We are currently developing an extension board for the TX2 development board which is connected over the camera connector. On the extension board, there is a deserializer hub from Maxim (MAX9286). Over 4 GMSL links we connect 4 serializers from Maxim(MAX96705). On each serializer an AR0144 from OnSemi is connected.
+--> MAX96705 <---parallel---> AR0144
Jetson TX2 <---CSI2---> MAX9286 <---GMSL--+
Hardware:
We have testing hardware for the Frontends (MAX96705 + AR0144), therefore we can assume, that the hardware with the serializer and the sensor works.
Software:
We can configure over i2c the deserialzer-hub (MAX9286). After configuring it correctly we get the configuration link running, and we can communicate over i2c with the serializer(MAX92705) and the sensor(AR0144). After configuring the sensor, we get the pixel clock out of the sensor, and we can switch the GMSL from configuration link to video link. The deserializer-hub(MAX9286) confirms the video link and can lock on the video link. We can now also measure decent looking MIPI/CSI data on D0 and D1 and get a 110MHz clock on the MIPI/CSI2 clock lans. (I hope you can see the uploaded file)
Now our problem starts:
We are not able to capture the an image on the TX2. We use L4T 32.3.1. We modified the device tree by adding the following code at the end of the otherwise unmodified device tree file from the dev-board (tegra186-quill-p3310-1000-c03-00-base.dts):
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
#include "dt-bindings/clock/tegra186-clock.h"
host1x {
vi@15700000 {
status = "okay";
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
port@0 {
reg = <0>;
status = "okay";
max9286_vi_in: endpoint {
status = "okay";
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&max9286_csi_out>;
nvcsi@150c0000 {
num-channels = <1>;
#size-cells = <0>;
status = "okay";
channel@0 {
reg = <0>;
status = "okay";
ports {
#size-cells = <0>;
status = "okay";
port@0 {
reg = <0>;
status = "okay";
max9286_csi_in: endpoint@0 {
status = "okay";
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&max9286_out>;
port@1 {
reg = <1>;
status = "okay";
max9286_csi_out: endpoint@1 {
status = "okay";
remote-endpoint = <&max9286_vi_in>;
i2c@3180000 {
status = "okay";
#size-cells = <0>;
gpio_expander: gpio@20{
compatible = "nxp,pca9555";
gpio-controller;
#gpio-cells = <2>;
reg = <0x20>;
vcc-supply = <&en_vdd_cam>;
vdd-supply = <&en_vdd_cam>;
max9286@48 {
status = "okay";
compatible = "nvidia,imx185";
reg = <0x48>;
avdd-reg = "vana";
iovdd-reg = "vif";
post_crop_frame_drop = "0";
clocks = <&tegra_car TEGRA186_CLK_EXTPERIPH1>,
<&tegra_car TEGRA186_CLK_PLLP_OUT0>;
clock-names = "extperiph1", "pllp_grtba";
mclk = "extperiph1";
clock-frequency = <24000000>;
vana-supply = <&vdd_fan>;
vif-supply = <&vdd_fan>;
mode0 {
mclk_khz = "27000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
pixel_phase = "rggb";
active_w = "1280";
active_h = "720";
pix_clk_hz = "74250000";
deskew_initial_enable = "true";
line_length = "1488";
readout_orientation = "0";
inherent_gain = "1";
mclk_multiplier = "4";
min_gain_val = "0"; /* dB */
max_gain_val = "48"; /* dB */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "1.5";
max_framerate = "30";
min_exp_time = "30";
max_exp_time = "660000";
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
max9286_out: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&max9286_csi_in>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
modules {
module0 {
badge = "max9286_hub";
position = "top";
orientation = "1";
drivernode0 {
pcl_id = "v4l2_sensor";
devname = "MAX 9286";
proc-device-tree = "/proc/device-tree/i2c@3180000/max9286@48";
status = "okay";
We also modified the imx185 driver as the driver development guide recommends. We removed all configuration abilities from the driver, because we configure the GMSL link and the sensor over i2c from user space. We did this also on another project where the method worked quite well. Here is our modified driver:
imx185.c
* imx185.c - imx185 sensor driver
* Copyright (c) 2016-2019, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify it
* under the terms and conditions of the GNU General Public License,
* version 2, as published by the Free Software Foundation.
