When I try nvgstcapture-1.0, there are a lot of debug messages:
[ 224.134660] vi4_power_on
[ 224.143801] imx362 2-001a: imx362_power_on: power on
[ 224.154588] imx362 2-001a: imx362_s_stream++
[ 224.158886] imx362_write_table: imx362_stop
[ 224.165532] imx362 2-001a: imx362_s_stream mode[0]
[ 224.170402] imx362_write_table: mode_2016X1136_1Gbps_1
[ 224.205369] imx362_write_table: imx362_start
[ 224.215173] imx362_power_on,flag=2
[ 224.218680] imx362 2-001a: imx362_s_stream++
[ 224.223011] imx362_write_table: imx362_stop
[ 224.229224] imx362_set_fmt
[ 224.232060] imx362_set_fmt
[ 224.243200] vi4_channel_start_streaming
[ 224.247168] imx362_get_fmt
[ 224.249990] imx362_get_fmt end
[ 224.256164] tegra-vi4 15700000.vi: Create Surface with imgW=2016, imgH=1136, memFmt=32
[ 224.264996] tegra_mipi_cal 3990000.mipical: tegra_mipi_bias_pad_enable
[ 224.272703] csi4_mipi_cal
[ 224.275435] chan->numports=1,chan->numlanes=4
[ 224.279898] csi port:0
[ 224.282252] tegra_mipi_calibration:lanes=3145728
[ 224.286978] tegra_mipi_cal 3990000.mipical: tegra_mipi_calibration
[ 224.293158] tegra_mipical_using_prod
[ 224.296884] tegra_mipi_wait
[ 224.299871] imx362 2-001a: imx362_s_stream++
[ 224.304143] imx362_write_table: imx362_stop
[ 224.310099] imx362 2-001a: imx362_s_stream mode[0]
[ 224.314902] imx362_write_table: mode_2016X1136_1Gbps_1
[ 224.349518] imx362_write_table: imx362_start
[ 224.383411] tegra-vi4 15700000.vi: Status: 7 channel:00 frame:0001
[ 224.389695] tegra-vi4 15700000.vi: timestamp sof 234313236512 eof 234327297216 data 0x00000001
[ 224.399160] tegra-vi4 15700000.vi: capture_id 1 stream 0 vchan 0
[ 224.406378] vi4_channel_stop_streaming
[ 225.367237] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 226.371169] tegra-vi4 15700000.vi: ATOMP_FE syncpt timeout!
[ 226.377270] imx362 2-001a: imx362_s_stream++
[ 226.381736] imx362_write_table: imx362_stop
[ 226.388059] tegra_mipi_cal 3990000.mipical: tegra_mipi_bias_pad_disable
[ 226.408948] vi4_power_off
[ 226.411793] imx362 2-001a: imx362_power_off: power off
[ 226.419593] tegra_vi4_power_off
[ 436.593808] vi4_power_on
[ 436.597934] imx362 2-001a: imx362_power_on: power on
[ 436.608859] imx362 2-001a: imx362_s_stream++
[ 436.613315] imx362_write_table: imx362_stop
[ 436.619456] imx362 2-001a: imx362_s_stream mode[0]
[ 436.624391] imx362_write_table: mode_2016X1136_1Gbps_1
[ 436.659060] imx362_write_table: imx362_start
[ 436.669175] imx362_power_on,flag=3
[ 436.672707] imx362 2-001a: imx362_s_stream++
[ 436.677006] imx362_write_table: imx362_stop
[ 436.683261] imx362_set_fmt
[ 436.686185] imx362_set_fmt
[ 436.698141] vi4_channel_start_streaming
[ 436.702161] imx362_get_fmt
[ 436.704981] imx362_get_fmt end
[ 436.708884] tegra-vi4 15700000.vi: Create Surface with imgW=2016, imgH=1136, memFmt=32
[ 436.722349] tegra_mipi_cal 3990000.mipical: tegra_mipi_bias_pad_enable
[ 436.730114] csi4_mipi_cal
[ 436.732875] chan->numports=1,chan->numlanes=4
[ 436.737510] csi port:0
[ 436.739902] tegra_mipi_calibration:lanes=3145728
[ 436.744633] tegra_mipi_cal 3990000.mipical: tegra_mipi_calibration
[ 436.750849] tegra_mipical_using_prod
[ 436.754589] tegra_mipi_wait
[ 436.757593] imx362 2-001a: imx362_s_stream++
[ 436.761904] imx362_write_table: imx362_stop
[ 436.767871] imx362 2-001a: imx362_s_stream mode[0]
[ 436.772688] imx362_write_table: mode_2016X1136_1Gbps_1
[ 436.807314] imx362_write_table: imx362_start
[ 436.841282] tegra-vi4 15700000.vi: Status: 7 channel:00 frame:0001
[ 436.847613] tegra-vi4 15700000.vi: timestamp sof 446771043360 eof 446785104032 data 0x00000001
[ 436.857085] tegra-vi4 15700000.vi: capture_id 61 stream 0 vchan 0
[ 436.864468] vi4_channel_stop_streaming
[ 437.824413] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 438.828397] tegra-vi4 15700000.vi: ATOMP_FE syncpt timeout!
[ 438.834299] imx362 2-001a: imx362_s_stream++
[ 438.839130] imx362_write_table: imx362_stop
[ 438.845240] tegra_mipi_cal 3990000.mipical: tegra_mipi_bias_pad_disable
[ 438.856877] vi4_power_off
[ 438.859605] imx362 2-001a: imx362_power_off: power off
[ 438.865271] tegra_vi4_power_off
[ 951.128042] vi4_power_on
[ 951.134734] imx362 2-001a: imx362_power_on: power on
[ 951.145441] imx362 2-001a: imx362_s_stream++
[ 951.149723] imx362_write_table: imx362_stop
[ 951.155387] imx362 2-001a: imx362_s_stream mode[0]
[ 951.160181] imx362_write_table: mode_2016X1136_1Gbps_1
[ 951.194663] imx362_write_table: imx362_start
[ 951.204173] imx362_power_on,flag=4
[ 951.207682] imx362 2-001a: imx362_s_stream++
[ 951.211971] imx362_write_table: imx362_stop
[ 951.218081] vi4_power_off
[ 951.220863] imx362 2-001a: imx362_power_off: power off
[ 951.226483] tegra_vi4_power_off
[ 951.231501] vi4_power_on
[ 951.234274] imx362 2-001a: imx362_power_on: power on
[ 951.245068] imx362 2-001a: imx362_s_stream++
[ 951.249379] imx362_write_table: imx362_stop
[ 951.255408] imx362 2-001a: imx362_s_stream mode[0]
[ 951.260240] imx362_write_table: mode_2016X1136_1Gbps_1
[ 951.295335] imx362_write_table: imx362_start
[ 951.305401] imx362_power_on,flag=5
[ 951.308914] imx362 2-001a: imx362_s_stream++
[ 951.313216] imx362_write_table: imx362_stop
[ 951.318954] vi4_power_off
[ 951.321702] imx362 2-001a: imx362_power_off: power off
[ 951.327329] tegra_vi4_power_off
[ 951.354513] vi4_power_on
[ 951.357344] imx362 2-001a: imx362_power_on: power on
[ 951.368103] imx362 2-001a: imx362_s_stream++
[ 951.372395] imx362_write_table: imx362_stop
[ 951.378389] imx362 2-001a: imx362_s_stream mode[0]
[ 951.383260] imx362_write_table: mode_2016X1136_1Gbps_1
[ 951.418221] imx362_write_table: imx362_start
[ 951.428281] imx362_power_on,flag=6
[ 951.431787] imx362 2-001a: imx362_s_stream++
[ 951.436082] imx362_write_table: imx362_stop
[ 951.442096] vi4_power_off
[ 951.444864] imx362 2-001a: imx362_power_off: power off
[ 951.450453] tegra_vi4_power_off
[ 951.454172] vi4_power_on
[ 951.456932] imx362 2-001a: imx362_power_on: power on
[ 951.467568] imx362 2-001a: imx362_s_stream++
[ 951.471848] imx362_write_table: imx362_stop
[ 951.477833] imx362 2-001a: imx362_s_stream mode[0]
[ 951.482667] imx362_write_table: mode_2016X1136_1Gbps_1
[ 951.517789] imx362_write_table: imx362_start
[ 951.527892] imx362_power_on,flag=7
[ 951.531429] imx362 2-001a: imx362_s_stream++
[ 951.535761] imx362_write_table: imx362_stop
[ 951.541886] vi4_power_off
[ 951.544636] imx362 2-001a: imx362_power_off: power off
[ 951.550218] tegra_vi4_power_off
[ 951.553830] vi4_power_on
[ 951.556596] imx362 2-001a: imx362_power_on: power on
[ 951.567362] imx362 2-001a: imx362_s_stream++
[ 951.571647] imx362_write_table: imx362_stop
[ 951.577622] imx362 2-001a: imx362_s_stream mode[0]
[ 951.582435] imx362_write_table: mode_2016X1136_1Gbps_1
[ 951.618066] imx362_write_table: imx362_start
[ 951.628149] imx362_power_on,flag=8
[ 951.631657] imx362 2-001a: imx362_s_stream++
[ 951.635993] imx362_write_table: imx362_stop
[ 951.642019] imx362_g_input_status
[ 951.645500] vi4_power_off
[ 951.648246] imx362 2-001a: imx362_power_off: power off
[ 951.653886] tegra_vi4_power_off
[ 951.732546] vi4_power_on
[ 951.735565] imx362 2-001a: imx362_power_on: power on
