Hi NVIDIA Developers
I would like to be able to use a Jetson AGX Xavier running R32 (release), REVISION: 5.1 to read a 2-lane MIPI CSI-2 without I2C from a Xilinx FGPA. The video is 1920 x 1080, 30fps, YUV444.
I change the cs_imx307.c driver, remove all the code about the I2C,
And create the devicenode - “/dev/video0” successfully. But i cant use the gstreamer tool get the capture from the fpga.
I use the oscilloscope measure the fpga capture singnal, and it is correct.
And the following is my devicetree , code and dmesg printing.
1.tegra194-p2822-0000-camera-csimx307-a00.dtsi
* Copyright (c) 2015-2018, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <t19x-common-modules/tegra194-camera-csimx307-a00.dtsi>
#include "dt-bindings/clock/tegra194-clock.h"
#define CAM0_RST_L TEGRA194_MAIN_GPIO(H, 3)
#define CAM0_PWDN TEGRA194_MAIN_GPIO(H, 6)
#define CAM1_RST_L TEGRA194_MAIN_GPIO(T, 6)
#define CAM1_PWDN TEGRA194_MAIN_GPIO(T, 5)
#define CAMERA_I2C_MUX_BUS(x) (0x1E + x)
/* camera control gpio definitions */
gpio@2200000 {
camera-control-output-high {
gpio-hog;
output-high;
gpios = <CAM0_RST_L 0>;
label = "cam0-rst";
camera-control-output-low {
status = "disabled";
camera-control-input {
i2c@3180000 {
tca9548@70 {
compatible = "nxp,pca9548";
reg = <0x70>;
#address-cells = <1>;
#size-cells = <0>;
vcc-supply = <&p2822_vdd_1v8_cvb>;
skip_mux_detect;
force_bus_start = <CAMERA_I2C_MUX_BUS(0)>;
i2c@0 {
reg = <0>;
i2c-mux,deselect-on-exit;
#size-cells = <0>;
i2c@3180000 {
tca9548@70 {
i2c@0 {
csimx307_a@3b {
clocks = <&bpmp_clks TEGRA194_CLK_EXTPERIPH1>;
clock-names = "extperiph1";
mclk = "extperiph1";
//reset-gpios = <&tca6408_21 0 GPIO_ACTIVE_HIGH>;
vana-supply = <&p2822_avdd_cam_2v8>;
//vdig-supply = <&en_vdd_sys>;
dovdd-supply = <&p2822_vdd_1v8_cvb>;
2. tegra194-camera-csimx307-a00.dtsi
* more details.
#define CSI_ADP
host1x {
vi@15c10000 {
#ifndef CSI_ADP
num-channels = <6>;
#else
num-channels = <1>;
#endif
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_vi_in0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_out0>;
status = "okay";
nvcsi@15a00000 {
#ifndef CSI_ADP
num-channels = <6>;
#else
num-channels = <1>;
#endif
#address-cells = <0x1>;
#size-cells = <0x0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&e3322_csimx307_out0>;
port@1 {
reg = <1>;
e3322_csi_out0: endpoint@1 {
remote-endpoint = <&e3322_vi_in0>;
i2c@3180000 {
tca9548@70 {
i2c@0 {
csimx307_a@3b {
devnode = "video0";
compatible = "nvidia,cs_imx307";
reg = <0x3b>;
/* Physical dimensions of sensor */
physical_w = "5.6";
physical_h = "3.1";
sensor_model = "csimx307";
use_sensor_mode_id = "false";
dovdd-supply = <&en_vdd_cam>;
avdd-reg = "vana";
dvdd-reg = "vdig";
iovdd-reg = "dovdd";
mode0 { /* CS307_MODE_1920X1080_30FPS */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1920";
active_h = "1080";
pixel_t = "yuv_vyuy16";
readout_orientation = "0";
line_length = "2200";
inherent_gain = "1";
mclk_multiplier = "2";
pix_clk_hz = "74250000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16"; /* 1.00x */
max_gain_val = "170"; /* 10.66x */
step_gain_val = "1";
default_gain = "16"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "1000000"; /* 1.0 fps */
max_framerate = "30000000"; /* 30 fps */
step_framerate = "1000000";
default_framerate = "30000000"; /* 30 fps */
min_exp_time = "13"; /* us */
max_exp_time = "333333"; /* us */
step_exp_time = "1";
default_exp_time = "2495"; /* us */
embedded_metadata_height = "0";
mode1 { /* CS307_MODE_1280X720_CROP_60FPS */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1280";
active_h = "720";
pixel_t = "yuv_uyvy16";
line_length = "1650";
gain_factor = "16";
max_framerate = "60000000"; /* 60 fps */
default_framerate = "60000000"; /* 60 fps */
max_exp_time = "166666"; /* us */
mode2 { /* CS307_MODE_640X480_CROP_130FPS */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "640";
active_h = "480";
line_length = "1100";
gain_factor = "16";
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "130000000"; /* 130 fps */
step_framerate = "1";
default_framerate = "130000000"; /* 130 fps */
max_exp_time = "7692"; /* us */
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_csimx307_out0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_in0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
#ifndef CSI_ADP
num_csi_lanes = <12>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <8>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
#else
num_csi_lanes = <2>;
#endif
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. “rear” or “front”.
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "e3322_bottomleft_A815P2";
position = "bottomleft";
orientation = "1";
drivernode0 {
status = "okay";
pcl_id = "v4l2_sensor";
devname = "csx307 30-003b";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@70/i2c@0/csimx307_a@3b";
/*drivernode1 {
pcl_id = "v4l2_lens";
3. tegra194-camera-csimx307-a00.dtsi
* Top level DTS file for CVM:P2888-0001 and CVB:P2822-0000.
* Copyright (c) 2017-2019, NVIDIA CORPORATION. All rights reserved.
* the Free Software Foundation; version 2 of the License.
* more details.
#include "common/tegra194-p2888-0001-p2822-0000-common.dtsi"
//#include "common/tegra194-p2822-camera-modules.dtsi"
//#include "t19x-common-modules/tegra194-camera-plugin-manager.dtsi"
#include "common/tegra194-p2822-0000-camera-csimx307-a00.dtsi"
//#include "common/tegra194-p2822-0000-camera-e3326-a00.dtsi"
4. cs_imx307.c
* veye327.c - veye327 sensor driver
* Copyright (c) 2016-2019, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify it
* under the terms and conditions of the GNU General Public License,
* version 2, as published by the Free Software Foundation.
* This program is distributed in the hope it will be useful, but WITHOUT
* more details.
