Hi all,
I am trying to apply the custom camera sensor driver used by xavier to jetson tx2.
The camera device driver is registered normally.
For the stream test, I tested using the v4l2-ctl command below.
> v4l2-ctl -d /dev/video0 --set-fmt-video=width=3840,height=2160 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=10
The following serial log message appeared.
[ 1098.738673] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1098.745188] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1098.974680] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1098.981161] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1098.991137] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000008
[ 1098.999057] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000008
[ 1099.226665] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1099.233160] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1099.243126] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000008
[ 1099.251029] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000008
[ 1099.478698] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1099.485235] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1099.495319] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
[ 1099.503216] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
[ 1099.730765] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1099.737244] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1099.747543] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
[ 1099.755525] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
this is trace debugging message.
# tracer: nop
# entries-in-buffer/entries-written: 641/641 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-8524 [000] .... 1098.217697: tegra_channel_open: vi-output, imx415 2-001a
v4l2-ctl-8524 [000] .... 1098.218867: tegra_channel_set_power: imx415 2-001a : 0x1
v4l2-ctl-8524 [000] .... 1098.218880: camera_common_s_power: status : 0x1
v4l2-ctl-8524 [000] .... 1098.240345: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-8524 [000] .... 1098.240352: csi_s_power: enable : 0x1
v4l2-ctl-8524 [005] .... 1098.265503: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-8525 [004] .... 1098.265602: tegra_channel_set_stream: enable : 0x1
vi-output, imx4-8525 [000] .... 1098.267110: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
vi-output, imx4-8525 [000] .... 1098.267114: csi_s_stream: enable : 0x1
vi-output, imx4-8525 [000] .... 1098.267150: tegra_channel_set_stream: imx415 2-001a : 0x1
kworker/5:1-8429 [005] .... 1098.290607: rtos_queue_peek_from_isr_failed: tstamp:34606968781 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1098.290615: rtcpu_start: tstamp:34606969866
kworker/5:1-8429 [005] .... 1098.290619: rtos_queue_send_from_isr_failed: tstamp:34606978625 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1098.290621: rtos_queue_send_from_isr_failed: tstamp:34606978733 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1098.290624: rtos_queue_send_from_isr_failed: tstamp:34606978850 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1098.290626: rtos_queue_send_from_isr_failed: tstamp:34606978957 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1098.290628: rtos_queue_send_from_isr_failed: tstamp:34606979066 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1098.290630: rtos_queue_send_from_isr_failed: tstamp:34606979171 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1098.290632: rtos_queue_send_from_isr_failed: tstamp:34606979276 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1098.290634: rtos_queue_send_from_isr_failed: tstamp:34606979380 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1098.290638: rtos_queue_send_failed: tstamp:34606979853 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1098.290641: rtos_queue_send_from_isr_failed: tstamp:34606981525 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1098.290643: rtos_queue_send_from_isr_failed: tstamp:34606981642 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1098.290645: rtos_queue_send_from_isr_failed: tstamp:34606981747 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1098.290647: rtos_queue_send_from_isr_failed: tstamp:34606981853 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1098.290649: rtos_queue_send_from_isr_failed: tstamp:34606981958 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1098.290652: rtos_queue_send_from_isr_failed: tstamp:34606982063 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1098.290654: rtos_queue_send_from_isr_failed: tstamp:34606982168 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1098.290656: rtos_queue_send_from_isr_failed: tstamp:34606982273 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1098.290658: rtos_queue_send_failed: tstamp:34606983223 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1098.458663: rtos_queue_peek_from_isr_failed: tstamp:34611969179 queue:0x0b4b4500
vi-output, imx4-8525 [003] .... 1098.535862: tegra_channel_capture_frame: sof:1098.333199997
kworker/5:1-8429 [005] .... 1098.570667: rtcpu_vinotify_event: tstamp:34615419677 tag:ATOMP_FS channel:0x00 frame:12 vi_tstamp:34615419280 data:0x00000000
kworker/5:1-8429 [005] .... 1098.570674: rtcpu_vinotify_event: tstamp:34615429075 tag:CHANSEL_PXL_SOF channel:0x00 frame:12 vi_tstamp:34615428696 data:0x00000001
kworker/5:1-8429 [005] .... 1098.570676: rtcpu_vinotify_event: tstamp:34615434224 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:12 vi_tstamp:34615433849 data:0x08000000
kworker/5:1-8429 [005] .... 1098.570679: rtcpu_vinotify_event: tstamp:34615978830 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:12 vi_tstamp:34615978240 data:0x00000001
kworker/5:1-8429 [005] .... 1098.570681: rtcpu_vinotify_event: tstamp:34615979077 tag:ATOMP_FE channel:0x00 frame:12 vi_tstamp:34615978240 data:0x00000000
kworker/5:1-8429 [005] .... 1098.626639: rtos_queue_peek_from_isr_failed: tstamp:34616969152 queue:0x0b4b4500
vi-output, imx4-8525 [005] .... 1098.755471: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-8525 [005] .... 1098.755507: tegra_channel_capture_frame: sof:1098.333199997
vi-output, imx4-8525 [005] .... 1098.770909: tegra_channel_capture_frame: sof:1098.568269603
kworker/5:1-8429 [005] .... 1098.794632: rtos_queue_peek_from_isr_failed: tstamp:34621969157 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1098.794640: rtos_queue_send_from_isr_failed: tstamp:34622275433 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1098.794643: rtos_queue_send_from_isr_failed: tstamp:34622275580 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1098.794646: rtos_queue_send_from_isr_failed: tstamp:34622275721 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1098.794648: rtos_queue_send_from_isr_failed: tstamp:34622275861 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1098.794650: rtos_queue_send_from_isr_failed: tstamp:34622275999 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1098.794653: rtos_queue_send_from_isr_failed: tstamp:34622276136 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1098.794655: rtos_queue_send_from_isr_failed: tstamp:34622276275 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1098.794658: rtos_queue_send_from_isr_failed: tstamp:34622276411 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1098.794663: rtos_queue_send_failed: tstamp:34622277128 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1098.794666: rtos_queue_send_from_isr_failed: tstamp:34622280895 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1098.794668: rtos_queue_send_from_isr_failed: tstamp:34622281039 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1098.794671: rtos_queue_send_from_isr_failed: tstamp:34622281178 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1098.794673: rtos_queue_send_from_isr_failed: tstamp:34622281316 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1098.794675: rtos_queue_send_from_isr_failed: tstamp:34622281454 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1098.794678: rtos_queue_send_from_isr_failed: tstamp:34622281591 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1098.794680: rtos_queue_send_from_isr_failed: tstamp:34622281729 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1098.794683: rtos_queue_send_from_isr_failed: tstamp:34622281866 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1098.794685: rtos_queue_send_failed: tstamp:34622282426 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1098.794688: rtos_queue_send_from_isr_failed: tstamp:34622287836 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1098.794690: rtos_queue_send_from_isr_failed: tstamp:34622287981 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1098.794693: rtos_queue_send_from_isr_failed: tstamp:34622288120 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1098.794695: rtos_queue_send_from_isr_failed: tstamp:34622288260 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1098.794698: rtos_queue_send_from_isr_failed: tstamp:34622288398 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1098.794700: rtos_queue_send_from_isr_failed: tstamp:34622288534 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1098.794702: rtos_queue_send_from_isr_failed: tstamp:34622288671 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1098.794705: rtos_queue_send_from_isr_failed: tstamp:34622288815 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1098.794707: rtos_queue_send_failed: tstamp:34622289383 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1098.794710: rtos_queue_send_from_isr_failed: tstamp:34622291812 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1098.794712: rtos_queue_send_from_isr_failed: tstamp:34622291952 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1098.794714: rtos_queue_send_from_isr_failed: tstamp:34622292092 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1098.794717: rtos_queue_send_from_isr_failed: tstamp:34622292231 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1098.794719: rtos_queue_send_from_isr_failed: tstamp:34622292368 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1098.794721: rtos_queue_send_from_isr_failed: tstamp:34622292506 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1098.794724: rtos_queue_send_from_isr_failed: tstamp:34622292643 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1098.794726: rtos_queue_send_from_isr_failed: tstamp:34622292787 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1098.794729: rtos_queue_send_failed: tstamp:34622294216 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1098.794733: rtcpu_vinotify_event: tstamp:34622765614 tag:ATOMP_FS channel:0x00 frame:25 vi_tstamp:34622765216 data:0x00000000
