Jetpack: 5.0.2GA
Hardware: orin + rn6752
rn6752: output 4Lanes CSI, 1080p@25 fps, YUYV422 8Bit, mipi clock 324M Hz
Mipi data can be captured by oscilloscope, but i get “VIFALC_TDSTATE” in the trace log after
v4l2-ctl -V --set-fmt-video=width=1920,height=1080 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=camera.yuv -d /dev/video0
Is the dtsi configuration wrong?
Any ideas? Thank you.
Logs with debug-camera-fw.7z
kernel log
Sep 8 10:11:29 nvidia-agx-orin kernel: [ 52.696507] [RCE] NVCSILP clock rate = 408000000 Hz. Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.240742] bwmgr API not supported Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269937] [RCE] VM0 deactivating.VM0 activating.NVCSILP clock rate = 408000000 Hz. Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269941] [RCE] tegra_nvcsi_stream_set_config(vm0, stream=0, csi=0) Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269943] [RCE] MIPI clock = 324000 kHz, tHS-SETTLE = 0, tCLK-SETTLE = 0 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269945] [RCE] ===== NVCSI Stream Configuration ===== Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269947] [RCE] stream_id: PP 0, csi_port: PORT A Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269949] [RCE] Brick: PHY 0, Mode: D-PHY Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269951] [RCE] Partition: CIL A, LP bypass: Enabled, Lanes: 4 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269953] [RCE] Clock information: Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269955] [RCE] MIPI clock rate: 324.00 MHz Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269957] [RCE] T_HS settle: 0, T_CLK settle: 0 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269959] [RCE] ====================================== Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269961] [RCE] tegra_nvcsi_stream_open(vm0, stream=0, csi=0) Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269963] [RCE] nvcsi_calc_ths_settle ths_settle 65 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269965] [RCE] nvcsi_calc_ths_settle ths_settle 65 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269967] [RCE] nvcsi_calc_ths_settle ths_settle 65 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269968] [RCE] nvcsi_calc_tclk_settle tclk_settle 75 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269973] [RCE] ISR PHY 0 CIL_A 0x8 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269976] [RCE] ISR PHY 0 CIL_B 0x80 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269978] [RCE] ISR PHY 0 CIL_A 0x44 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269980] [RCE] ISR PHY 0 CIL_B 0x44 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269982] [RCE] ISR PHY 0 CIL_A 0x44 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269984] [RCE] ISR PHY 0 CIL_B 0x44 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269986] [RCE] ISR PHY 0 CIL_A 0x44 Sep 8 10:12:04 nvidia-agx-orin kernel: [ 87.269988] [RCE] ISR PHY 0 CIL_B 0x44 ......(repeat) Sep 8 10:12:06 nvidia-agx-orin kernel: [ 89.804629] (NULL device *): vi_capture_control_message: NULL VI channel received Sep 8 10:12:06 nvidia-agx-orin kernel: [ 89.812351] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0 Sep 8 10:12:06 nvidia-agx-orin kernel: [ 89.823029] (NULL device *): vi_capture_control_message: NULL VI channel received Sep 8 10:12:06 nvidia-agx-orin kernel: [ 89.830756] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
trace