[ 951.746360] imx362 2-001a: imx362_s_stream++
[ 951.750808] imx362_write_table: imx362_stop
[ 951.757215] imx362 2-001a: imx362_s_stream mode[0]
[ 951.763611] imx362_write_table: mode_2016X1136_1Gbps_1
[ 951.804268] imx362_write_table: imx362_start
[ 951.814675] imx362_power_on,flag=9
[ 951.818274] imx362 2-001a: imx362_s_stream++
[ 951.822804] imx362_write_table: imx362_stop
[ 951.828809] imx362_set_fmt
[ 951.832350] imx362_set_fmt
[ 951.835259] imx362_s_ctrl
[ 951.837967] imx362_s_ctrl
[ 951.840706] imx362_set_frame_length
[ 951.844323] imx362_s_ctrl
[ 951.847024] imx362_set_coarse_time
[ 951.850533] imx362_s_ctrl
[ 951.853318] imx362_set_group_hold
[ 951.868362] vi4_channel_start_streaming
[ 951.872303] imx362_get_fmt
[ 951.875098] imx362_get_fmt end
[ 951.878333] tegra_mipi_cal 3990000.mipical: tegra_mipi_bias_pad_enable
[ 951.886108] csi4_mipi_cal
[ 951.888840] chan->numports=1,chan->numlanes=4
[ 951.893301] csi port:0
[ 951.895672] tegra_mipi_calibration:lanes=3145728
[ 951.900387] tegra_mipi_cal 3990000.mipical: tegra_mipi_calibration
[ 951.906657] tegra_mipical_using_prod
[ 951.910449] tegra_mipi_wait
[ 951.913433] imx362 2-001a: imx362_s_stream++
[ 951.917740] imx362_write_table: imx362_stop
[ 951.923391] imx362 2-001a: imx362_s_stream mode[0]
[ 951.928258] imx362_write_table: mode_2016X1136_1Gbps_1
[ 951.962197] imx362_set_gain
[ 951.965092] imx362_set_frame_length
[ 951.968671] imx362_set_coarse_time
[ 951.972166] imx362_write_table: imx362_start
[ 953.523215] fence timeout on [ffffffc0227fcd00] after 1500ms
[ 953.528883] name=[nvhost_sync:33], current value=96 waiting value=97
[ 953.535249] ---- mlocks ----
[ 953.538139] 8: locked by channel 6
[ 953.543044] ---- syncpts ----
[ 953.543213] fence timeout on [ffffffc15dbd2100] after 1500ms
[ 953.543216] name=[nvhost_sync:54], current value=41 waiting value=42
[ 953.543218] ---- mlocks ----
[ 953.543228] 8: locked by channel 6
[ 953.543243] ---- syncpts ----
[ 953.543253] id 4 (disp_d) min 6952 max 6952 refs 1 (previous client : )
[ 953.543256] id 5 (disp_e) min 2 max 2 refs 1 (previous client : )
[ 953.543260] id 7 (vblank1) min 56999 max 0 refs 1 (previous client : )
[ 953.543273] id 18 (17000000.gp10b_507) min 146320 max 146320 refs 1 (previous client : 17000000.gp10b_507)
[ 953.543276] id 19 (17000000.gp10b_506) min 58 max 58 refs 1 (previous client : 17000000.gp10b_506)
[ 953.543279] id 20 (17000000.gp10b_505) min 35554 max 35554 refs 1 (previous client : 17000000.gp10b_505)
[ 953.543282] id 21 (17000000.gp10b_504) min 10 max 10 refs 1 (previous client : tegra-vi4)
[ 953.543285] id 22 (17000000.gp10b_503) min 13648 max 13648 refs 1 (previous client : tegra-vi4)
[ 953.543287] id 23 (17000000.gp10b_502) min 22842 max 22842 refs 1 (previous client : )
[ 953.543290] id 24 (17000000.gp10b_501) min 16292 max 16292 refs 1 (previous client : )
[ 953.543292] id 25 (17000000.gp10b_500) min 3346 max 3346 refs 1 (previous client : )
[ 953.543297] id 28 (17000000.gp10b_499) min 7380 max 7380 refs 1 (previous client : )
[ 953.543299] id 29 (17000000.gp10b_498) min 2006 max 2006 refs 1 (previous client : )
[ 953.543302] id 30 (17000000.gp10b_497) min 298 max 298 refs 1 (previous client : )
[ 953.543304] id 31 (17000000.gp10b_496) min 8 max 8 refs 1 (previous client : )
[ 953.543307] id 32 (17000000.gp10b_495) min 8 max 8 refs 1 (previous client : )
[ 953.543310] id 33 (15600000.isp_nvcamera-daemon_0) min 96 max 100 refs 4 (previous client : 17000000.gp10b_494)
[ 953.543313] id 34 (15600000.isp_nvcamera-daemon_1) min 32 max 34 refs 4 (previous client : 17000000.gp10b_493)
[ 953.543316] id 35 (17000000.gp10b_492) min 8 max 8 refs 1 (previous client : )
[ 953.543318] id 36 (17000000.gp10b_491) min 8 max 8 refs 1 (previous client : )
[ 953.543321] id 37 (17000000.gp10b_490) min 8 max 8 refs 1 (previous client : )
[ 953.543323] id 38 (17000000.gp10b_489) min 8 max 8 refs 1 (previous client : )
[ 953.543326] id 39 (17000000.gp10b_488) min 8 max 8 refs 1 (previous client : )
[ 953.543328] id 40 (17000000.gp10b_487) min 8 max 8 refs 1 (previous client : )
[ 953.543331] id 41 (17000000.gp10b_486) min 54 max 54 refs 1 (previous client : 17000000.gp10b_486)
[ 953.543333] id 42 (17000000.gp10b_485) min 8 max 8 refs 1 (previous client : )
[ 953.543336] id 43 (17000000.gp10b_484) min 8 max 8 refs 1 (previous client : )
[ 953.543338] id 44 (17000000.gp10b_483) min 8 max 8 refs 1 (previous client : )
[ 953.543341] id 45 (17000000.gp10b_482) min 8 max 8 refs 1 (previous client : )
[ 953.543343] id 46 (17000000.gp10b_481) min 8 max 8 refs 1 (previous client : )
[ 953.543345] id 47 (17000000.gp10b_480) min 8 max 8 refs 1 (previous client : )
[ 953.543349] id 48 (17000000.gp10b_475) min 296 max 296 refs 1 (previous client : 17000000.gp10b_475)
[ 953.543351] id 49 (17000000.gp10b_477) min 202 max 202 refs 1 (previous client : 17000000.gp10b_478)
[ 953.543354] id 50 (17000000.gp10b_476) min 3348 max 3348 refs 1 (previous client : tegra-vi4)
[ 953.543357] id 51 (17000000.gp10b_478) min 662 max 662 refs 1 (previous client : tegra-vi4)
[ 953.543360] id 52 (15600000.isp_nvcamera-daemon_2) min 40 max 42 refs 4 (previous client : 17000000.gp10b_475)
[ 953.543362] id 53 (17000000.gp10b_474) min 8 max 8 refs 1 (previous client : )
[ 953.543365] id 54 (15600000.isp_nvcamera-daemon_3) min 41 max 42 refs 4 (previous client : 17000000.gp10b_473)
[ 953.543368] id 55 (17000000.gp10b_472) min 62 max 62 refs 1 (previous client : )
[ 953.543370] id 56 (15600000.isp_nvcamera-daemon_4) min 15 max 26 refs 9 (previous client : )
[ 953.543373] id 57 (15600000.isp_nvcamera-daemon_5) min 1 max 2 refs 4 (previous client : )
[ 953.543379] id 62 (17000000.gp10b_471) min 2 max 2 refs 1 (previous client : )
[ 953.543388] id 69 (17000000.gp10b_462) min 13 max 13 refs 1 (previous client : 15700000.vi_0)
[ 953.543391] id 70 (17000000.gp10b_461) min 6 max 6 refs 1 (previous client : 15700000.vi_0)
[ 953.543394] id 71 (17000000.gp10b_460) min 6 max 6 refs 1 (previous client : 15700000.vi_1)
[ 953.543396] id 72 (15700000.vi_0) min 7 max 7 refs 2 (previous client : 15700000.vi_2)
[ 953.543406] id 80 (17000000.gp10b_465) min 2 max 2 refs 1 (previous client : )
[ 953.543408] id 81 (17000000.gp10b_464) min 8 max 8 refs 1 (previous client : )
[ 953.543414] id 85 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : )
[ 953.543417] id 86 (17000000.gp10b_459) min 6 max 6 refs 1 (previous client : )
[ 953.543419] id 87 (17000000.gp10b_458) min 6 max 6 refs 1 (previous client : )
[ 953.543891] ---- channels ----
[ 953.543900]
channel 1 - 15820000.se
[ 953.543901] NvHost basic channel registers:
[ 953.543903] CMDFIFO_STAT_0: 00002040
[ 953.543905] CMDFIFO_RDATA_0: b311a200
[ 953.543908] CMDP_OFFSET_0: 00000000
[ 953.543910] CMDP_CLASS_0: 00000000
[ 953.543912] CHANNELSTAT_0: 00000000
[ 953.543913] The CDMA sync queue is empty.
[ 953.543915]
channel 2 - 15830000.se
[ 953.543916] NvHost basic channel registers:
[ 953.543918] CMDFIFO_STAT_0: 00002040
[ 953.543919] CMDFIFO_RDATA_0: c9831b22
[ 953.543923] CMDP_OFFSET_0: 00000000
[ 953.543924] CMDP_CLASS_0: 00000000
[ 953.543926] CHANNELSTAT_0: 00000000
[ 953.543926] The CDMA sync queue is empty.
