: rtos_queue_send_from_isr_failed: tstamp:8887838914 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.482635: rtos_queue_send_from_isr_failed: tstamp:8887839051 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.482638: rtos_queue_send_from_isr_failed: tstamp:8887839189 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.482640: rtos_queue_send_failed: tstamp:8887840580 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.482644: rtcpu_vinotify_event: tstamp:8888991544 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:2 vi_tstamp:8888990771 data:0x00000001
kworker/3:1-1809 [003] … 275.482647: rtcpu_vinotify_event: tstamp:8888992058 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:8888990774 data:0x00000001
kworker/3:1-1809 [003] … 275.482649: rtcpu_vinotify_event: tstamp:8889009562 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8889009018 data:0x00000010
kworker/3:1-1809 [003] … 275.538659: rtcpu_vinotify_event: tstamp:8889633334 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8889632765 data:0x00000010
kworker/3:1-1809 [003] … 275.538667: rtcpu_vinotify_event: tstamp:8890259081 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8890258510 data:0x00000010
kworker/3:1-1809 [003] … 275.538670: rtcpu_vinotify_event: tstamp:8890882827 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8890882257 data:0x00000010
kworker/3:1-1809 [003] … 275.594590: rtcpu_vinotify_event: tstamp:8891508571 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8891508002 data:0x00000010
kworker/3:1-1809 [003] … 275.594605: rtos_queue_peek_from_isr_failed: tstamp:8891869087 queue:0x0b4b4500
kworker/3:1-1809 [003] … 275.594610: rtcpu_vinotify_event: tstamp:8892132321 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8892131749 data:0x00000010
kworker/3:1-1809 [003] … 275.594615: rtcpu_vinotify_event: tstamp:8892758063 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8892757495 data:0x00000010
kworker/3:1-1809 [003] … 275.650572: rtcpu_vinotify_event: tstamp:8893381808 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8893381241 data:0x00000010
kworker/3:1-1809 [003] … 275.650581: rtcpu_vinotify_event: tstamp:8894007553 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8894006987 data:0x00000010
kworker/3:1-1809 [003] … 275.650584: rtcpu_vinotify_event: tstamp:8894631286 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8894630734 data:0x00000010
vi-output, adv7-8009 [003] … 275.668471: tegra_channel_capture_setup: vnc_id 0 W 720 H 576 fmt 20
vi-output, adv7-8009 [003] … 275.668499: tegra_channel_capture_frame: sof:-549620695332.-267596731584
kworker/3:1-1809 [003] … 275.706562: rtos_queue_send_from_isr_failed: tstamp:8894689566 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.706568: rtos_queue_send_from_isr_failed: tstamp:8894690022 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.706571: rtos_queue_send_from_isr_failed: tstamp:8894690478 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.706574: rtos_queue_send_from_isr_failed: tstamp:8894690931 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.706577: rtos_queue_send_from_isr_failed: tstamp:8894691413 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.706580: rtos_queue_send_from_isr_failed: tstamp:8894691868 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.706583: rtos_queue_send_from_isr_failed: tstamp:8894692324 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.706585: rtos_queue_send_from_isr_failed: tstamp:8894692777 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.706588: rtos_queue_send_failed: tstamp:8894694755 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.706591: rtos_queue_send_from_isr_failed: tstamp:8894700118 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.706594: rtos_queue_send_from_isr_failed: tstamp:8894700573 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.706596: rtos_queue_send_from_isr_failed: tstamp:8894701033 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.706599: rtos_queue_send_from_isr_failed: tstamp:8894701488 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.706601: rtos_queue_send_from_isr_failed: tstamp:8894701941 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.706604: rtos_queue_send_from_isr_failed: tstamp:8894702394 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.706607: rtos_queue_send_from_isr_failed: tstamp:8894702845 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.706609: rtos_queue_send_from_isr_failed: tstamp:8894703297 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.706612: rtos_queue_send_failed: tstamp:8894705236 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.706615: rtos_queue_send_from_isr_failed: tstamp:8895229984 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.706617: rtos_queue_send_from_isr_failed: tstamp:8895230091 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.706620: rtos_queue_send_from_isr_failed: tstamp:8895230198 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.706623: rtos_queue_send_from_isr_failed: tstamp:8895230305 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.706626: rtos_queue_send_from_isr_failed: tstamp:8895230408 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.706628: rtos_queue_send_from_isr_failed: tstamp:8895230512 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.706631: rtos_queue_send_from_isr_failed: tstamp:8895230617 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.706633: rtos_queue_send_from_isr_failed: tstamp:8895230721 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.706636: rtos_queue_send_failed: tstamp:8895231183 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.706639: rtos_queue_send_from_isr_failed: tstamp:8895232562 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.706642: rtos_queue_send_from_isr_failed: tstamp:8895232669 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.706644: rtos_queue_send_from_isr_failed: tstamp:8895232774 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.706647: rtos_queue_send_from_isr_failed: tstamp:8895232880 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.706649: rtos_queue_send_from_isr_failed: tstamp:8895232985 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.706652: rtos_queue_send_from_isr_failed: tstamp:8895233090 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.706655: rtos_queue_send_from_isr_failed: tstamp:8895233194 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.706657: rtos_queue_send_from_isr_failed: tstamp:8895233297 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.706660: rtos_queue_send_failed: tstamp:8895234245 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.706664: rtcpu_vinotify_event: tstamp:8895862606 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:1 vi_tstamp:8895861979 data:0x00000001
kworker/3:1-1809 [003] … 275.706666: rtcpu_vinotify_event: tstamp:8895862781 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:8895861982 data:0x00000001
kworker/3:1-1809 [003] … 275.706669: rtcpu_vinotify_event: tstamp:8895880621 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8895880225 data:0x00000010
kworker/3:1-1809 [003] … 275.762605: rtcpu_vinotify_event: tstamp:8896506527 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8896505971 data:0x00000010
kworker/3:1-1809 [003] … 275.762619: rtos_queue_peek_from_isr_failed: tstamp:8896869222 queue:0x0b4b4500
kworker/3:1-1809 [003] … 275.762623: rtcpu_vinotify_event: tstamp:8897130289 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8897129717 data:0x00000010
kworker/3:1-1809 [003] … 275.762626: rtcpu_vinotify_event: tstamp:8897756034 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8897755464 data:0x00000010
kworker/3:1-1809 [003] … 275.818611: rtcpu_vinotify_event: tstamp:8898379779 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8898379210 data:0x00000010
kworker/3:1-1809 [003] … 275.818618: rtcpu_vinotify_event: tstamp:8899005526 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8899004955 data:0x00000010
kworker/3:1-1809 [003] … 275.818623: rtcpu_vinotify_event: tstamp:8899629271 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8899628702 data:0x00000010
kworker/3:1-1809 [003] … 275.877296: rtcpu_vinotify_event: tstamp:8900255016 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8900254447 data:0x00000010
kworker/3:1-1809 [003] … 275.877310: rtcpu_vinotify_event: tstamp:8900878760 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8900878193 data:0x00000010
kworker/3:1-1809 [003] … 275.877314: rtcpu_vinotify_event: tstamp:8901504509 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8901503940 data:0x00000010
vi-output, adv7-8009 [000] … 275.922574: tegra_channel_capture_setup: vnc_id 0 W 720 H 576 fmt 20
vi-output, adv7-8009 [000] … 275.922620: tegra_channel_capture_frame: sof:-549620695332.-267596731584
kworker/3:1-1809 [003] … 275.930597: rtos_queue_peek_from_isr_failed: tstamp:8901868948 queue:0x0b4b4500