* This program is distributed in the hope it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include "imx185_mode_tbls.h"
#include <linux/gpio.h>
#include <linux/module.h>
#include <linux/of.h>
#include <linux/of_device.h>
#include <linux/of_gpio.h>
#include <linux/seq_file.h>
#include <linux/slab.h>
#include <linux/uaccess.h>
#include <media/tegra_v4l2_camera.h>
#include <media/tegracam_core.h>
#define CREATE_TRACE_POINTS
#include <trace/events/imx185.h>
#define IMX185_MIN_FRAME_LENGTH (1125)
#define IMX185_MAX_FRAME_LENGTH (0x1FFFF)
#define IMX185_MIN_SHS1_1080P_HDR (5)
#define IMX185_MIN_SHS2_1080P_HDR (82)
#define IMX185_MAX_SHS2_1080P_HDR (IMX185_MAX_FRAME_LENGTH - 5)
#define IMX185_MAX_SHS1_1080P_HDR (IMX185_MAX_SHS2_1080P_HDR / 16)
#define IMX185_FRAME_LENGTH_ADDR_MSB 0x301A
#define IMX185_FRAME_LENGTH_ADDR_MID 0x3019
#define IMX185_FRAME_LENGTH_ADDR_LSB 0x3018
#define IMX185_COARSE_TIME_SHS1_ADDR_MSB 0x3022
#define IMX185_COARSE_TIME_SHS1_ADDR_MID 0x3021
#define IMX185_COARSE_TIME_SHS1_ADDR_LSB 0x3020
#define IMX185_COARSE_TIME_SHS2_ADDR_MSB 0x3025
#define IMX185_COARSE_TIME_SHS2_ADDR_MID 0x3024
#define IMX185_COARSE_TIME_SHS2_ADDR_LSB 0x3023
#define IMX185_GAIN_ADDR 0x3014
#define IMX185_GROUP_HOLD_ADDR 0x3001
#define IMX185_SW_RESET_ADDR 0x3003
#define IMX185_ANALOG_GAIN_LIMIT_ADDR 0x3012
#define IMX185_ANALOG_GAIN_LIMIT_VALUE 0x0f
#define IMX185_FUSE_ID_ADDR 0x3382
#define IMX185_FUSE_ID_SIZE 6
#define IMX185_FUSE_ID_STR_SIZE 0 //(IMX185_FUSE_ID_SIZE * 2)
static const struct of_device_id imx185_of_match[] = {
.compatible = "nvidia,imx185",
MODULE_DEVICE_TABLE(of, imx185_of_match);
static const u32 ctrl_cid_list[] = {
// TEGRA_CAMERA_CID_GAIN, TEGRA_CAMERA_CID_EXPOSURE, TEGRA_CAMERA_CID_FRAME_RATE,
// TEGRA_CAMERA_CID_FUSE_ID, TEGRA_CAMERA_CID_HDR_EN, TEGRA_CAMERA_CID_SENSOR_MODE_ID,
struct imx185
struct i2c_client * i2c_client;
struct v4l2_subdev * subdev;
u8 fuse_id[IMX185_FUSE_ID_SIZE];
u32 frame_length;
s64 last_wdr_et_val;
struct camera_common_data *s_data;
struct tegracam_device * tc_dev;
static const struct regmap_config sensor_regmap_config = {
.reg_bits = 16,
.val_bits = 8,
.cache_type = REGCACHE_RBTREE,
.use_single_rw = true,
static inline void imx185_get_frame_length_regs(imx185_reg *regs, u32 frame_length)
regs->addr = IMX185_FRAME_LENGTH_ADDR_MSB;
regs->val = (frame_length >> 16) & 0x01;
(regs + 1)->addr = IMX185_FRAME_LENGTH_ADDR_MID;
(regs + 1)->val = (frame_length >> 8) & 0xff;
(regs + 2)->addr = IMX185_FRAME_LENGTH_ADDR_LSB;
(regs + 2)->val = (frame_length)&0xff;
static inline void imx185_get_coarse_time_regs_shs1(imx185_reg *regs, u32 coarse_time)
regs->addr = IMX185_COARSE_TIME_SHS1_ADDR_MSB;
regs->val = (coarse_time >> 16) & 0x01;
(regs + 1)->addr = IMX185_COARSE_TIME_SHS1_ADDR_MID;
(regs + 1)->val = (coarse_time >> 8) & 0xff;
(regs + 2)->addr = IMX185_COARSE_TIME_SHS1_ADDR_LSB;
(regs + 2)->val = (coarse_time)&0xff;
static inline void imx185_get_coarse_time_regs_shs2(imx185_reg *regs, u32 coarse_time)
regs->addr = IMX185_COARSE_TIME_SHS2_ADDR_MSB;
(regs + 1)->addr = IMX185_COARSE_TIME_SHS2_ADDR_MID;
(regs + 2)->addr = IMX185_COARSE_TIME_SHS2_ADDR_LSB;
static inline void imx185_get_gain_reg(imx185_reg *regs, u8 gain)
regs->addr = IMX185_GAIN_ADDR;
regs->val = (gain)&0xff;
static int test_mode;
module_param(test_mode, int, 0644);
static inline int imx185_read_reg(struct camera_common_data *s_data, u16 addr, u8 *val)
int err = 0;
u32 reg_val = 0;
err = regmap_read(s_data->regmap, addr, ®_val);
*val = reg_val & 0xFF;
return err;
static int imx185_write_reg(struct camera_common_data *s_data, u16 addr, u8 val)
int err;
struct device *dev = s_data->dev;
err = regmap_write(s_data->regmap, addr, val);
if (err)