[ 953.543929]
channel 3 - 15840000.se
[ 953.543930] NvHost basic channel registers:
[ 953.543931] CMDFIFO_STAT_0: 00002040
[ 953.543933] CMDFIFO_RDATA_0: 0820c840
[ 953.543936] CMDP_OFFSET_0: 00000000
[ 953.543938] CMDP_CLASS_0: 00000000
[ 953.543939] CHANNELSTAT_0: 00000000
[ 953.543940] The CDMA sync queue is empty.
[ 953.543942]
channel 6 - 15600000.isp
[ 953.543943] NvHost basic channel registers:
[ 953.543944] CMDFIFO_STAT_0: 00004000
[ 953.543946] CMDFIFO_RDATA_0: 004e0041
[ 953.543949] CMDP_OFFSET_0: 00000050
[ 953.543951] CMDP_CLASS_0: 00000001
[ 953.543953] CHANNELSTAT_0: 00000000
[ 953.543956]
ffffffc15e598600: JOB, syncpt_id=33, syncpt_val=98, first_get=000001f8, timeout=10000, num_slots=19
[ 953.543962] GATHER at 5a708000+3bec, 12 words
[ 953.543972] 20000001 00006421 20000001 00006822 20000001 00006c34 20000001 00007c36 20000001 00007439 200c0001 00000005
[ 953.543974] GATHER at 5a708000+3c1c, 2 words
[ 953.543977] 20000001 00000038
[ 953.543979]
channel 5 - 150c0000.nvcsi
[ 953.543980] NvHost basic channel registers:
[ 953.543981] CMDFIFO_STAT_0: 00002040
[ 953.543983] CMDFIFO_RDATA_0: 00000055
[ 953.543986] CMDP_OFFSET_0: 00000000
[ 953.543988] CMDP_CLASS_0: 00000001
[ 953.543990] CHANNELSTAT_0: 00000000
[ 953.543990] The CDMA sync queue is empty.
[ 953.543992]
channel 0 - 15700000.vi
[ 953.543993] NvHost basic channel registers:
[ 953.543995] CMDFIFO_STAT_0: 00002040
[ 953.543997] CMDFIFO_RDATA_0: 00000048
[ 953.544000] CMDP_OFFSET_0: 00000000
[ 953.544001] CMDP_CLASS_0: 00000001
[ 953.544003] CHANNELSTAT_0: 00000000
[ 953.544003] The CDMA sync queue is empty.
[ 953.544005]
---- host general irq ----
[ 953.544007] sync_intc0mask = 0x00000001
[ 953.544009] sync_intmask = 0x50000003
[ 953.544009]
---- host syncpt irq mask ----
[ 953.544010]
---- host syncpt irq status ----
[ 953.544012] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 953.544014] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 953.544016] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 953.544018] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 953.544020] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 953.544022] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 953.544023] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 953.544025] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 953.544027] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 953.544029] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 953.544030] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 953.544032] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 953.544034] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 953.544036] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 953.544038] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 953.544039] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 953.544041] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 953.544043] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 954.340151] id 4 (disp_d) min 6952 max 6953 refs 1 (previous client : )
[ 954.346776] id 5 (disp_e) min 2 max 2 refs 1 (previous client : )
[ 954.352914] id 7 (vblank1) min 57048 max 0 refs 1 (previous client : )
[ 954.359554] id 18 (17000000.gp10b_507) min 146656 max 146656 refs 1 (previous client : 17000000.gp10b_507)
[ 954.369240] id 19 (17000000.gp10b_506) min 58 max 58 refs 1 (previous client : 17000000.gp10b_506)
[ 954.378238] id 20 (17000000.gp10b_505) min 35566 max 35568 refs 1 (previous client : 17000000.gp10b_505)
[ 954.387744] id 21 (17000000.gp10b_504) min 10 max 10 refs 1 (previous client : tegra-vi4)
[ 954.395917] id 22 (17000000.gp10b_503) min 13648 max 13648 refs 1 (previous client : tegra-vi4)
[ 954.404606] id 23 (17000000.gp10b_502) min 22842 max 22842 refs 1 (previous client : )
[ 954.412518] id 24 (17000000.gp10b_501) min 16292 max 16292 refs 1 (previous client : )
[ 954.420428] id 25 (17000000.gp10b_500) min 3346 max 3346 refs 1 (previous client : )
[ 954.428166] id 28 (17000000.gp10b_499) min 7380 max 7380 refs 1 (previous client : )
[ 954.435901] id 29 (17000000.gp10b_498) min 2006 max 2006 refs 1 (previous client : )
[ 954.443638] id 30 (17000000.gp10b_497) min 298 max 298 refs 1 (previous client : )
[ 954.451202] id 31 (17000000.gp10b_496) min 8 max 8 refs 1 (previous client : )
[ 954.458420] id 32 (17000000.gp10b_495) min 8 max 8 refs 1 (previous client : )
[ 954.465637] id 33 (15600000.isp_nvcamera-daemon_0) min 96 max 100 refs 4 (previous client : 17000000.gp10b_494)
[ 954.475715] id 34 (15600000.isp_nvcamera-daemon_1) min 32 max 34 refs 4 (previous client : 17000000.gp10b_493)
[ 954.485704] id 35 (17000000.gp10b_492) min 8 max 8 refs 1 (previous client : )
[ 954.492922] id 36 (17000000.gp10b_491) min 8 max 8 refs 1 (previous client : )
[ 954.500139] id 37 (17000000.gp10b_490) min 8 max 8 refs 1 (previous client : )
[ 954.507355] id 38 (17000000.gp10b_489) min 8 max 8 refs 1 (previous client : )
[ 954.514574] id 39 (17000000.gp10b_488) min 8 max 8 refs 1 (previous client : )
[ 954.521791] id 40 (17000000.gp10b_487) min 8 max 8 refs 1 (previous client : )
[ 954.529007] id 41 (17000000.gp10b_486) min 54 max 54 refs 1 (previous client : 17000000.gp10b_486)
[ 954.537957] id 42 (17000000.gp10b_485) min 8 max 8 refs 1 (previous client : )
[ 954.545172] id 43 (17000000.gp10b_484) min 8 max 8 refs 1 (previous client : )
[ 954.552390] id 44 (17000000.gp10b_483) min 8 max 8 refs 1 (previous client : )
[ 954.559607] id 45 (17000000.gp10b_482) min 8 max 8 refs 1 (previous client : )
[ 954.566825] id 46 (17000000.gp10b_481) min 8 max 8 refs 1 (previous client : )
[ 954.574041] id 47 (17000000.gp10b_480) min 8 max 8 refs 1 (previous client : )
[ 954.581257] id 48 (17000000.gp10b_475) min 296 max 296 refs 1 (previous client : 17000000.gp10b_475)
[ 954.590383] id 49 (17000000.gp10b_477) min 202 max 202 refs 1 (previous client : 17000000.gp10b_478)
[ 954.599507] id 50 (17000000.gp10b_476) min 3348 max 3348 refs 1 (previous client : tegra-vi4)
[ 954.608026] id 51 (17000000.gp10b_478) min 662 max 662 refs 1 (previous client : tegra-vi4)
[ 954.616410] id 52 (15600000.isp_nvcamera-daemon_2) min 40 max 42 refs 4 (previous client : 17000000.gp10b_475)
[ 954.626461] id 53 (17000000.gp10b_474) min 8 max 8 refs 1 (previous client : )
[ 954.633684] id 54 (15600000.isp_nvcamera-daemon_3) min 41 max 42 refs 4 (previous client : 17000000.gp10b_473)
[ 954.643710] id 55 (17000000.gp10b_472) min 62 max 62 refs 1 (previous client : )
[ 954.651103] id 56 (15600000.isp_nvcamera-daemon_4) min 15 max 26 refs 9 (previous client : )
[ 954.659535] id 57 (15600000.isp_nvcamera-daemon_5) min 1 max 2 refs 4 (previous client : )
[ 954.667806] id 62 (17000000.gp10b_471) min 2 max 2 refs 1 (previous client : )
[ 954.675030] id 69 (17000000.gp10b_462) min 13 max 13 refs 1 (previous client : 15700000.vi_0)
[ 954.683618] id 70 (17000000.gp10b_461) min 6 max 6 refs 1 (previous client : 15700000.vi_0)
[ 954.692006] id 71 (17000000.gp10b_460) min 6 max 6 refs 1 (previous client : 15700000.vi_1)
[ 954.700357] id 72 (15700000.vi_0) min 7 max 7 refs 2 (previous client : 15700000.vi_2)
[ 954.708276] id 80 (17000000.gp10b_465) min 2 max 2 refs 1 (previous client : )
[ 954.715495] id 81 (17000000.gp10b_464) min 8 max 8 refs 1 (previous client : )
[ 954.722718] id 85 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : )
[ 954.729936] id 86 (17000000.gp10b_459) min 6 max 6 refs 1 (previous client : )
[ 954.737155] id 87 (17000000.gp10b_458) min 6 max 6 refs 1 (previous client : )
[ 954.746337] ---- channels ----
[ 954.749410]
[ 954.755854] NvHost basic channel registers:
[ 954.760039] CMDFIFO_STAT_0: 00002040
[ 954.763741] CMDFIFO_RDATA_0: b311a200
[ 954.767418] CMDP_OFFSET_0: 00000000
[ 954.771071] CMDP_CLASS_0: 00000000
[ 954.774735] CHANNELSTAT_0: 00000000
[ 954.778398] The CDMA sync queue is empty.
[ 954.783908]
[ 954.790347] NvHost basic channel registers:
[ 954.794531] CMDFIFO_STAT_0: 00002040
[ 954.798196] CMDFIFO_RDATA_0: c9831b22
[ 954.801860] CMDP_OFFSET_0: 00000000
[ 954.805523] CMDP_CLASS_0: 00000000
[ 954.809187] CHANNELSTAT_0: 00000000
[ 954.812849] The CDMA sync queue is empty.