kworker/5:1-8429 [005] .... 1098.794735: rtcpu_vinotify_event: tstamp:34622775019 tag:CHANSEL_PXL_SOF channel:0x00 frame:25 vi_tstamp:34622774632 data:0x00000001
kworker/5:1-8429 [005] .... 1098.794737: rtcpu_vinotify_event: tstamp:34622779363 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:25 vi_tstamp:34622778989 data:0x08000000
kworker/5:1-8429 [005] .... 1098.794739: rtcpu_vinotify_event: tstamp:34623324765 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:25 vi_tstamp:34623324176 data:0x00000001
kworker/5:1-8429 [005] .... 1098.794741: rtcpu_vinotify_event: tstamp:34623325046 tag:ATOMP_FE channel:0x00 frame:25 vi_tstamp:34623324176 data:0x00000000
kworker/5:1-8429 [005] .... 1098.906661: rtos_queue_peek_from_isr_failed: tstamp:34626969215 queue:0x0b4b4500
vi-output, imx4-8525 [005] .... 1099.007625: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-8525 [005] .... 1099.007663: tegra_channel_capture_frame: sof:1098.568269603
kworker/5:1-8429 [005] .... 1099.018579: rtos_queue_send_from_isr_failed: tstamp:34629649427 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.018583: rtos_queue_send_from_isr_failed: tstamp:34629649580 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.018585: rtos_queue_send_from_isr_failed: tstamp:34629649721 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.018587: rtos_queue_send_from_isr_failed: tstamp:34629649860 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.018589: rtos_queue_send_from_isr_failed: tstamp:34629650000 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.018591: rtos_queue_send_from_isr_failed: tstamp:34629650137 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.018593: rtos_queue_send_from_isr_failed: tstamp:34629650275 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.018595: rtos_queue_send_from_isr_failed: tstamp:34629650414 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.018598: rtos_queue_send_failed: tstamp:34629651129 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.018601: rtos_queue_send_from_isr_failed: tstamp:34629654700 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.018602: rtos_queue_send_from_isr_failed: tstamp:34629654840 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.018604: rtos_queue_send_from_isr_failed: tstamp:34629654979 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.018606: rtos_queue_send_from_isr_failed: tstamp:34629655123 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.018608: rtos_queue_send_from_isr_failed: tstamp:34629655261 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.018610: rtos_queue_send_from_isr_failed: tstamp:34629655398 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.018611: rtos_queue_send_from_isr_failed: tstamp:34629655535 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.018613: rtos_queue_send_from_isr_failed: tstamp:34629655677 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.018615: rtos_queue_send_failed: tstamp:34629656232 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.018617: rtos_queue_send_from_isr_failed: tstamp:34630168374 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.018619: rtos_queue_send_from_isr_failed: tstamp:34630168518 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.018621: rtos_queue_send_from_isr_failed: tstamp:34630168657 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.018623: rtos_queue_send_from_isr_failed: tstamp:34630168795 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.018624: rtos_queue_send_from_isr_failed: tstamp:34630168933 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.018626: rtos_queue_send_from_isr_failed: tstamp:34630169070 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.018628: rtos_queue_send_from_isr_failed: tstamp:34630169208 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.018630: rtos_queue_send_from_isr_failed: tstamp:34630169345 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.018632: rtos_queue_send_failed: tstamp:34630170004 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.018634: rtos_queue_send_from_isr_failed: tstamp:34630172116 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.018635: rtos_queue_send_from_isr_failed: tstamp:34630172257 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.018637: rtos_queue_send_from_isr_failed: tstamp:34630172396 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.018639: rtos_queue_send_from_isr_failed: tstamp:34630172535 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.018641: rtos_queue_send_from_isr_failed: tstamp:34630172692 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.018643: rtos_queue_send_from_isr_failed: tstamp:34630172836 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.018645: rtos_queue_send_from_isr_failed: tstamp:34630172977 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.018647: rtos_queue_send_from_isr_failed: tstamp:34630173117 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.018648: rtos_queue_send_failed: tstamp:34630174505 queue:0x0b4a7258
vi-output, imx4-8525 [003] .... 1099.024041: tegra_channel_capture_frame: sof:1098.821421485
kworker/5:1-8429 [005] .... 1099.074650: rtcpu_vinotify_event: tstamp:34630676620 tag:ATOMP_FS channel:0x00 frame:39 vi_tstamp:34630676225 data:0x00000000
kworker/5:1-8429 [005] .... 1099.074656: rtcpu_vinotify_event: tstamp:34630686016 tag:CHANSEL_PXL_SOF channel:0x00 frame:39 vi_tstamp:34630685641 data:0x00000001
kworker/5:1-8429 [005] .... 1099.074659: rtcpu_vinotify_event: tstamp:34630689696 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:39 vi_tstamp:34630689326 data:0x08000000
kworker/5:1-8429 [005] .... 1099.074661: rtcpu_vinotify_event: tstamp:34631235785 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:39 vi_tstamp:34631235185 data:0x00000001
kworker/5:1-8429 [005] .... 1099.074663: rtcpu_vinotify_event: tstamp:34631236048 tag:ATOMP_FE channel:0x00 frame:39 vi_tstamp:34631235185 data:0x00000000
kworker/5:1-8429 [005] .... 1099.074667: rtos_queue_peek_from_isr_failed: tstamp:34631969169 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1099.242591: rtos_queue_peek_from_isr_failed: tstamp:34636969188 queue:0x0b4b4500
vi-output, imx4-8525 [005] .... 1099.259723: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-8525 [005] .... 1099.259761: tegra_channel_capture_frame: sof:1098.821421485
vi-output, imx4-8525 [003] .... 1099.277216: tegra_channel_capture_frame: sof:1099.74573399
kworker/5:1-8429 [005] .... 1099.298670: rtos_queue_send_from_isr_failed: tstamp:34637523725 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.298678: rtos_queue_send_from_isr_failed: tstamp:34637523872 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.298681: rtos_queue_send_from_isr_failed: tstamp:34637524013 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.298683: rtos_queue_send_from_isr_failed: tstamp:34637524153 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.298686: rtos_queue_send_from_isr_failed: tstamp:34637524290 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.298688: rtos_queue_send_from_isr_failed: tstamp:34637524433 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.298691: rtos_queue_send_from_isr_failed: tstamp:34637524570 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.298693: rtos_queue_send_from_isr_failed: tstamp:34637524708 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.298696: rtos_queue_send_failed: tstamp:34637525418 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.298699: rtos_queue_send_from_isr_failed: tstamp:34637530208 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.298701: rtos_queue_send_from_isr_failed: tstamp:34637530347 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.298704: rtos_queue_send_from_isr_failed: tstamp:34637530486 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.298706: rtos_queue_send_from_isr_failed: tstamp:34637530626 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.298712: rtos_queue_send_from_isr_failed: tstamp:34637530763 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.298714: rtos_queue_send_from_isr_failed: tstamp:34637530901 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.298718: rtos_queue_send_from_isr_failed: tstamp:34637531038 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.298721: rtos_queue_send_from_isr_failed: tstamp:34637531176 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.298724: rtos_queue_send_failed: tstamp:34637531732 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.298727: rtos_queue_send_from_isr_failed: tstamp:34638042765 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.298729: rtos_queue_send_from_isr_failed: tstamp:34638042908 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.298731: rtos_queue_send_from_isr_failed: tstamp:34638043048 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.298734: rtos_queue_send_from_isr_failed: tstamp:34638043209 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.298736: rtos_queue_send_from_isr_failed: tstamp:34638043347 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.298739: rtos_queue_send_from_isr_failed: tstamp:34638043484 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.298741: rtos_queue_send_from_isr_failed: tstamp:34638043622 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.298743: rtos_queue_send_from_isr_failed: tstamp:34638043759 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.298746: rtos_queue_send_failed: tstamp:34638044424 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.298748: rtos_queue_send_from_isr_failed: tstamp:34638048761 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.298751: rtos_queue_send_from_isr_failed: tstamp:34638048927 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.298753: rtos_queue_send_from_isr_failed: tstamp:34638049069 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.298755: rtos_queue_send_from_isr_failed: tstamp:34638049209 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.298758: rtos_queue_send_from_isr_failed: tstamp:34638049346 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.298760: rtos_queue_send_from_isr_failed: tstamp:34638049485 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.298762: rtos_queue_send_from_isr_failed: tstamp:34638049622 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.298765: rtos_queue_send_from_isr_failed: tstamp:34638049760 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.298767: rtos_queue_send_failed: tstamp:34638051153 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.298771: rtcpu_vinotify_event: tstamp:34638587628 tag:ATOMP_FS channel:0x00 frame:53 vi_tstamp:34638587233 data:0x00000000
kworker/5:1-8429 [005] .... 1099.298774: rtcpu_vinotify_event: tstamp:34638597029 tag:CHANSEL_PXL_SOF channel:0x00 frame:53 vi_tstamp:34638596649 data:0x00000001
kworker/5:1-8429 [005] .... 1099.298776: rtcpu_vinotify_event: tstamp:34638601465 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:53 vi_tstamp:34638601094 data:0x08000000
kworker/5:1-8429 [005] .... 1099.298778: rtcpu_vinotify_event: tstamp:34639146819 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:53 vi_tstamp:34639146193 data:0x00000001
kworker/5:1-8429 [005] .... 1099.298780: rtcpu_vinotify_event: tstamp:34639147071 tag:ATOMP_FE channel:0x00 frame:53 vi_tstamp:34639146193 data:0x00000000
kworker/5:1-8429 [005] .... 1099.410685: rtos_queue_peek_from_isr_failed: tstamp:34641969202 queue:0x0b4b4500
vi-output, imx4-8525 [004] .... 1099.511802: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-8525 [004] .... 1099.511867: tegra_channel_capture_frame: sof:1099.74573399
kworker/5:1-8429 [005] .... 1099.522646: rtos_queue_send_from_isr_failed: tstamp:34645403848 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.522652: rtos_queue_send_from_isr_failed: tstamp:34645404010 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.522655: rtos_queue_send_from_isr_failed: tstamp:34645404150 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.522657: rtos_queue_send_from_isr_failed: tstamp:34645404290 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.522660: rtos_queue_send_from_isr_failed: tstamp:34645404426 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.522662: rtos_queue_send_from_isr_failed: tstamp:34645404565 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.522665: rtos_queue_send_from_isr_failed: tstamp:34645404702 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.522667: rtos_queue_send_from_isr_failed: tstamp:34645404840 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.522671: rtos_queue_send_failed: tstamp:34645405571 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.522674: rtos_queue_send_from_isr_failed: tstamp:34645410304 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.522676: rtos_queue_send_from_isr_failed: tstamp:34645410467 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.522679: rtos_queue_send_from_isr_failed: tstamp:34645410606 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.522682: rtos_queue_send_from_isr_failed: tstamp:34645410745 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.522684: rtos_queue_send_from_isr_failed: tstamp:34645410882 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.522686: rtos_queue_send_from_isr_failed: tstamp:34645411020 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.522689: rtos_queue_send_from_isr_failed: tstamp:34645411157 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.522691: rtos_queue_send_from_isr_failed: tstamp:34645411296 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.522693: rtos_queue_send_failed: tstamp:34645411882 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.522696: rtos_queue_send_from_isr_failed: tstamp:34645922577 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.522699: rtos_queue_send_from_isr_failed: tstamp:34645922721 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.522701: rtos_queue_send_from_isr_failed: tstamp:34645922861 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.522703: rtos_queue_send_from_isr_failed: tstamp:34645923001 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.522706: rtos_queue_send_from_isr_failed: tstamp:34645923139 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.522708: rtos_queue_send_from_isr_failed: tstamp:34645923276 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.522711: rtos_queue_send_from_isr_failed: tstamp:34645923415 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.522713: rtos_queue_send_from_isr_failed: tstamp:34645923552 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.522715: rtos_queue_send_failed: tstamp:34645924162 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.522718: rtos_queue_send_from_isr_failed: tstamp:34645927341 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.522720: rtos_queue_send_from_isr_failed: tstamp:34645927481 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.522723: rtos_queue_send_from_isr_failed: tstamp:34645927621 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.522725: rtos_queue_send_from_isr_failed: tstamp:34645927760 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.522728: rtos_queue_send_from_isr_failed: tstamp:34645927898 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.522730: rtos_queue_send_from_isr_failed: tstamp:34645928035 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.522732: rtos_queue_send_from_isr_failed: tstamp:34645928171 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.522735: rtos_queue_send_from_isr_failed: tstamp:34645928310 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.522737: rtos_queue_send_failed: tstamp:34645929713 queue:0x0b4a7258
vi-output, imx4-8525 [003] .... 1099.530342: tegra_channel_capture_frame: sof:1099.327725117
kworker/5:1-8429 [005] .... 1099.578638: rtcpu_vinotify_event: tstamp:34646498636 tag:ATOMP_FS channel:0x00 frame:67 vi_tstamp:34646498241 data:0x00000000
kworker/5:1-8429 [005] .... 1099.578643: rtcpu_vinotify_event: tstamp:34646508034 tag:CHANSEL_PXL_SOF channel:0x00 frame:67 vi_tstamp:34646507657 data:0x00000001
kworker/5:1-8429 [005] .... 1099.578645: rtcpu_vinotify_event: tstamp:34646511545 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:67 vi_tstamp:34646511173 data:0x08000000
kworker/5:1-8429 [005] .... 1099.578650: rtos_queue_peek_from_isr_failed: tstamp:34646969207 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1099.578652: rtcpu_vinotify_event: tstamp:34647057789 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:67 vi_tstamp:34647057201 data:0x00000001
kworker/5:1-8429 [005] .... 1099.578654: rtcpu_vinotify_event: tstamp:34647058033 tag:ATOMP_FE channel:0x00 frame:67 vi_tstamp:34647057201 data:0x00000000
kworker/5:1-8429 [005] .... 1099.750689: rtos_queue_peek_from_isr_failed: tstamp:34651969197 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1099.750699: rtos_queue_send_from_isr_failed: tstamp:34653279081 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.750701: rtos_queue_send_from_isr_failed: tstamp:34653279228 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.750702: rtos_queue_send_from_isr_failed: tstamp:34653279369 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.750704: rtos_queue_send_from_isr_failed: tstamp:34653279509 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.750705: rtos_queue_send_from_isr_failed: tstamp:34653279646 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.750707: rtos_queue_send_from_isr_failed: tstamp:34653279784 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.750709: rtos_queue_send_from_isr_failed: tstamp:34653279920 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.750710: rtos_queue_send_from_isr_failed: tstamp:34653280056 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.750714: rtos_queue_send_failed: tstamp:34653280747 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.750716: rtos_queue_send_from_isr_failed: tstamp:34653289810 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.750717: rtos_queue_send_from_isr_failed: tstamp:34653289948 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.750719: rtos_queue_send_from_isr_failed: tstamp:34653290087 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.750720: rtos_queue_send_from_isr_failed: tstamp:34653290227 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.750722: rtos_queue_send_from_isr_failed: tstamp:34653290365 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.750724: rtos_queue_send_from_isr_failed: tstamp:34653290501 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.750725: rtos_queue_send_from_isr_failed: tstamp:34653290637 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.750727: rtos_queue_send_from_isr_failed: tstamp:34653290781 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.750728: rtos_queue_send_failed: tstamp:34653291337 queue:0x0b4a7258