dev_err(dev, "%s: i2c write failed, 0x%x = %x\n", __func__, addr, val);
return err;
static int imx185_set_group_hold(struct tegracam_device *tc_dev, bool val)
// struct camera_common_data *s_data = tc_dev->s_data;
// struct device * dev = tc_dev->dev;
// int err;
// err = imx185_write_reg(s_data, IMX185_GROUP_HOLD_ADDR, val);
// if (err)
// dev_dbg(dev, "%s: Group hold control error\n", __func__);
// return err;
return 0;
static int imx185_set_gain(struct tegracam_device *tc_dev, s64 val)
// struct camera_common_data * s_data = tc_dev->s_data;
// struct imx185 * priv = (struct imx185 *)tc_dev->priv;
// const struct sensor_mode_properties *mode = &s_data->sensor_props.sensor_modes[s_data->mode_prop_idx];
// imx185_reg reg_list[1];
// int err;
// u8 gain;
///* translate value */
// gain = (u8)(val * 160 / (48 * mode->control_properties.gain_factor));
// dev_dbg(dev, "%s: gain reg: %d\n", __func__, gain);
// imx185_get_gain_reg(reg_list, gain);
// err = imx185_write_reg(priv->s_data, reg_list[0].addr, reg_list[0].val);
// if (err)
// goto fail;
return 0;
// fail:
// dev_dbg(dev, "%s: GAIN control error\n", __func__);
// return err;
static int imx185_set_frame_rate(struct tegracam_device *tc_dev, s64 val)
// imx185_reg reg_list[3];
// int err;
// u32 frame_length;
// struct v4l2_control control;
// int hdr_en;
// int i = 0;
// frame_length = mode->signal_properties.pixel_clock.val * mode->control_properties.framerate_factor /
// mode->image_properties.line_length / val;
// priv->frame_length = frame_length;
// if (priv->frame_length > IMX185_MAX_FRAME_LENGTH)
// priv->frame_length = IMX185_MAX_FRAME_LENGTH;
// dev_dbg(dev, "%s: val: %lld, , frame_length: %d\n", __func__, val, priv->frame_length);
// imx185_get_frame_length_regs(reg_list, priv->frame_length);
// for (i = 0; i < 3; i++)
// err = imx185_write_reg(priv->s_data, reg_list[i].addr, reg_list[i].val);
// if (err)
// goto fail;
// /* check hdr enable ctrl */
// control.id = TEGRA_CAMERA_CID_HDR_EN;
// err = camera_common_g_ctrl(s_data, &control);
// if (err < 0)
// dev_err(dev, "could not find device ctrl.\n");
// return err;
// hdr_en = switch_ctrl_qmenu[control.value];
// if ((hdr_en == SWITCH_ON) && (priv->last_wdr_et_val != 0))
// err = imx185_set_coarse_time_hdr(priv, priv->last_wdr_et_val);
// if (err)
// dev_dbg(dev, "%s: error coarse time SHS1 SHS2 override\n", __func__);
return 0;
// fail:
// dev_dbg(dev, "%s: FRAME_LENGTH control error\n", __func__);
// return err;
static int imx185_set_exposure(struct tegracam_device *tc_dev, s64 val)
// int err;
// int hdr_en;
// dev_dbg(dev, "%s: val: %lld\n", __func__, val);
// if (err < 0)
// return err;
// if (hdr_en == SWITCH_ON)
// err = imx185_set_coarse_time_hdr(priv, val);
// if (err)
// else
// err = imx185_set_coarse_time(priv, val);
// if (err)
// dev_dbg(dev, "%s: error coarse time SHS1 override\n", __func__);
// return err;
return 0;
static int imx185_fill_string_ctrl(struct tegracam_device *tc_dev, struct v4l2_ctrl *ctrl)
// struct imx185 *priv = tc_dev->priv;
// int i;
// switch (ctrl->id)
// case TEGRA_CAMERA_CID_FUSE_ID:
// for (i = 0; i < IMX185_FUSE_ID_SIZE; i++)
// sprintf(&ctrl->p_new.p_char[i * 2], "%02x", priv->fuse_id[i]);
// break;
// default:
// return -EINVAL;
// ctrl->p_cur.p_char = ctrl->p_new.p_char;
return 0;
static struct tegracam_ctrl_ops imx185_ctrl_ops = {
.numctrls = ARRAY_SIZE(ctrl_cid_list),
.ctrl_cid_list = ctrl_cid_list,
.string_ctrl_size = {0, IMX185_FUSE_ID_STR_SIZE},
.set_gain = imx185_set_gain,
.set_exposure = imx185_set_exposure,
.set_frame_rate = imx185_set_frame_rate,
.set_group_hold = imx185_set_group_hold,
.fill_string_ctrl = imx185_fill_string_ctrl,
static int imx185_power_on(struct camera_common_data *s_data)