[ 954.818347]
[ 954.824787] NvHost basic channel registers:
[ 954.828969] CMDFIFO_STAT_0: 00002040
[ 954.832632] CMDFIFO_RDATA_0: 0820c840
[ 954.836296] CMDP_OFFSET_0: 00000000
[ 954.839956] CMDP_CLASS_0: 00000000
[ 954.843619] CHANNELSTAT_0: 00000000
[ 954.847281] The CDMA sync queue is empty.
[ 954.852777]
[ 954.859304] NvHost basic channel registers:
[ 954.863487] CMDFIFO_STAT_0: 00004000
[ 954.867141] CMDFIFO_RDATA_0: 004e0041
[ 954.870804] CMDP_OFFSET_0: 00000050
[ 954.874465] CMDP_CLASS_0: 00000001
[ 954.878128] CHANNELSTAT_0: 00000000
[ 954.881790]
[ 954.893344] GATHER at 5a708000+3bec, 12 words
[ 954.898050] 20000001 00006421 20000001 00006822 20000001 00006c34 20000001 00007c36 20000001 00007439 200c0001 00000005
[ 954.909046] GATHER at 5a708000+3c1c, 2 words
[ 954.913662] 20000001 00000038
[ 954.918225]
[ 954.924925] NvHost basic channel registers:
[ 954.929109] CMDFIFO_STAT_0: 00002040
[ 954.932771] CMDFIFO_RDATA_0: 00000055
[ 954.936434] CMDP_OFFSET_0: 00000000
[ 954.940097] CMDP_CLASS_0: 00000001
[ 954.943757] CHANNELSTAT_0: 00000000
[ 954.947417] The CDMA sync queue is empty.
[ 954.952910]
[ 954.959347] NvHost basic channel registers:
[ 954.963528] CMDFIFO_STAT_0: 00002040
[ 954.967182] CMDFIFO_RDATA_0: 00000048
[ 954.970846] CMDP_OFFSET_0: 00000000
[ 954.974507] CMDP_CLASS_0: 00000001
[ 954.978172] CHANNELSTAT_0: 00000000
[ 954.981833] The CDMA sync queue is empty.
[ 954.987336]
[ 954.994037] sync_intc0mask = 0x00000001
[ 954.997875] sync_intmask = 0x50000003
[ 955.001548]
[ 955.008602]
[ 955.015830] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 955.021232] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 955.026632] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 955.032028] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 955.037427] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 955.042825] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 955.048220] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 955.053618] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 955.059016] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 955.064414] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 955.069814] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 955.075297] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 955.080779] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 955.086263] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 955.091748] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 955.097230] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 955.102716] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 955.108198] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 958.023292] host1x 13e10000.host1x: CaptureSchedule: syncpoint id 56 (15600000.isp_nvcamera-daemon_4) stuck waiting 18, timeout=-1
[ 958.035335] ---- syncpts ----
[ 958.038368] id 4 (disp_d) min 6962 max 6962 refs 1 (previous client : )
[ 958.045132] id 5 (disp_e) min 2 max 2 refs 1 (previous client : )
[ 958.051386] id 7 (vblank1) min 57270 max 0 refs 1 (previous client : )
[ 958.058042] id 18 (17000000.gp10b_507) min 146838 max 146838 refs 1 (previous client : 17000000.gp10b_507)
[ 958.067803] id 19 (17000000.gp10b_506) min 58 max 58 refs 1 (previous client : 17000000.gp10b_506)
[ 958.076831] id 20 (17000000.gp10b_505) min 35604 max 35604 refs 1 (previous client : 17000000.gp10b_505)
[ 958.086360] id 21 (17000000.gp10b_504) min 10 max 10 refs 1 (previous client : tegra-vi4)
[ 958.094580] id 22 (17000000.gp10b_503) min 13648 max 13648 refs 1 (previous client : tegra-vi4)
[ 958.103384] id 23 (17000000.gp10b_502) min 22842 max 22842 refs 1 (previous client : )
[ 958.111366] id 24 (17000000.gp10b_501) min 16292 max 16292 refs 1 (previous client : )
[ 958.119372] id 25 (17000000.gp10b_500) min 3346 max 3346 refs 1 (previous client : )
[ 958.127145] id 28 (17000000.gp10b_499) min 7380 max 7380 refs 1 (previous client : )
[ 958.134939] id 29 (17000000.gp10b_498) min 2006 max 2006 refs 1 (previous client : )
[ 958.142713] id 30 (17000000.gp10b_497) min 298 max 298 refs 1 (previous client : )
[ 958.150302] id 31 (17000000.gp10b_496) min 8 max 8 refs 1 (previous client : )
[ 958.157590] id 32 (17000000.gp10b_495) min 8 max 8 refs 1 (previous client : )
[ 958.164839] id 33 (15600000.isp_nvcamera-daemon_0) min 96 max 100 refs 4 (previous client : 17000000.gp10b_494)
[ 958.174943] id 34 (15600000.isp_nvcamera-daemon_1) min 32 max 34 refs 4 (previous client : 17000000.gp10b_493)
[ 958.185028] id 35 (17000000.gp10b_492) min 8 max 8 refs 1 (previous client : )
[ 958.192309] id 36 (17000000.gp10b_491) min 8 max 8 refs 1 (previous client : )
[ 958.199545] id 37 (17000000.gp10b_490) min 8 max 8 refs 1 (previous client : )
[ 958.206805] id 38 (17000000.gp10b_489) min 8 max 8 refs 1 (previous client : )
[ 958.214025] id 39 (17000000.gp10b_488) min 8 max 8 refs 1 (previous client : )
[ 958.221286] id 40 (17000000.gp10b_487) min 8 max 8 refs 1 (previous client : )
[ 958.228507] id 41 (17000000.gp10b_486) min 54 max 54 refs 1 (previous client : 17000000.gp10b_486)
[ 958.237496] id 42 (17000000.gp10b_485) min 8 max 8 refs 1 (previous client : )
[ 958.244718] id 43 (17000000.gp10b_484) min 8 max 8 refs 1 (previous client : )
[ 958.251972] id 44 (17000000.gp10b_483) min 8 max 8 refs 1 (previous client : )
[ 958.259194] id 45 (17000000.gp10b_482) min 8 max 8 refs 1 (previous client : )
[ 958.266410] id 46 (17000000.gp10b_481) min 8 max 8 refs 1 (previous client : )
[ 958.273671] id 47 (17000000.gp10b_480) min 8 max 8 refs 1 (previous client : )
[ 958.280894] id 48 (17000000.gp10b_475) min 296 max 296 refs 1 (previous client : 17000000.gp10b_475)
[ 958.290056] id 49 (17000000.gp10b_477) min 202 max 202 refs 1 (previous client : 17000000.gp10b_478)
[ 958.299183] id 50 (17000000.gp10b_476) min 3348 max 3348 refs 1 (previous client : tegra-vi4)
[ 958.307740] id 51 (17000000.gp10b_478) min 662 max 662 refs 1 (previous client : tegra-vi4)
[ 958.316092] id 52 (15600000.isp_nvcamera-daemon_2) min 40 max 42 refs 4 (previous client : 17000000.gp10b_475)
[ 958.326130] id 53 (17000000.gp10b_474) min 8 max 8 refs 1 (previous client : )
[ 958.333354] id 54 (15600000.isp_nvcamera-daemon_3) min 41 max 42 refs 4 (previous client : 17000000.gp10b_473)
[ 958.343397] id 55 (17000000.gp10b_472) min 62 max 62 refs 1 (previous client : )
[ 958.350848] id 56 (15600000.isp_nvcamera-daemon_4) min 15 max 26 refs 9 (previous client : )
[ 958.359288] id 57 (15600000.isp_nvcamera-daemon_5) min 1 max 2 refs 4 (previous client : )
[ 958.367595] id 62 (17000000.gp10b_471) min 2 max 2 refs 1 (previous client : )
[ 958.374824] id 69 (17000000.gp10b_462) min 13 max 13 refs 1 (previous client : 15700000.vi_0)
[ 958.383365] id 70 (17000000.gp10b_461) min 6 max 6 refs 1 (previous client : 15700000.vi_0)
[ 958.391767] id 71 (17000000.gp10b_460) min 6 max 6 refs 1 (previous client : 15700000.vi_1)
[ 958.400117] id 72 (15700000.vi_0) min 7 max 7 refs 2 (previous client : 15700000.vi_2)
[ 958.408083] id 80 (17000000.gp10b_465) min 2 max 2 refs 1 (previous client : )
[ 958.415304] id 81 (17000000.gp10b_464) min 8 max 8 refs 1 (previous client : )
[ 958.422564] id 85 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : )
[ 958.429782] id 86 (17000000.gp10b_459) min 6 max 6 refs 1 (previous client : )
[ 958.437050] id 87 (17000000.gp10b_458) min 6 max 6 refs 1 (previous client : )