#include <linux/slab.h>
#include <linux/uaccess.h>
#include <linux/gpio.h>
#include <linux/module.h>
#include <linux/seq_file.h>
#include <linux/of.h>
#include <linux/of_device.h>
#include <linux/of_gpio.h>
#include <media/tegra_v4l2_camera.h>
#include <media/tegracam_core.h>
#include "cs_imx307.h"
#define CREATE_TRACE_POINTS
/* zp add */
#define label "imx307: zp: "
#define pri_fmt(fmt) label fmt
#define pri_line() \
printk(label "func[%s] line[%d]\n", __FUNCTION__, __LINE__)
#define pri_err(fmt, ...) \
printk(KERN_ERR label "[ERR]: " "func[%s] line[%d]->|ERR| " fmt,\
__FUNCTION__, __LINE__, ##__VA_ARGS__)
#define pri_all(fmt, ...) \
printk(label " func[%s] line[%d]->|| " fmt ,\
#define CSI_ADP 1
//#include <trace/events/veye327.h>
//#define CS307_FUSE_ID_ADDR 0x3382
//#define CS307_FUSE_ID_SIZE 6
//#define CS307_FUSE_ID_STR_SIZE (CS307_FUSE_ID_SIZE * 2)
/* cs_imx307 sensor register address */
//#define CS307_MODEL_ID_ADDR 0x01
//#define DEBUG_PRINTK
#ifndef DEBUG_PRINTK
#define debug_printk(s , ... )
#define VEYE_TRACE
#else
#define debug_printk printk
#define VEYE_TRACE printk("%s %s %d \n",__FILE__,__FUNCTION__,__LINE__);
#endif
static const struct of_device_id cs_imx307_of_match[] = {
{ .compatible = "nvidia,cs_imx307",},
MODULE_DEVICE_TABLE(of, cs_imx307_of_match);
static const u32 ctrl_cid_list[] = {
/*TEGRA_CAMERA_CID_GAIN,
TEGRA_CAMERA_CID_EXPOSURE,
TEGRA_CAMERA_CID_FRAME_RATE,
TEGRA_CAMERA_CID_FUSE_ID,
TEGRA_CAMERA_CID_HDR_EN,*/
TEGRA_CAMERA_CID_SENSOR_MODE_ID,
struct cs_imx307 {
struct i2c_client *i2c_client;
struct v4l2_subdev *subdev;
//u8 fuse_id[VEYE327_FUSE_ID_SIZE];
u32 frame_length;
s64 last_wdr_et_val;
struct camera_common_data *s_data;
struct tegracam_device *tc_dev;
static const struct regmap_config sensor_regmap_config = {
.reg_bits = 16,
.val_bits = 8,
.cache_type = REGCACHE_RBTREE,
.use_single_rw = true,
static inline void cs_imx307_get_frame_length_regs(cs307_reg *regs,
u32 frame_length)
/*regs->addr = VEYE327_FRAME_LENGTH_ADDR_MSB;
regs->val = (frame_length >> 16) & 0x01;
(regs + 1)->addr = VEYE327_FRAME_LENGTH_ADDR_MID;
(regs + 1)->val = (frame_length >> 8) & 0xff;
(regs + 2)->addr = VEYE327_FRAME_LENGTH_ADDR_LSB;
(regs + 2)->val = (frame_length) & 0xff;*/
VEYE_TRACE
return ;
static inline void cs_imx307_get_coarse_time_regs_shs1(cs307_reg *regs,
u32 coarse_time)
/*regs->addr = VEYE327_COARSE_TIME_SHS1_ADDR_MSB;
regs->val = (coarse_time >> 16) & 0x01;
(regs + 1)->addr = VEYE327_COARSE_TIME_SHS1_ADDR_MID;
(regs + 1)->val = (coarse_time >> 8) & 0xff;
(regs + 2)->addr = VEYE327_COARSE_TIME_SHS1_ADDR_LSB;
(regs + 2)->val = (coarse_time) & 0xff;*/
VEYE_TRACE
return ;
static inline void cs_imx307_get_coarse_time_regs_shs2(cs307_reg *regs,
u32 coarse_time)
/*regs->addr = VEYE327_COARSE_TIME_SHS2_ADDR_MSB;
(regs + 1)->addr = VEYE327_COARSE_TIME_SHS2_ADDR_MID;
(regs + 2)->addr = VEYE327_COARSE_TIME_SHS2_ADDR_LSB;
VEYE_TRACE
return;
static inline void cs_imx307_get_gain_reg(cs307_reg *regs,
u8 gain)
/*regs->addr = VEYE327_GAIN_ADDR;
regs->val = (gain) & 0xff;*/
VEYE_TRACE
return;
//static int test_mode;
//module_param(test_mode, int, 0644);
static inline int cs_imx307_read_reg(struct camera_common_data *s_data,
u16 addr, u8 *val)
#ifndef CSI_ADP
int err = 0;
u32 reg_val = 0;
err = regmap_read(s_data->regmap, addr, ®_val);
*val = reg_val & 0xFF;
VEYE_TRACE
return err;
#else
return 0;
#endif
static int cs_imx307_write_reg(struct camera_common_data *s_data,
u16 addr, u8 val)
#ifndef CSI_ADP
int err;
struct device *dev = s_data->dev;
err = regmap_write(s_data->regmap, addr, val);
if (err)
dev_err(dev, "%s: i2c write failed, 0x%x = %x\n",
__func__, addr, val);
VEYE_TRACE
return err;
#else
return 0;
#endif
static int cs_imx307_write_table(struct cs_imx307 *priv,
const cs307_reg table[])
#ifndef CSI_ADP
struct camera_common_data *s_data = priv->s_data;
return regmap_util_write_table_8(s_data->regmap,
table,
NULL, 0,
CS307_TABLE_WAIT_MS,
CS307_TABLE_END);
#else
return 0;
#endif
static int cs_imx307_set_group_hold(struct tegracam_device *tc_dev, bool val)
/*struct camera_common_data *s_data = tc_dev->s_data;
struct device *dev = tc_dev->dev;
int err;
err = veye327_write_reg(s_data,
VEYE327_GROUP_HOLD_ADDR, val);
if (err) {
dev_dbg(dev,
"%s: Group hold control error\n", __func__);
return err;
VEYE_TRACE
return 0;
#if 0
static int cs_imx307_set_gain(struct tegracam_device *tc_dev, s64 val)
#if 0
struct cs_imx307 *priv = (struct cs_imx307 *)tc_dev->priv;
const struct sensor_mode_properties *mode =
&s_data->sensor_props.sensor_modes[s_data->mode_prop_idx];
cs307_reg reg_list[1];
int err;
u8 gain;
/* translate value */
gain = (u8) (val * 160 / (48 * mode->control_properties.gain_factor));
dev_dbg(dev, "%s: gain reg: %d\n", __func__, gain);
cs_imx307_get_gain_reg(reg_list, gain);
err = cs_imx307_write_reg(priv->s_data, reg_list[0].addr,
reg_list[0].val);
if (err)
goto fail;
return 0;
fail:
dev_dbg(dev, "%s: GAIN control error\n", __func__);
return err;
#endif
VEYE_TRACE
return 0;
static int cs_imx307_set_coarse_time(struct cs_imx307 *priv, s64 val)
&s_data->sensor_props.sensor_modes[s_data->mode];
struct device *dev = &priv->i2c_client->dev;
cs307_reg reg_list[3];
int err;
u32 coarse_time_shs1;
u32 reg_shs1;
int i = 0;
coarse_time_shs1 = mode->signal_properties.pixel_clock.val *
val / mode->image_properties.line_length /
mode->control_properties.exposure_factor;
if (priv->frame_length == 0)
priv->frame_length = CS307_MIN_FRAME_LENGTH;
reg_shs1 = priv->frame_length - coarse_time_shs1 - 1;