vi-output, imx4-8525 [003] .... 1099.764337: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-8525 [003] .... 1099.764377: tegra_channel_capture_frame: sof:1099.327725117
vi-output, imx4-8525 [004] .... 1099.765399: tegra_channel_capture_frame: sof:1099.562794656
kworker/5:1-8429 [005] .... 1099.806640: rtos_queue_send_from_isr_failed: tstamp:34653809951 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.806646: rtos_queue_send_from_isr_failed: tstamp:34653810096 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.806649: rtos_queue_send_from_isr_failed: tstamp:34653810235 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.806651: rtos_queue_send_from_isr_failed: tstamp:34653810375 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.806654: rtos_queue_send_from_isr_failed: tstamp:34653810513 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.806656: rtos_queue_send_from_isr_failed: tstamp:34653810651 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.806659: rtos_queue_send_from_isr_failed: tstamp:34653810789 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.806661: rtos_queue_send_from_isr_failed: tstamp:34653810925 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.806665: rtos_queue_send_failed: tstamp:34653811510 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.806668: rtos_queue_send_from_isr_failed: tstamp:34653815138 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.806670: rtos_queue_send_from_isr_failed: tstamp:34653815278 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1099.806672: rtos_queue_send_from_isr_failed: tstamp:34653815417 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1099.806675: rtos_queue_send_from_isr_failed: tstamp:34653815555 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1099.806678: rtos_queue_send_from_isr_failed: tstamp:34653815712 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1099.806680: rtos_queue_send_from_isr_failed: tstamp:34653815855 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1099.806682: rtos_queue_send_from_isr_failed: tstamp:34653815991 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1099.806685: rtos_queue_send_from_isr_failed: tstamp:34653816130 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1099.806687: rtos_queue_send_failed: tstamp:34653817581 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1099.806692: rtcpu_vinotify_event: tstamp:34653844589 tag:ATOMP_FS channel:0x00 frame:80 vi_tstamp:34653844177 data:0x00000000
kworker/5:1-8429 [005] .... 1099.806695: rtcpu_vinotify_event: tstamp:34653853973 tag:CHANSEL_PXL_SOF channel:0x00 frame:80 vi_tstamp:34653853593 data:0x00000001
kworker/5:1-8429 [005] .... 1099.806697: rtcpu_vinotify_event: tstamp:34653857040 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:80 vi_tstamp:34653856662 data:0x08000000
kworker/5:1-8429 [005] .... 1099.806699: rtcpu_vinotify_event: tstamp:34654403723 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:80 vi_tstamp:34654403137 data:0x00000001
kworker/5:1-8429 [005] .... 1099.806701: rtcpu_vinotify_event: tstamp:34654403972 tag:ATOMP_FE channel:0x00 frame:80 vi_tstamp:34654403138 data:0x00000000
kworker/5:1-8429 [005] .... 1099.918659: rtos_queue_peek_from_isr_failed: tstamp:34656969204 queue:0x0b4b4500
vi-output, imx4-8525 [005] .... 1099.999786: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-8525 [005] .... 1099.999821: tegra_channel_capture_frame: sof:1099.562794656
vi-output, imx4-8525 [005] .... 1100.000459: tegra_channel_capture_frame: sof:1099.797864259
kworker/5:1-8429 [005] .... 1100.030660: rtos_queue_send_from_isr_failed: tstamp:34660650862 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.030670: rtos_queue_send_from_isr_failed: tstamp:34660651011 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.030673: rtos_queue_send_from_isr_failed: tstamp:34660651155 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.030675: rtos_queue_send_from_isr_failed: tstamp:34660651295 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.030678: rtos_queue_send_from_isr_failed: tstamp:34660651434 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.030680: rtos_queue_send_from_isr_failed: tstamp:34660651571 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.030683: rtos_queue_send_from_isr_failed: tstamp:34660651713 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.030685: rtos_queue_send_from_isr_failed: tstamp:34660651852 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.030690: rtos_queue_send_failed: tstamp:34660652559 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.030693: rtos_queue_send_from_isr_failed: tstamp:34660656862 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.030695: rtos_queue_send_from_isr_failed: tstamp:34660657002 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.030697: rtos_queue_send_from_isr_failed: tstamp:34660657142 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.030700: rtos_queue_send_from_isr_failed: tstamp:34660657281 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.030702: rtos_queue_send_from_isr_failed: tstamp:34660657418 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.030704: rtos_queue_send_from_isr_failed: tstamp:34660657557 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.030707: rtos_queue_send_from_isr_failed: tstamp:34660657694 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.030709: rtos_queue_send_from_isr_failed: tstamp:34660657832 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.030712: rtos_queue_send_failed: tstamp:34660658392 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.030714: rtos_queue_send_from_isr_failed: tstamp:34661172173 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.030720: rtos_queue_send_from_isr_failed: tstamp:34661172317 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.030723: rtos_queue_send_from_isr_failed: tstamp:34661172457 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.030726: rtos_queue_send_from_isr_failed: tstamp:34661172597 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.030729: rtos_queue_send_from_isr_failed: tstamp:34661172744 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.030732: rtos_queue_send_from_isr_failed: tstamp:34661172881 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.030734: rtos_queue_send_from_isr_failed: tstamp:34661173019 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.030737: rtos_queue_send_from_isr_failed: tstamp:34661173156 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.030739: rtos_queue_send_failed: tstamp:34661173757 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.030742: rtos_queue_send_from_isr_failed: tstamp:34661176547 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.030744: rtos_queue_send_from_isr_failed: tstamp:34661176690 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.030746: rtos_queue_send_from_isr_failed: tstamp:34661176828 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.030749: rtos_queue_send_from_isr_failed: tstamp:34661176968 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.030751: rtos_queue_send_from_isr_failed: tstamp:34661177106 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.030754: rtos_queue_send_from_isr_failed: tstamp:34661177243 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.030756: rtos_queue_send_from_isr_failed: tstamp:34661177381 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.030759: rtos_queue_send_from_isr_failed: tstamp:34661177523 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.030761: rtos_queue_send_failed: tstamp:34661178900 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.030766: rtcpu_vinotify_event: tstamp:34661190490 tag:ATOMP_FS channel:0x00 frame:93 vi_tstamp:34661190114 data:0x00000000
kworker/5:1-8429 [005] .... 1100.030768: rtcpu_vinotify_event: tstamp:34661199943 tag:CHANSEL_PXL_SOF channel:0x00 frame:93 vi_tstamp:34661199530 data:0x00000001
kworker/5:1-8429 [005] .... 1100.030770: rtcpu_vinotify_event: tstamp:34661202631 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:93 vi_tstamp:34661202247 data:0x08000000
kworker/5:1-8429 [005] .... 1100.030772: rtcpu_vinotify_event: tstamp:34661749673 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:93 vi_tstamp:34661749073 data:0x00000001
kworker/5:1-8429 [005] .... 1100.030775: rtcpu_vinotify_event: tstamp:34661749925 tag:ATOMP_FE channel:0x00 frame:93 vi_tstamp:34661749074 data:0x00000000
kworker/5:1-8429 [005] .... 1100.030779: rtos_queue_peek_from_isr_failed: tstamp:34661969222 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1100.198672: rtos_queue_peek_from_isr_failed: tstamp:34666969220 queue:0x0b4b4500