[ 962.047278] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 33 (15600000.isp_nvcamera-daemon_0) clientid 1, HW thresh 96, done 98
[ 962.059622] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 34 (15600000.isp_nvcamera-daemon_1) clientid 1, HW thresh 32, done 33
[ 962.071933] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 52 (15600000.isp_nvcamera-daemon_2) clientid 1, HW thresh 40, done 41
[ 962.084262] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 54 (15600000.isp_nvcamera-daemon_3) clientid 1, HW thresh 41, done 41
[ 962.096567] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 57 (15600000.isp_nvcamera-daemon_5) clientid 1, HW thresh 1, done 1
[ 962.108705] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 56 (15600000.isp_nvcamera-daemon_4) clientid 1, HW thresh 15, done 15
[ 962.121014] ---- mlocks ----
[ 962.124033] 8: locked by channel 6
[ 962.129051] ---- syncpts ----
[ 962.132104] id 4 (disp_d) min 6975 max 6975 refs 1 (previous client : )
[ 962.138824] id 5 (disp_e) min 2 max 2 refs 1 (previous client : )
[ 962.144954] id 7 (vblank1) min 57515 max 0 refs 1 (previous client : )
[ 962.151580] id 18 (17000000.gp10b_507) min 146924 max 146924 refs 1 (previous client : 17000000.gp10b_507)
[ 962.161271] id 19 (17000000.gp10b_506) min 58 max 58 refs 1 (previous client : 17000000.gp10b_506)
[ 962.170275] id 20 (17000000.gp10b_505) min 35676 max 35676 refs 1 (previous client : 17000000.gp10b_505)
[ 962.179790] id 21 (17000000.gp10b_504) min 10 max 10 refs 1 (previous client : tegra-vi4)
[ 962.188031] id 22 (17000000.gp10b_503) min 13648 max 13648 refs 1 (previous client : tegra-vi4)
[ 962.196742] id 23 (17000000.gp10b_502) min 22842 max 22842 refs 1 (previous client : )
[ 962.204706] id 24 (17000000.gp10b_501) min 16292 max 16292 refs 1 (previous client : )
[ 962.212640] id 25 (17000000.gp10b_500) min 3346 max 3346 refs 1 (previous client : )
[ 962.220404] id 28 (17000000.gp10b_499) min 7380 max 7380 refs 1 (previous client : )
[ 962.228199] id 29 (17000000.gp10b_498) min 2006 max 2006 refs 1 (previous client : )
[ 962.235996] id 30 (17000000.gp10b_497) min 298 max 298 refs 1 (previous client : )
[ 962.243577] id 31 (17000000.gp10b_496) min 8 max 8 refs 1 (previous client : )
[ 962.250842] id 32 (17000000.gp10b_495) min 8 max 8 refs 1 (previous client : )
[ 962.258077] id 33 (15600000.isp_nvcamera-daemon_0) min 96 max 100 refs 4 (previous client : 17000000.gp10b_494)
[ 962.268173] id 34 (15600000.isp_nvcamera-daemon_1) min 32 max 34 refs 4 (previous client : 17000000.gp10b_493)
[ 962.278217] id 35 (17000000.gp10b_492) min 8 max 8 refs 1 (previous client : )
[ 962.285484] id 36 (17000000.gp10b_491) min 8 max 8 refs 1 (previous client : )
[ 962.292716] id 37 (17000000.gp10b_490) min 8 max 8 refs 1 (previous client : )
[ 962.299934] id 38 (17000000.gp10b_489) min 8 max 8 refs 1 (previous client : )
[ 962.307193] id 39 (17000000.gp10b_488) min 8 max 8 refs 1 (previous client : )
[ 962.314406] id 40 (17000000.gp10b_487) min 8 max 8 refs 1 (previous client : )
[ 962.321654] id 41 (17000000.gp10b_486) min 54 max 54 refs 1 (previous client : 17000000.gp10b_486)
[ 962.330606] id 42 (17000000.gp10b_485) min 8 max 8 refs 1 (previous client : )
[ 962.337854] id 43 (17000000.gp10b_484) min 8 max 8 refs 1 (previous client : )
[ 962.345075] id 44 (17000000.gp10b_483) min 8 max 8 refs 1 (previous client : )
[ 962.352325] id 45 (17000000.gp10b_482) min 8 max 8 refs 1 (previous client : )
[ 962.359544] id 46 (17000000.gp10b_481) min 8 max 8 refs 1 (previous client : )
[ 962.366760] id 47 (17000000.gp10b_480) min 8 max 8 refs 1 (previous client : )
[ 962.374019] id 48 (17000000.gp10b_475) min 296 max 296 refs 1 (previous client : 17000000.gp10b_475)
[ 962.383149] id 49 (17000000.gp10b_477) min 202 max 202 refs 1 (previous client : 17000000.gp10b_478)
[ 962.392307] id 50 (17000000.gp10b_476) min 3348 max 3348 refs 1 (previous client : tegra-vi4)
[ 962.400859] id 51 (17000000.gp10b_478) min 662 max 662 refs 1 (previous client : tegra-vi4)
[ 962.409215] id 52 (15600000.isp_nvcamera-daemon_2) min 40 max 42 refs 4 (previous client : 17000000.gp10b_475)
[ 962.419244] id 53 (17000000.gp10b_474) min 8 max 8 refs 1 (previous client : )
[ 962.426467] id 54 (15600000.isp_nvcamera-daemon_3) min 41 max 42 refs 4 (previous client : 17000000.gp10b_473)
[ 962.436494] id 55 (17000000.gp10b_472) min 62 max 62 refs 1 (previous client : )
[ 962.443896] id 56 (15600000.isp_nvcamera-daemon_4) min 15 max 26 refs 9 (previous client : )
[ 962.452366] id 57 (15600000.isp_nvcamera-daemon_5) min 1 max 2 refs 4 (previous client : )
[ 962.460634] id 62 (17000000.gp10b_471) min 2 max 2 refs 1 (previous client : )
[ 962.467893] id 69 (17000000.gp10b_462) min 13 max 13 refs 1 (previous client : 15700000.vi_0)
[ 962.476414] id 70 (17000000.gp10b_461) min 6 max 6 refs 1 (previous client : 15700000.vi_0)
[ 962.484791] id 71 (17000000.gp10b_460) min 6 max 6 refs 1 (previous client : 15700000.vi_1)
[ 962.493138] id 72 (15700000.vi_0) min 7 max 7 refs 2 (previous client : 15700000.vi_2)
[ 962.501089] id 80 (17000000.gp10b_465) min 2 max 2 refs 1 (previous client : )
[ 962.508309] id 81 (17000000.gp10b_464) min 8 max 8 refs 1 (previous client : )
[ 962.515531] id 85 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : )
[ 962.522781] id 86 (17000000.gp10b_459) min 6 max 6 refs 1 (previous client : )
[ 962.530001] id 87 (17000000.gp10b_458) min 6 max 6 refs 1 (previous client : )
[ 962.539221] ---- channels ----
[ 962.542274]
[ 962.548722] NvHost basic channel registers:
[ 962.552943] CMDFIFO_STAT_0: 00002040
[ 962.556615] CMDFIFO_RDATA_0: b311a200
[ 962.560286] CMDP_OFFSET_0: 00000000
[ 962.563957] CMDP_CLASS_0: 00000000
[ 962.567657] CHANNELSTAT_0: 00000000
[ 962.571329] The CDMA sync queue is empty.
[ 962.576828]
[ 962.583274] NvHost basic channel registers:
[ 962.587501] CMDFIFO_STAT_0: 00002040
[ 962.591157] CMDFIFO_RDATA_0: c9831b22
[ 962.594828] CMDP_OFFSET_0: 00000000
[ 962.598500] CMDP_CLASS_0: 00000000
[ 962.602212] CHANNELSTAT_0: 00000000
[ 962.605879] The CDMA sync queue is empty.
[ 962.611396]
[ 962.617875] NvHost basic channel registers:
[ 962.622064] CMDFIFO_STAT_0: 00002040
[ 962.625729] CMDFIFO_RDATA_0: 0820c840
[ 962.629392] CMDP_OFFSET_0: 00000000
[ 962.633055] CMDP_CLASS_0: 00000000
[ 962.636758] CHANNELSTAT_0: 00000000
[ 962.640423] The CDMA sync queue is empty.
[ 962.645919]
[ 962.652477] NvHost basic channel registers:
[ 962.656663] CMDFIFO_STAT_0: 00004000
[ 962.660324] CMDFIFO_RDATA_0: 004e0041
[ 962.663988] CMDP_OFFSET_0: 00000050
[ 962.667683] CMDP_CLASS_0: 00000001
[ 962.671347] CHANNELSTAT_0: 00000000
[ 962.675003]
[ 962.686589] GATHER at 5a708000+3bec, 12 words
[ 962.691294] 20000001 00006421 20000001 00006822 20000001 00006c34 20000001 00007c36 20000001 00007439 200c0001 00000005
[ 962.702320] GATHER at 5a708000+3c1c, 2 words
[ 962.706937] 20000001 00000038
[ 962.711510]
[ 962.718236] NvHost basic channel registers:
[ 962.722418] CMDFIFO_STAT_0: 00002040
[ 962.726082] CMDFIFO_RDATA_0: 00000055
[ 962.729746] CMDP_OFFSET_0: 00000000
[ 962.733407] CMDP_CLASS_0: 00000001
[ 962.737101] CHANNELSTAT_0: 00000000
[ 962.740763] The CDMA sync queue is empty.
[ 962.746258]
[ 962.752724] NvHost basic channel registers:
[ 962.756908] CMDFIFO_STAT_0: 00002040
[ 962.760570] CMDFIFO_RDATA_0: 00000048
[ 962.764236] CMDP_OFFSET_0: 00000000
[ 962.767928] CMDP_CLASS_0: 00000001
[ 962.771591] CHANNELSTAT_0: 00000000
[ 962.775254] The CDMA sync queue is empty.