kworker/3:1-1809 [003] … 275.930607: rtos_queue_send_from_isr_failed: tstamp:8902123338 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.930610: rtos_queue_send_from_isr_failed: tstamp:8902123482 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.930613: rtos_queue_send_from_isr_failed: tstamp:8902123627 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.930616: rtos_queue_send_from_isr_failed: tstamp:8902123766 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.930618: rtos_queue_send_from_isr_failed: tstamp:8902123904 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.930621: rtos_queue_send_from_isr_failed: tstamp:8902124040 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.930624: rtos_queue_send_from_isr_failed: tstamp:8902124176 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.930627: rtos_queue_send_from_isr_failed: tstamp:8902124313 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.930632: rtos_queue_send_failed: tstamp:8902125004 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.930635: rtos_queue_send_from_isr_failed: tstamp:8902127892 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.930637: rtos_queue_send_from_isr_failed: tstamp:8902128031 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.930640: rtos_queue_send_from_isr_failed: tstamp:8902128170 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.930643: rtos_queue_send_from_isr_failed: tstamp:8902128312 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.930646: rtos_queue_send_from_isr_failed: tstamp:8902128451 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.930648: rtos_queue_send_from_isr_failed: tstamp:8902128587 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.930651: rtos_queue_send_from_isr_failed: tstamp:8902128725 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.930654: rtos_queue_send_from_isr_failed: tstamp:8902128861 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.930656: rtos_queue_send_failed: tstamp:8902129464 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.930659: rtos_queue_send_from_isr_failed: tstamp:8903159251 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.930662: rtos_queue_send_from_isr_failed: tstamp:8903159433 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.930664: rtos_queue_send_from_isr_failed: tstamp:8903159607 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.930667: rtos_queue_send_from_isr_failed: tstamp:8903159788 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.930670: rtos_queue_send_from_isr_failed: tstamp:8903159962 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.930672: rtos_queue_send_from_isr_failed: tstamp:8903160146 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.930675: rtos_queue_send_from_isr_failed: tstamp:8903160320 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.930678: rtos_queue_send_from_isr_failed: tstamp:8903160499 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.930680: rtos_queue_send_failed: tstamp:8903161211 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.930683: rtos_queue_send_from_isr_failed: tstamp:8903170736 queue:0x0b4a7258
kworker/3:1-1809 [003] … 275.930686: rtos_queue_send_from_isr_failed: tstamp:8903170911 queue:0x0b4aad68
kworker/3:1-1809 [003] … 275.930688: rtos_queue_send_from_isr_failed: tstamp:8903171086 queue:0x0b4ac998
kworker/3:1-1809 [003] … 275.930691: rtos_queue_send_from_isr_failed: tstamp:8903171261 queue:0x0b4ae518
kworker/3:1-1809 [003] … 275.930693: rtos_queue_send_from_isr_failed: tstamp:8903171434 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 275.930696: rtos_queue_send_from_isr_failed: tstamp:8903171613 queue:0x0b4b0098
kworker/3:1-1809 [003] … 275.930699: rtos_queue_send_from_isr_failed: tstamp:8903171785 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 275.930701: rtos_queue_send_from_isr_failed: tstamp:8903171965 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 275.930704: rtos_queue_send_failed: tstamp:8903173843 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.042613: rtos_queue_peek_from_isr_failed: tstamp:8906869163 queue:0x0b4b4500
kworker/3:1-1809 [003] … 276.161559: rtos_queue_send_from_isr_failed: tstamp:8910089756 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.161580: rtos_queue_send_from_isr_failed: tstamp:8910090212 queue:0x0b4aad68
kworker/3:1-1809 [003] … 276.161583: rtos_queue_send_from_isr_failed: tstamp:8910090665 queue:0x0b4ac998
kworker/3:1-1809 [003] … 276.161587: rtos_queue_send_from_isr_failed: tstamp:8910091130 queue:0x0b4ae518
kworker/3:1-1809 [003] … 276.161591: rtos_queue_send_from_isr_failed: tstamp:8910091578 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 276.161594: rtos_queue_send_from_isr_failed: tstamp:8910092029 queue:0x0b4b0098