dev_dbg(dev, "%s: coarse1:%d, shs1:%d, FL:%d\n", __func__,
coarse_time_shs1, reg_shs1, priv->frame_length);
cs_imx307_get_coarse_time_regs_shs1(reg_list, reg_shs1);
for (i = 0; i < 3; i++) {
err = cs_imx307_write_reg(priv->s_data, reg_list[i].addr,
reg_list[i].val);
if (err)
goto fail;
return 0;
fail:
dev_dbg(dev, "%s: set coarse time error\n", __func__);
return err;
VEYE_TRACE
return 0;
#endif
#if 0
static int cs_imx307_set_coarse_time_hdr(struct cs_imx307 *priv, s64 val)
cs307_reg reg_list_shs1[3];
cs307_reg reg_list_shs2[3];
u32 coarse_time_shs2;
u32 reg_shs1;
u32 reg_shs2;
int err;
int i = 0;
priv->last_wdr_et_val = val;
/*WDR, update SHS1 as short ET, and SHS2 is 16x of short*/
mode->control_properties.exposure_factor / 16;
if (coarse_time_shs1 < CS307_MIN_SHS1_1080P_HDR)
coarse_time_shs1 = CS307_MIN_SHS1_1080P_HDR;
if (coarse_time_shs1 > CS307_MAX_SHS1_1080P_HDR)
coarse_time_shs1 = CS307_MAX_SHS1_1080P_HDR;
coarse_time_shs2 = (coarse_time_shs1 - CS307_MIN_SHS1_1080P_HDR) * 16 +
CS307_MIN_SHS2_1080P_HDR;
reg_shs2 = priv->frame_length - coarse_time_shs2 - 1;
cs_imx307_get_coarse_time_regs_shs1(reg_list_shs1, reg_shs1);
cs_imx307_get_coarse_time_regs_shs2(reg_list_shs2, reg_shs2);
dev_dbg(dev, "%s: coarse1:%d, shs1:%d, coarse2:%d, shs2: %d, FL:%d\n",
__func__,
coarse_time_shs2, reg_shs2,
err = cs_imx307_write_reg(priv->s_data, reg_list_shs1[i].addr,
reg_list_shs1[i].val);
if (err)
goto fail;
err = cs_imx307_write_reg(priv->s_data, reg_list_shs2[i].addr,
reg_list_shs2[i].val);
if (err)
goto fail;
return 0;
fail:
dev_dbg(dev, "%s: set WDR coarse time error\n", __func__);
return err;
VEYE_TRACE
return 0;
static int cs_imx307_set_frame_rate(struct tegracam_device *tc_dev, s64 val)
//debug_printk("veye327_set_frame_rate want set rate %d\n",val);
#if 0
int err;
u32 frame_length;
struct v4l2_control control;
int hdr_en;
int i = 0;
frame_length = mode->signal_properties.pixel_clock.val *
mode->control_properties.framerate_factor /
mode->image_properties.line_length / val;
priv->frame_length = frame_length;
if (priv->frame_length > CS307_MAX_FRAME_LENGTH)
priv->frame_length = CS307_MAX_FRAME_LENGTH;
dev_dbg(dev, "%s: val: %lld, , frame_length: %d\n", __func__,
val, priv->frame_length);
cs_imx307_get_frame_length_regs(reg_list, priv->frame_length);
reg_list[i].val);
if (err)
goto fail;
/* check hdr enable ctrl */
control.id = TEGRA_CAMERA_CID_HDR_EN;
err = camera_common_g_ctrl(s_data, &control);
if (err < 0) {
dev_err(dev, "could not find device ctrl.\n");
return err;
hdr_en = switch_ctrl_qmenu[control.value];
if ((hdr_en == SWITCH_ON) && (priv->last_wdr_et_val != 0)) {
err = cs_imx307_set_coarse_time_hdr(priv, priv->last_wdr_et_val);
if (err)
dev_dbg(dev,
"%s: error coarse time SHS1 SHS2 override\n", __func__);
return 0;
fail:
dev_dbg(dev, "%s: FRAME_LENGTH control error\n", __func__);
return err;
#endif
VEYE_TRACE
return 0;
static int cs_imx307_set_exposure(struct tegracam_device *tc_dev, s64 val)
#if 0
int err;
int hdr_en;
dev_dbg(dev, "%s: val: %lld\n", __func__, val);
if (err < 0) {
return err;
if (hdr_en == SWITCH_ON) {
err = cs_imx307_set_coarse_time_hdr(priv, val);
if (err)
dev_dbg(dev,
} else {
err = cs_imx307_set_coarse_time(priv, val);
if (err)
dev_dbg(dev,
"%s: error coarse time SHS1 override\n", __func__);
return err;
VEYE_TRACE
#endif
return 0;
#endif
static int cs_imx307_fill_string_ctrl(struct tegracam_device *tc_dev,
struct v4l2_ctrl *ctrl)
#if 0
struct cs_imx307 *priv = tc_dev->priv;
int i;
switch (ctrl->id) {
case TEGRA_CAMERA_CID_FUSE_ID:
for (i = 0; i < CS307_FUSE_ID_SIZE; i++)
sprintf(&ctrl->p_new.p_char[i*2], "%02x",
priv->fuse_id[i]);
break;
default:
return -EINVAL;
ctrl->p_cur.p_char = ctrl->p_new.p_char;
#endif
VEYE_TRACE
return 0;
static struct tegracam_ctrl_ops cs_imx307_ctrl_ops = {
.numctrls = ARRAY_SIZE(ctrl_cid_list),
.ctrl_cid_list = ctrl_cid_list,
//.string_ctrl_size = {0, CS307_FUSE_ID_STR_SIZE},
//delete for jetpack 4.5
//.set_gain = cs_imx307_set_gain,
//.set_exposure = cs_imx307_set_exposure,
//.set_frame_rate = cs_imx307_set_frame_rate,
.set_group_hold = cs_imx307_set_group_hold,
.fill_string_ctrl = cs_imx307_fill_string_ctrl,
static int cs_imx307_power_on(struct camera_common_data *s_data)
int err = 0;
struct camera_common_power_rail *pw = s_data->power;
struct camera_common_pdata *pdata = s_data->pdata;
printk("\n");
pri_line();
pw->state = SWITCH_ON;
VEYE_TRACE
return 0;
dev_dbg(dev, "%s: power on\n", __func__);
if (pdata && pdata->power_on) {
err = pdata->power_on(pw);
if (err)
dev_err(dev, "%s failed.\n", __func__);
pri_err("failed\n");
else
return err;
/*exit reset mode: XCLR */
if (pw->reset_gpio) {
#ifndef CSI_ADP
gpio_set_value(pw->reset_gpio, 0);
usleep_range(30, 50);
gpio_set_value(pw->reset_gpio, 1);
#else
pri_all("gpio_set_value(pw->reset_gpio, 1);");
#endif
VEYE_TRACE
return 0;
static int cs_imx307_power_off(struct camera_common_data *s_data)
int err = 0;
pri_line();
pw->state = SWITCH_OFF;
VEYE_TRACE
return 0;
dev_dbg(dev, "%s: power off\n", __func__);
if (pdata && pdata->power_off) {
err = pdata->power_off(pw);
if (!err)
goto power_off_done;
else
return err;
/* enter reset mode: XCLR */
usleep_range(1, 2);
if (pw->reset_gpio)
#ifndef CSI_ADP
#else
pri_all("gpio_set_value(pw->reset_gpio, 0);");
#endif
power_off_done:
VEYE_TRACE
return 0;
static int cs_imx307_power_get(struct tegracam_device *tc_dev)
const char *mclk_name;
struct clk *parent;
int err = 0;
pri_line();
if(pdata->mclk_name)
mclk_name = pdata->mclk_name ?