int err = 0;
struct camera_common_power_rail *pw = s_data->power;
struct camera_common_pdata * pdata = s_data->pdata;
struct device * dev = s_data->dev;
dev_dbg(dev, "%s: power on\n", __func__);
if (pdata && pdata->power_on)
err = pdata->power_on(pw);
if (err)
dev_err(dev, "%s failed.\n", __func__);
else
pw->state = SWITCH_ON;
return err;
// /*exit reset mode: XCLR */
// if (pw->reset_gpio)
// gpio_set_value(pw->reset_gpio, 0);
// usleep_range(30, 50);
// gpio_set_value(pw->reset_gpio, 1);
return 0;
static int imx185_power_off(struct camera_common_data *s_data)
int err = 0;
dev_dbg(dev, "%s: power off\n", __func__);
if (pdata && pdata->power_off)
err = pdata->power_off(pw);
if (!err)
goto power_off_done;
else
return err;
// /* enter reset mode: XCLR */
// usleep_range(1, 2);
power_off_done:
pw->state = SWITCH_OFF;
return 0;
static int imx185_power_get(struct tegracam_device *tc_dev)
const char * mclk_name;
struct clk * parent;
int err = 0;
mclk_name = pdata->mclk_name ? pdata->mclk_name : "extperiph1";
pw->mclk = devm_clk_get(dev, mclk_name);
if (IS_ERR(pw->mclk))
dev_err(dev, "unable to get clock %s\n", mclk_name);
return PTR_ERR(pw->mclk);
parent = devm_clk_get(dev, "pllp_grtba");
if (IS_ERR(parent))
dev_err(dev, "devm_clk_get failed for pllp_grtba");
else
clk_set_parent(pw->mclk, parent);
pw->reset_gpio = pdata->reset_gpio;
return err;
static int imx185_power_put(struct tegracam_device *tc_dev)
if (unlikely(!pw))
return -EFAULT;
return 0;
static struct camera_common_pdata *imx185_parse_dt(struct tegracam_device *tc_dev)
struct device_node * np = dev->of_node;
struct camera_common_pdata *board_priv_pdata;
const struct of_device_id * match;
// struct camera_common_pdata *ret = NULL;
int err;
// int gpio;
if (!np)
return NULL;
match = of_match_device(imx185_of_match, dev);
if (!match)
dev_err(dev, "Failed to find matching dt id\n");
return NULL;
board_priv_pdata = devm_kzalloc(dev, sizeof(*board_priv_pdata), GFP_KERNEL);
if (!board_priv_pdata)
return NULL;
err = of_property_read_string(np, "mclk", &board_priv_pdata->mclk_name);
if (err)
dev_err(dev, "mclk not in DT\n");
// gpio = of_get_named_gpio(np, "reset-gpios", 0);
// if (gpio < 0)
// if (gpio == -EPROBE_DEFER)
// ret = ERR_PTR(-EPROBE_DEFER);
// dev_err(dev, "reset-gpios not found %d\n", err);
// goto error;
// board_priv_pdata->reset_gpio = (unsigned int)gpio;
return board_priv_pdata;
// error:
// devm_kfree(dev, board_priv_pdata);
// return ret;
static int imx185_set_mode(struct tegracam_device *tc_dev)
// struct imx185 * priv = (struct imx185 *)tegracam_get_privdata(tc_dev);
struct device *dev = tc_dev->dev;
// struct device_node * np = dev->of_node;
// bool limit_analog_gain = false;
const struct of_device_id *match;
// int err;
if (!match)
return -EINVAL;
// limit_analog_gain = of_property_read_bool(np, "limit_analog_gain");
// err = imx185_write_table(priv, mode_table[s_data->mode_prop_idx]);
// if (err)
// return err;
// if (limit_analog_gain) {
// IMX185_ANALOG_GAIN_LIMIT_ADDR,
// IMX185_ANALOG_GAIN_LIMIT_VALUE);
// if (err)
// return err;
return 0;
static int imx185_start_streaming(struct tegracam_device *tc_dev)
(void)tc_dev;
// struct imx185 *priv = (struct imx185 *)tegracam_get_privdata(tc_dev);
// int err;
// if (test_mode)
// err = imx185_write_table(priv, mode_table[IMX185_MODE_TEST_PATTERN]);
// if (err)
// return err;
// err = imx185_write_table(priv, mode_table[IMX185_MODE_START_STREAM]);
// if (err)
// return err;
return 0;
static int imx185_stop_streaming(struct tegracam_device *tc_dev)
(void)tc_dev;
// int err;
// err = imx185_write_table(priv, mode_table[IMX185_MODE_STOP_STREAM]);
// if (err)
// return err;
///* SW_RESET will have no ACK */
