Nvdewarper causes screen tearing
I’ve verified this only happens when i add this specific element to the pipeline.
Video of screen tearing
Jetson AGX Orin - Jetpack 35.2.1 (32GB)
• DeepStream Version
deepstream-6.3_6.3.0-1
35.2.1
• TensorRT Version
8.5.2.2
Question
Using nvdewarper.
I am using nvdewarper to convert a fish eye camera to prespective.
here is my pipline:
gst-launch-1.0 v4l2src device=/dev/video0 !
capsfilter caps=“video/x-raw,format=YUY2,width=1920,height=1080,framerate=30/1” !
nvvidconv ! ‘video/x-raw(memory:NVMM),width=1920,height=1080’ !
nvdewarper config-file=/path/to/dewarp_config.txt ! \
nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12,width=1920,height=1080’ !
nvv4l2h264enc bitrate=2000000 !
tee name=t t. ! queue ! rtph264pay ! udpsink host=224.224.255.255 port=5400
and my config is just
projection-type=4
src-fov=124 (based on camera spec)
Why would the nvdewarper cause horizontal screen tearing and how can I solve it?
How can you run DeepStream 6.3 with JetPack 35.2.1? Can you follow the compatibility? Quickstart Guide — DeepStream documentation 6.4 documentation
Fiona,
I installed deep stream from a deb file, the Jetpack version was what I copied from JTOP.
Rest assured, the nvdewarp plugin became available only after I installed deep stream.
Also I would not be able to update the JetPack as this is production unit not a dev board.
I once had a similar issue when I was running DP 6.2 with JP 5.1.1.
Once I upgraded my JP version to JP 5.1.2 which had DP 6.3, the issue was resolved.
Refer this: Nvdewarper not working properly 2 - #15 by rajupadhyay59
Since you are not using a dev kit, you cannot really upgrade your JP version, can you?
I think even if you try to use opencv to convert a fish eye camera to perspective, you may have a kind of a similar problem (I did)? not really the screen tearing but like black lines.
If you are really good at python and have a good understanding of libvips/pyvips, maybe you could try changing this code and modify it accordingly.
Fiona,
its simply not practical for folks using Edge computers to upgrade the equipment at will, sometimes these boards have customization on top that would make the BSP development long (imagine having to upgrade your operating system every time the mail application doesn’t work)
Is there anyway to make dewarp work with the Deepstream 6.3 ? Is it something that is not advised to use ?
The key problem is that you need to follow the platform compatibility. If your board should keep JetPack 35.2.1, you can only use DeepStream 6.2 version.
I can downgrade the deepstream, will report back