vi-output, imx4-8525 [005] .... 1100.235521: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-8525 [005] .... 1100.235556: tegra_channel_capture_frame: sof:1099.797864259
vi-output, imx4-8525 [003] .... 1100.253641: tegra_channel_capture_frame: sof:1100.51016201
kworker/5:1-8429 [005] .... 1100.254590: rtos_queue_send_from_isr_failed: tstamp:34668023675 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.254594: rtos_queue_send_from_isr_failed: tstamp:34668023822 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.254596: rtos_queue_send_from_isr_failed: tstamp:34668023963 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.254598: rtos_queue_send_from_isr_failed: tstamp:34668024107 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.254600: rtos_queue_send_from_isr_failed: tstamp:34668024245 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.254602: rtos_queue_send_from_isr_failed: tstamp:34668024382 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.254604: rtos_queue_send_from_isr_failed: tstamp:34668024525 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.254606: rtos_queue_send_from_isr_failed: tstamp:34668024662 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.254609: rtos_queue_send_failed: tstamp:34668025379 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.254611: rtos_queue_send_from_isr_failed: tstamp:34668028057 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.254613: rtos_queue_send_from_isr_failed: tstamp:34668028197 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.254615: rtos_queue_send_from_isr_failed: tstamp:34668028340 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.254617: rtos_queue_send_from_isr_failed: tstamp:34668028478 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.254620: rtos_queue_send_from_isr_failed: tstamp:34668028616 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.254622: rtos_queue_send_from_isr_failed: tstamp:34668028753 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.254624: rtos_queue_send_from_isr_failed: tstamp:34668028891 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.254627: rtos_queue_send_from_isr_failed: tstamp:34668029027 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.254629: rtos_queue_send_failed: tstamp:34668029606 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.254632: rtos_queue_send_from_isr_failed: tstamp:34668540159 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.254634: rtos_queue_send_from_isr_failed: tstamp:34668540303 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.254637: rtos_queue_send_from_isr_failed: tstamp:34668540442 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.254639: rtos_queue_send_from_isr_failed: tstamp:34668540582 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.254642: rtos_queue_send_from_isr_failed: tstamp:34668540719 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.254644: rtos_queue_send_from_isr_failed: tstamp:34668540857 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.254646: rtos_queue_send_from_isr_failed: tstamp:34668540993 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.254649: rtos_queue_send_from_isr_failed: tstamp:34668541130 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.254651: rtos_queue_send_failed: tstamp:34668541747 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.254654: rtos_queue_send_from_isr_failed: tstamp:34668543763 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.254656: rtos_queue_send_from_isr_failed: tstamp:34668543908 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.254658: rtos_queue_send_from_isr_failed: tstamp:34668544048 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.254661: rtos_queue_send_from_isr_failed: tstamp:34668544189 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.254663: rtos_queue_send_from_isr_failed: tstamp:34668544328 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.254666: rtos_queue_send_from_isr_failed: tstamp:34668544467 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.254668: rtos_queue_send_from_isr_failed: tstamp:34668544604 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.254670: rtos_queue_send_from_isr_failed: tstamp:34668544742 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.254673: rtos_queue_send_failed: tstamp:34668546160 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.254677: rtcpu_vinotify_event: tstamp:34669101515 tag:ATOMP_FS channel:0x00 frame:107 vi_tstamp:34669101122 data:0x00000000
kworker/5:1-8429 [005] .... 1100.254679: rtcpu_vinotify_event: tstamp:34669110924 tag:CHANSEL_PXL_SOF channel:0x00 frame:107 vi_tstamp:34669110538 data:0x00000001
kworker/5:1-8429 [005] .... 1100.254681: rtcpu_vinotify_event: tstamp:34669114670 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:107 vi_tstamp:34669114295 data:0x08000000
kworker/5:1-8429 [005] .... 1100.310649: rtcpu_vinotify_event: tstamp:34669660678 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:107 vi_tstamp:34669660082 data:0x00000001
kworker/5:1-8429 [005] .... 1100.310654: rtcpu_vinotify_event: tstamp:34669660929 tag:ATOMP_FE channel:0x00 frame:107 vi_tstamp:34669660082 data:0x00000000
kworker/5:1-8429 [005] .... 1100.366640: rtos_queue_peek_from_isr_failed: tstamp:34671969241 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1100.478576: rtos_queue_send_from_isr_failed: tstamp:34675901270 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.478579: rtos_queue_send_from_isr_failed: tstamp:34675901462 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.478580: rtos_queue_send_from_isr_failed: tstamp:34675901603 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.478581: rtos_queue_send_from_isr_failed: tstamp:34675901744 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.478582: rtos_queue_send_from_isr_failed: tstamp:34675901882 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.478583: rtos_queue_send_from_isr_failed: tstamp:34675902019 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.478584: rtos_queue_send_from_isr_failed: tstamp:34675902158 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.478586: rtos_queue_send_from_isr_failed: tstamp:34675902296 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.478587: rtos_queue_send_failed: tstamp:34675903025 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.478589: rtos_queue_send_from_isr_failed: tstamp:34675907801 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.478590: rtos_queue_send_from_isr_failed: tstamp:34675907941 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.478591: rtos_queue_send_from_isr_failed: tstamp:34675908081 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.478592: rtos_queue_send_from_isr_failed: tstamp:34675908221 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.478593: rtos_queue_send_from_isr_failed: tstamp:34675908359 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.478595: rtos_queue_send_from_isr_failed: tstamp:34675908498 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.478596: rtos_queue_send_from_isr_failed: tstamp:34675908635 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.478597: rtos_queue_send_from_isr_failed: tstamp:34675908772 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.478598: rtos_queue_send_failed: tstamp:34675909357 queue:0x0b4a7258
vi-output, imx4-8525 [000] .... 1100.487698: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-8525 [000] .... 1100.487731: tegra_channel_capture_frame: sof:1100.51016201
vi-output, imx4-8525 [003] .... 1100.488687: tegra_channel_capture_frame: sof:1100.286085640
kworker/5:1-8429 [005] .... 1100.534625: rtos_queue_send_from_isr_failed: tstamp:34676420593 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.534630: rtos_queue_send_from_isr_failed: tstamp:34676420737 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.534632: rtos_queue_send_from_isr_failed: tstamp:34676420876 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.534633: rtos_queue_send_from_isr_failed: tstamp:34676421016 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.534636: rtos_queue_send_from_isr_failed: tstamp:34676421153 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.534637: rtos_queue_send_from_isr_failed: tstamp:34676421291 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.534639: rtos_queue_send_from_isr_failed: tstamp:34676421428 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.534641: rtos_queue_send_from_isr_failed: tstamp:34676421566 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.534644: rtos_queue_send_failed: tstamp:34676422174 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.534646: rtos_queue_send_from_isr_failed: tstamp:34676423971 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.534648: rtos_queue_send_from_isr_failed: tstamp:34676424110 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.534649: rtos_queue_send_from_isr_failed: tstamp:34676424248 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.534651: rtos_queue_send_from_isr_failed: tstamp:34676424387 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.534653: rtos_queue_send_from_isr_failed: tstamp:34676424544 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.534655: rtos_queue_send_from_isr_failed: tstamp:34676424702 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.534657: rtos_queue_send_from_isr_failed: tstamp:34676424845 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.534659: rtos_queue_send_from_isr_failed: tstamp:34676424982 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.534660: rtos_queue_send_failed: tstamp:34676426389 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.534663: rtcpu_vinotify_event: tstamp:34676447448 tag:ATOMP_FS channel:0x00 frame:120 vi_tstamp:34676447058 data:0x00000000