pdata->mclk_name : "extperiph1";
//devm_clk_get extperiph1 OK
pw->mclk = devm_clk_get(dev, mclk_name);
if (IS_ERR(pw->mclk)) {
dev_err(dev, "unable to get clock %s\n", mclk_name);
pri_all("unable to get clock %s\n", mclk_name);
return PTR_ERR(pw->mclk);
//devm_clk_get pllp_grtba ERR
parent = devm_clk_get(dev, "pllp_grtba");
if (IS_ERR(parent)){
dev_err(dev, "devm_clk_get failed for pllp_grtba");
pri_all("devm_clk_get failed for pllp_grtba");
else
clk_set_parent(pw->mclk, parent);
pw->reset_gpio = pdata->reset_gpio;
VEYE_TRACE
return err;
static int cs_imx307_power_put(struct tegracam_device *tc_dev)
pri_line();
if (unlikely(!pw))
return -EFAULT;
VEYE_TRACE
return 0;
static struct camera_common_pdata *cs_imx307_parse_dt(struct tegracam_device *tc_dev)
struct device_node *np = dev->of_node;
struct camera_common_pdata *board_priv_pdata;
const struct of_device_id *match;
//struct camera_common_pdata *ret = NULL;
int err;
//int gpio;
if (!np)
return NULL;
match = of_match_device(cs_imx307_of_match, dev);
if (!match) {
dev_err(dev, "Failed to find matching dt id\n");
return NULL;
board_priv_pdata = devm_kzalloc(dev,
sizeof(*board_priv_pdata), GFP_KERNEL);
if (!board_priv_pdata)
return NULL;
/*gpio = of_get_named_gpio(np, "reset-gpios", 0);
if (gpio < 0) {
if (gpio == -EPROBE_DEFER)
ret = ERR_PTR(-EPROBE_DEFER);
dev_err(dev, "reset-gpios not found \n");
goto error;
board_priv_pdata->reset_gpio = (unsigned int)gpio;*/
//no reset gpio
board_priv_pdata->reset_gpio = 0;
err = of_property_read_string(np, "mclk", &board_priv_pdata->mclk_name);
if (err)
dev_dbg(dev, "mclk name not present, "
"assume sensor driven externally\n");
err = of_property_read_string(np, "avdd-reg",
&board_priv_pdata->regulators.avdd);
err |= of_property_read_string(np, "iovdd-reg",
&board_priv_pdata->regulators.iovdd);
err |= of_property_read_string(np, "dvdd-reg",
&board_priv_pdata->regulators.dvdd);
if (err)
dev_dbg(dev, "avdd, iovdd and/or dvdd reglrs. not present, "
"assume sensor powered independently\n");
board_priv_pdata->has_eeprom =
of_property_read_bool(np, "has-eeprom");
VEYE_TRACE
return board_priv_pdata;
/*error:
devm_kfree(dev, board_priv_pdata);
return ret;*/
static int cs_imx307_set_mode(struct tegracam_device *tc_dev)
struct cs_imx307 *priv = (struct cs_imx307 *)tegracam_get_privdata(tc_dev);
bool limit_analog_gain = false;
int err;
if (!match) {
return -EINVAL;
limit_analog_gain = of_property_read_bool(np, "limit_analog_gain");
err = cs_imx307_write_table(priv, mode_table[s_data->mode_prop_idx]);
if (err)
return err;
/*if (limit_analog_gain) {
err = veye327_write_reg(priv->s_data,
CS307_ANALOG_GAIN_LIMIT_ADDR,
CS307_ANALOG_GAIN_LIMIT_VALUE);
if (err)
return err;
VEYE_TRACE
return 0;
static int cs_imx307_start_streaming(struct tegracam_device *tc_dev)
int err;
/*if (test_mode) {
err = veye327_write_table(priv,
mode_table[CS307_MODE_TEST_PATTERN]);
if (err)
return err;
pri_line();
mode_table[CS307_MODE_START_STREAM]);
if (err)
return err;
VEYE_TRACE
return 0;
static int cs_imx307_stop_streaming(struct tegracam_device *tc_dev)
//struct camera_common_data *s_data = tc_dev->s_data;
int err;
pri_line();
err = cs_imx307_write_table(priv, mode_table[CS307_MODE_STOP_STREAM]);
if (err)
return err;
/* SW_RESET will have no ACK */
//veye327_write_reg(s_data, CS307_SW_RESET_ADDR, 0x01);
* Wait for one frame to make sure sensor is set to
* software standby in V-blank
* delay = frame length rows * Tline (10 us)
usleep_range(priv->frame_length * 10, priv->frame_length * 10 + 1000);
VEYE_TRACE
return 0;
static struct camera_common_sensor_ops cs_imx307_common_ops = {
.numfrmfmts = ARRAY_SIZE(cs_imx307_frmfmt),
.frmfmt_table = cs_imx307_frmfmt,
.power_on = cs_imx307_power_on,
.power_off = cs_imx307_power_off,
.write_reg = cs_imx307_write_reg, //OK
.read_reg = cs_imx307_read_reg, //OK
.parse_dt = cs_imx307_parse_dt,
.power_get = cs_imx307_power_get,
.power_put = cs_imx307_power_put,
.set_mode = cs_imx307_set_mode,
.start_streaming = cs_imx307_start_streaming,
.stop_streaming = cs_imx307_stop_streaming,
static int cs_imx307_fuse_id_setup(struct cs_imx307 *priv)
//读一下id试试?