// imx185_write_reg(s_data, IMX185_SW_RESET_ADDR, 0x01);
// * Wait for one frame to make sure sensor is set to
// * software standby in V-blank
// * delay = frame length rows * Tline (10 us)
// usleep_range(priv->frame_length * 10, priv->frame_length * 10 + 1000);
return 0;
static struct camera_common_sensor_ops imx185_common_ops = {
.numfrmfmts = ARRAY_SIZE(imx185_frmfmt),
.frmfmt_table = imx185_frmfmt,
.power_on = imx185_power_on,
.power_off = imx185_power_off,
.write_reg = imx185_write_reg,
.read_reg = imx185_read_reg,
.parse_dt = imx185_parse_dt,
.power_get = imx185_power_get,
.power_put = imx185_power_put,
.set_mode = imx185_set_mode,
.start_streaming = imx185_start_streaming,
.stop_streaming = imx185_stop_streaming,
static int imx185_fuse_id_setup(struct imx185 *priv)
// int err;
// int i;
// struct camera_common_data *s_data = priv->s_data;
// struct device * dev = s_data->dev;
// u8 bak = 0;
// err |= imx185_read_reg(s_data, IMX185_FUSE_ID_ADDR + i, &bak);
// if (!err)
// priv->fuse_id[i] = bak;
// else
// dev_err(dev, "%s: can not read fuse id\n", __func__);
// return -EINVAL;
return 0;
static int imx185_board_setup(struct imx185 *priv)
int err = 0;
dev_dbg(dev, "%s++\n", __func__);
err = camera_common_mclk_enable(s_data);
if (err)
dev_err(dev, "Error %d turning on mclk\n", err);
return err;
err = imx185_power_on(s_data);
if (err)
dev_err(dev, "Error %d during power on sensor\n", err);
return err;
err = imx185_fuse_id_setup(priv);
if (err)
dev_err(dev, "Error %d reading fuse id data\n", err);
goto error;
error:
imx185_power_off(s_data);
camera_common_mclk_disable(s_data);
return err;
static int imx185_open(struct v4l2_subdev *sd, struct v4l2_subdev_fh *fh)
(void)sd;
(void)fh;
// struct i2c_client *client = v4l2_get_subdevdata(sd);
// dev_dbg(&client->dev, "%s:\n", __func__);
return 0;
static const struct v4l2_subdev_internal_ops imx185_subdev_internal_ops = {
.open = imx185_open,
static int imx185_probe(struct i2c_client *client, const struct i2c_device_id *id)
struct device * dev = &client->dev;
struct tegracam_device *tc_dev;
struct imx185 * priv;
int err;
dev_info(dev, "probing v4l2 sensor\n");
if (!IS_ENABLED(CONFIG_OF) || !client->dev.of_node)
return -EINVAL;
priv = devm_kzalloc(dev, sizeof(struct imx185), GFP_KERNEL);
if (!priv)
return -ENOMEM;
tc_dev = devm_kzalloc(dev, sizeof(struct tegracam_device), GFP_KERNEL);
if (!tc_dev)
return -ENOMEM;
priv->i2c_client = tc_dev->client = client;
tc_dev->dev = dev;
strncpy(tc_dev->name, "imx185", sizeof(tc_dev->name));
tc_dev->dev_regmap_config = &sensor_regmap_config;
tc_dev->sensor_ops = &imx185_common_ops;
tc_dev->v4l2sd_internal_ops = &imx185_subdev_internal_ops;
tc_dev->tcctrl_ops = &imx185_ctrl_ops;
err = tegracam_device_register(tc_dev);
if (err)
dev_err(dev, "tegra camera driver registration failed\n");
return err;
priv->tc_dev = tc_dev;
priv->s_data = tc_dev->s_data;
priv->subdev = &tc_dev->s_data->subdev;
tegracam_set_privdata(tc_dev, (void *)priv);
err = imx185_board_setup(priv);
if (err)
dev_err(dev, "board setup failed\n");
return err;
err = tegracam_v4l2subdev_register(tc_dev, true);
if (err)
dev_err(dev, "tegra camera subdev registration failed\n");
return err;
dev_info(dev, "Detected IMX185 sensor\n");
return 0;
static int imx185_remove(struct i2c_client *client)
struct camera_common_data *s_data = to_camera_common_data(&client->dev);
struct imx185 * priv = (struct imx185 *)s_data->priv;
tegracam_v4l2subdev_unregister(priv->tc_dev);
tegracam_device_unregister(priv->tc_dev);
return 0;
static const struct i2c_device_id imx185_id[] = {{"imx185", 0}, {}};
MODULE_DEVICE_TABLE(i2c, imx185_id);
static struct i2c_driver imx185_i2c_driver = {
.driver =
.name = "imx185",
.owner = THIS_MODULE,