kworker/3:1-1809 [003] … 276.161598: rtos_queue_send_from_isr_failed: tstamp:8910092479 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 276.161603: rtos_queue_send_from_isr_failed: tstamp:8910092929 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 276.161611: rtos_queue_send_failed: tstamp:8910095043 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.161615: rtos_queue_send_from_isr_failed: tstamp:8910102846 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.161624: rtos_queue_send_from_isr_failed: tstamp:8910103299 queue:0x0b4aad68
kworker/3:1-1809 [003] … 276.161628: rtos_queue_send_from_isr_failed: tstamp:8910103751 queue:0x0b4ac998
kworker/3:1-1809 [003] … 276.161632: rtos_queue_send_from_isr_failed: tstamp:8910104204 queue:0x0b4ae518
kworker/3:1-1809 [003] … 276.161636: rtos_queue_send_from_isr_failed: tstamp:8910104717 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 276.161639: rtos_queue_send_from_isr_failed: tstamp:8910105167 queue:0x0b4b0098
kworker/3:1-1809 [003] … 276.161645: rtos_queue_send_from_isr_failed: tstamp:8910105617 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 276.161648: rtos_queue_send_from_isr_failed: tstamp:8910106067 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 276.161652: rtos_queue_send_failed: tstamp:8910107936 queue:0x0b4a7258
vi-output, adv7-8009 [000] … 276.187692: tegra_channel_capture_setup: vnc_id 0 W 720 H 576 fmt 20
vi-output, adv7-8009 [000] … 276.187779: tegra_channel_capture_frame: sof:-549620695332.-267596731584
kworker/3:1-1809 [003] … 276.214567: rtos_queue_send_from_isr_failed: tstamp:8911436312 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.214573: rtos_queue_send_from_isr_failed: tstamp:8911436766 queue:0x0b4aad68
kworker/3:1-1809 [003] … 276.214576: rtos_queue_send_from_isr_failed: tstamp:8911437221 queue:0x0b4ac998
kworker/3:1-1809 [003] … 276.214578: rtos_queue_send_from_isr_failed: tstamp:8911437676 queue:0x0b4ae518
kworker/3:1-1809 [003] … 276.214581: rtos_queue_send_from_isr_failed: tstamp:8911438128 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 276.214583: rtos_queue_send_from_isr_failed: tstamp:8911438580 queue:0x0b4b0098
kworker/3:1-1809 [003] … 276.214586: rtos_queue_send_from_isr_failed: tstamp:8911439038 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 276.214589: rtos_queue_send_from_isr_failed: tstamp:8911439490 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 276.214591: rtos_queue_send_failed: tstamp:8911441464 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.214594: rtos_queue_send_from_isr_failed: tstamp:8911448258 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.214597: rtos_queue_send_from_isr_failed: tstamp:8911448712 queue:0x0b4aad68
kworker/3:1-1809 [003] … 276.214600: rtos_queue_send_from_isr_failed: tstamp:8911449196 queue:0x0b4ac998
kworker/3:1-1809 [003] … 276.214602: rtos_queue_send_from_isr_failed: tstamp:8911449654 queue:0x0b4ae518
kworker/3:1-1809 [003] … 276.214605: rtos_queue_send_from_isr_failed: tstamp:8911450109 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 276.214608: rtos_queue_send_from_isr_failed: tstamp:8911450575 queue:0x0b4b0098
kworker/3:1-1809 [003] … 276.214610: rtos_queue_send_from_isr_failed: tstamp:8911451029 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 276.214613: rtos_queue_send_from_isr_failed: tstamp:8911451482 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 276.214616: rtos_queue_send_failed: tstamp:8911457383 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.214620: rtos_queue_peek_from_isr_failed: tstamp:8911869004 queue:0x0b4b4500
kworker/3:1-1809 [003] … 276.214626: rtcpu_vinotify_event: tstamp:8912106145 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:1 vi_tstamp:8912105377 data:0x00000001
kworker/3:1-1809 [003] … 276.214629: rtcpu_vinotify_event: tstamp:8912106636 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:8912105380 data:0x00000001
kworker/3:1-1809 [003] … 276.214631: rtcpu_vinotify_event: tstamp:8912124044 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8912123623 data:0x00000010
kworker/3:1-1809 [003] … 276.270598: rtcpu_vinotify_event: tstamp:8912749940 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8912749368 data:0x00000010
kworker/3:1-1809 [003] … 276.270608: rtcpu_vinotify_event: tstamp:8913373686 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8913373115 data:0x00000010