# if 0
int err;
int i;
u8 bak = 0;
for (i = 0; i < CS307_FUSE_ID_SIZE; i++) {
err |= cs_imx307_read_reg(s_data,
CS307_FUSE_ID_ADDR + i, &bak);
if (!err)
priv->fuse_id[i] = bak;
else {
dev_err(dev, "%s: can not read fuse id\n", __func__);
return -EINVAL;
#endif
VEYE_TRACE
return 0;
static int cs_imx307_board_setup(struct cs_imx307 *priv)
int err = 0;
#ifndef CSI_ADP
u8 reg_val[2];
u16 cameraid = 0;
#endif
dev_dbg(dev, "%s++\n", __func__);
err = camera_common_mclk_enable(s_data);
if (err) {
dev_err(dev,
"Error %d turning on mclk\n", err);
return err;
err = cs_imx307_power_on(s_data);
if (err) {
dev_err(dev,
"Error %d during power on sensor\n", err);
return err;
err = cs_imx307_fuse_id_setup(priv);
if (err) {
dev_err(dev,
"Error %d reading fuse id data\n", err);
goto err_power_on;
/* Probe sensor model id registers */
#ifndef CSI_ADP
err = cs_imx307_read_reg(s_data, PRODUCTID_L, ®_val[0]);
if (err) {
dev_err(dev, "%s: error during i2c read probe (%d)\n",
__func__, err);
goto err_reg_probe;
err = cs_imx307_read_reg(s_data, PRODUCTID_H, ®_val[1]);
if (err) {
__func__, err);
goto err_reg_probe;
cameraid = ((u16)reg_val[1]<<8) + reg_val[0];
dev_err(dev,"read sensor id %04x \n", cameraid);
if (cameraid == CS_MIPI_IMX307)
err = 0;
dev_err(dev, " camera id is cs-mipi-imx307\n");
else
err = -ENODEV;
dev_err(dev, "%s: invalid sensor model id: %d\n",
__func__, cameraid);
#else
err = 0;
#endif
VEYE_TRACE
//err_reg_probe:
cs_imx307_power_off(s_data);
err_power_on:
if (pdata->mclk_name)
camera_common_mclk_disable(s_data);
return err;
static int cs_imx307_open(struct v4l2_subdev *sd, struct v4l2_subdev_fh *fh)
struct i2c_client *client = v4l2_get_subdevdata(sd);
dev_dbg(&client->dev, "%s:\n", __func__);
VEYE_TRACE
return 0;
static const struct v4l2_subdev_internal_ops cs_imx307_subdev_internal_ops = {
.open = cs_imx307_open,
static int cs_imx307_probe(struct i2c_client *client,
const struct i2c_device_id *id)
struct device *dev = &client->dev;
struct cs_imx307 *priv;
int err;
#ifdef CSI_ADP
pri_all("\n Probe start\n");
#endif
dev_info(dev, "probing v4l2 sensor\n");
VEYE_TRACE
if (!IS_ENABLED(CONFIG_OF) || !client->dev.of_node)
return -EINVAL;
priv = devm_kzalloc(dev,
sizeof(struct cs_imx307), GFP_KERNEL);
if (!priv)
return -ENOMEM;
#ifdef CSI_ADP
else
pri_all("[OK] - tc_dev\n");
#endif
tc_dev = devm_kzalloc(dev,
sizeof(struct tegracam_device), GFP_KERNEL);
if (!tc_dev)
return -ENOMEM;
#ifdef CSI_ADP
else
#endif
priv->i2c_client = tc_dev->client = client;
tc_dev->dev = dev;
strncpy(tc_dev->name, "csx307", sizeof(tc_dev->name));
tc_dev->dev_regmap_config = &sensor_regmap_config;
tc_dev->sensor_ops = &cs_imx307_common_ops;
tc_dev->v4l2sd_internal_ops = &cs_imx307_subdev_internal_ops; //OK
tc_dev->tcctrl_ops = &cs_imx307_ctrl_ops; //OK
err = tegracam_device_register(tc_dev);
if (err) {
dev_err(dev, "zp tegra camera driver registration failed %d\n",err);
return err;
#ifdef CSI_ADP
else
pri_all("[OK] - tegracam_device_register\n");
#endif
priv->tc_dev = tc_dev;
priv->s_data = tc_dev->s_data;
priv->subdev = &tc_dev->s_data->subdev;
tegracam_set_privdata(tc_dev, (void *)priv);
err = cs_imx307_board_setup(priv);
if (err) {
dev_err(dev, "board setup failed\n");
return err;
#ifdef CSI_ADP
else
pri_all("[OK] - cs_imx307_board_setup\n");
#endif
err = tegracam_v4l2subdev_register(tc_dev, true);
if (err) {
dev_err(dev, "tegra camera subdev registration failed\n");
return err;
#ifdef CSI_ADP
else
pri_all("[OK] - tegracam_v4l2subdev_register\n");
#endif
dev_info(dev, "Detected CS307 sensor\n");
#ifdef CSI_ADP
pri_all("[OK] - Probe end, OK\n\n");
#endif
return 0;
static int
cs_imx307_remove(struct i2c_client *client)
struct camera_common_data *s_data = to_camera_common_data(&client->dev);
struct cs_imx307 *priv = (struct cs_imx307 *)s_data->priv;
tegracam_v4l2subdev_unregister(priv->tc_dev);
tegracam_device_unregister(priv->tc_dev);
VEYE_TRACE
return 0;
static const struct i2c_device_id cs_imx307_id[] = {
{ "csx307", 0 },
MODULE_DEVICE_TABLE(i2c, cs_imx307_id);
static struct i2c_driver cs_imx307_i2c_driver = {
.driver = {
.name = "csx307",
.owner = THIS_MODULE,
.of_match_table = of_match_ptr(cs_imx307_of_match),
.probe = cs_imx307_probe,
.remove = cs_imx307_remove,
.id_table = cs_imx307_id,
module_i2c_driver(cs_imx307_i2c_driver);
MODULE_DESCRIPTION("Media Controller driver for CSONEPLUS CS-MIPI-IMX307");
MODULE_AUTHOR("xumm@csoneplus.com Tianjin Zhonganyijia Tech Co.,Ltd.");
MODULE_LICENSE("GPL v2");
5. dmesg
[ 1.959033] tegra-i2c 31c0000.i2c: no acknowledge from address 0x50
[ 1.959233] i2c i2c-2: Added multiplexed i2c bus 30
[ 1.959573] i2c i2c-2: Added multiplexed i2c bus 31
[ 1.959895] i2c i2c-2: Added multiplexed i2c bus 32
[ 1.960150] i2c i2c-2: Added multiplexed i2c bus 33
[ 1.960384] i2c i2c-2: Added multiplexed i2c bus 34
[ 1.960718] i2c i2c-2: Added multiplexed i2c bus 35
[ 1.960983] i2c i2c-2: Added multiplexed i2c bus 36
[ 1.961337] i2c i2c-2: Added multiplexed i2c bus 37
[ 1.961347] pca954x 2-0070: registered 8 multiplexed busses for I2C switch pca9548
[ 1.962081] imx307: zp: func[cs_imx307_probe] line[919]->||
Probe start
[ 1.962089] csx307 30-003b: probing v4l2 sensor
[ 1.962095] imx307: zp: func[cs_imx307_probe] line[933]->|| [OK] - tc_dev
[ 1.962100] imx307: zp: func[cs_imx307_probe] line[942]->|| [OK] - tc_dev
[ 1.962182] imx307: zp: func[cs_imx307_power_get] line[600]
[ 1.962526] csx307 30-003b: devm_clk_get failed for pllp_grtba
[ 1.962669] imx307: zp: func[cs_imx307_power_get] line[617]->|| devm_clk_get failed for pllp_grtba
[ 1.962867] csx307 30-003b: tegracam sensor driver:csx307_v2.0.6
[ 1.962874] imx307: zp: func[cs_imx307_probe] line[960]->|| [OK] - tegracam_device_register
[ 1.963000] tegra-i2c 31c0000.i2c: no acknowledge from address 0x50
[ 1.963341] imx307: zp: func[cs_imx307_power_on] line[514]
[ 1.963369] imx307: zp: func[cs_imx307_power_off] line[557]
[ 1.963552] imx307: zp: func[cs_imx307_probe] line[975]->|| [OK] - cs_imx307_board_setup
[ 1.963579] imx307: zp: func[cs_imx307_probe] line[985]->|| [OK] - tegracam_v4l2subdev_register
[ 1.963585] csx307 30-003b: Detected CS307 sensor
[ 1.963591] imx307: zp: func[cs_imx307_probe] line[990]->|| [OK] - Probe end, OK
6.dmesg
gst-launch-1.0 nvv4l2camerasrc device=/dev/video0 ! nvvidconv ! xvimagesink
[ 78.809038] imx307: zp: func[cs_imx307_power_on] line[514]
[ 78.810485] imx307: zp: func[cs_imx307_power_off] line[557]
[ 79.543828] imx307: zp: func[cs_imx307_power_on] line[514]
[ 79.557207] imx307: zp: func[cs_imx307_start_streaming] line[746]