.of_match_table = of_match_ptr(imx185_of_match),
.probe = imx185_probe,
.remove = imx185_remove,
.id_table = imx185_id,
module_i2c_driver(imx185_i2c_driver);
MODULE_DESCRIPTION("Media Controller driver for Sony IMX185");
MODULE_AUTHOR("NVIDIA Corporation");
MODULE_LICENSE("GPL v2");
And here is the imx185_mode_tbls.h:
* imx185_mode_tbls.h - imx185 sensor mode tables
* Copyright (c) 2016-2017, NVIDIA CORPORATION. All rights reserved.
* more details.
#ifndef __IMX185_I2C_TABLES__
#define __IMX185_I2C_TABLES__
#include <linux/miscdevice.h>
#include <media/camera_common.h>
#define IMX185_TABLE_WAIT_MS 0
#define IMX185_TABLE_END 1
#define IMX185_MAX_RETRIES 3
#define IMX185_WAIT_MS_STOP 1
#define IMX185_WAIT_MS_START 30
#define IMX185_WAIT_MS_STREAM 210
#define IMX185_GAIN_TABLE_SIZE 255
/* #define INIT_ET_INSETTING 1 */
#define imx185_reg struct reg_8
enum
IMX185_MODE_1920X1080_CROP_30FPS,
IMX185_MODE_START_STREAM,
IMX185_MODE_STOP_STREAM,
static const int imx185_30fps[] = {
30,
* WARNING: frmfmt ordering need to match mode definition in
* device tree!
static const struct camera_common_frmfmt imx185_frmfmt[] = {
{{1280, 720}, imx185_30fps, 1, 0, IMX185_MODE_1920X1080_CROP_30FPS},
#endif /* __IMX185_I2C_TABLES__ */
The driver probes without problems and we get a /dev/video0. However when we try to capture from this v4l-device, we get the following errors over dmesg:
[ 257.166843] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 257.173356] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 257.402882] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 257.409428] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 257.419534] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000008
[ 257.427431] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000008
[ 257.654834] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 257.661349] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 257.671455] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
[ 257.679406] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
[ 257.902835] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 257.909304] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 257.919280] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
[ 257.927172] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
[ 258.154827] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 258.161312] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 258.390837] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 258.397359] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 258.626841] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 258.633303] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 258.643232] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
[ 258.651149] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
[ 258.878933] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 258.885465] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 258.897455] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
[ 258.905376] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
[ 259.130853] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 259.137328] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 259.147961] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000008
[ 259.155919] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000008
[ 259.164800] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x00000004
[ 259.173558] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
[ 259.181453] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
Can anyone give me a hit where I can start debugging this problem?
I appriciate every litte hint you can provide!