kworker/5:1-8429 [005] .... 1100.534665: rtcpu_vinotify_event: tstamp:34676456864 tag:CHANSEL_PXL_SOF channel:0x00 frame:120 vi_tstamp:34676456474 data:0x00000001
kworker/5:1-8429 [005] .... 1100.534667: rtcpu_vinotify_event: tstamp:34676459724 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:120 vi_tstamp:34676459347 data:0x08000000
kworker/5:1-8429 [005] .... 1100.534671: rtos_queue_peek_from_isr_failed: tstamp:34676969248 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1100.534672: rtcpu_vinotify_event: tstamp:34677006606 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:120 vi_tstamp:34677006018 data:0x00000001
kworker/5:1-8429 [005] .... 1100.534674: rtcpu_vinotify_event: tstamp:34677006848 tag:ATOMP_FE channel:0x00 frame:120 vi_tstamp:34677006018 data:0x00000000
kworker/5:1-8429 [005] .... 1100.702618: rtos_queue_peek_from_isr_failed: tstamp:34681969248 queue:0x0b4b4500
vi-output, imx4-8525 [004] .... 1100.723763: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-8525 [004] .... 1100.723801: tegra_channel_capture_frame: sof:1100.286085640
vi-output, imx4-8525 [003] .... 1100.741894: tegra_channel_capture_frame: sof:1100.539237673
kworker/5:1-8429 [005] .... 1100.758646: rtos_queue_send_from_isr_failed: tstamp:34683277509 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.758652: rtos_queue_send_from_isr_failed: tstamp:34683277657 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.758655: rtos_queue_send_from_isr_failed: tstamp:34683277798 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.758658: rtos_queue_send_from_isr_failed: tstamp:34683277938 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.758660: rtos_queue_send_from_isr_failed: tstamp:34683278076 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.758662: rtos_queue_send_from_isr_failed: tstamp:34683278212 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.758665: rtos_queue_send_from_isr_failed: tstamp:34683278353 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.758667: rtos_queue_send_from_isr_failed: tstamp:34683278491 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.758672: rtos_queue_send_failed: tstamp:34683279208 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.758675: rtos_queue_send_from_isr_failed: tstamp:34683284861 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.758677: rtos_queue_send_from_isr_failed: tstamp:34683285001 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.758679: rtos_queue_send_from_isr_failed: tstamp:34683285140 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.758682: rtos_queue_send_from_isr_failed: tstamp:34683285280 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.758684: rtos_queue_send_from_isr_failed: tstamp:34683285417 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.758687: rtos_queue_send_from_isr_failed: tstamp:34683285555 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.758689: rtos_queue_send_from_isr_failed: tstamp:34683285692 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.758691: rtos_queue_send_from_isr_failed: tstamp:34683285830 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.758694: rtos_queue_send_failed: tstamp:34683286387 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.758697: rtos_queue_send_from_isr_failed: tstamp:34683798097 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.758699: rtos_queue_send_from_isr_failed: tstamp:34683798239 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.758702: rtos_queue_send_from_isr_failed: tstamp:34683798379 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.758704: rtos_queue_send_from_isr_failed: tstamp:34683798519 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.758706: rtos_queue_send_from_isr_failed: tstamp:34683798666 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.758709: rtos_queue_send_from_isr_failed: tstamp:34683798803 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.758711: rtos_queue_send_from_isr_failed: tstamp:34683798942 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.758717: rtos_queue_send_from_isr_failed: tstamp:34683799079 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.758719: rtos_queue_send_failed: tstamp:34683799682 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.758722: rtos_queue_send_from_isr_failed: tstamp:34683801493 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.758724: rtos_queue_send_from_isr_failed: tstamp:34683801631 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.758727: rtos_queue_send_from_isr_failed: tstamp:34683801771 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.758729: rtos_queue_send_from_isr_failed: tstamp:34683801911 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.758732: rtos_queue_send_from_isr_failed: tstamp:34683802055 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.758734: rtos_queue_send_from_isr_failed: tstamp:34683802194 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.758737: rtos_queue_send_from_isr_failed: tstamp:34683802332 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.758739: rtos_queue_send_from_isr_failed: tstamp:34683802469 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.758741: rtos_queue_send_failed: tstamp:34683803833 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.758745: rtcpu_vinotify_event: tstamp:34684358458 tag:ATOMP_FS channel:0x00 frame:134 vi_tstamp:34684358067 data:0x00000000
kworker/5:1-8429 [005] .... 1100.758748: rtcpu_vinotify_event: tstamp:34684367858 tag:CHANSEL_PXL_SOF channel:0x00 frame:134 vi_tstamp:34684367482 data:0x00000001
kworker/5:1-8429 [005] .... 1100.758750: rtcpu_vinotify_event: tstamp:34684372683 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:134 vi_tstamp:34684372311 data:0x08000000
kworker/5:1-8429 [005] .... 1100.814667: rtcpu_vinotify_event: tstamp:34684917625 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:134 vi_tstamp:34684917027 data:0x00000001
kworker/5:1-8429 [005] .... 1100.814673: rtcpu_vinotify_event: tstamp:34684917863 tag:ATOMP_FE channel:0x00 frame:134 vi_tstamp:34684917027 data:0x00000000
kworker/5:1-8429 [005] .... 1100.870647: rtos_queue_peek_from_isr_failed: tstamp:34686969271 queue:0x0b4b4500
vi-output, imx4-8525 [004] .... 1100.975653: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-8525 [004] .... 1100.975690: tegra_channel_capture_frame: sof:1100.539237673
vi-output, imx4-8525 [003] .... 1100.976897: tegra_channel_capture_frame: sof:1100.774307080
kworker/5:1-8429 [005] .... 1100.982562: rtos_queue_send_from_isr_failed: tstamp:34691150207 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.982567: rtos_queue_send_from_isr_failed: tstamp:34691150352 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.982569: rtos_queue_send_from_isr_failed: tstamp:34691150495 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.982572: rtos_queue_send_from_isr_failed: tstamp:34691150635 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.982574: rtos_queue_send_from_isr_failed: tstamp:34691150772 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.982576: rtos_queue_send_from_isr_failed: tstamp:34691150910 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.982579: rtos_queue_send_from_isr_failed: tstamp:34691151047 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.982581: rtos_queue_send_from_isr_failed: tstamp:34691151185 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.982584: rtos_queue_send_failed: tstamp:34691151898 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.982587: rtos_queue_send_from_isr_failed: tstamp:34691154952 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.982589: rtos_queue_send_from_isr_failed: tstamp:34691155092 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.982591: rtos_queue_send_from_isr_failed: tstamp:34691155232 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.982593: rtos_queue_send_from_isr_failed: tstamp:34691155376 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.982596: rtos_queue_send_from_isr_failed: tstamp:34691155512 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.982598: rtos_queue_send_from_isr_failed: tstamp:34691155650 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.982600: rtos_queue_send_from_isr_failed: tstamp:34691155788 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.982602: rtos_queue_send_from_isr_failed: tstamp:34691155925 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.982604: rtos_queue_send_failed: tstamp:34691156487 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.982607: rtos_queue_send_from_isr_failed: tstamp:34691668986 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.982609: rtos_queue_send_from_isr_failed: tstamp:34691669130 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.982611: rtos_queue_send_from_isr_failed: tstamp:34691669268 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.982614: rtos_queue_send_from_isr_failed: tstamp:34691669411 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.982616: rtos_queue_send_from_isr_failed: tstamp:34691669550 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.982618: rtos_queue_send_from_isr_failed: tstamp:34691669687 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.982620: rtos_queue_send_from_isr_failed: tstamp:34691669830 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.982622: rtos_queue_send_from_isr_failed: tstamp:34691669969 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.982625: rtos_queue_send_failed: tstamp:34691670591 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.982627: rtos_queue_send_from_isr_failed: tstamp:34691672928 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.982629: rtos_queue_send_from_isr_failed: tstamp:34691673072 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1100.982631: rtos_queue_send_from_isr_failed: tstamp:34691673210 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1100.982633: rtos_queue_send_from_isr_failed: tstamp:34691673349 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1100.982636: rtos_queue_send_from_isr_failed: tstamp:34691673488 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1100.982638: rtos_queue_send_from_isr_failed: tstamp:34691673625 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1100.982640: rtos_queue_send_from_isr_failed: tstamp:34691673763 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1100.982642: rtos_queue_send_from_isr_failed: tstamp:34691673900 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1100.982645: rtos_queue_send_failed: tstamp:34691675317 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1100.982647: rtcpu_vinotify_event: tstamp:34691704393 tag:ATOMP_FS channel:0x00 frame:147 vi_tstamp:34691704003 data:0x00000000