[ 79.603590] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 82.271601] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 82.271792] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 82.271964] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 82.274789] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x39
[ 82.275005] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x41
[ 82.275175] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x37
[ 82.275356] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 84.831607] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 84.831795] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 84.831956] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 84.834702] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 87.391602] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 87.391783] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 87.391944] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 87.394477] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 89.951558] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 89.951769] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 89.951934] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 89.954726] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 92.511570] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 92.511791] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 92.511951] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 92.514733] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 95.071564] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 95.071771] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 95.071941] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 95.074638] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 97.631588] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 97.631813] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 97.631970] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 97.634848] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 100.191320] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 100.191507] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 100.191664] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 100.194776] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 100.195041] imx307: zp: func[cs_imx307_stop_streaming] line[762]
[ 100.204694] imx307: zp: func[cs_imx307_power_off] line[557]
v4l2 dmesg
root@dev:~# cat /etc/nv_tegra_release
# R32 (release), REVISION: 5.1, GCID: 26202423, BOARD: t186ref, EABI: aarch64, DATE: Fri Feb 19 16:50:29 UTC 2021
root@dev:~#
root@dev:~# v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'UYVY'
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.017s (60.000 fps)
Interval: Discrete 0.008s (130.000 fps)
Index : 1
Pixel Format: 'VYUY'
Index : 2
Pixel Format: 'NV16'
Index : 3
Index : 4
root@dev:~# v4l2-ctl --all
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, csx307 30-003b
Bus info : platform:15c10000.vi:0
Driver version: 4.9.201
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: ok)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : 'VYUY'
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
Camera Controls
sensor_mode 0x009a2008 (int64) : min=0 max=0 step=0 default=0 value=0 flags=slider
sensor_configuration 0x009a2032 (u32) : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
sensor_mode_i2c_packet 0x009a2033 (u32) : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
sensor_control_i2c_packet 0x009a2034 (u32) : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
write_isp_format 0x009a2068 (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties 0x009a2069 (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
preferred_stride 0x009a206e (int) : min=0 max=65535 step=1 default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=3 flags=read-only
Results of boosting the clock appear normal, but the capture results do not change.
root@dev:~# echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
root@dev:~# echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
root@dev:~# echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
root@dev:~#
root@dev:~# cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
998400000
root@dev:~#
root@dev:~# cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
1190400000
root@dev:~#
root@dev:~# cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
400000000
Running a trace produces a series of failures:
root@dev:~# echo 1 > /sys/kernel/debug/tracing/tracing_on
root@dev:~# echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
root@dev:~# echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
root@dev:~# echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
root@dev:~# echo 2 > /sys/kernel/debug/camrtc/log-level
root@dev:~# echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
root@dev:~# echo > /sys/kernel/debug/tracing/trace
root@dev:~# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 33/33 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:2-1180 [000] .... 2011.311679: rtos_queue_peek_from_isr_failed: tstamp:63213149593 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2011.479641: rtos_queue_peek_from_isr_failed: tstamp:63218149591 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2011.647632: rtos_queue_peek_from_isr_failed: tstamp:63223149602 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2011.759627: rtos_queue_peek_from_isr_failed: tstamp:63228149598 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2011.927639: rtos_queue_peek_from_isr_failed: tstamp:63233149591 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2012.095624: rtos_queue_peek_from_isr_failed: tstamp:63238149593 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2012.263614: rtos_queue_peek_from_isr_failed: tstamp:63243149591 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2012.431597: rtos_queue_peek_from_isr_failed: tstamp:63248149591 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2012.599599: rtos_queue_peek_from_isr_failed: tstamp:63253149595 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2012.715642: rtos_queue_peek_from_isr_failed: tstamp:63258149495 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2012.883674: rtos_queue_peek_from_isr_failed: tstamp:63263149593 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2013.051588: rtos_queue_peek_from_isr_failed: tstamp:63268149594 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2013.219571: rtos_queue_peek_from_isr_failed: tstamp:63273149590 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2013.387558: rtos_queue_peek_from_isr_failed: tstamp:63278149617 