[ 962.780762]
[ 962.787501] sync_intc0mask = 0x00000001
[ 962.791342] sync_intmask = 0x50000003
[ 962.794994]
[ 962.802067]
[ 962.809288] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 962.814685] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 962.820114] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 962.825512] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 962.830907] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 962.836331] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 962.841727] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 962.847123] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 962.852555] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 962.857957] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 962.863355] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 962.868874] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 962.874362] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 962.879847] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 962.885363] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 962.890848] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 962.896330] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 962.901841] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 962.927598] isp 15600000.isp: SYNCPT_ID 33
[ 962.932216] isp 15600000.isp: SYNCPT_VAL 98
[ 962.936867] isp 15600000.isp: FIRST_GET 0x1f8
[ 962.941748] isp 15600000.isp: TIMEOUT 10000
[ 962.946628] isp 15600000.isp: NUM_SLOTS 19
[ 962.951279] isp 15600000.isp: NUM_HANDLES 1
[ 962.955825] isp 15600000.isp: SYNCPT_ID 56
[ 962.960442] isp 15600000.isp: SYNCPT_VAL 17
[ 962.965058] isp 15600000.isp: FIRST_GET 0x290
[ 962.969966] isp 15600000.isp: TIMEOUT 10000
[ 962.974848] isp 15600000.isp: NUM_SLOTS 12
[ 962.979464] isp 15600000.isp: NUM_HANDLES 1
[ 962.983998] isp 15600000.isp: SYNCPT_ID 56
[ 962.988644] isp 15600000.isp: SYNCPT_VAL 19
[ 962.993265] isp 15600000.isp: FIRST_GET 0x2f0
[ 962.998140] isp 15600000.isp: TIMEOUT 10000
[ 963.007271] isp 15600000.isp: NUM_SLOTS 9
[ 963.011814] isp 15600000.isp: NUM_HANDLES 1
[ 963.016358] isp 15600000.isp: SYNCPT_ID 56
[ 963.021017] isp 15600000.isp: SYNCPT_VAL 21
[ 963.025641] isp 15600000.isp: FIRST_GET 0x338
[ 963.030520] isp 15600000.isp: TIMEOUT 10000
[ 963.035429] isp 15600000.isp: NUM_SLOTS 9
[ 963.039962] isp 15600000.isp: NUM_HANDLES 1
[ 963.044496] isp 15600000.isp: SYNCPT_ID 56
[ 963.049113] isp 15600000.isp: SYNCPT_VAL 23
[ 963.053758] isp 15600000.isp: FIRST_GET 0x380
[ 963.058638] isp 15600000.isp: TIMEOUT 10000
[ 963.063515] isp 15600000.isp: NUM_SLOTS 9
[ 963.068077] isp 15600000.isp: NUM_HANDLES 5
[ 963.072610] isp 15600000.isp: SYNCPT_ID 33
[ 963.077232] isp 15600000.isp: SYNCPT_VAL 100
[ 963.081939] isp 15600000.isp: FIRST_GET 0x3c8
[ 963.086847] isp 15600000.isp: TIMEOUT 10000
[ 963.091727] isp 15600000.isp: NUM_SLOTS 19
[ 963.096344] isp 15600000.isp: NUM_HANDLES 1
[ 963.100915] isp 15600000.isp: SYNCPT_ID 56
[ 963.105536] isp 15600000.isp: SYNCPT_VAL 26
[ 963.110159] isp 15600000.isp: FIRST_GET 0x460
[ 963.115045] isp 15600000.isp: TIMEOUT 10000
[ 963.119957] isp 15600000.isp: NUM_SLOTS 12
[ 963.124581] isp 15600000.isp: NUM_HANDLES 1
When I run gstreamer, there are following errors and debug messages:
gst-launch-1.0 nvcamerasrc ! 'video/x-raw(memory:NVMM), width=2016, height=1136, framerate=30/1, format=NV12' ! nvvidconv flip-method=2 ! nvegltransform ! nveglglessink
Setting pipeline to PAUSED ...
Available Sensor modes :
2016 x 1136 FR=30.000000 CF=0x1009208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
NvCameraSrc: Trying To Set Default Camera Resolution. Selected sensorModeIndex = 0 WxH = 2016x1136 FrameRate = 30.000000 ...
ERROR: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: Output window was closed
Additional debug info:
/dvs/git/dirty/git-master_linux/external/gstreamer/gst-nveglglessink/ext/eglgles/gsteglglessink.c(832): gst_eglglessink_event_thread (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0
Execution ended after 0:00:07.530872284
Setting pipeline to READY ...
dmesg:
[ 69.755751] vi4_power_on
[ 69.758714] imx362 2-001a: imx362_power_on: power on
[ 69.776890] imx362 2-001a: imx362_s_stream++
[ 69.790931] imx362_write_table: imx362_stop
[ 69.803895] imx362 2-001a: imx362_s_stream mode[0]
[ 69.813187] imx362_write_table: mode_2016X1136_1Gbps_1
[ 69.856298] imx362_write_table: imx362_start
[ 69.866368] imx362_power_on,flag=8
[ 69.869882] imx362 2-001a: imx362_s_stream++
[ 69.874189] imx362_write_table: imx362_stop
[ 69.880209] imx362_set_fmt
[ 69.883109] imx362_set_fmt
[ 69.887961] imx362_s_ctrl
[ 69.890671] imx362_s_ctrl
[ 69.893780] imx362_set_frame_length
[ 69.897684] imx362_s_ctrl
[ 69.900702] imx362_set_coarse_time
[ 69.904523] imx362_s_ctrl
[ 69.907503] imx362_set_group_hold
[ 69.922680] vi4_channel_start_streaming
[ 69.927554] imx362_get_fmt
[ 69.930595] imx362_get_fmt end
[ 69.934063] tegra_mipi_cal 3990000.mipical: tegra_mipi_bias_pad_enable
[ 69.941929] csi4_mipi_cal
[ 69.944913] chan->numports=1,chan->numlanes=4
[ 69.949524] csi port:0
[ 69.951902] tegra_mipi_calibration:lanes=3145728
[ 69.956787] tegra_mipi_cal 3990000.mipical: tegra_mipi_calibration
[ 69.963176] tegra_mipical_using_prod
[ 69.966923] tegra_mipi_wait
[ 69.969871] imx362 2-001a: imx362_s_stream++
[ 69.974151] imx362_write_table: imx362_stop
[ 69.980122] imx362 2-001a: imx362_s_stream mode[0]
[ 69.984925] imx362_write_table: mode_2016X1136_1Gbps_1
[ 70.018075] imx362_set_gain
[ 70.020980] imx362_set_frame_length
[ 70.024574] imx362_set_coarse_time
[ 70.028078] imx362_write_table: imx362_start
[ 71.665243] fence timeout on [ffffffc1716b5600] after 1500ms
[ 71.665289] fence timeout on [ffffffc1716b5400] after 1500ms
[ 71.665306] name=[nvhost_sync:53], current value=38 waiting value=39
[ 71.665322] fence timeout on [ffffffc028d63600] after 1500ms
[ 71.665325] ---- mlocks ----
[ 71.665338] name=[nvhost_sync:79], current value=0 waiting value=1
[ 71.665344] 8: locked by channel 6
[ 71.665371] ---- syncpts ----
[ 71.665394] id 4 (disp_d) min 767 max 767 refs 1 (previous client : )
[ 71.665405] id 5 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 71.665416] id 7 (vblank1) min 3961 max 0 refs 1 (previous client : )
[ 71.665444] id 18 (17000000.gp10b_507) min 20428 max 20428 refs 1 (previous client : 17000000.gp10b_507)
[ 71.665455] id 19 (17000000.gp10b_506) min 56 max 56 refs 1 (previous client : 17000000.gp10b_506)
[ 71.665459] ---- mlocks ----
[ 71.665466] id 20 (17000000.gp10b_505) min 3922 max 3922 refs 1 (previous client : 17000000.gp10b_505)
[ 71.665476] id 21 (17000000.gp10b_504) min 8 max 8 refs 1 (previous client : )
[ 71.665479] 8: locked by channel 6
[ 71.665486] id 22 (17000000.gp10b_503) min 3454 max 3454 refs 1 (previous client : )
[ 71.665495] id 23 (17000000.gp10b_502) min 2744 max 2744 refs 1 (previous client : )
[ 71.665505] id 24 (17000000.gp10b_501) min 1070 max 1070 refs 1 (previous client : )
[ 71.665507] ---- syncpts ----
[ 71.665514] id 25 (17000000.gp10b_500) min 178 max 178 refs 1 (previous client : )
[ 71.665527] id 28 (17000000.gp10b_499) min 892 max 892 refs 1 (previous client : )
[ 71.665536] id 29 (17000000.gp10b_498) min 8 max 8 refs 1 (previous client : )
[ 71.665544] id 30 (17000000.gp10b_497) min 8 max 8 refs 1 (previous client : )
[ 71.665553] id 31 (17000000.gp10b_496) min 8 max 8 refs 1 (previous client : )
[ 71.665563] id 32 (17000000.gp10b_495) min 8 max 8 refs 1 (previous client : )
[ 71.665572] id 33 (17000000.gp10b_494) min 8 max 8 refs 1 (previous client : )
[ 71.665580] id 34 (17000000.gp10b_493) min 8 max 8 refs 1 (previous client : )
[ 71.665589] id 35 (17000000.gp10b_492) min 8 max 8 refs 1 (previous client : )
[ 71.665598] id 36 (17000000.gp10b_491) min 8 max 8 refs 1 (previous client : )
[ 71.665607] id 37 (17000000.gp10b_490) min 8 max 8 refs 1 (previous client : )
[ 71.665615] id 38 (17000000.gp10b_489) min 8 max 8 refs 1 (previous client : )
[ 71.665624] id 39 (17000000.gp10b_488) min 8 max 8 refs 1 (previous client : )
[ 71.665633] id 40 (17000000.gp10b_487) min 8 max 8 refs 1 (previous client : )