kworker/5:1-8429 [005] .... 1100.982650: rtcpu_vinotify_event: tstamp:34691713794 tag:CHANSEL_PXL_SOF channel:0x00 frame:147 vi_tstamp:34691713419 data:0x00000001
kworker/5:1-8429 [005] .... 1100.982652: rtcpu_vinotify_event: tstamp:34691716318 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:147 vi_tstamp:34691715948 data:0x08000000
kworker/5:1-8429 [005] .... 1101.038661: rtos_queue_peek_from_isr_failed: tstamp:34691969254 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1101.038667: rtcpu_vinotify_event: tstamp:34692263599 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:147 vi_tstamp:34692262963 data:0x00000001
kworker/5:1-8429 [005] .... 1101.038669: rtcpu_vinotify_event: tstamp:34692263852 tag:ATOMP_FE channel:0x00 frame:147 vi_tstamp:34692262963 data:0x00000000
kworker/5:1-8429 [005] .... 1101.150618: rtos_queue_peek_from_isr_failed: tstamp:34696969288 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1101.206576: rtos_queue_send_from_isr_failed: tstamp:34698526955 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.206581: rtos_queue_send_from_isr_failed: tstamp:34698527121 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1101.206582: rtos_queue_send_from_isr_failed: tstamp:34698527262 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1101.206584: rtos_queue_send_from_isr_failed: tstamp:34698527402 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1101.206585: rtos_queue_send_from_isr_failed: tstamp:34698527539 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1101.206586: rtos_queue_send_from_isr_failed: tstamp:34698527677 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1101.206588: rtos_queue_send_from_isr_failed: tstamp:34698527814 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1101.206589: rtos_queue_send_from_isr_failed: tstamp:34698527952 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1101.206592: rtos_queue_send_failed: tstamp:34698528671 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.206594: rtos_queue_send_from_isr_failed: tstamp:34698531378 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.206595: rtos_queue_send_from_isr_failed: tstamp:34698531519 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1101.206596: rtos_queue_send_from_isr_failed: tstamp:34698531659 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1101.206598: rtos_queue_send_from_isr_failed: tstamp:34698531799 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1101.206599: rtos_queue_send_from_isr_failed: tstamp:34698531936 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1101.206601: rtos_queue_send_from_isr_failed: tstamp:34698532074 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1101.206602: rtos_queue_send_from_isr_failed: tstamp:34698532211 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1101.206603: rtos_queue_send_from_isr_failed: tstamp:34698532349 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1101.206605: rtos_queue_send_failed: tstamp:34698532905 queue:0x0b4a7258
vi-output, imx4-8525 [004] .... 1101.211950: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-8525 [004] .... 1101.211990: tegra_channel_capture_frame: sof:1100.774307080
vi-output, imx4-8525 [000] .... 1101.230134: tegra_channel_capture_frame: sof:1101.27459081
kworker/5:1-8429 [005] .... 1101.262651: rtos_queue_send_from_isr_failed: tstamp:34699049923 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.262658: rtos_queue_send_from_isr_failed: tstamp:34699050067 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1101.262660: rtos_queue_send_from_isr_failed: tstamp:34699050207 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1101.262662: rtos_queue_send_from_isr_failed: tstamp:34699050348 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1101.262665: rtos_queue_send_from_isr_failed: tstamp:34699050487 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1101.262667: rtos_queue_send_from_isr_failed: tstamp:34699050624 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1101.262670: rtos_queue_send_from_isr_failed: tstamp:34699050762 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1101.262672: rtos_queue_send_from_isr_failed: tstamp:34699050899 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1101.262675: rtos_queue_send_failed: tstamp:34699051503 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.262678: rtos_queue_send_from_isr_failed: tstamp:34699054615 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.262680: rtos_queue_send_from_isr_failed: tstamp:34699054757 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1101.262683: rtos_queue_send_from_isr_failed: tstamp:34699054897 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1101.262685: rtos_queue_send_from_isr_failed: tstamp:34699055037 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1101.262687: rtos_queue_send_from_isr_failed: tstamp:34699055174 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1101.262690: rtos_queue_send_from_isr_failed: tstamp:34699055331 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1101.262692: rtos_queue_send_from_isr_failed: tstamp:34699055475 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1101.262695: rtos_queue_send_from_isr_failed: tstamp:34699055614 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1101.262697: rtos_queue_send_failed: tstamp:34699057017 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.262702: rtcpu_vinotify_event: tstamp:34699615407 tag:ATOMP_FS channel:0x00 frame:161 vi_tstamp:34699615011 data:0x00000000
kworker/5:1-8429 [005] .... 1101.262705: rtcpu_vinotify_event: tstamp:34699624807 tag:CHANSEL_PXL_SOF channel:0x00 frame:161 vi_tstamp:34699624427 data:0x00000001
kworker/5:1-8429 [005] .... 1101.262707: rtcpu_vinotify_event: tstamp:34699630139 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:161 vi_tstamp:34699629769 data:0x08000000
kworker/5:1-8429 [005] .... 1101.262709: rtcpu_vinotify_event: tstamp:34700174559 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:161 vi_tstamp:34700173970 data:0x00000001
kworker/5:1-8429 [005] .... 1101.262711: rtcpu_vinotify_event: tstamp:34700174809 tag:ATOMP_FE channel:0x00 frame:161 vi_tstamp:34700173971 data:0x00000000
kworker/5:1-8429 [005] .... 1101.318679: rtos_queue_peek_from_isr_failed: tstamp:34701969281 queue:0x0b4b4500
v4l2-ctl-8524 [005] .... 1101.344017: tegra_channel_close: vi-output, imx415 2-001a
vi-output, imx4-8525 [000] .... 1101.463660: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 20
vi-output, imx4-8525 [000] .... 1101.463708: tegra_channel_capture_frame: sof:1101.27459081
v4l2-ctl-8524 [003] .... 1101.463947: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-8524 [003] .... 1101.463950: tegra_channel_set_stream: imx415 2-001a : 0x0
v4l2-ctl-8524 [000] .... 1101.465770: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-8524 [000] .... 1101.465774: csi_s_stream: enable : 0x0