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2013.555564: rtos_queue_peek_from_isr_failed: tstamp:63283149595 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2013.723579: rtos_queue_peek_from_isr_failed: tstamp:63288149595 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2013.835557: rtos_queue_peek_from_isr_failed: tstamp:63293149596 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2014.007536: rtos_queue_peek_from_isr_failed: tstamp:63298149593 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2014.175530: rtos_queue_peek_from_isr_failed: tstamp:63303149600 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2014.343568: rtos_queue_peek_from_isr_failed: tstamp:63308149596 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2014.511520: rtos_queue_peek_from_isr_failed: tstamp:63313149598 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2014.679527: rtos_queue_peek_from_isr_failed: tstamp:63318149595 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2014.847504: rtos_queue_peek_from_isr_failed: tstamp:63323149599 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2014.959513: rtos_queue_peek_from_isr_failed: tstamp:63328149591 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2015.127500: rtos_queue_peek_from_isr_failed: tstamp:63333149595 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2015.295504: rtos_queue_peek_from_isr_failed: tstamp:63338149594 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2015.463482: rtos_queue_peek_from_isr_failed: tstamp:63343149593 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2015.631473: rtos_queue_peek_from_isr_failed: tstamp:63348149591 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2015.799479: rtos_queue_peek_from_isr_failed: tstamp:63353149600 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2015.967477: rtos_queue_peek_from_isr_failed: tstamp:63358149612 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2016.079468: rtos_queue_peek_from_isr_failed: tstamp:63363149594 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2016.247456: rtos_queue_peek_from_isr_failed: tstamp:63368149590 queue:0x0bcbcf78
kworker/0:2-1180 [000] .... 2016.303457: rtos_queue_peek_from_isr_failed: tstamp:63369096330 queue:0x0bcbcf78
gst-launch-1.0-8925 [002] .... 2469.200982: tegra_channel_open: vi-output, csx307 30-003b
gst-launch-1.0-8925 [001] .... 2469.208863: tegra_channel_set_power: csx307 30-003b : 0x1
gst-launch-1.0-8925 [001] .... 2469.208897: camera_common_s_power: status : 0x1
gst-launch-1.0-8925 [002] .... 2469.216485: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
gst-launch-1.0-8925 [002] .... 2469.216496: csi_s_power: enable : 0x1
nvv4l2camerasrc-8927 [003] .... 2469.222142: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 12
kworker/0:1-8757 [000] .... 2469.234747: rtos_queue_peek_from_isr_failed: tstamp:77524429618 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2469.234755: rtcpu_start: tstamp:77524432542
nvv4l2camerasrc-8927 [001] .... 2469.239805: tegra_channel_set_stream: enable : 0x1
nvv4l2camerasrc-8927 [001] .... 2469.248109: tegra_channel_set_stream: 15a00000.nvcsi--1 : 0x1
nvv4l2camerasrc-8927 [001] .... 2469.248112: csi_s_stream: enable : 0x1
nvv4l2camerasrc-8927 [001] .... 2469.248120: tegra_channel_set_stream: csx307 30-003b : 0x1
kworker/0:1-8757 [000] .... 2469.290762: rtos_queue_send_from_isr_failed: tstamp:77524558340 queue:0x0bcb41f8
kworker/0:1-8757 [000] .... 2469.290767: rtos_queue_send_from_isr_failed: tstamp:77524558564 queue:0x0bcb8a60
kworker/0:1-8757 [000] .... 2469.290768: rtos_queue_send_from_isr_failed: tstamp:77524558786 queue:0x0bcba5e0
kworker/0:1-8757 [000] .... 2469.290769: rtos_queue_send_from_isr_failed: tstamp:77524559004 queue:0x0bcbb3a0
kworker/0:1-8757 [000] .... 2469.290770: rtos_queue_send_from_isr_failed: tstamp:77524559222 queue:0x0bcbc160
kworker/0:1-8757 [000] .... 2469.290772: rtcpu_string: tstamp:77524559882 id:0x04010000 str:"Configuring VI GoS.
kworker/0:1-8757 [000] .... 2469.290805: rtcpu_string: tstamp:77524560151 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:1-8757 [000] .... 2469.290812: rtcpu_string: tstamp:77524560478 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:1-8757 [000] .... 2469.290818: rtcpu_string: tstamp:77524560845 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:1-8757 [000] .... 2469.290847: rtcpu_string: tstamp:77524561159 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:1-8757 [000] .... 2469.290855: rtcpu_string: tstamp:77524561465 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:1-8757 [000] .... 2469.290861: rtcpu_string: tstamp:77524561771 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:1-8757 [000] .... 2469.290867: rtcpu_string: tstamp:77524569845 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol vers"
kworker/0:1-8757 [000] .... 2469.290868: rtcpu_string: tstamp:77524570036 id:0x04010000 str:"on 2.2
kworker/0:1-8757 [000] .... 2469.290875: rtos_queue_send_from_isr_failed: tstamp:77524599189 queue:0x0bcb41f8
kworker/0:1-8757 [000] .... 2469.290875: rtos_queue_send_from_isr_failed: tstamp:77524599414 queue:0x0bcb8a60
kworker/0:1-8757 [000] .... 2469.290876: rtos_queue_send_from_isr_failed: tstamp:77524599639 queue:0x0bcba5e0
kworker/0:1-8757 [000] .... 2469.290877: rtos_queue_send_from_isr_failed: tstamp:77524599857 queue:0x0bcbb3a0
kworker/0:1-8757 [000] .... 2469.290878: rtos_queue_send_from_isr_failed: tstamp:77524600074 queue:0x0bcbc160
kworker/0:1-8757 [000] .... 2469.290878: rtcpu_string: tstamp:77524601230 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:1-8757 [000] .... 2469.290884: rtos_queue_send_from_isr_failed: tstamp:77524860887 queue:0x0bcb41f8
kworker/0:1-8757 [000] .... 2469.290885: rtos_queue_send_from_isr_failed: tstamp:77524861047 queue:0x0bcb8a60
kworker/0:1-8757 [000] .... 2469.290886: rtos_queue_send_from_isr_failed: tstamp:77524861209 queue:0x0bcba5e0
kworker/0:1-8757 [000] .... 2469.290887: rtos_queue_send_from_isr_failed: tstamp:77524861366 queue:0x0bcbb3a0
kworker/0:1-8757 [000] .... 2469.290887: rtos_queue_send_from_isr_failed: tstamp:77524861523 queue:0x0bcbc160
kworker/0:1-8757 [000] .... 2469.290890: rtcpu_vinotify_event: tstamp:77524882581 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:75605590464 data:0x10000000
kworker/0:1-8757 [000] .... 2469.290890: rtcpu_vinotify_event: tstamp:77524882756 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:75605594272 data:0x31000001
kworker/0:1-8757 [000] .... 2469.290911: rtcpu_vinotify_event: tstamp:77524882930 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:75605595264 data:0x07020001