kworker/3:1-1809 [003] … 276.270611: rtcpu_vinotify_event: tstamp:8913999433 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8913998861 data:0x00000010
kworker/3:1-1809 [003] … 276.326817: rtcpu_vinotify_event: tstamp:8914623179 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8914622607 data:0x00000010
kworker/3:1-1809 [003] … 276.326845: rtcpu_vinotify_event: tstamp:8915248926 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8915248353 data:0x00000010
kworker/3:1-1809 [003] … 276.382795: rtcpu_vinotify_event: tstamp:8915872511 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8915872100 data:0x00000010
kworker/3:1-1809 [003] … 276.382820: rtcpu_vinotify_event: tstamp:8916498468 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8916497845 data:0x00000010
kworker/3:1-1809 [003] … 276.382839: rtos_queue_peek_from_isr_failed: tstamp:8916869176 queue:0x0b4b4500
kworker/3:1-1809 [003] … 276.382843: rtcpu_vinotify_event: tstamp:8917122162 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8917121591 data:0x00000010
vi-output, adv7-8009 [003] … 276.426057: tegra_channel_capture_setup: vnc_id 0 W 720 H 576 fmt 20
vi-output, adv7-8009 [003] … 276.426093: tegra_channel_capture_frame: sof:-549620695332.-267596731584
kworker/3:1-1809 [003] … 276.438596: rtcpu_vinotify_event: tstamp:8917747906 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8917747337 data:0x00000010
kworker/3:1-1809 [003] … 276.438617: rtos_queue_send_from_isr_failed: tstamp:8918354502 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.438623: rtos_queue_send_from_isr_failed: tstamp:8918354967 queue:0x0b4aad68
kworker/3:1-1809 [003] … 276.438627: rtos_queue_send_from_isr_failed: tstamp:8918355419 queue:0x0b4ac998
kworker/3:1-1809 [003] … 276.438633: rtos_queue_send_from_isr_failed: tstamp:8918355874 queue:0x0b4ae518
kworker/3:1-1809 [003] … 276.438638: rtos_queue_send_from_isr_failed: tstamp:8918356324 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 276.438642: rtos_queue_send_from_isr_failed: tstamp:8918356774 queue:0x0b4b0098
kworker/3:1-1809 [003] … 276.438648: rtos_queue_send_from_isr_failed: tstamp:8918357224 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 276.438652: rtos_queue_send_from_isr_failed: tstamp:8918357674 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 276.438664: rtos_queue_send_failed: tstamp:8918360039 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.438668: rtos_queue_send_from_isr_failed: tstamp:8918370213 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.438672: rtos_queue_send_from_isr_failed: tstamp:8918370666 queue:0x0b4aad68
kworker/3:1-1809 [003] … 276.438676: rtos_queue_send_from_isr_failed: tstamp:8918371145 queue:0x0b4ac998
kworker/3:1-1809 [003] … 276.438681: rtos_queue_send_from_isr_failed: tstamp:8918371601 queue:0x0b4ae518
kworker/3:1-1809 [003] … 276.438685: rtos_queue_send_from_isr_failed: tstamp:8918372053 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 276.438689: rtos_queue_send_from_isr_failed: tstamp:8918372504 queue:0x0b4b0098
kworker/3:1-1809 [003] … 276.438694: rtos_queue_send_from_isr_failed: tstamp:8918372958 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 276.438698: rtos_queue_send_from_isr_failed: tstamp:8918373411 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 276.438702: rtos_queue_send_failed: tstamp:8918375204 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.438707: rtos_queue_send_from_isr_failed: tstamp:8918901899 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.438711: rtos_queue_send_from_isr_failed: tstamp:8918902037 queue:0x0b4aad68
kworker/3:1-1809 [003] … 276.438716: rtos_queue_send_from_isr_failed: tstamp:8918902177 queue:0x0b4ac998
kworker/3:1-1809 [003] … 276.438720: rtos_queue_send_from_isr_failed: tstamp:8918902316 queue:0x0b4ae518
kworker/3:1-1809 [003] … 276.438724: rtos_queue_send_from_isr_failed: tstamp:8918902454 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 276.438728: rtos_queue_send_from_isr_failed: tstamp:8918902591 queue:0x0b4b0098
kworker/3:1-1809 [003] … 276.438733: rtos_queue_send_from_isr_failed: tstamp:8918902730 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 276.438737: rtos_queue_send_from_isr_failed: tstamp:8918902867 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 276.438741: rtos_queue_send_failed: tstamp:8918903447 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.438745: rtos_queue_send_from_isr_failed: tstamp:8918905856 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.438749: rtos_queue_send_from_isr_failed: tstamp:8918905995 queue:0x0b4aad68