kworker/5:1-8429 [005] .... 1101.486586: rtos_queue_send_from_isr_failed: tstamp:34706402430 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.486590: rtos_queue_send_from_isr_failed: tstamp:34706402590 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1101.486591: rtos_queue_send_from_isr_failed: tstamp:34706402731 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1101.486591: rtos_queue_send_from_isr_failed: tstamp:34706402870 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1101.486592: rtos_queue_send_from_isr_failed: tstamp:34706403006 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1101.486592: rtos_queue_send_from_isr_failed: tstamp:34706403143 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1101.486593: rtos_queue_send_from_isr_failed: tstamp:34706403281 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1101.486594: rtos_queue_send_from_isr_failed: tstamp:34706403426 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1101.486595: rtos_queue_send_failed: tstamp:34706404160 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.486596: rtos_queue_send_from_isr_failed: tstamp:34706409632 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.486596: rtos_queue_send_from_isr_failed: tstamp:34706409772 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1101.486597: rtos_queue_send_from_isr_failed: tstamp:34706409911 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1101.486598: rtos_queue_send_from_isr_failed: tstamp:34706410051 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1101.486598: rtos_queue_send_from_isr_failed: tstamp:34706410188 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1101.486599: rtos_queue_send_from_isr_failed: tstamp:34706410332 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1101.486599: rtos_queue_send_from_isr_failed: tstamp:34706410471 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1101.486600: rtos_queue_send_from_isr_failed: tstamp:34706410608 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1101.486601: rtos_queue_send_failed: tstamp:34706411170 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.486602: rtos_queue_send_from_isr_failed: tstamp:34706919646 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.486602: rtos_queue_send_from_isr_failed: tstamp:34706919790 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1101.486603: rtos_queue_send_from_isr_failed: tstamp:34706919930 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1101.486603: rtos_queue_send_from_isr_failed: tstamp:34706920090 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1101.486604: rtos_queue_send_from_isr_failed: tstamp:34706920227 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1101.486604: rtos_queue_send_from_isr_failed: tstamp:34706920375 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1101.486605: rtos_queue_send_from_isr_failed: tstamp:34706920513 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1101.486606: rtos_queue_send_from_isr_failed: tstamp:34706920650 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1101.486606: rtos_queue_send_failed: tstamp:34706921241 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.486607: rtos_queue_send_from_isr_failed: tstamp:34706923138 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.486607: rtos_queue_send_from_isr_failed: tstamp:34706923278 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1101.486608: rtos_queue_send_from_isr_failed: tstamp:34706923417 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1101.486609: rtos_queue_send_from_isr_failed: tstamp:34706923557 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1101.486609: rtos_queue_send_from_isr_failed: tstamp:34706923697 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1101.486610: rtos_queue_send_from_isr_failed: tstamp:34706923836 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1101.486612: rtos_queue_send_from_isr_failed: tstamp:34706923974 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1101.486612: rtos_queue_send_from_isr_failed: tstamp:34706924111 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1101.486613: rtos_queue_send_failed: tstamp:34706925511 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.486614: rtos_queue_send_from_isr_failed: tstamp:34706929453 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.486614: rtos_queue_send_from_isr_failed: tstamp:34706929593 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1101.486615: rtos_queue_send_from_isr_failed: tstamp:34706929732 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1101.486615: rtos_queue_send_from_isr_failed: tstamp:34706929876 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1101.486616: rtos_queue_send_from_isr_failed: tstamp:34706930013 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1101.486617: rtos_queue_send_from_isr_failed: tstamp:34706930151 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1101.486617: rtos_queue_send_from_isr_failed: tstamp:34706930288 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1101.486618: rtos_queue_send_from_isr_failed: tstamp:34706930428 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1101.486619: rtos_queue_send_failed: tstamp:34706931156 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.486619: rtos_queue_send_from_isr_failed: tstamp:34706932485 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.486620: rtos_queue_send_from_isr_failed: tstamp:34706932625 queue:0x0b4aad68
kworker/5:1-8429 [005] .... 1101.486620: rtos_queue_send_from_isr_failed: tstamp:34706932765 queue:0x0b4ac998
kworker/5:1-8429 [005] .... 1101.486621: rtos_queue_send_from_isr_failed: tstamp:34706932905 queue:0x0b4ae518
kworker/5:1-8429 [005] .... 1101.486622: rtos_queue_send_from_isr_failed: tstamp:34706933042 queue:0x0b4af2d8
kworker/5:1-8429 [005] .... 1101.486622: rtos_queue_send_from_isr_failed: tstamp:34706933181 queue:0x0b4b0098
kworker/5:1-8429 [005] .... 1101.486623: rtos_queue_send_from_isr_failed: tstamp:34706933317 queue:0x0b4b0e58
kworker/5:1-8429 [005] .... 1101.486623: rtos_queue_send_from_isr_failed: tstamp:34706933458 queue:0x0b4b1c18
kworker/5:1-8429 [005] .... 1101.486624: rtos_queue_send_failed: tstamp:34706934062 queue:0x0b4a7258
kworker/5:1-8429 [005] .... 1101.486625: rtos_queue_peek_from_isr_failed: tstamp:34706969274 queue:0x0b4b4500
v4l2-ctl-8524 [000] .... 1101.489587: tegra_channel_set_power: imx415 2-001a : 0x0
v4l2-ctl-8524 [000] .... 1101.489598: camera_common_s_power: status : 0x0
v4l2-ctl-8524 [003] .... 1101.496408: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-8524 [003] .... 1101.496413: csi_s_power: enable : 0x0
kworker/5:1-8429 [005] .... 1101.654663: rtos_queue_peek_from_isr_failed: tstamp:34711969337 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1101.822640: rtos_queue_peek_from_isr_failed: tstamp:34716969290 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1101.990692: rtos_queue_peek_from_isr_failed: tstamp:34721969291 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1102.158690: rtos_queue_peek_from_isr_failed: tstamp:34726969346 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1102.272450: rtos_queue_peek_from_isr_failed: tstamp:34731969317 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1102.438674: rtos_queue_peek_from_isr_failed: tstamp:34736969370 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1102.606648: rtos_queue_peek_from_isr_failed: tstamp:34741969332 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1102.774609: rtos_queue_peek_from_isr_failed: tstamp:34746969309 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1102.942621: rtos_queue_peek_from_isr_failed: tstamp:34751969355 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1103.110664: rtos_queue_peek_from_isr_failed: tstamp:34756969422 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1103.278627: rtos_queue_peek_from_isr_failed: tstamp:34761969389 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1103.390628: rtos_queue_peek_from_isr_failed: tstamp:34766969390 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1103.558596: rtos_queue_peek_from_isr_failed: tstamp:34771969343 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1103.726561: rtos_queue_peek_from_isr_failed: tstamp:34776969354 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1103.894599: rtos_queue_peek_from_isr_failed: tstamp:34781969386 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1104.062596: rtos_queue_peek_from_isr_failed: tstamp:34786969363 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1104.230651: rtos_queue_peek_from_isr_failed: tstamp:34791969426 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1104.398691: rtos_queue_peek_from_isr_failed: tstamp:34796969406 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1104.510686: rtos_queue_peek_from_isr_failed: tstamp:34801969438 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1104.678682: rtos_queue_peek_from_isr_failed: tstamp:34806969421 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1104.846665: rtos_queue_peek_from_isr_failed: tstamp:34811969427 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1105.014647: rtos_queue_peek_from_isr_failed: tstamp:34816969460 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1105.182638: rtos_queue_peek_from_isr_failed: tstamp:34821969443 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1105.350632: rtos_queue_peek_from_isr_failed: tstamp:34826969468 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1105.518659: rtos_queue_peek_from_isr_failed: tstamp:34831969478 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1105.630610: rtos_queue_peek_from_isr_failed: tstamp:34836969484 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1105.798635: rtos_queue_peek_from_isr_failed: tstamp:34841969469 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1105.966706: rtos_queue_peek_from_isr_failed: tstamp:34846969500 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1106.134603: rtos_queue_peek_from_isr_failed: tstamp:34851969468 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1106.302606: rtos_queue_peek_from_isr_failed: tstamp:34856969470 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1106.470673: rtos_queue_peek_from_isr_failed: tstamp:34861969553 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1106.638662: rtos_queue_peek_from_isr_failed: tstamp:34866969493 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1106.750686: rtos_queue_peek_from_isr_failed: tstamp:34871969509 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1106.918649: rtos_queue_peek_from_isr_failed: tstamp:34876969505 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1107.086695: rtos_queue_peek_from_isr_failed: tstamp:34881969509 queue:0x0b4b4500
kworker/5:1-8429 [005] .... 1107.142682: rtos_queue_peek_from_isr_failed: tstamp:34883521142 queue:0x0b4b4500