kworker/0:1-8757 [000] .... 2469.290912: rtcpu_vinotify_event: tstamp:77524883078 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:75605652736 data:0x10000000
kworker/0:1-8757 [000] .... 2469.290913: rtcpu_vinotify_event: tstamp:77524883249 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:75605656608 data:0x31000002
kworker/0:1-8757 [000] .... 2469.402779: rtos_queue_peek_from_isr_failed: tstamp:77529429980 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2469.570776: rtos_queue_peek_from_isr_failed: tstamp:77534429980 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2469.738703: rtos_queue_peek_from_isr_failed: tstamp:77539429980 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2469.906702: rtos_queue_peek_from_isr_failed: tstamp:77544429980 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2470.074691: rtos_queue_peek_from_isr_failed: tstamp:77549429980 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2470.242671: rtos_queue_peek_from_isr_failed: tstamp:77554429980 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2470.354667: rtos_queue_peek_from_isr_failed: tstamp:77559429982 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2470.522655: rtos_queue_peek_from_isr_failed: tstamp:77564429982 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2470.690642: rtos_queue_peek_from_isr_failed: tstamp:77569429982 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2470.858636: rtos_queue_peek_from_isr_failed: tstamp:77574429984 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2471.030673: rtos_queue_peek_from_isr_failed: tstamp:77579429980 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2471.198613: rtos_queue_peek_from_isr_failed: tstamp:77584429980 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2471.366603: rtos_queue_peek_from_isr_failed: tstamp:77589429979 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2471.478599: rtos_queue_peek_from_isr_failed: tstamp:77594429979 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2471.646590: rtos_queue_peek_from_isr_failed: tstamp:77599429979 queue:0x0bcbcf78
kworker/0:1-8757 [000] .... 2471.814606: rtos_queue_peek_from_isr_failed: tstamp:77604429979 queue:0x0bcbcf78
vi-output, csx3-8930 [001] .... 2471.921316: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 12
kworker/0:1-8757 [000] .... 2471.926604: rtos_queue_send_from_isr_failed: tstamp:77608329087 queue:0x0bcb41f8
kworker/0:1-8757 [000] .... 2471.926610: rtos_queue_send_from_isr_failed: tstamp:77608329268 queue:0x0bcb8a60
kworker/0:1-8757 [000] .... 2471.926611: rtos_queue_send_from_isr_failed: tstamp:77608329433 queue:0x0bcba5e0
kworker/0:1-8757 [000] .... 2471.926613: rtos_queue_send_from_isr_failed: tstamp:77608329590 queue:0x0bcbb3a0
kworker/0:1-8757 [000] .... 2471.926614: rtos_queue_send_from_isr_failed: tstamp:77608329746 queue:0x0bcbc160
kworker/0:1-8757 [000] .... 2471.926616: rtos_queue_send_from_isr_failed: tstamp:77608395666 queue:0x0bcb41f8
kworker/0:1-8757 [000] .... 2471.926617: rtos_queue_send_from_isr_failed: tstamp:77608395826 queue:0x0bcb8a60
kworker/0:1-8757 [000] .... 2471.926618: rtos_queue_send_from_isr_failed: tstamp:77608395989 queue:0x0bcba5e0
kworker/0:1-8757 [000] .... 2471.926620: rtos_queue_send_from_isr_failed: tstamp:77608396146 queue:0x0bcbb3a0
kworker/0:1-8757 [000] .... 2471.926621: rtos_queue_send_from_isr_failed: tstamp:77608396303 queue:0x0bcbc160
kworker/0:1-8757 [000] .... 2471.926622: rtos_queue_send_from_isr_failed: tstamp:77608403520 queue:0x0bcb41f8
kworker/0:1-8757 [000] .... 2471.926624: rtos_queue_send_from_isr_failed: tstamp:77608403678 queue:0x0bcb8a60
kworker/0:1-8757 [000] .... 2471.926625: rtos_queue_send_from_isr_failed: tstamp:77608403839 queue:0x0bcba5e0
kworker/0:1-8757 [000] .... 2471.926626: rtos_queue_send_from_isr_failed: tstamp:77608403996 queue:0x0bcbb3a0
kworker/0:1-8757 [000] .... 2471.926628: rtos_queue_send_from_isr_failed: tstamp:77608404152 queue:0x0bcbc160
dmesg - after open the trace
[ 2469.216476] imx307: zp: func[cs_imx307_power_on] line[514]
[ 2469.248143] imx307: zp: func[cs_imx307_start_streaming] line[746]
[ 2469.290797] [RCE] Configuring VI GoS.
[ 2469.290809] [RCE] VM GOS[#0] addr=0xc2100000
[ 2469.290816] [RCE] VM GOS[#1] addr=0xc2101000
[ 2469.290822] [RCE] VM GOS[#2] addr=0xc2102000
[ 2469.290852] [RCE] VM GOS[#3] addr=0xc2103000
[ 2469.290858] [RCE] VM GOS[#4] addr=0xc2104000
[ 2469.290865] [RCE] VM GOS[#5] addr=0xc2105000
[ 2469.290872] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 2469.290882] [RCE] VI GOS[#0] set to VM GOS[4] base 0xc2104000
[ 2471.918590] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 2471.918765] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 2471.918947] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 2471.921671] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 2479.606183] [RCE] Configuring VI GoS.
[ 2479.606194] [RCE] VM GOS[#0] addr=0xc2100000
[ 2479.606200] [RCE] VM GOS[#1] addr=0xc2101000
[ 2479.606206] [RCE] VM GOS[#2] addr=0xc2102000
[ 2479.606212] [RCE] VM GOS[#3] addr=0xc2103000
[ 2479.606218] [RCE] VM GOS[#4] addr=0xc2104000
[ 2479.606224] [RCE] VM GOS[#5] addr=0xc2105000
[ 2482.158024] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 2482.158196] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 2482.158350] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 2482.160755] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 2484.761894] [RCE] Configuring VI GoS.
[ 2484.761914] [RCE] VM GOS[#0] addr=0xc2100000
[ 2484.761922] [RCE] VM GOS[#1] addr=0xc2101000
[ 2484.761928] [RCE] VM GOS[#2] addr=0xc2102000
[ 2484.761934] [RCE] VM GOS[#3] addr=0xc2103000
[ 2484.761940] [RCE] VM GOS[#4] addr=0xc2104000
[ 2484.761946] [RCE] VM GOS[#5] addr=0xc2105000
[ 2487.277711] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 2487.277886] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 2487.278070] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 2487.280650] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 2487.280932] imx307: zp: func[cs_imx307_stop_streaming] line[762]
[ 2487.286004] [RCE] Configuring VI GoS.
[ 2487.286029] [RCE] VM GOS[#0] addr=0xc2100000
[ 2487.286036] [RCE] VM GOS[#1] addr=0xc2101000
[ 2487.286042] [RCE] VM GOS[#2] addr=0xc2102000
[ 2487.286048] [RCE] VM GOS[#3] addr=0xc2103000
[ 2487.286055] [RCE] VM GOS[#4] addr=0xc2104000
[ 2487.286061] [RCE] VM GOS[#5] addr=0xc2105000
[ 2487.300356] imx307: zp: func[cs_imx307_power_off] line[557]
I’m confused to how to look for the problem and solve it.
Thank you.