[ 71.665642] id 41 (17000000.gp10b_486) min 8 max 8 refs 1 (previous client : )
[ 71.665651] id 42 (17000000.gp10b_485) min 8 max 8 refs 1 (previous client : )
[ 71.665659] id 43 (17000000.gp10b_484) min 8 max 8 refs 1 (previous client : )
[ 71.665668] id 44 (17000000.gp10b_483) min 8 max 8 refs 1 (previous client : )
[ 71.665677] id 45 (17000000.gp10b_482) min 8 max 8 refs 1 (previous client : )
[ 71.665686] id 46 (17000000.gp10b_481) min 8 max 8 refs 1 (previous client : )
[ 71.665694] id 47 (17000000.gp10b_480) min 8 max 8 refs 1 (previous client : )
[ 71.665703] id 48 (17000000.gp10b_479) min 8 max 8 refs 1 (previous client : )
[ 71.665715] id 49 (15340000.vic_gst-launch-1.0_0) min 104 max 104 refs 1 (previous client : 17000000.gp10b_477)
[ 71.665726] id 50 (15600000.isp_nvcamera-daemon_0) min 62 max 66 refs 4 (previous client : 17000000.gp10b_477)
[ 71.665736] id 51 (15600000.isp_nvcamera-daemon_1) min 46 max 48 refs 4 (previous client : 17000000.gp10b_476)
[ 71.665746] id 52 (15600000.isp_nvcamera-daemon_2) min 40 max 42 refs 4 (previous client : 17000000.gp10b_475)
[ 71.665756] id 53 (15600000.isp_nvcamera-daemon_3) min 38 max 40 refs 4 (previous client : 17000000.gp10b_474)
[ 71.665765] id 54 (17000000.gp10b_473) min 8 max 8 refs 1 (previous client : )
[ 71.665775] id 55 (17000000.gp10b_472) min 130 max 130 refs 1 (previous client : )
[ 71.665785] id 56 (15600000.isp_nvcamera-daemon_4) min 15 max 26 refs 9 (previous client : )
[ 71.665794] id 57 (15600000.isp_nvcamera-daemon_5) min 0 max 2 refs 4 (previous client : )
[ 71.665809] id 62 (17000000.gp10b_471) min 2 max 2 refs 1 (previous client : )
[ 71.665821] id 64 (17000000.gp10b_463) min 13 max 13 refs 1 (previous client : 15700000.vi_0)
[ 71.665831] id 65 (17000000.gp10b_462) min 6 max 6 refs 1 (previous client : 15700000.vi_0)
[ 71.665841] id 66 (17000000.gp10b_461) min 6 max 6 refs 1 (previous client : 15700000.vi_1)
[ 71.665851] id 67 (17000000.gp10b_460) min 6 max 6 refs 1 (previous client : 15700000.vi_2)
[ 71.665861] id 68 (15700000.vi_0) min 23 max 23 refs 2 (previous client : 150c0000.nvcsi_0)
[ 71.665876] id 74 (17000000.gp10b_466) min 2 max 2 refs 1 (previous client : )
[ 71.665888] id 77 (17000000.gp10b_464) min 8 max 8 refs 1 (previous client : )
[ 71.665898] id 78 (15700000.vi_0) min 1 max 2 refs 4 (previous client : )
[ 71.665907] id 79 (15700000.vi_1) min 0 max 2 refs 4 (previous client : )
[ 71.665916] id 80 (15700000.vi_2) min 0 max 2 refs 4 (previous client : )
[ 71.665925] id 81 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : )
[ 71.665934] id 82 (17000000.gp10b_459) min 6 max 6 refs 1 (previous client : )
[ 71.665943] id 83 (17000000.gp10b_458) min 6 max 6 refs 1 (previous client : )
[ 71.666630] ---- channels ----
[ 71.666643] id 4 (disp_d) min 767 max 767 refs 1 (previous client : )
[ 71.666654] id 5 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 71.666666] id 7 (vblank1) min 3961 max 0 refs 1 (previous client : )
[ 71.666686]
[ 71.666691] NvHost basic channel registers:
[ 71.666694] id 18 (17000000.gp10b_507) min 20428 max 20428 refs 1 (previous client : 17000000.gp10b_507)
[ 71.666699] CMDFIFO_STAT_0: 00002040
[ 71.666705] id 19 (17000000.gp10b_506) min 56 max 56 refs 1 (previous client : 17000000.gp10b_506)
[ 71.666708] CMDFIFO_RDATA_0: b311a200
[ 71.666717] id 20 (17000000.gp10b_505) min 3922 max 3922 refs 1 (previous client : 17000000.gp10b_505)
[ 71.666719] CMDP_OFFSET_0: 00000000
[ 71.666725] CMDP_CLASS_0: 00000000
[ 71.666728] id 21 (17000000.gp10b_504) min 8 max 8 refs 1 (previous client : )
[ 71.666732] CHANNELSTAT_0: 00000000
[ 71.666736] The CDMA sync queue is empty.
[ 71.666739] id 22 (17000000.gp10b_503) min 3454 max 3454 refs 1 (previous client : )
[ 71.666749] id 23 (17000000.gp10b_502) min 2744 max 2744 refs 1 (previous client : )
[ 71.666751]
[ 71.666756] NvHost basic channel registers:
[ 71.666758] id 24 (17000000.gp10b_501) min 1070 max 1070 refs 1 (previous client : )
[ 71.666762] CMDFIFO_STAT_0: 00002040
[ 71.666768] id 25 (17000000.gp10b_500) min 178 max 178 refs 1 (previous client : )
[ 71.666770] CMDFIFO_RDATA_0: c9831b22
[ 71.666778] CMDP_OFFSET_0: 00000000
[ 71.666781] id 28 (17000000.gp10b_499) min 892 max 892 refs 1 (previous client : )
[ 71.666783] CMDP_CLASS_0: 00000000
[ 71.666788] CHANNELSTAT_0: 00000000
[ 71.666791] id 29 (17000000.gp10b_498) min 8 max 8 refs 1 (previous client : )
[ 71.666793] The CDMA sync queue is empty.
[ 71.666800] id 30 (17000000.gp10b_497) min 8 max 8 refs 1 (previous client : )
[ 71.666806]
[ 71.666809] id 31 (17000000.gp10b_496) min 8 max 8 refs 1 (previous client : )
[ 71.666812] NvHost basic channel registers:
[ 71.666818] CMDFIFO_STAT_0: 00002040
[ 71.666820] id 32 (17000000.gp10b_495) min 8 max 8 refs 1 (previous client : )
[ 71.666824] CMDFIFO_RDATA_0: 0820c840
[ 71.666829] id 33 (17000000.gp10b_494) min 8 max 8 refs 1 (previous client : )
[ 71.666831] CMDP_OFFSET_0: 00000000
[ 71.666836] CMDP_CLASS_0: 00000000
[ 71.666839] id 34 (17000000.gp10b_493) min 8 max 8 refs 1 (previous client : )
[ 71.666841] CHANNELSTAT_0: 00000000
[ 71.666846] The CDMA sync queue is empty.
[ 71.666848] id 35 (17000000.gp10b_492) min 8 max 8 refs 1 (previous client : )
[ 71.666858] id 36 (17000000.gp10b_491) min 8 max 8 refs 1 (previous client : )
[ 71.666860]
[ 71.666864] NvHost basic channel registers:
[ 71.666867] id 37 (17000000.gp10b_490) min 8 max 8 refs 1 (previous client : )
[ 71.666870] CMDFIFO_STAT_0: 00004000
[ 71.666876] id 38 (17000000.gp10b_489) min 8 max 8 refs 1 (previous client : )
[ 71.666878] CMDFIFO_RDATA_0: 004e0041
[ 71.666885] id 39 (17000000.gp10b_488) min 8 max 8 refs 1 (previous client : )
[ 71.666887] CMDP_OFFSET_0: 00000050
[ 71.666892] CMDP_CLASS_0: 00000001
[ 71.666894] id 40 (17000000.gp10b_487) min 8 max 8 refs 1 (previous client : )
[ 71.666897] CHANNELSTAT_0: 00000000
[ 71.666903] id 41 (17000000.gp10b_486) min 8 max 8 refs 1 (previous client : )
[ 71.666913] id 42 (17000000.gp10b_485) min 8 max 8 refs 1 (previous client : )
[ 71.666916]
ffffffc172b39800: JOB, syncpt_id=50, syncpt_val=64, first_get=000001f8, timeout=10000, num_slots=19
[ 71.666921] id 43 (17000000.gp10b_484) min 8 max 8 refs 1 (previous client : )
[ 71.666930] id 44 (17000000.gp10b_483) min 8 max 8 refs 1 (previous client : )
[ 71.666939] GATHER at 5a708000+3bec, 12 words
[ 71.666941] id 45 (17000000.gp10b_482) min 8 max 8 refs 1 (previous client : )
[ 71.666951] 20000001
[ 71.666952] id 46 (17000000.gp10b_481) min 8 max 8 refs 1 (previous client : )
[ 71.666961] 00006432 20000001
[ 71.666962] id 47 (17000000.gp10b_480) min 8 max 8 refs 1 (previous client : )
[ 71.666972] 00006833 20000001
[ 71.666973] id 48 (17000000.gp10b_479) min 8 max 8 refs 1 (previous client : )
[ 71.666984] 00006c34 20000001 00007c35
[ 71.666985] id 49 (15340000.vic_gst-launch-1.0_0) min 104 max 104 refs 1 (previous client : 17000000.gp10b_477)
[ 71.666997] 20000001 00007439 200c0001
[ 71.666998] id 50 (15600000.isp_nvcamera-daemon_0) min 62 max 66 refs 4 (previous client : 17000000.gp10b_477)
[ 71.667003] 00000005
[ 71.667009] id 51 (15600000.isp_nvcamera-daemon_1) min 46 max 48 refs 4 (previous client : 17000000.gp10b_476)
[ 71.667014] GATHER at 5a708000+3c1c, 2 words
[ 71.667019] id 52 (15600000.isp_nvcamera-daemon_2) min 40 max 42 refs 4 (previous client : 17000000.gp10b_475)
[ 71.667028] 20000001 00000038
[ 71.667031] id 53 (15600000.isp_nvcamera-daemon_3) min 38 max 40 refs 4 (previous client : 17000000.gp10b_474)
[ 71.667041] id 54 (17000000.gp10b_473) min 8 max 8 refs 1 (previous client : )
[ 71.667043]
[ 71.667048] NvHost basic channel registers:
[ 71.667051] id 55 (17000000.gp10b_472) min 130 max 130 refs 1 (previous client : )
[ 71.667054] CMDFIFO_STAT_0: 00002040
[ 71.667060] CMDFIFO_RDATA_0: 00000051
[ 71.667062] id 56 (15600000.isp_nvcamera-daemon_4) min 15 max 26 refs 9 (previous client : )
[ 71.667067] CMDP_OFFSET_0: 00000000
[ 71.667072] id 57 (15600000.isp_nvcamera-daemon_5) min 0 max 2 refs 4 (previous client : )
[ 71.667074] CMDP_CLASS_0: 00000001
[ 71.667079] CHANNELSTAT_0: 00000000
[ 71.667084] The CDMA sync queue is empty.