kworker/0:1-15 [000] .... 52.696484: rtcpu_string: tstamp:2327555680 id:0x04010000 str:"NVCSILP clock rate = 408000000 Hz. " kworker/0:1-15 [000] .... 52.696520: rtcpu_dbg_set_loglevel: tstamp:2327583858 old:0 new:2 kworker/0:1-15 [000] .... 57.796491: rtcpu_string: tstamp:2486508443 id:0x04010000 str:"VM0 deactivating." v4l2-ctl-2388 [003] .... 86.813399: tegra_channel_open: vi-output, rn6752 2-002c v4l2-ctl-2388 [003] .... 86.822022: tegra_channel_set_power: rn6752 2-002c : 0x1 v4l2-ctl-2388 [003] .... 86.822036: camera_common_s_power: status : 0x1 v4l2-ctl-2388 [003] .... 87.225245: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1 v4l2-ctl-2388 [003] .... 87.225251: csi_s_power: enable : 0x1 v4l2-ctl-2388 [003] .... 87.226499: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13 v4l2-ctl-2388 [003] .... 87.236213: tegra_channel_set_stream: enable : 0x1 v4l2-ctl-2388 [003] .... 87.250589: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1 v4l2-ctl-2388 [003] .... 87.250591: csi_s_stream: enable : 0x1 v4l2-ctl-2388 [003] .... 87.251035: tegra_channel_set_stream: rn6752 2-002c : 0x1 kworker/0:1-15 [000] .... 87.269931: rtcpu_string: tstamp:3407710717 id:0x04010000 str:"VM0 activating." kworker/0:1-15 [000] .... 87.269933: rtcpu_string: tstamp:3407807460 id:0x04010000 str:"NVCSILP clock rate = 408000000 Hz. " kworker/0:1-15 [000] .... 87.269939: rtcpu_string: tstamp:3408317381 id:0x04010000 str:"tegra_nvcsi_stream_set_config(vm0, stream=0, csi" kworker/0:1-15 [000] .... 87.269940: rtcpu_string: tstamp:3408317482 id:0x04010000 str:"=0) " kworker/0:1-15 [000] .... 87.269942: rtcpu_string: tstamp:3408317853 id:0x04010000 str:"MIPI clock = 324000 kHz, tHS-SETTLE = 0, tCLK-SE" kworker/0:1-15 [000] .... 87.269943: rtcpu_string: tstamp:3408317954 id:0x04010000 str:"TTLE = 0 " kworker/0:1-15 [000] .... 87.269945: rtcpu_string: tstamp:3408318164 id:0x04010000 str:"===== NVCSI Stream Configuration ===== " kworker/0:1-15 [000] .... 87.269947: rtcpu_string: tstamp:3408318407 id:0x04010000 str:"stream_id: PP 0, csi_port: PORT A " kworker/0:1-15 [000] .... 87.269949: rtcpu_string: tstamp:3408318667 id:0x04010000 str:"Brick: PHY 0, Mode: D-PHY " kworker/0:1-15 [000] .... 87.269951: rtcpu_string: tstamp:3408318950 id:0x04010000 str:"Partition: CIL A, LP bypass: Enabled, Lanes: 4 " kworker/0:1-15 [000] .... 87.269953: rtcpu_string: tstamp:3408319126 id:0x04010000 str:"Clock information: " kworker/0:1-15 [000] .... 87.269954: rtcpu_string: tstamp:3408319427 id:0x04010000 str:"MIPI clock rate: 324.00 MHz " kworker/0:1-15 [000] .... 87.269956: rtcpu_string: tstamp:3408319671 id:0x04010000 str:"T_HS settle: 0, T_CLK settle: 0 " kworker/0:1-15 [000] .... 87.269958: rtcpu_string: tstamp:3408319895 id:0x04010000 str:"====================================== " kworker/0:1-15 [000] .... 87.269960: rtcpu_string: tstamp:3408321424 id:0x04010000 str:"tegra_nvcsi_stream_open(vm0, stream=0, csi=0) " kworker/0:1-15 [000] .... 87.269962: rtcpu_string: tstamp:3408328575 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 65 " kworker/0:1-15 [000] .... 87.269964: rtcpu_string: tstamp:3408328837 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 65 " kworker/0:1-15 [000] .... 87.269966: rtcpu_string: tstamp:3408329095 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 65 " kworker/0:1-15 [000] .... 87.269968: rtcpu_string: tstamp:3408329352 id:0x04010000 str:"nvcsi_calc_tclk_settle tclk_settle 75 " kworker/0:1-15 [000] .... 87.269971: rtcpu_vinotify_event: tstamp:3408364807 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:109051563328 data:0x379d580010000000 kworker/0:1-15 [000] .... 87.269971: rtcpu_vinotify_event: tstamp:3408364943 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:109051569760 data:0x0000000031000001 kworker/0:1-15 [000] .... 87.269972: rtcpu_vinotify_event: tstamp:3408365099 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:109051625056 data:0x379d550010000000 kworker/0:1-15 [000] .... 87.269972: rtcpu_vinotify_event: tstamp:3408365230 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:109051631584 data:0x0000000031000002 kworker/0:1-15 [000] .... 87.269972: rtcpu_string: tstamp:3408601975 id:0x04010000 str:"ISR PHY 0 CIL_A 0x8 " kworker/0:1-15 [000] .... 87.269975: rtcpu_nvcsi_intr: tstamp:3408601735 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000008 kworker/0:1-15 [000] .... 87.269975: rtcpu_string: tstamp:3408602360 id:0x04010000 str:"ISR PHY 0 CIL_B 0x80 " kworker/0:1-15 [000] .... 