kworker/3:1-1809 [003] … 276.438754: rtos_queue_send_from_isr_failed: tstamp:8918906134 queue:0x0b4ac998
kworker/3:1-1809 [003] … 276.438758: rtos_queue_send_from_isr_failed: tstamp:8918906271 queue:0x0b4ae518
kworker/3:1-1809 [003] … 276.438762: rtos_queue_send_from_isr_failed: tstamp:8918906409 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 276.438766: rtos_queue_send_from_isr_failed: tstamp:8918906567 queue:0x0b4b0098
kworker/3:1-1809 [003] … 276.438770: rtos_queue_send_from_isr_failed: tstamp:8918906704 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 276.438775: rtos_queue_send_from_isr_failed: tstamp:8918906842 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 276.438779: rtos_queue_send_failed: tstamp:8918908245 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.494601: rtcpu_vinotify_event: tstamp:8919603111 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:1 vi_tstamp:8919602329 data:0x00000001
kworker/3:1-1809 [003] … 276.494612: rtcpu_vinotify_event: tstamp:8919603738 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:8919602332 data:0x00000001
kworker/3:1-1809 [003] … 276.494616: rtcpu_vinotify_event: tstamp:8919621146 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8919620576 data:0x00000010
kworker/3:1-1809 [003] … 276.494622: rtcpu_vinotify_event: tstamp:8920246893 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8920246322 data:0x00000010
kworker/3:1-1809 [003] … 276.494625: rtcpu_vinotify_event: tstamp:8920870638 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8920870068 data:0x00000010
kworker/3:1-1809 [003] … 276.550566: rtcpu_vinotify_event: tstamp:8921496382 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8921495813 data:0x00000010
kworker/3:1-1809 [003] … 276.550580: rtos_queue_peek_from_isr_failed: tstamp:8921869241 queue:0x0b4b4500
kworker/3:1-1809 [003] … 276.550584: rtcpu_vinotify_event: tstamp:8922120132 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8922119560 data:0x00000010
kworker/3:1-1809 [003] … 276.550587: rtcpu_vinotify_event: tstamp:8922745878 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8922745306 data:0x00000010
kworker/3:1-1809 [003] … 276.606620: rtcpu_vinotify_event: tstamp:8923369621 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8923369052 data:0x00000010
kworker/3:1-1809 [003] … 276.606628: rtcpu_vinotify_event: tstamp:8923995369 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8923994799 data:0x00000010
vi-output, adv7-8009 [004] … 276.661892: tegra_channel_capture_setup: vnc_id 0 W 720 H 576 fmt 20
vi-output, adv7-8009 [004] … 276.661974: tegra_channel_capture_frame: sof:-549620695332.-267596731584
kworker/3:1-1809 [003] … 276.662622: rtcpu_vinotify_event: tstamp:8924619115 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8924618545 data:0x00000010
kworker/3:1-1809 [003] … 276.662626: rtcpu_vinotify_event: tstamp:8925244861 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:8925244291 data:0x00000010
kworker/3:1-1809 [003] … 276.662637: rtos_queue_send_from_isr_failed: tstamp:8925700788 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.662642: rtos_queue_send_from_isr_failed: tstamp:8925700967 queue:0x0b4aad68
kworker/3:1-1809 [003] … 276.662646: rtos_queue_send_from_isr_failed: tstamp:8925701145 queue:0x0b4ac998
kworker/3:1-1809 [003] … 276.662648: rtos_queue_send_from_isr_failed: tstamp:8925701322 queue:0x0b4ae518
kworker/3:1-1809 [003] … 276.662651: rtos_queue_send_from_isr_failed: tstamp:8925701495 queue:0x0b4af2d8
kworker/3:1-1809 [003] … 276.662655: rtos_queue_send_from_isr_failed: tstamp:8925701667 queue:0x0b4b0098
kworker/3:1-1809 [003] … 276.662659: rtos_queue_send_from_isr_failed: tstamp:8925701840 queue:0x0b4b0e58
kworker/3:1-1809 [003] … 276.662663: rtos_queue_send_from_isr_failed: tstamp:8925702014 queue:0x0b4b1c18
kworker/3:1-1809 [003] … 276.662669: rtos_queue_send_failed: tstamp:8925702853 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.662673: rtos_queue_send_from_isr_failed: tstamp:8925708807 queue:0x0b4a7258
kworker/3:1-1809 [003] … 276.662677: rtos_queue_send_from_isr_failed: tstamp:8925708987 queue:0x0b4aad68
kworker/3:1-1809 [003] … 276.662681: rtos_queue_send_from_isr_failed: tstamp:8925709161 queue:0x0b4ac998
kworker/3:1-1809 [003] … 276.662686: rtos_queue_send_from_isr_failed: tstamp:8925709336 queue:0x0b4ae518
kworker/3:1-1809 [003] … 276.662690: rtos_qu
Looks like there’s no FS package for a frame.
but, the vendor reply me such as:
ADV728x-M outputs MIPI frame start/end packets as well as line start/end packets.
how to check this point ?