[ 71.667089] id 62 (17000000.gp10b_471) min 2 max 2 refs 1 (previous client : )
[ 71.667096]
[ 71.667100] NvHost basic channel registers:
[ 71.667103] id 64 (17000000.gp10b_463) min 13 max 13 refs 1 (previous client : 15700000.vi_0)
[ 71.667105] CMDFIFO_STAT_0: 00002040
[ 71.667111] CMDFIFO_RDATA_0: 00000044
[ 71.667114] id 65 (17000000.gp10b_462) min 6 max 6 refs 1 (previous client : 15700000.vi_0)
[ 71.667118] CMDP_OFFSET_0: 00000000
[ 71.667123] CMDP_CLASS_0: 00000001
[ 71.667126] id 66 (17000000.gp10b_461) min 6 max 6 refs 1 (previous client : 15700000.vi_1)
[ 71.667129] CHANNELSTAT_0: 00000000
[ 71.667132] The CDMA sync queue is empty.
[ 71.667136] id 67 (17000000.gp10b_460) min 6 max 6 refs 1 (previous client : 15700000.vi_2)
[ 71.667143]
channel 4 - 15700000.vi
[ 71.667146] id 68 (15700000.vi_0) min 23 max 23 refs 2 (previous client : 150c0000.nvcsi_0)
[ 71.667148] NvHost basic channel registers:
[ 71.667154] CMDFIFO_STAT_0: 0000001f
[ 71.667159] CMDFIFO_RDATA_0: 304e0005
[ 71.667163] id 74 (17000000.gp10b_466) min 2 max 2 refs 1 (previous client : )
[ 71.667166] CMDP_OFFSET_0: 00000050
[ 71.667172] CMDP_CLASS_0: 00000001
[ 71.667175] id 77 (17000000.gp10b_464) min 8 max 8 refs 1 (previous client : )
[ 71.667177] CHANNELSTAT_0: 00000000
[ 71.667184] id 78 (15700000.vi_0) min 1 max 2 refs 4 (previous client : )
[ 71.667190]
ffffffc1d6908000: JOB, syncpt_id=80, syncpt_val=1, first_get=00000000, timeout=0, num_slots=7
[ 71.667193] id 79 (15700000.vi_1) min 0 max 2 refs 4 (previous client : )
[ 71.667202] id 80 (15700000.vi_2) min 0 max 2 refs 4 (previous client : )
[ 71.667206] GATHER at 5a718000+0000, 6 words
[ 71.667214] 304e0005
[ 71.667215] id 81 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : )
[ 71.667224] 0000000f 00000038
[ 71.667225] id 82 (17000000.gp10b_459) min 6 max 6 refs 1 (previous client : )
[ 71.667234] 304e0005 00000000
[ 71.667235] id 83 (17000000.gp10b_458) min 6 max 6 refs 1 (previous client : )
[ 71.667240] 0000004f
[ 71.667249] GATHER at 5a718000+0018, 22 words
[ 71.667322] 90000002 a0004008 00007f1f 00000aff 9000000c a000400c 000007e0 00000470 00000001 00000001 00000000 00000000 00000000 00000000 00000000 00000000 000007e0 00000470 90000002 a0004018 007f0000 00000104
[ 71.667330] GATHER at 5a718000+0070, 26 words
[ 71.667414] 90000001 a0000401 00000000 90000001 a000404d 00000001 90000001 a0004020 00000000 90000003 a0004042 5a526000 00000000 00000001 90000001 a0004048 00000000 90000001 a000400a 00000000 90000001 a0004001 00000001 90000001 a0004007 00000003
[ 71.667421] GATHER at 5a718000+00d8, 2 words
[ 71.667431] 20000001 0000004e
[ 71.667442]
[ 71.667449] sync_intc0mask = 0x00000001
[ 71.667455] sync_intmask = 0x50000003
[ 71.667459]
[ 71.667463]
[ 71.667471] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 71.667478] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 71.667484] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 71.667490] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 71.667496] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 71.667502] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 71.667508] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 71.667514] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 71.667520] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 71.667526] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 71.667532] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 71.667539] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 71.667545] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 71.667551] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 71.667557] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 71.667563] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 71.667569] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 71.667575] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 71.667927] ---- channels ----
[ 71.667950]
[ 71.667955] NvHost basic channel registers:
[ 71.667962] CMDFIFO_STAT_0: 00002040
[ 71.667968] CMDFIFO_RDATA_0: b311a200
[ 71.667976] CMDP_OFFSET_0: 00000000
[ 71.667982] CMDP_CLASS_0: 00000000
[ 71.667988] CHANNELSTAT_0: 00000000
[ 71.667992] The CDMA sync queue is empty.
[ 71.668006]
[ 71.668010] NvHost basic channel registers:
[ 71.668015] CMDFIFO_STAT_0: 00002040
[ 71.668021] CMDFIFO_RDATA_0: c9831b22
[ 71.668028] CMDP_OFFSET_0: 00000000
[ 71.668033] CMDP_CLASS_0: 00000000
[ 71.668038] CHANNELSTAT_0: 00000000
[ 71.668043] The CDMA sync queue is empty.
[ 71.668054]
[ 71.668058] NvHost basic channel registers:
[ 71.668064] CMDFIFO_STAT_0: 00002040
[ 71.668069] CMDFIFO_RDATA_0: 0820c840
[ 71.668076] CMDP_OFFSET_0: 00000000
[ 71.668081] CMDP_CLASS_0: 00000000
[ 71.668086] CHANNELSTAT_0: 00000000
[ 71.668091] The CDMA sync queue is empty.
[ 71.668101]
[ 71.668105] NvHost basic channel registers:
[ 71.668110] CMDFIFO_STAT_0: 00004000
[ 71.668116] CMDFIFO_RDATA_0: 004e0041
[ 71.668123] CMDP_OFFSET_0: 00000050
[ 71.668128] CMDP_CLASS_0: 00000001
[ 71.668133] CHANNELSTAT_0: 00000000
[ 71.668148]
[ 71.668160] GATHER at 5a708000+3bec, 12 words
[ 71.668205] 20000001 00006432 20000001 00006833 20000001 00006c34 20000001 00007c35 20000001 00007439 200c0001 00000005
[ 71.668217] GATHER at 5a708000+3c1c, 2 words
[ 71.668228] 20000001 00000038
[ 71.668240]
[ 71.668244] NvHost basic channel registers:
[ 71.668249] CMDFIFO_STAT_0: 00002040
[ 71.668255] CMDFIFO_RDATA_0: 00000051
[ 71.668262] CMDP_OFFSET_0: 00000000
[ 71.668268] CMDP_CLASS_0: 00000001
[ 71.668273] CHANNELSTAT_0: 00000000
[ 71.668276] The CDMA sync queue is empty.
[ 71.668287]
[ 71.668290] NvHost basic channel registers:
[ 71.668296] CMDFIFO_STAT_0: 00002040
[ 71.668301] CMDFIFO_RDATA_0: 00000044
[ 71.668308] CMDP_OFFSET_0: 00000000
[ 71.668313] CMDP_CLASS_0: 00000001
[ 71.668318] CHANNELSTAT_0: 00000000
[ 71.668321] The CDMA sync queue is empty.
[ 71.668329]
[ 71.668332] NvHost basic channel registers:
[ 71.668338] CMDFIFO_STAT_0: 0000001f
[ 71.668343] CMDFIFO_RDATA_0: 304e0005
[ 71.668350] CMDP_OFFSET_0: 00000050
[ 71.668355] CMDP_CLASS_0: 00000001
[ 71.668360] CHANNELSTAT_0: 00000000
[ 71.668373]
[ 71.668382] GATHER at 5a718000+0000, 6 words
[ 71.668406] 304e0005 0000000f 00000038 304e0005 00000000 0000004f
[ 71.668414] GATHER at 5a718000+0018, 22 words
[ 71.668486] 90000002 a0004008 00007f1f 00000aff 9000000c a000400c 000007e0 00000470 00000001 00000001 00000000 00000000 00000000 00000000 00000000 00000000 000007e0 00000470 90000002 a0004018 007f0000 00000104
[ 71.668494] GATHER at 5a718000+0070, 26 words
[ 71.668577] 90000001 a0000401 00000000 90000001 a000404d 00000001 90000001 a0004020 00000000 90000003 a0004042 5a526000 00000000 00000001 90000001 a0004048 00000000 90000001 a000400a 00000000 90000001 a0004001 00000001 90000001 a0004007 00000003
[ 71.668584] GATHER at 5a718000+00d8, 2 words
[ 71.668594] 20000001 0000004e
[ 71.668604]
Do you have any idea about these debug messages?