87.269977: rtcpu_nvcsi_intr: tstamp:3408601735 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000080 kworker/0:1-15 [000] .... 87.269977: rtcpu_string: tstamp:3408676669 id:0x04010000 str:"ISR PHY 0 CIL_A 0x44 " kworker/0:1-15 [000] .... 87.269979: rtcpu_nvcsi_intr: tstamp:3408676433 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000044 kworker/0:1-15 [000] .... 87.269980: rtcpu_string: tstamp:3408677045 id:0x04010000 str:"ISR PHY 0 CIL_B 0x44 " kworker/0:1-15 [000] .... 87.269981: rtcpu_nvcsi_intr: tstamp:3408676433 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044 kworker/0:1-15 [000] .... 87.269982: rtcpu_string: tstamp:3408677626 id:0x04010000 str:"ISR PHY 0 CIL_A 0x44 " kworker/0:1-15 [000] .... 87.269983: rtcpu_nvcsi_intr: tstamp:3408677395 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000044 kworker/0:1-15 [000] .... 87.269984: rtcpu_string: tstamp:3408677996 id:0x04010000 str:"ISR PHY 0 CIL_B 0x44 ......(repeat)
CSI port used
dtsi config
The trace log prints “MIPI clock rate: 324.00 MHz”, when i set pix_clk_hz to “162000000”.
According to “CSI port used”, i set tegra_sinterface to “serial_a”.
tegra-capture-vi {
num-channels = <1>;
status = "okay";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
rn6752_vi_in0: endpoint {
status = "okay";
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&rn6752_csi_out0>;
host1x@13e00000 {
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
status = "okay";
channel@0 {
reg = <0>;
status = "okay";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
rn6752_csi_in0: endpoint@0 {
status = "okay";
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&rn6752_rn6752_out0>;
port@1 {
reg = <1>;
status = "okay";
rn6752_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&rn6752_vi_in0>;
i2c@3180000 {
status = "okay";
rn6752_a@2c {
status = "okay";
compatible = "rn,rn6752";
reg = <0x2c>;
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "15.0";
physical_h = "12.5";
sensor_model ="rn6752";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
clocks = <&bpmp_clks TEGRA234_CLK_EXTPERIPH1>,
<&bpmp_clks TEGRA234_CLK_EXTPERIPH1>;
clock-names = "extperiph1", "pllp_grtba";
mclk = "extperiph1";
pwdn-gpios = <&tegra_main_gpio CAM1_RST_L GPIO_ACTIVE_HIGH>;
reset-gpios = <&tegra_main_gpio CAM_PWDN GPIO_ACTIVE_HIGH>;
post_crop_frame_drop = "0";
/* Convert Gain to unit of dB (decibel) befor passing to kernel driver */
use_decibel_gain = "true";
/* if true, delay gain setting by one frame to be in sync with exposure */
delayed_gain = "true";
/* enable CID_SENSOR_MODE_ID for sensor modes selection */
use_sensor_mode_id = "true";
/* WAR to prevent banding by reducing analog gain. Bug 2229902 */
limit_analog_gain = "true";
mode0 {/*mode RN6752_MODE_1920X1080_25FPS*/
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
mode_type = "yuv";
pixel_phase = "uyvy";
csi_pixel_bit_depth = "16";
dynamic_pixel_bit_depth = "16";
active_w = "1920";
active_h = "1080";
readout_orientation = "0";
line_length = "1920";
inherent_gain = "1";
mclk_multiplier = "6.75";
pix_clk_hz = "162000000";
embedded_metadata_height = "0";
gain_factor = "10";
min_gain_val = "0"; /* 0dB */
max_gain_val = "480"; /* 48dB */
step_gain_val = "3"; /* 0.3 */
default_gain = "0";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "25000000"; /* 25 */
max_framerate = "25000000"; /* 25 */
step_framerate = "1";
default_framerate= "25000000";
exposure_factor = "1000000";
min_exp_time = "30"; /* us */
max_exp_time = "660000"; /* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rn6752_rn6752_out0: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&rn6752_csi_in0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
module0 {
badge = "rn6752_bottom_rn6752";
position = "bottom";
orientation = "0";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "rn6752 30-002c";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/rn6752_a@2c";
status = "okay";
